Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The CFS-204 is a 90's style analog AM/FM radio and cassette tape player. It can be powered by either six C-cell batteries or A/C power from a standard wall outlet.
Broadcast fuzzy when light switched on
Whenever I switched on the ceiling LED light the radio broadcast became fuzzy with static interference but not so when switched off the light. And this only happened with that one particular light but not with other similar lights in the house . I tried to disconnect the earth wire but it didn't help. I also tried replacing it with another unit of similar type but problem persisted.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
A lot of cheap LED bulbs do this, so you probably put a bulb in that caused the same problem. Radios and cheap LED bulbs do not mix, ever.
You need to look for more expensive bulbs like GE or Feit Electric, especially with a radio.
Indice 1
1 commentaire:
thanks Nick. will try this solution.
par
Réponse la plus utile
Hi
Did you change the LED driver (aka LED transformer) or only the LED light?
If only the LED light then most likely the problem is with the driver.
The driver is what converts the AC input to a DC output to power the LED light.
Indice 1
1 commentaire:
I did change the driver as well but it did not fix the problem.
par
Ajouter une réponse
alexee1959 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 23
Total : 375
