Aller au contenu principal
Modèle A2159, EMC 3301. Mise à jour du MacBook Pro 13" entrée de gamme. Disponible en Argent et Gris sidéral. Mis sur le marché en juillet 2019.
20 questions Voir tout
Original Battery not recognized
Hi,
I was assembling my macbook pro 13" 2019 and I have this problem: my macbook not recognized the original battery.
Have I damage the battery flex data cable? because, I pulled of this flex cable and I did not open the connector flex of the mainboard.
Photos:
Thank you,
Update (05/03/24)
Continue:
The only way to turn on my macbook pro is: connecting it to the electical network with my power adapter.
Thank you
Update (05/03/24)
Hi Dan,
Photos:
Update (05/06/24)
Hi
I have already had a new flex cable !!! and I have just fixed my macbook pro !!!
Thank you for all answers !!
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
3 commentaires
So the only way to use it is to plug it into the wall?
par
Exactly! That is the only way to use my macbook...
If I install Cocunut Battery... It will show "nan"
par
Both connectors seem to be fine and their tabs too, so is it possible that I have damaged the flex cable or the connectors of the mainboard?
I hope I have damaged only that cable...
par
Ajouter un commentaire
1 Réponse
Solution retenue
Can you post images of both connectors so we can see if they are damaged. If it’s just the cable that’s replaceable MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
Image Replace the small flex cable that connects the battery daughter board to the logic board.
Produit
$19.99
Indice 1
4 commentaires:
Hi @danj,
Very close to being a short circuit between connector pins 9 and 10 (from the left) in the 2nd image posted above.
What do you think?
par
@jayeff - I would replace the cable for sure, but the real issue is what happed within the connectors.
par
@consu - Looking at the connectors they look OK, so maybe all you’ll need is a new cable! I wish you luck!
par
Thank you so much for your point of view!!
I will write here when I have the new Flex Cable.
par
Ajouter une réponse
Consu sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 12
Total : 137
