Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 5 Front Camera Replacement
Ce dont vous avez besoin
  1. Google Pixel 5 Front Camera Replacement, Eject the SIM card tray: étape 1, image 1 de 3 Google Pixel 5 Front Camera Replacement, Eject the SIM card tray: étape 1, image 2 de 3 Google Pixel 5 Front Camera Replacement, Eject the SIM card tray: étape 1, image 3 de 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • The SIM card tray is located on the left edge of the phone near the bottom.
    • Press firmly to eject the SIM card tray.
    • Remove the SIM card tray.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixel 5 Front Camera Replacement, Heat the bottom edge of the screen: étape 2, image 1 de 1
    • Heat an iOpener and apply it to the bottom edge of the screen for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Demander à FixBot
  3. Google Pixel 5 Front Camera Replacement, Screen removal information: étape 3, image 1 de 3 Google Pixel 5 Front Camera Replacement, Screen removal information: étape 3, image 2 de 3 Google Pixel 5 Front Camera Replacement, Screen removal information: étape 3, image 3 de 3
    • While you're waiting for the adhesive to loosen, take note of the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    Demander à FixBot
  4. Google Pixel 5 Front Camera Replacement, Anti-Clamp instructions: étape 4, image 1 de 3 Google Pixel 5 Front Camera Replacement, Anti-Clamp instructions: étape 4, image 2 de 3 Google Pixel 5 Front Camera Replacement, Anti-Clamp instructions: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the screen—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
    Demander à FixBot
  5. Google Pixel 5 Front Camera Replacement: étape 5, image 1 de 3 Google Pixel 5 Front Camera Replacement: étape 5, image 2 de 3 Google Pixel 5 Front Camera Replacement: étape 5, image 3 de 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and its bezel frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    Demander à FixBot
  6. Google Pixel 5 Front Camera Replacement, Insert an opening pick: étape 6, image 1 de 3 Google Pixel 5 Front Camera Replacement, Insert an opening pick: étape 6, image 2 de 3 Google Pixel 5 Front Camera Replacement, Insert an opening pick: étape 6, image 3 de 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • If your screen is badly cracked, follow this guide to tape over the cracked screen. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the opening pick into the gap.
    Demander à FixBot
  7. Google Pixel 5 Front Camera Replacement, Slice the bottom adhesive: étape 7, image 1 de 3 Google Pixel 5 Front Camera Replacement, Slice the bottom adhesive: étape 7, image 2 de 3 Google Pixel 5 Front Camera Replacement, Slice the bottom adhesive: étape 7, image 3 de 3
    • Slide the opening pick back and forth along the bottom of the screen to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Demander à FixBot
  8. Google Pixel 5 Front Camera Replacement, Heat the left edge of the screen: étape 8, image 1 de 1
    • Apply a heated iOpener to the left edge of the screen for one minute.
    Demander à FixBot
  9. Google Pixel 5 Front Camera Replacement: étape 9, image 1 de 3 Google Pixel 5 Front Camera Replacement: étape 9, image 2 de 3 Google Pixel 5 Front Camera Replacement: étape 9, image 3 de 3
    • Insert another opening pick into the bottom left corner of the screen.
    • Slide the opening pick around the left corner.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable located in the middle of the left edge.
    • Continue to slide the pick up towards the front camera to slice the adhesive on the left edge of the screen.
    • Leave the pick inserted to prevent the adhesive from re-sealing.
    Demander à FixBot
  10. Google Pixel 5 Front Camera Replacement: étape 10, image 1 de 3 Google Pixel 5 Front Camera Replacement: étape 10, image 2 de 3 Google Pixel 5 Front Camera Replacement: étape 10, image 3 de 3
    • Insert another opening pick into the top left corner of the screen.
    • Slide the pick around the front camera and across the top edge of the phone.
    • If the adhesive is difficult to slice, apply heat to the area for one minute and try again.
    • Slide the pick to the top right corner of the phone and leave the pick inserted.
    Demander à FixBot
  11. Google Pixel 5 Front Camera Replacement: étape 11, image 1 de 3 Google Pixel 5 Front Camera Replacement: étape 11, image 2 de 3 Google Pixel 5 Front Camera Replacement: étape 11, image 3 de 3
    • Insert an opening pick into the bottom right corner of the screen.
    • Slide the pick up to the top right corner to slice the last edge of adhesive.
    • You may need to run an opening pick around the edges again to ensure all the adhesive is cut. It is applied the thickest on the four corners.
    Demander à FixBot
  12. Google Pixel 5 Front Camera Replacement, Open up the screen: étape 12, image 1 de 2 Google Pixel 5 Front Camera Replacement, Open up the screen: étape 12, image 2 de 2
    • Use the opening pick from the top left corner to lift up the left edge of the screen a few millimeters. This will keep the clips from snapping back down into the case.
    • Lift up on the right side of the screen and open up the phone like a book.
    • Do not open the screen more than 90 degrees to prevent damaging the screen flex cable.
    Demander à FixBot
  13. Google Pixel 5 Front Camera Replacement, Disconnect the screen: étape 13, image 1 de 2 Google Pixel 5 Front Camera Replacement, Disconnect the screen: étape 13, image 2 de 2
    • Use tweezers to grip the screen connector cover securing the screen flex cable.
    • Push the clip in towards the connector to unlatch it.
    Demander à FixBot
  14. Google Pixel 5 Front Camera Replacement: étape 14, image 1 de 2 Google Pixel 5 Front Camera Replacement: étape 14, image 2 de 2
    • Remove the screen connector cover.
    • Make sure to keep this component to reinstall it during reassembly.
    Demander à FixBot
  15. Google Pixel 5 Front Camera Replacement: étape 15, image 1 de 2 Google Pixel 5 Front Camera Replacement: étape 15, image 2 de 2
    • Use the tip of the spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage
    Demander à FixBot
  16. Google Pixel 5 Front Camera Replacement, Screen information: étape 16, image 1 de 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Demander à FixBot
  17. Google Pixel 5 Front Camera Replacement, Remove the screen: étape 17, image 1 de 2 Google Pixel 5 Front Camera Replacement, Remove the screen: étape 17, image 2 de 2
    • Remove the screen.
    • Use tweezers to pick off the remaining adhesive on the case.
    • If you use isopropyl alcohol to clean the adhesive off the display, be sure to not let it splash onto any unintended components, as this can weaken their adhesive bond.
    • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
    • If your replacement screen's display cable is held down by tape, remove the tape before installation.
    • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    Demander à FixBot
  18. Google Pixel 5 Front Camera Replacement, Remove the graphite tape: étape 18, image 1 de 3 Google Pixel 5 Front Camera Replacement, Remove the graphite tape: étape 18, image 2 de 3 Google Pixel 5 Front Camera Replacement, Remove the graphite tape: étape 18, image 3 de 3
    • Use tweezers to lift up the graphite tape until you are able to grip it with your fingers.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Peel off the graphite tape.
    Demander à FixBot
  19. Google Pixel 5 Front Camera Replacement: étape 19, image 1 de 2 Google Pixel 5 Front Camera Replacement: étape 19, image 2 de 2
    • Use tweezers to peel off the graphite pad covering the charging plate cover.
    • If you are able to keep the graphite pad in good condition, you may reapply it during reassembly.
    Demander à FixBot
  20. Google Pixel 5 Front Camera Replacement, Remove the charging plate cover: étape 20, image 1 de 1
    Magnetic Project Mat
    $16.96
    • Use a T3 Torx driver to remove the two 4.6 mm-long screws securing the charging plate cover to the midframe.
    Demander à FixBot
  21. Google Pixel 5 Front Camera Replacement: étape 21, image 1 de 2 Google Pixel 5 Front Camera Replacement: étape 21, image 2 de 2
    • Use tweezers to remove the charging plate cover.
    Demander à FixBot
  22. Google Pixel 5 Front Camera Replacement: étape 22, image 1 de 1
    • Use a T3 Torx driver to remove the eight 4.6 mm-long screws securing the midframe.
    Demander à FixBot
  23. Google Pixel 5 Front Camera Replacement, Remove the midframe: étape 23, image 1 de 3 Google Pixel 5 Front Camera Replacement, Remove the midframe: étape 23, image 2 de 3 Google Pixel 5 Front Camera Replacement, Remove the midframe: étape 23, image 3 de 3
    • Use tweezers to lift up the right side of the midframe.
    • Remove the midframe.
    • The spacer at the top of the phone is likely to fall out when you remove the midframe. Remember to save this spacer for reassembly. See pictures in the motherboard replacement guide.
    Demander à FixBot
  24. Google Pixel 5 Front Camera Replacement, Disconnect the battery: étape 24, image 1 de 2 Google Pixel 5 Front Camera Replacement, Disconnect the battery: étape 24, image 2 de 2
    • Use the pointed end of the spudger to pry the battery connector straight up and disconnect it from the motherboard.
    Demander à FixBot
  25. Google Pixel 5 Front Camera Replacement, Remove the shouldered screw: étape 25, image 1 de 1
    • Use a T3 Torx driver to remove the 4.1 mm shouldered screw.
    Demander à FixBot
  26. Google Pixel 5 Front Camera Replacement, Disconnect the rear cameras: étape 26, image 1 de 3 Google Pixel 5 Front Camera Replacement, Disconnect the rear cameras: étape 26, image 2 de 3 Google Pixel 5 Front Camera Replacement, Disconnect the rear cameras: étape 26, image 3 de 3
    • Use the spudger to disconnect the two rear camera press connectors from the motherboard.
    • Use your finger to hold down the rear camera assembly and prevent bending the motherboard.
    Demander à FixBot
  27. Google Pixel 5 Front Camera Replacement, Remove the rear cameras: étape 27, image 1 de 3 Google Pixel 5 Front Camera Replacement, Remove the rear cameras: étape 27, image 2 de 3 Google Pixel 5 Front Camera Replacement, Remove the rear cameras: étape 27, image 3 de 3
    • Use tweezers to lift up on the rear camera assembly to remove it from its housing.
    • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
    • Make sure the lens surface is smudge and dust free before you install the camera assembly.
    Demander à FixBot
  28. Google Pixel 5 Front Camera Replacement, Remove adhesive pull tabs: étape 28, image 1 de 3 Google Pixel 5 Front Camera Replacement, Remove adhesive pull tabs: étape 28, image 2 de 3 Google Pixel 5 Front Camera Replacement, Remove adhesive pull tabs: étape 28, image 3 de 3
    • Use blunt nose tweezers to grip the black adhesive pull tab located on the top right edge of the battery. Lift the pull tab with the tweezers until you are able to grip it with your fingers.
    • Pull on the pull tab with a slow, steady force at a shallow angle to prevent the pull tab from snapping in the middle.
    • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
    • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
    • If the pull tab breaks prematurely, use tweezers to retrieve the remaining length of adhesive and continue pulling.
    • If you are unable to retrieve it, move on to the next step.
    Demander à FixBot
  29. Google Pixel 5 Front Camera Replacement: étape 29, image 1 de 3 Google Pixel 5 Front Camera Replacement: étape 29, image 2 de 3 Google Pixel 5 Front Camera Replacement: étape 29, image 3 de 3
    • Use the same process to remove the pull tab located at the bottom left edge of the battery.
    • If this tab breaks prematurely and you are not able to retrieve it with tweezers, move on to the next step.
    Demander à FixBot
  30. Google Pixel 5 Front Camera Replacement, Loosen the adhesive: étape 30, image 1 de 2 Google Pixel 5 Front Camera Replacement, Loosen the adhesive: étape 30, image 2 de 2
    • If any of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol into the opening of the affected tab.
    Demander à FixBot
  31. Google Pixel 5 Front Camera Replacement: étape 31, image 1 de 2 Google Pixel 5 Front Camera Replacement: étape 31, image 2 de 2
    • Tilt the phone so that the alcohol flows towards the remaining adhesive.
    • Wait one minute for the adhesive to soften, then proceed to the next step.
    Demander à FixBot
  32. Google Pixel 5 Front Camera Replacement, Remove the battery: étape 32, image 1 de 2 Google Pixel 5 Front Camera Replacement, Remove the battery: étape 32, image 2 de 2
    Plastic Cards
    $2.99
    • Insert an opening pick into the gap long the left side of the battery.
    • Use the opening pick to slice the remaining adhesive at the top and bottom of the battery.
    • Avoid scraping the two flex cables under the battery with your opening pick.
    • This may be difficult as the adhesive is strategically located between the cables and the battery tray. A possible solution is to cut a plastic card to fit between the flex cables and battery tray edge.
    • Do not bend the battery.
    • Avoid the earpiece contact pins located near the top left corner of the battery as you pry up with your opening pick.
    • If you cannot pry the battery up, add a few more drops of isopropyl alcohol to the adhesive. A plastic card can also be helpful during this process.
    Demander à FixBot
  33. Google Pixel 5 Front Camera Replacement: étape 33, image 1 de 2 Google Pixel 5 Front Camera Replacement: étape 33, image 2 de 2
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove your old battery.
    Demander à FixBot
  34. Google Pixel 5 Front Camera Replacement, Disconnect the press connectors: étape 34, image 1 de 3 Google Pixel 5 Front Camera Replacement, Disconnect the press connectors: étape 34, image 2 de 3 Google Pixel 5 Front Camera Replacement, Disconnect the press connectors: étape 34, image 3 de 3
    • Use the pointed end of a spudger to disconnect the two press connectors by lifting them straight up from the motherboard.
    Demander à FixBot
  35. Google Pixel 5 Front Camera Replacement, Remove the motherboard screws: étape 35, image 1 de 1
    • Use a T3 Torx driver to remove the two 2.9 mm screws securing the motherboard to the rear case.
    Demander à FixBot
  36. Google Pixel 5 Front Camera Replacement, Bend the flex cable out of the way: étape 36, image 1 de 3 Google Pixel 5 Front Camera Replacement, Bend the flex cable out of the way: étape 36, image 2 de 3 Google Pixel 5 Front Camera Replacement, Bend the flex cable out of the way: étape 36, image 3 de 3
    • Use a spudger to gently fold the flex cable covering the rear case press connector out of the way.
    Demander à FixBot
  37. Google Pixel 5 Front Camera Replacement, Disconnect the press connector: étape 37, image 1 de 2 Google Pixel 5 Front Camera Replacement, Disconnect the press connector: étape 37, image 2 de 2
    • Use the spudger to disconnect the rear case press connector.
    Demander à FixBot
  38. Google Pixel 5 Front Camera Replacement, Remove the motherboard: étape 38, image 1 de 2 Google Pixel 5 Front Camera Replacement, Remove the motherboard: étape 38, image 2 de 2
    • Insert the pointed end of the spudger into the screw holes near the front facing camera.
    • Push the motherboard down towards the bottom of the phone, then lift up to free the top of the motherboard from the rear case.
    Demander à FixBot
  39. Google Pixel 5 Front Camera Replacement: étape 39, image 1 de 3 Google Pixel 5 Front Camera Replacement: étape 39, image 2 de 3 Google Pixel 5 Front Camera Replacement: étape 39, image 3 de 3
    • Use your fingers to pull the motherboard up towards the top of the rear case to free the charging port.
    • Do not bend or twist the motherboard.
    • If the motherboard gets caught on the case, use a spudger to go around the edges and loosen it up.
    • Remove the motherboard.
    Demander à FixBot
  40. Google Pixel 5 Front Camera Replacement: étape 40, image 1 de 2 Google Pixel 5 Front Camera Replacement: étape 40, image 2 de 2
    • After removing the motherboard, the top spacer will usually fall out. To replace it, reposition the midframe without screwing it down. Grasp the spacer with the tweezers and compress the interior foam to squeeze it into position. Then screw the midframe into place.
    • Grip the spacer by the body and not by the delicate end tabs.
    Demander à FixBot
  41. Google Pixel 5 Front Camera Replacement, Remove the front camera: étape 41, image 1 de 3 Google Pixel 5 Front Camera Replacement, Remove the front camera: étape 41, image 2 de 3 Google Pixel 5 Front Camera Replacement, Remove the front camera: étape 41, image 3 de 3
    • Use the pointed end of the spudger to lift up and disconnect the front camera from the motherboard.
    • Remove the camera.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Robert Boyd
Membre depuis le 02/01/21
33 206 Réputation
94 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 83
Total : 4,392
