Aller au contenu principal
Sorti en avril 2010 / Processeur Intel Core i5 2.4, 2.53 GHz ou Intel Core i7 2.66, 2.8 GHz
590 questions Voir tout
Why my click is not responding
my touchpad is working the pointer is moving properly ,the click is not responding ,the button getting clicked physically but not getting any inputs
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
I had this exact machine in for the same problem this week. Cursor worked fine, could not click. Tried adjusting the click screw and still got nothing. I initially assumed it was a swollen battery like Dan stated (it usually is). Removed battery and got the same thing. Worked fine with an external mouse. Had another trackpad in stock with the cable, replaced it and it works fine now. Did not try to further diagnose to see if it was the cable or the pad.
Indice 1
A swelling battery could be the cause. Check your battery using this app: CoconutBattery if your cycles are near 1000 I would recommend you replace the battery. Follow this guide to replace it: Remplacement de la batterie du MacBook Pro 15" Unibody mi-2010
Even after replacing your battery the trackpad may need adjusting. Pop the battery out and underneath it you'll see the trackpad. Jump to this IFIXIT guide: Remplacement du pavé tactile du MacBook Pro 15" Unibody début 2011 Here we are jumping down to Step30 which goes over the adjustment of the click switch.
Image MacBook Pro 15" Unibody Mid 2010 Batterie
Tutoriel
Difficulté :
Facile
10 - 45 minutes
Image MacBook Pro 15" Unibody Early 2011 Pavé tactile
Tutoriel
Difficulté :
Modérée
45 minutes - 2 hours
Indice 0
Ajouter une réponse
Mahaveer Prasad Singh sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 62
