Mid-2009 MacBook Pro Not Charging
I was just wondering if someone could help me determine whether the issue I am having is related to the battery or if its a conduct issue relating to the logic board/charging port. The laptop is not charging or turning on.
1) The issue has not been solved through an SMC reset, cleaning the charging port, or using a different charging cable.
2) When I press the charging indicator on the side, I see one circle light up.
3) When I plug in a charger, there is no green light. When I unplug the battery and plug in the charger, there is still no green light.
As such, will getting a new battery help with the issue or is this likely due to the logic board/charging port? My battery is from Mid-2009 and has a high cycle count. Also,
1 commentaire
To be clear the battery tester does light one green LED - Correct?
par Dan
