MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Replacement Battery
  • MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Replacement Battery / Fix Kit
  • MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Replacement Battery / Part Only
  • 360°
360
$89.99
$89.99
Nous vous enverrons un message lorsque le produit sera à nouveau disponible.
Détails du produit
Description
Description
This MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Replacement Battery Fix Kit is everything you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 5510 mAh—so you know you're getting the best part money can buy. This fix kit comes with a brand new battery and all the tools you need to make the fix.
Fix Kit Contents:
Note: Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Design Capacity: 5800 mAh
Compatibilité
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 13" Unibody Mid 2009
2.26 GHz
2.53 GHz
MacBook Pro 13" Unibody Mid 2010
2.4 GHz
2.66 GHz
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
Voir 2 appareils supplémentaires
Histoires de réparations
Avatar de l'utilisateur
James May's Story Photo #1426220
Mon problème
Battery life was getting so miserable, I couldn't depend on the old 'Pro anymore. I was seriously thinking it might be time to buy a new one, but I decided to try a new battery first.
Ma solution
The iFixit kit came with everything I needed, and swapping the battery took only a few minutes. It was wonderfully re . . .
borist72's Story Photo #1426210
Mon problème
Due to an upcoming trip, I finally decided to upgrade the original battery in my mid-2010 MacBook Pro. I contemplated purchasing the replacement on Amazon, eBay, or directly from Apple, but decided to go with iFixit after using their other products for multiple Mac repairs over the past 10 years. . . .
Scott Stuck's Story Photo #1367620
Mon problème
As you can see from the photo, my old battery decided to hit puberty and started growing. To my surprise, the existing home we provided for that battery was too small. As a result, it decided to grow through the trackpad as quickly as possible.
Ma solution
This was a super easy repair, albeit slightly scary be . . .
Mon problème
dead battery
Ma solution
nicely
Mon conseil
no
Mon problème
Original battery from 2010 was dead - not handy for a laptop :)
Ma solution
Flawless
Mon conseil
Great tools to go with it - gets the job done well!
Mon problème
Battery life zero
Ma solution
The driver bits did not fit screw heads well, if not careful could strip screw heads. Don’t be afraid to use excessive pressure
Mon conseil
Machine driver bits that fit screw heads better ie. find a better quality supplier maybe Germany
Mon problème
battery said it needed to be replaced and was not holding as charge for very long
Ma solution
Perfect. Using the provided tool I complete the repair in about 10 minutes with any problems.
Mon conseil
I've been using ifixit repair guides for years and they are simple the best. Nice step by step instructions.
Mon problème
I still had the factory battery in my MacBook Pro. I bought it in 2009 so the battery was definitely at end of life. It would only stay charged for a half hour if it was off the charger.
Ma solution
Great! Super easy. I did watch a Youtube video to make sure I was doing it correctly, but most could do the switch . . .
Mon problème
wanted more battery life
Ma solution
Great - this is easy.
Mon conseil
The instructions a bunch of steps for removing the faceplate entirely. The video skips that. I started removing the faceplate then realized I didn't need to -- so go with the video version. Much faster!
Works like a charm
Mon problème
old battery
Ma solution
great
Mon conseil
nope
Voir plus
