Introduction
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the motherboard in your Google Pixel 6a.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: this guide was made using the Verizon GB62Z model, which features a 5G mmWave antenna. Ignore the steps that include the 5G mmWave antenna if you have a different model, as the procedure is identical.
You'll need replacement adhesive in order to complete this repair.
Ce dont vous avez besoin
Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
Remove the SIM card tray.
Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
Outil utilisé dans cette étape :Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over the right edge of your phone.
Position the suction cups near the middle of the right edge of the phone—one on the front, and one on the back.
Squeeze the cups together to apply suction.
Heat an iOpener and thread it through the arms of the Anti-Clamp so it lays on the right edge of the phone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Heat an iOpener and apply it to the right edge of the screen for two minutes.
Apply a suction cup to the screen, as close to the center of the right edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the bezel and the frame.
Insert an opening pick into the gap.
While still applying suction, pivot the pick upwards to a steep angle.
Carefully push the pick in while prying to reposition the opening pick into the bezel seam.
Slide the pick along the right edge to release the plastic clips securing the bezel to the frame.
Position the pick at the top-right edge before moving to the next step.
Rotate the opening pick around the top-right corner of the phone to release the clips.
Leave the opening pick in the top-right corner to prevent the clips from re-locking.
Insert a new opening pick into the gap you just created.
Slide the pick along the top edge to release the clips.
Rotate the opening pick around the top-left corner of the phone to release the clips.
Leave the opening pick in the top-left corner to prevent the clips from re-locking.
Slide the pick along the left edge to release the clips.
Repeat the rotating and sliding procedure for the remaining edge.
Lift the right edge of the screen up and towards the left side of the device, like opening a book.
Rest the screen upside down and parallel to the frame before continuing.
Insert the tip of an opening pick under the bottom right edge of the display cable press connector, right above the nearby screw hole.
Pry up and disconnect the display cable press connector.
Remove the screen.
If you replaced your screen, check the front-facing camera hole and the sensor cutout on your replacement screen, and remove any remaining liners.
This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
Follow this guide to replace the screen adhesive.
If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
Use a T3 Torx screwdriver to remove the 16 screws securing the midframe to the frame:
Eight 4.3 mm screws
Five 2.9 mm screws
Two 4.9 mm screws
One 4.6 mm screw
Insert a spudger between the top of the midframe and the frame, near the front camera.
Pry up with the spudger to release the top of the midframe from its clips.
Use the flat end of a spudger to scrape off the thermal paste.
Clean any remaining thermal paste with isopropyl alcohol and either a coffee filter or a lint-free cloth.
Repeat the cleaning process for the thermal paste on the midframe.
Use a spudger to pry up and disconnect the battery's press connector.
Use a T3 Torx screwdriver to remove the 2.9 mm screw securing the 5G mmWave antenna bracket.
Use a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
Use a spudger to pry up and disconnect the ultrawide rear camera's press connector.
Remove the ultrawide rear camera.
Use a spudger to pry up and disconnect the wide rear camera's press connector.
Remove the wide rear camera.
Use the flat end of a spudger to pry up the volume and power button press connector near the top left corner of the motherboard.
Use a T3 Torx screwdriver to remove the 2.9 mm screw securing the motherboard.
Insert a spudger between the top of the motherboard and the frame, near the front camera.
Pry up to lift the motherboard until you can grip it with your fingers.
Use a spudger to pry up and disconnect the front camera's press connector located on the bottom of the logic board.
Remove the front camera.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 6a Answers community for help.
Un commentaire
As of right now, is it possible to get a replacement motherboard for the Pixel 6a? I spoke with a repair shop and they said the phone would need to be under warranty (which in the case of my wife's phone, it is not due to getting smashed in a car door) to get a replacement motherboard.
