Introduction
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to remove or replace the Soli radar module responsible for Google’s “Motion Sense” on your Google Pixel 4 XL.
Caution: Google warns that disassembly of the front laser assembly could result in hazardous exposure to invisible infrared laser emissions. Read their safety warnings here.
Ce dont vous avez besoin
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick across the bottom towards the left corner to slice the adhesive.
With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it on the left edge of the phone for one minute.
Prepare an iOpener and apply it on the right edge of the phone for one minute.
Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
Do not try to pull the panel all the way off yet, as it is still connected to the phone.
Outil utilisé dans cette étape :Magnetic Project Mat$19.95
Remove the four T3 Torx screws securing the battery connector shield:
One 1.8 mm screw
One 4.1 mm screw
One 4.4 mm shouldered screw
One 4.0 mm shouldered screw
Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
Gently pry back the battery adhesive pull tab to allow easier access to the screws underneath it.
Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
Remove the three T3 Torx screws securing the front camera and sensor assembly:
Two 2.7 mm screws
One 3.1 mm screw
Use a T3 Torx driver to remove the four 3.5 mm screws securing the display connector cover.
Outil utilisé dans cette étape :Tweezers$4.99
Use a pair of tweezers to remove the display connector cover.
Use the flat end of a spudger to disconnect the display connector from the motherboard.
Use a T3 Torx driver to remove the 2.7 mm screw securing the motherboard to the frame.
Use the pointed end of a spudger to disconnect the side buttons connector from the motherboard.
Disconnect the two rear-facing camera connectors from the motherboard.
Use the pointed end of a spudger and pry up gently to unclip the top antenna connector from the motherboard.
Disconnect the bottom antenna connector.
Using a spudger, pivot the top end of the motherboard up and out of the phone's frame.
Use a pair of tweezers to remove the rear-facing camera module.
Use a T3 Torx driver to remove the 2 mm screw securing the small earpiece module board to the phone.
Using the pointed end of a spudger, peel the microphone away from the light adhesive holding it to the phone's top frame.
Ensure the microphone is completely detached from the top frame before continuing to the next step.
Use a pair of tweezers to peel away and remove the Soli motion sensor cable, which is held in place with some light adhesive.
