Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 6 Pro Front Camera Replacement
Ce dont vous avez besoin
  1. Google Pixel 6 Pro Front Camera Replacement, Safety precautions: étape 1, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Safety precautions: étape 1, image 2 de 2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel 6 Pro Front Camera Replacement, Anti-Clamp instructions: étape 2, image 1 de 3 Google Pixel 6 Pro Front Camera Replacement, Anti-Clamp instructions: étape 2, image 2 de 3 Google Pixel 6 Pro Front Camera Replacement, Anti-Clamp instructions: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. Google Pixel 6 Pro Front Camera Replacement: étape 3, image 1 de 3 Google Pixel 6 Pro Front Camera Replacement: étape 3, image 2 de 3 Google Pixel 6 Pro Front Camera Replacement: étape 3, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Google Pixel 6 Pro Front Camera Replacement: étape 4, image 1 de 3 Google Pixel 6 Pro Front Camera Replacement: étape 4, image 2 de 3 Google Pixel 6 Pro Front Camera Replacement: étape 4, image 3 de 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. Google Pixel 6 Pro Front Camera Replacement, Loosen the display adhesive: étape 5, image 1 de 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  6. Google Pixel 6 Pro Front Camera Replacement, Insert an opening pick: étape 6, image 1 de 3 Google Pixel 6 Pro Front Camera Replacement, Insert an opening pick: étape 6, image 2 de 3 Google Pixel 6 Pro Front Camera Replacement, Insert an opening pick: étape 6, image 3 de 3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom left corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. Google Pixel 6 Pro Front Camera Replacement, Slice the adhesive: étape 7, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Slice the adhesive: étape 7, image 2 de 2
    • Insert a second opening pick at the bottom edge and slide it to the bottom right corner of the screen to slice the adhesive.
  8. Google Pixel 6 Pro Front Camera Replacement: étape 8, image 1 de 3 Google Pixel 6 Pro Front Camera Replacement: étape 8, image 2 de 3 Google Pixel 6 Pro Front Camera Replacement: étape 8, image 3 de 3
    • The screen of the Google Pixel 6 Pro is not only held in place by adhesive but also small plastic pins. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (~3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. Google Pixel 6 Pro Front Camera Replacement: étape 9, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement: étape 9, image 2 de 2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. Google Pixel 6 Pro Front Camera Replacement: étape 10, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement: étape 10, image 2 de 2
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
  11. Google Pixel 6 Pro Front Camera Replacement, Open up the phone assembly: étape 11, image 1 de 3 Google Pixel 6 Pro Front Camera Replacement, Open up the phone assembly: étape 11, image 2 de 3 Google Pixel 6 Pro Front Camera Replacement, Open up the phone assembly: étape 11, image 3 de 3
    • Avoid straining the display cable during the following procedure.
    • Carefully fold the screen to the left side of the phone assembly like you would open the front cover of a book.
  12. Google Pixel 6 Pro Front Camera Replacement, Unfasten the display bracket screw: étape 12, image 1 de 1
    Magnetic Project Mat
    $19.95
    • While the Pixel 6 Pro uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx T3 screwdriver to remove the 2.0 mm-long 3IP Torx Plus screw securing the display cable metal bracket.
  13. Google Pixel 6 Pro Front Camera Replacement, Remove the display cable bracket: étape 13, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Remove the display cable bracket: étape 13, image 2 de 2
    • Use a pair of tweezers to remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
  14. Google Pixel 6 Pro Front Camera Replacement, Disconnect the display cable: étape 14, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Disconnect the display cable: étape 14, image 2 de 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  15. Google Pixel 6 Pro Front Camera Replacement, Screen information: étape 15, image 1 de 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  16. Google Pixel 6 Pro Front Camera Replacement, Remove the screen: étape 16, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Remove the screen: étape 16, image 2 de 2
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the screen's front-facing camera hole and sensor cutout for any protective liners. Remove these liners before you close the phone up.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide in case you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
  17. Google Pixel 6 Pro Front Camera Replacement, Loosen the graphite film adhesive: étape 17, image 1 de 1
    • Apply a heated iOpener or a heat gun to the rear glass to loosen the adhesive underneath the graphite films on top of the battery. Apply the iOpener for at least two minutes.
    • Don't apply heat directly onto the battery. It is susceptible to heat damage and could cause a thermal event.
  18. Google Pixel 6 Pro Front Camera Replacement, Remove the graphite film: étape 18, image 1 de 3 Google Pixel 6 Pro Front Camera Replacement, Remove the graphite film: étape 18, image 2 de 3 Google Pixel 6 Pro Front Camera Replacement, Remove the graphite film: étape 18, image 3 de 3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the bottom edge of the battery and the motherboard shield.
    • Remove the graphite film.
  19. Google Pixel 6 Pro Front Camera Replacement, Peel off the graphite film: étape 19, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Peel off the graphite film: étape 19, image 2 de 2
    • If you want to replace your battery it's enough to peel the bottom part of the graphite film off the battery. If you want to replace your rear camera you need to remove it completely. In case you only want to replace the earpiece speaker or the front facing camera, you can leave it in its place.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the top right corner of the battery.
    • Fold the graphite film in direction of the selfie camera to get free access to the battery.
  20. Google Pixel 6 Pro Front Camera Replacement, Remove the graphite film: étape 20, image 1 de 3 Google Pixel 6 Pro Front Camera Replacement, Remove the graphite film: étape 20, image 2 de 3 Google Pixel 6 Pro Front Camera Replacement, Remove the graphite film: étape 20, image 3 de 3
    • If the graphite film becomes hard to peel off, it has most likely cooled down. Reapply your iOpener or heat gun to the rear glass for 1-2 minutes to reheat it.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the left edge of the battery and the motherboard shield.
  21. Google Pixel 6 Pro Front Camera Replacement, Unfasten the charging port bracket screws: étape 21, image 1 de 1
    • Use a Torx T3 screwdriver to remove the two 5.1 mm-long 3IP Torx Plus screws securing the charging port metal bracket.
  22. Google Pixel 6 Pro Front Camera Replacement, Remove the charging port bracket: étape 22, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Remove the charging port bracket: étape 22, image 2 de 2
    • Use a pair of tweezers to remove the charging port bracket.
  23. Google Pixel 6 Pro Front Camera Replacement, Unfasten the motherboard cover screws: étape 23, image 1 de 1
    • Use a Torx T3 screwdriver to remove the five 5.1 mm-long 3IP Torx Plus screws securing the motherboard cover.
  24. Google Pixel 6 Pro Front Camera Replacement, Remove the motherboard cover: étape 24, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Remove the motherboard cover: étape 24, image 2 de 2
    • Use a pair of tweezers or your fingers to carefully remove the motherboard cover.
  25. Google Pixel 6 Pro Front Camera Replacement, Disconnect the battery cable: étape 25, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Disconnect the battery cable: étape 25, image 2 de 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  26. Google Pixel 6 Pro Front Camera Replacement, Unfasten the earpiece speaker screws: étape 26, image 1 de 1
    • Use a Torx T3 screwdriver to remove the two 3.3 mm-long 3IP Torx Plus screws securing the earpiece speaker.
  27. Google Pixel 6 Pro Front Camera Replacement, Pry up the earpiece speaker: étape 27, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Pry up the earpiece speaker: étape 27, image 2 de 2
    • Insert a spudger underneath the bottom left edge of the earpiece speaker.
    • Use the spudger to pry up the earpiece speaker by tilting it downwards.
  28. Google Pixel 6 Pro Front Camera Replacement, Remove the earpiece speaker: étape 28, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Remove the earpiece speaker: étape 28, image 2 de 2
    • Use a pair of tweezers or your fingers to carefully remove the earpiece speaker.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
  29. Google Pixel 6 Pro Front Camera Replacement, Disconnect the front camera cable: étape 29, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Disconnect the front camera cable: étape 29, image 2 de 2
    • Use a spudger to disconnect the front camera cable by prying the connector straight up from its socket.
  30. Google Pixel 6 Pro Front Camera Replacement, Remove the front camera: étape 30, image 1 de 2 Google Pixel 6 Pro Front Camera Replacement, Remove the front camera: étape 30, image 2 de 2
    • Use your fingers or a pair of tweezers to carefully lift the front camera out of its recess and remove it.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Dominik Schnabelrauch
Membre depuis le 11/23/16
249 314 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 918 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 64
Total : 3,632
