Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel Fold Back Glass Replacement
Ce dont vous avez besoin
  1. Google Pixel Fold Back Glass Replacement, Safety Precautions: étape 1, image 1 de 1
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixel Fold Back Glass Replacement, Heat the bottom edge: étape 2, image 1 de 1
    • Lay the phone down on a clean, smooth surface so the back glass is facing up.
    • Heat an iOpener and apply it to the bottom edge of the back glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the displays and/or internal batteries, so proceed with care.
    Demander à FixBot
  3. Google Pixel Fold Back Glass Replacement, Anti-Clamp instructions: étape 3, image 1 de 3 Google Pixel Fold Back Glass Replacement, Anti-Clamp instructions: étape 3, image 2 de 3 Google Pixel Fold Back Glass Replacement, Anti-Clamp instructions: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Unfold your phone completely and slide the Anti-Clamp arms over the left edge of the back glass, below the Google "G" logo.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Make sure the suction cup on the inner screen isn't touching the bezel, as it won't stick properly.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface. If the glass if cracked, use packing tape to help the suction cups adhere.
    Demander à FixBot
  4. Google Pixel Fold Back Glass Replacement: étape 4, image 1 de 3 Google Pixel Fold Back Glass Replacement: étape 4, image 2 de 3 Google Pixel Fold Back Glass Replacement: étape 4, image 3 de 3
    • Place an object under your phone, like a box or a stack of books, so it rests level while between the Anti-Clamp's arms.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, detach the suction cups and realign the arms.
    Demander à FixBot
  5. Google Pixel Fold Back Glass Replacement: étape 5, image 1 de 1
    • Insert an opening pick into the gap under the back glass.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    Demander à FixBot
  6. Google Pixel Fold Back Glass Replacement, Insert an opening pick: étape 6, image 1 de 3 Google Pixel Fold Back Glass Replacement, Insert an opening pick: étape 6, image 2 de 3 Google Pixel Fold Back Glass Replacement, Insert an opening pick: étape 6, image 3 de 3
    • Apply a suction cup to the back glass, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back glass and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back glass.
    Demander à FixBot
  7. Google Pixel Fold Back Glass Replacement, Separate the bottom adhesive: étape 7, image 1 de 3 Google Pixel Fold Back Glass Replacement, Separate the bottom adhesive: étape 7, image 2 de 3 Google Pixel Fold Back Glass Replacement, Separate the bottom adhesive: étape 7, image 3 de 3
    • Don’t insert the opening pick deeper than 3.5 mm when separating the back glass adhesive, as you risk damaging internal components.
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive.
    • Leave the opening pick in the bottom left corner before continuing.
    Demander à FixBot
  8. Google Pixel Fold Back Glass Replacement, Heat the left edge: étape 8, image 1 de 1
    • Apply a heated iOpener to the left edge of the back glass for two minutes.
    Demander à FixBot
  9. Google Pixel Fold Back Glass Replacement, Separate the bottom left adhesive: étape 9, image 1 de 2 Google Pixel Fold Back Glass Replacement, Separate the bottom left adhesive: étape 9, image 2 de 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
    Demander à FixBot
  10. Google Pixel Fold Back Glass Replacement, Separate the left adhesive: étape 10, image 1 de 3 Google Pixel Fold Back Glass Replacement, Separate the left adhesive: étape 10, image 2 de 3 Google Pixel Fold Back Glass Replacement, Separate the left adhesive: étape 10, image 3 de 3
    • Insert a second opening pick at the bottom left corner.
    • Slide the opening pick toward the top left corner to separate the adhesive.
    • Leave the opening pick in the top left corner before continuing.
    Demander à FixBot
  11. Google Pixel Fold Back Glass Replacement, Heat the top edge: étape 11, image 1 de 1
    • Apply a heated iOpener to the top edge of the back glass for two minutes.
    Demander à FixBot
  12. Google Pixel Fold Back Glass Replacement, Separate the top left adhesive: étape 12, image 1 de 2 Google Pixel Fold Back Glass Replacement, Separate the top left adhesive: étape 12, image 2 de 2
    • Rotate the opening pick around the top left corner to separate the adhesive.
    Demander à FixBot
  13. Google Pixel Fold Back Glass Replacement, Separate the top adhesive: étape 13, image 1 de 2 Google Pixel Fold Back Glass Replacement, Separate the top adhesive: étape 13, image 2 de 2
    • Insert a third opening pick in the top left corner.
    • Slide the opening pick toward the top right corner to separate the adhesive.
    Demander à FixBot
  14. Google Pixel Fold Back Glass Replacement, Heat the right edge: étape 14, image 1 de 1
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
    Demander à FixBot
  15. Google Pixel Fold Back Glass Replacement, Separate the top right adhesive: étape 15, image 1 de 2 Google Pixel Fold Back Glass Replacement, Separate the top right adhesive: étape 15, image 2 de 2
    • This sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
    • Angle your pick so it's as flat as possible to the back glass.
    • Rotate the opening pick around the top right corner to separate the adhesive.
    Demander à FixBot
  16. Google Pixel Fold Back Glass Replacement, Separate the right adhesive: étape 16, image 1 de 3 Google Pixel Fold Back Glass Replacement, Separate the right adhesive: étape 16, image 2 de 3 Google Pixel Fold Back Glass Replacement, Separate the right adhesive: étape 16, image 3 de 3
    • Insert a fourth opening pick in the top right corner.
    • Slide the opening pick toward the bottom right corner to separate the adhesive.
    Demander à FixBot
  17. Google Pixel Fold Back Glass Replacement, Separate the bottom right adhesive: étape 17, image 1 de 2 Google Pixel Fold Back Glass Replacement, Separate the bottom right adhesive: étape 17, image 2 de 2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
    Demander à FixBot
  18. Google Pixel Fold Back Glass Replacement, Reposition the back glass: étape 18, image 1 de 3 Google Pixel Fold Back Glass Replacement, Reposition the back glass: étape 18, image 2 de 3 Google Pixel Fold Back Glass Replacement, Reposition the back glass: étape 18, image 3 de 3
    • Don't fully remove the back glass yet, as it's still connected to the phone by a cable.
    • At this point, the back glass should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Swing the left edge of the back glass up and over the right edge of the phone.
    • Lay the back glass to the right side of the phone before continuing.
    Demander à FixBot
  19. Google Pixel Fold Back Glass Replacement, Unfasten the middle bracket: étape 19, image 1 de 1
    FixMat
    $36.95
    • While the Pixel Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the two 2.8 mm‑long screws securing the middle bracket.
    Demander à FixBot
  20. Google Pixel Fold Back Glass Replacement, Remove the middle bracket: étape 20, image 1 de 3 Google Pixel Fold Back Glass Replacement, Remove the middle bracket: étape 20, image 2 de 3 Google Pixel Fold Back Glass Replacement, Remove the middle bracket: étape 20, image 3 de 3
    • Use tweezers, or your fingers, to pull the middle bracket toward the left edge of the phone and release its clip.
    • Remove the middle bracket.
    • During reassembly, reinsert the middle bracket clip under its slot in the frame before aligning the screw holes.
    Demander à FixBot
  21. Google Pixel Fold Back Glass Replacement, Disconnect the back glass cable: étape 21, image 1 de 2 Google Pixel Fold Back Glass Replacement, Disconnect the back glass cable: étape 21, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the back glass cable from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Demander à FixBot
  22. Google Pixel Fold Back Glass Replacement, Remove the back glass: étape 22, image 1 de 1
    • Remove the back glass.
    Demander à FixBot
  23. Google Pixel Fold Back Glass Replacement, Reassembly information: étape 23, image 1 de 2 Google Pixel Fold Back Glass Replacement, Reassembly information: étape 23, image 2 de 2
    Tesa 61395 Tape
    $8.95
    • During reassembly:
    • If you're reusing your back glass, use tweezers to remove big chunks of adhesive from the perimeter of the back glass.
    • Repeat for any adhesive on the frame.
    • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
    • Follow this guide to replace the back glass adhesive with custom cut strips.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the back glass to the frame.
    Demander à FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
244 661 Réputation
1 203 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
27 624 tutoriels rédigés
2 commentaires de tutoriel
Thanks! Great and detailed guide. Google Pixel Fold 1 FTW!
velocity211 - Réponse Partager
Mine My mirror doesn't show anything outside, how can I get the first service?
ibrahimumihulu0 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 124
Total : 3,547
