Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le OnePlus 6T est un smartphone Android fabriqué par OnePlus. Il a été annoncé le 29 octobre 2018 et commercialisé le 6 novembre 2018.
Which component is responsible for the network connection on the mobil
When I am connected to the Wi-Fi network at home, my OnePlus 6t occasionally disconnects from the Wi-Fi network and the mobile network out of the blue for about 20 seconds and then logs back in automatically. If, on the other hand, I switch off Wi-Fi and connect to the internet via the mobile network, the connection has never been interrupted. I have already reset the phone and during the set-up process the same problem occurred again, so it must be the hardware. My question now is, which component do I need to replace? Where is the antenna for the connection to the WLAN/mobile network, is it a separate circuit board or is it on the motherboard? It would be nice if someone could take care of me, as the problem is really annoying, especially when the connection simply drops out during a phone call. Thank you in advance.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi,
WiFi signalling is handled by the WiFi/BT IC whereas GSM signalling is handled by a different IC.
Try using the phone as close as possible to the WiFi router (<30cm) and check if the connection remains stable.
If it does it may be a loose WiFi antenna connection.
Here’s the ifixit Remplacement de la carte mère du OnePlus 6T guide. It is useful as it shows how to open the phone so that access to the WiFi antennae is possible. Go to Step.11 to view one end of the connection. The other end is under the speaker, unfortunately not shown here
Image OnePlus 6T Haut-parleur
Tutoriel
Remplacement du haut-parleur du OnePlus 6T
Difficulté :
Modérée
15 - 20 minutes
Image OnePlus 6T Carte mère
Tutoriel
Difficulté :
Modérée
40 - 45 minutes
Indice 1
Ajouter une réponse
OnePlus Nutzer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 487
