Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HTC Vive OLED Screen Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
    1. HTC Vive OLED Screen Replacement, Release the upper head strap: étape 1, image 1 de 2 HTC Vive OLED Screen Replacement, Release the upper head strap: étape 1, image 2 de 2
      • Be sure to power down and disconnect your Vive before beginning.
      • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
      Demander à FixBot
      Ajouter un commentaire
    2. HTC Vive OLED Screen Replacement, Remove the upper head strap: étape 2, image 1 de 2 HTC Vive OLED Screen Replacement, Remove the upper head strap: étape 2, image 2 de 2
      • Slide the top part of the head strap through its metal loop on the headset to remove it.
      Demander à FixBot
    3. HTC Vive OLED Screen Replacement, Remove the right side of the head strap: étape 3, image 1 de 3 HTC Vive OLED Screen Replacement, Remove the right side of the head strap: étape 3, image 2 de 3 HTC Vive OLED Screen Replacement, Remove the right side of the head strap: étape 3, image 3 de 3
      • Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
      • Slide the right side of the head strap through its metal loop to remove it.
      Demander à FixBot
    4. HTC Vive OLED Screen Replacement, Remove the left side of the head strap: étape 4, image 1 de 3 HTC Vive OLED Screen Replacement, Remove the left side of the head strap: étape 4, image 2 de 3 HTC Vive OLED Screen Replacement, Remove the left side of the head strap: étape 4, image 3 de 3
      • Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
      • Slide the left side of the head strap through its metal loop to remove it.
      Demander à FixBot
    5. HTC Vive OLED Screen Replacement, Remove the head strap: étape 5, image 1 de 3 HTC Vive OLED Screen Replacement, Remove the head strap: étape 5, image 2 de 3 HTC Vive OLED Screen Replacement, Remove the head strap: étape 5, image 3 de 3
      • Slide the head strap along the cable, away from the Vive.
      • When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
      Demander à FixBot
    1. HTC Vive OLED Screen Replacement, Unscrew the head strap mounts: étape 6, image 1 de 2 HTC Vive OLED Screen Replacement, Unscrew the head strap mounts: étape 6, image 2 de 2
      • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
      • For some devices, a T6 Torx driver may work better.
      • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
      Demander à FixBot
    2. HTC Vive OLED Screen Replacement, Remove the head strap mounts: étape 7, image 1 de 3 HTC Vive OLED Screen Replacement, Remove the head strap mounts: étape 7, image 2 de 3 HTC Vive OLED Screen Replacement, Remove the head strap mounts: étape 7, image 3 de 3
      • Remove both head strap mounts.
      Demander à FixBot
    3. HTC Vive OLED Screen Replacement, Remove the facerest: étape 8, image 1 de 2 HTC Vive OLED Screen Replacement, Remove the facerest: étape 8, image 2 de 2
      • Slide the facerest straight away from the headset to remove it.
      Demander à FixBot
    1. HTC Vive OLED Screen Replacement, Unscrew the outer shell: étape 9, image 1 de 3 HTC Vive OLED Screen Replacement, Unscrew the outer shell: étape 9, image 2 de 3 HTC Vive OLED Screen Replacement, Unscrew the outer shell: étape 9, image 3 de 3
      Outil utilisé dans cette étape :
      • Use tweezers to remove the small stickers over the four screws securing the outer shell.
      • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
      Demander à FixBot
    2. HTC Vive OLED Screen Replacement, Remove the outer shell: étape 10, image 1 de 2 HTC Vive OLED Screen Replacement, Remove the outer shell: étape 10, image 2 de 2
      • Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
      Demander à FixBot
    3. HTC Vive OLED Screen Replacement: étape 11, image 1 de 2 HTC Vive OLED Screen Replacement: étape 11, image 2 de 2
      • Grasp the right half the outer shell and pull it to the right and toward the front of the headset until you feel the clips on the front of the cover release.
      • If the shell is difficult to remove, try prying along the seam with the flat end of a spudger to release the clips.
      Demander à FixBot
    4. HTC Vive OLED Screen Replacement: étape 12, image 1 de 2 HTC Vive OLED Screen Replacement: étape 12, image 2 de 2
      • Slide the right side of the outer shell to the right and off of the headset.
      Demander à FixBot
    5. HTC Vive OLED Screen Replacement: étape 13, image 1 de 2 HTC Vive OLED Screen Replacement: étape 13, image 2 de 2
      • Repeat the last three steps for the left side of the outer shell and remove it.
      Demander à FixBot
    1. HTC Vive OLED Screen Replacement, Disconnect the sensor array cables: étape 14, image 1 de 3 HTC Vive OLED Screen Replacement, Disconnect the sensor array cables: étape 14, image 2 de 3 HTC Vive OLED Screen Replacement, Disconnect the sensor array cables: étape 14, image 3 de 3
      • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
      Demander à FixBot
    2. HTC Vive OLED Screen Replacement: étape 15, image 1 de 3 HTC Vive OLED Screen Replacement: étape 15, image 2 de 3 HTC Vive OLED Screen Replacement: étape 15, image 3 de 3
      • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
      • Slide the cable straight out of its socket on the motherboard.
      Demander à FixBot
    3. HTC Vive OLED Screen Replacement: étape 16, image 1 de 3 HTC Vive OLED Screen Replacement: étape 16, image 2 de 3 HTC Vive OLED Screen Replacement: étape 16, image 3 de 3
      • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
      Demander à FixBot
    4. HTC Vive OLED Screen Replacement: étape 17, image 1 de 2 HTC Vive OLED Screen Replacement: étape 17, image 2 de 2
      • Use tweezers or a spudger to pry up the camera cable cover and remove it.
      Demander à FixBot
    5. HTC Vive OLED Screen Replacement: étape 18, image 1 de 2 HTC Vive OLED Screen Replacement: étape 18, image 2 de 2
      • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
      Demander à FixBot
    6. HTC Vive OLED Screen Replacement, Unscrew the sensor array: étape 19, image 1 de 1
      • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
      Demander à FixBot
    7. HTC Vive OLED Screen Replacement: étape 20, image 1 de 1
      • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
      Demander à FixBot
    8. HTC Vive OLED Screen Replacement: étape 21, image 1 de 2 HTC Vive OLED Screen Replacement: étape 21, image 2 de 2
      Phillips #000 Screwdriver
      $5.49
      • You'll need a narrow, long-shaft driver to reach these screws.
      Demander à FixBot
    9. HTC Vive OLED Screen Replacement, Remove the sensor array: étape 22, image 1 de 2 HTC Vive OLED Screen Replacement, Remove the sensor array: étape 22, image 2 de 2
      • Lift the sensor array away from the headset to remove it.
      Demander à FixBot
    1. HTC Vive OLED Screen Replacement, Disconnect the motherboard: étape 23, image 1 de 3 HTC Vive OLED Screen Replacement, Disconnect the motherboard: étape 23, image 2 de 3 HTC Vive OLED Screen Replacement, Disconnect the motherboard: étape 23, image 3 de 3
      • Remove the tape covering the interconnect cable socket.
      • Use the point of a spudger to flip up the small locking flap on the cable socket.
      • Slide the interconnect cable straight out of its socket on the motherboard.
      Demander à FixBot
    2. HTC Vive OLED Screen Replacement: étape 24, image 1 de 3 HTC Vive OLED Screen Replacement: étape 24, image 2 de 3 HTC Vive OLED Screen Replacement: étape 24, image 3 de 3
      • Remove the tape covering the left OLED cable socket.
      • Slide the left OLED cable straight out of its socket on the motherboard.
      Demander à FixBot
    3. HTC Vive OLED Screen Replacement: étape 25, image 1 de 3 HTC Vive OLED Screen Replacement: étape 25, image 2 de 3 HTC Vive OLED Screen Replacement: étape 25, image 3 de 3
      • Remove the tape covering the right OLED cable socket.
      • Slide the right OLED cable straight out of its socket on the motherboard.
      Demander à FixBot
    4. HTC Vive OLED Screen Replacement: étape 26, image 1 de 2 HTC Vive OLED Screen Replacement: étape 26, image 2 de 2
      • Use a pair tweezers to slightly twist the interconnect cable and press it down until the tabs on either side of the cable clear the hole in the motherboard.
      • During reassembly, make sure to thread the interconnect cable through its slot in the motherboard.
      Demander à FixBot
    5. HTC Vive OLED Screen Replacement, Remove the motherboard: étape 27, image 1 de 3 HTC Vive OLED Screen Replacement, Remove the motherboard: étape 27, image 2 de 3 HTC Vive OLED Screen Replacement, Remove the motherboard: étape 27, image 3 de 3
      • Press the non-port-end of the motherboard toward the top of headset while hinging it away from the midframe to free it from the clips securing that end.
      • Slide the motherboard toward the bottom of the headset, over the clips, to remove it.
      • Take care not to snag any cables during removal.
      Demander à FixBot
    1. HTC Vive OLED Screen Replacement, Disconnect the facerest midframe: étape 28, image 1 de 3 HTC Vive OLED Screen Replacement, Disconnect the facerest midframe: étape 28, image 2 de 3 HTC Vive OLED Screen Replacement, Disconnect the facerest midframe: étape 28, image 3 de 3
      • Use a pair of tweezers to peel back the plastic covering the eyepiece midframe cable socket.
      • Use the pointed end of a spudger to flip up the plastic locking flap on the socket.
      • Slide the cable straight out of its socket to remove it.
      Demander à FixBot
    2. HTC Vive OLED Screen Replacement: étape 29, image 1 de 2 HTC Vive OLED Screen Replacement: étape 29, image 2 de 2
      • Gently peel the eyepiece midframe cable off of the facerest midframe.
      Demander à FixBot
    3. HTC Vive OLED Screen Replacement, Unscrew the facerest midframe: étape 30, image 1 de 1
      • Use a PH000 driver to remove the four 3.9 mm screws securing the facerest midframe.
      Demander à FixBot
    4. HTC Vive OLED Screen Replacement, Remove the facerest midframe: étape 31, image 1 de 2 HTC Vive OLED Screen Replacement, Remove the facerest midframe: étape 31, image 2 de 2
      • Lift the facerest midframe off of the eyepiece midframe.
      Demander à FixBot
    1. HTC Vive OLED Screen Replacement, Remove the eyepiece gasket: étape 32, image 1 de 3 HTC Vive OLED Screen Replacement, Remove the eyepiece gasket: étape 32, image 2 de 3 HTC Vive OLED Screen Replacement, Remove the eyepiece gasket: étape 32, image 3 de 3
      • Gently lift the eyepiece gasket off of the lens and OLED frames to remove it.
      Demander à FixBot
    2. HTC Vive OLED Screen Replacement, Remove the support rod: étape 33, image 1 de 3 HTC Vive OLED Screen Replacement, Remove the support rod: étape 33, image 2 de 3 HTC Vive OLED Screen Replacement, Remove the support rod: étape 33, image 3 de 3
      • Pull the rubber bumpers off of either end of the support rod.
      Demander à FixBot
    3. HTC Vive OLED Screen Replacement: étape 34, image 1 de 3 HTC Vive OLED Screen Replacement: étape 34, image 2 de 3 HTC Vive OLED Screen Replacement: étape 34, image 3 de 3
      • Slide the support rod out of its brackets on the lens and OLED frames.
      Demander à FixBot
    4. HTC Vive OLED Screen Replacement, Remove the focus rod: étape 35, image 1 de 1
      • Use a PH000 driver to remove the eight 3.1 mm screws securing the focus rod brackets.
      Demander à FixBot
    5. HTC Vive OLED Screen Replacement: étape 36, image 1 de 1
      • Remove the focus rod and its brackets.
      Demander à FixBot
    6. HTC Vive OLED Screen Replacement, Unscrew the OLED covers: étape 37, image 1 de 1
      • Use a PH000 driver to remove the eight 2.4 mm screws securing the OLED covers.
      Demander à FixBot
    7. HTC Vive OLED Screen Replacement, Remove the OLED covers: étape 38, image 1 de 2 HTC Vive OLED Screen Replacement, Remove the OLED covers: étape 38, image 2 de 2
      • Use the flat end of a spudger push up one edge of the OLED cover and start unclipping that edge.
      Demander à FixBot
    8. HTC Vive OLED Screen Replacement: étape 39, image 1 de 2 HTC Vive OLED Screen Replacement: étape 39, image 2 de 2
      • Slide the spudger under the clip along that edge to free the rest of the edge.
      Demander à FixBot
    9. HTC Vive OLED Screen Replacement: étape 40, image 1 de 3 HTC Vive OLED Screen Replacement: étape 40, image 2 de 3 HTC Vive OLED Screen Replacement: étape 40, image 3 de 3
      • Slide the spudger around the remaining edges of the OLED cover to unclip those edges.
      Demander à FixBot
    10. HTC Vive OLED Screen Replacement: étape 41, image 1 de 2 HTC Vive OLED Screen Replacement: étape 41, image 2 de 2
      • Remove the OLED cover.
      • Repeat the last three steps to remove the other OLED cover.
      • During reassembly, remember to thread the OLED cables through their slots in the OLED cover.
      Demander à FixBot
    11. HTC Vive OLED Screen Replacement, Remove the OLED displays: étape 42, image 1 de 1
      • Very carefully lift the OLED display by its edges out of its frame.
      • If you are reusing the OLED displays, be very careful to avoid touching the front of the displays or bending or cracking the displays.
      • Repeat this process for the other OLED display.
      Demander à FixBot
    12. HTC Vive OLED Screen Replacement, Remove the lenses: étape 43, image 1 de 1
      • Apply an iOpener to the lens to soften the adhesive securing it to the frame.
      Demander à FixBot
    13. HTC Vive OLED Screen Replacement: étape 44, image 1 de 2 HTC Vive OLED Screen Replacement: étape 44, image 2 de 2
      • Use an opening tool to pry up the flat edge of the lens.
      • If it's difficult to pry up, apply the iOpener for another 30 seconds to further soften the adhesive.
      Demander à FixBot
    14. HTC Vive OLED Screen Replacement, Remove the lens: étape 45, image 1 de 1
      • Remove the lens.
      • Repeat the last two steps to remove the other lens.
      • Only the lens and OLED frames remain.
      • During reassembly, make sure the convex side of the lens is facing away from the frame.
      Demander à FixBot
    1. HTC Vive OLED Screen Replacement, OLED Screen: étape 46, image 1 de 1
      • The screws are very close to the screen. Applying too much pressure to the screws can stress or crack the screen. Be careful when unscrewing and screwing around the screen.
      • Remove the four 2mm #00 Philips head screws holding the screen in place from the eyepiece assembly.
      Demander à FixBot
    2. HTC Vive OLED Screen Replacement: étape 47, image 1 de 3 HTC Vive OLED Screen Replacement: étape 47, image 2 de 3 HTC Vive OLED Screen Replacement: étape 47, image 3 de 3
      • Use a plastic opening tool to gently pry around the seam between the eyepiece housing and the screen.
      • Gently pull the screen cover away from the eyepiece housing, threading the ribbon cable through the hole.
      Demander à FixBot
    3. HTC Vive OLED Screen Replacement: étape 48, image 1 de 2 HTC Vive OLED Screen Replacement: étape 48, image 2 de 2
      • Remove the screen from the eyepiece housing by pulling the two pieces away from each other.
      Demander à FixBot
Caleb Watts
Membre depuis le 09/25/17
2 439 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, Forte Fall 2017 Membre de l'équipe Cal Poly, Team S18-G1, Forte Fall 2017
CPSU-FORTE-F17S18G1
5 membres
47 tutoriels rédigés
3 commentaires de tutoriel
This is a beautiful guide and I’m elated that I’ve found it. However, in order to use it, I need a place that I can get the screen since it has been flickering, color is off, and now it has a solid green vert line. Any direction? Thanks!
Jason - Réponse Partager
Hi can you clean the vive OLED screen? if it has smudge mark on it… And what would you use
Al Shelley - Réponse Partager
where do you buy a new screen from I’ve looked all over the net for it I can’t find one for my headset (htc vive cosmos elite)
Ian Miller - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 35
Total : 5,148
