Aller au contenu principal
Tutoriels de réparation et informations sur le démontage pour le MacBook Pro 14 pouces sorti en octobre 2021, équipé des SoC M1 Pro et M1 Max conçus par Apple. Modèle A2442.
55 questions Voir tout
Is this a broken battery connector?
I spilled some liquid on my MacBook Pro 14” and opened it to disconnect the battery and didn’t realize that the cable right above the battery screw had a latch that was meant to be lifted to remove the cable, didn’t seem to take much force to lift but now it seems to have no connection am I SOL at this point? If there was a spare part for the cable that seems to be the only thing messed up if I could manage to remove the piece still underneath the latch.
Does anyone have any info on this?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
The cable its self looks OK with the limited view you have here. As you appear to have more of an issue with getting the cable reconnected within the ZIF connector.
Review Step 11 in this guide Remplacement de la batterie du MacBook Pro 16" 2019 This is the same cable but routed differently in the 16" system. Basically you need to carefully lift the latch to release the clamping tension then feed the cable in making sure its square and fully pushed in.
Indice 1
1 commentaire:
Thank you so much, after taking a closer look I could see that the cable was in fact still intact, I just had to peel back the connections from the cable and was able to insert it into the connector above the battery. Thanks again, I really appreciate it
par
Ajouter une réponse
Jesus Bautista sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 29
Total : 457
