Aller au contenu principal
La mise à jour de mars 2015 du Macbook Pro 13" avec écran Retina d'Apple, modèle A1502, présente la cinquième génération de processeurs Intel Core i5 et i7 et introduit le trackpad Force Touch.
21 questions Voir tout
Green tint on screen after powering on
I recently got a 2015 MacBook Pro for cheap,
everything was working fine the first five days, after that I noticed a green tint on the display.
This only occurs if the display has been off for about 40 minutes or more and it seems to get worse in cold environments, I've tested to see if this issue happens in hot weather and it becomes not noticeable or not existent.
Even in cold weather the display goes back to normal after 20 minutes of it being turned on. If facing directly at the screen the tint is barely noticeable, at an angle it's pretty visible.
Also ran Apple Diagnostics and everything came back with no errors. Opened up the machine and it has no signs of liquid damage.
These two images were taken after being inside a room with the AC turned on during the night and the computer being off.
I know the Retina Displays for this model of MacBook are expensive, I would like to try any other posible solution before having to buy a new screen.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Got the same issue after almost 9 years. Probably it comes with our screen cleaning behaviors
par
And you are also right about the tempreture around. When it is hot around, this does not come. What I do is when it is cold around, I keep the MBP close to my table lamp. That helps.
par
Ajouter un commentaire
2 Réponses
Solution retenue
This was an unfortunate issue that ended up being somewhat common on several models of MacBooks in the 2013-2015 year models. It is an issue with the display assembly, either in the LCD panel itself or the inverter board. Either way the fix is to replace the LCD assembly per the MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement guide. You could try replacing just the inverter board (the motherboard that is attached directly to the LCD panel but that will require desoldering the ribbon cables that connect the board to the LCD panel which is very difficult unless you know what you are doing and can solder surface mount components. Also sourcing the board appears difficult as I could not find one.
Indice 2
1 commentaire:
Welp, that's really unfortunate. At least now I know the culprit. Time to start looking for a display assembly.
par
The T-CON logic within the display breaks the signal from the system to the different pixels which in turn sets the color. What you are seeing is this logic is failing. To prove it plug in an external display it should stay fine when your internal goes green.
You’ll need to replace the internal, here’s the guide Remplacement de l'écran complet du MacBook Pro 13" Retina début 2015
Indice 1
Ajouter une réponse
Amaury Leonel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 41
Total : 1,323
