Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Mavic Pro est un drone compact et pliable avec des capacités vidéo 4K. Il a été lancé en novembre 2016. Le numéro de modèle est M1P et sa manette porte le numéro de modèle GL200A.
Can I save my drone once it has gone be submerged in water?
I was flying my drone over a pond, the drone’s battery was low. I hovered it over the water and it decided to land. In the pond. Is there any way to save it??
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @celticfox ,
First do not turn on the drone.
Then you need to remove the battery as soon as possible to prevent further damage that may be caused by the moisture in the drone being in contact with the electronics and a power source. (water is a conductor of electricity and therefore there may be damaging current flow through components that was not catered for in the design of the circuit)
Here is a link to the ifixit Vue éclatée du DJI Mavic Pro guide which should help you to gain access to the battery, electronics etc.
Here is a link that in general describes what to do.
Electronics Water Damage.
You need to thoroughly clean all the components using IPA 99%+ (Isopropyl Alcohol - available at most electronics parts stores) to remove all traces of moisture and corrosion. Do not use "rubbing alcohol" as this is usually <70% IPA and may contain scents and therefore is not as effective. If you have to use it, check the label.
Hopefully you may be able to save your drone
Indice 3
Ajouter une réponse
Kayleigh McCarthy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 23
Total : 2,339
