Aller au contenu principal
« Retour à Toutes les histoires
iPhone 4 5-Point Pentalobe Screwdriver modification needed
dbuckel -
iPhone 4 Verizon
Image de l'histoire
iPhone 4 Verizon Rear Panel Replacement
5 minutes
Easy
Mon problème
Purchased the screwdriver to repair a broken back cover on an iPhone 4.
Ma solution
Fixing the iPhone was very easy and quick. Unfortunately, the screwdriver had to be modified prior to use. The tip of the screwdriver was too long and came to too fine of a point to grip the screw.
Mon conseil
Very, and I mean VERY, gently grind or file off a small amount of the excess tip. I'd suggest grinding a little and testing the fit and then grinding some more if needed. Be sure to keep the tip square to the grinder.
Image P2 Pentalobe Screwdriver iPhone
$5.99
Image iPhone 4 (CDMA/Verizon) Blank Rear Glass Panel
$9.99
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 204
