Aller au contenu principal
Pour réparer ensemble - Je crée un compte
8BitDo Ultimate Wireless Joystick Module Replacement
Ce dont vous avez besoin
  1. 8BitDo Ultimate Wireless Joystick Module Replacement, Case: étape 1, image 1 de 2 8BitDo Ultimate Wireless Joystick Module Replacement, Case: étape 1, image 2 de 2
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    Demander à FixBot
    Ajouter un commentaire
  2. 8BitDo Ultimate Wireless Joystick Module Replacement: étape 2, image 1 de 2 8BitDo Ultimate Wireless Joystick Module Replacement: étape 2, image 2 de 2
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    Demander à FixBot
  3. 8BitDo Ultimate Wireless Joystick Module Replacement: étape 3, image 1 de 3 8BitDo Ultimate Wireless Joystick Module Replacement: étape 3, image 2 de 3 8BitDo Ultimate Wireless Joystick Module Replacement: étape 3, image 3 de 3
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    Demander à FixBot
  4. 8BitDo Ultimate Wireless Joystick Module Replacement: étape 4, image 1 de 3 8BitDo Ultimate Wireless Joystick Module Replacement: étape 4, image 2 de 3 8BitDo Ultimate Wireless Joystick Module Replacement: étape 4, image 3 de 3
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    Demander à FixBot
  5. 8BitDo Ultimate Wireless Joystick Module Replacement, Joystick's Module: étape 5, image 1 de 1
    • Grip each analog stick cap firmly and pull straight up to remove them.
    Demander à FixBot
  6. 8BitDo Ultimate Wireless Joystick Module Replacement: étape 6, image 1 de 2 8BitDo Ultimate Wireless Joystick Module Replacement: étape 6, image 2 de 2
    • Remove the three 5 mm Phillips #00 screws securing the midframe to the back shell, then lift it straight out.
    Demander à FixBot
  7. 8BitDo Ultimate Wireless Joystick Module Replacement: étape 7, image 1 de 2 8BitDo Ultimate Wireless Joystick Module Replacement: étape 7, image 2 de 2
    • Turn to the backside of the circuit board for clear access to the solder joints.
    • Desolder all of the outlined solder joints.
    • Refer to the following solder guide if necessary: How To Solder and Desolder Connections
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Garcia
Membre depuis le 04/03/26
473 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 Membre de l'équipe UMass Dartmouth, Team 1-3, Biswokarma Spring 2026
UMASSD-BISWOKARMA-S26S1G3
5 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 57
Total : 155
