Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Asus ROG G20CB RAM Replacement
Ce dont vous avez besoin
    1. Asus ROG G20CB  RAM Replacement, Fan: étape 1, image 1 de 2 Asus ROG G20CB  RAM Replacement, Fan: étape 1, image 2 de 2
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
      Demander à FixBot
      Ajouter un commentaire
    2. Asus ROG G20CB  RAM Replacement: étape 2, image 1 de 1
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
      Demander à FixBot
    3. Asus ROG G20CB  RAM Replacement: étape 3, image 1 de 1
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
      Demander à FixBot
    4. Asus ROG G20CB  RAM Replacement: étape 4, image 1 de 1
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
      Demander à FixBot
    5. Asus ROG G20CB  RAM Replacement: étape 5, image 1 de 1
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
      Demander à FixBot
    6. Asus ROG G20CB  RAM Replacement: étape 6, image 1 de 1
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
      Demander à FixBot
    1. Asus ROG G20CB  RAM Replacement, CPU Cooler: étape 7, image 1 de 1
      • Remove the 4.6 mm Phillips screw that secures the optical drive.
      Demander à FixBot
    2. Asus ROG G20CB  RAM Replacement: étape 8, image 1 de 1
      • Push the optical drive out of the chassis.
      Demander à FixBot
    3. Asus ROG G20CB  RAM Replacement: étape 9, image 1 de 1
      • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
      • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
      Demander à FixBot
    4. Asus ROG G20CB  RAM Replacement: étape 10, image 1 de 1
      • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
      • Lift the CPU cooler out of the system.
      • Be sure to apply fresh thermal paste before reinstalling a cooler.
      Demander à FixBot
    1. Asus ROG G20CB  RAM Replacement, RAM: étape 11, image 1 de 1
      • Gently push outward on the two retaining clips on either side of the RAM stick.
      Demander à FixBot
    2. Asus ROG G20CB  RAM Replacement: étape 12, image 1 de 1
      • The RAM module should pop up at an angle.
      • Pull the RAM stick out carefully by grasping it by the edges.
      • Avoid touching gold contacts.
      Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kimber-Starr
Membre depuis le 03/21/25
361 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-3, Botvin Spring 2025 Membre de l'équipe UMass Dartmouth, Team 3-3, Botvin Spring 2025
UMASSD-BOTVIN-S25S3G3
3 membres
59 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 34
30 derniers jours : 94
Total : 830
