Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HTC Vive Pro Sensor Array Replacement
Ce dont vous avez besoin
    1. HTC Vive Pro Sensor Array Replacement, Reposition the head strap: étape 1, image 1 de 2 HTC Vive Pro Sensor Array Replacement, Reposition the head strap: étape 1, image 2 de 2
      • Rotate the head strap forward as far as it will go.
      Demander à FixBot
      Ajouter un commentaire
    2. HTC Vive Pro Sensor Array Replacement, Unplug the All-In-One Cable: étape 2, image 1 de 2 HTC Vive Pro Sensor Array Replacement, Unplug the All-In-One Cable: étape 2, image 2 de 2
      • Unplug the All-In-One Cable from your headset.
      Demander à FixBot
    3. HTC Vive Pro Sensor Array Replacement, Remove the All-In-One Cable: étape 3, image 1 de 3 HTC Vive Pro Sensor Array Replacement, Remove the All-In-One Cable: étape 3, image 2 de 3 HTC Vive Pro Sensor Array Replacement, Remove the All-In-One Cable: étape 3, image 3 de 3
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Demander à FixBot
    1. HTC Vive Pro Sensor Array Replacement, Remove the top strap: étape 4, image 1 de 2 HTC Vive Pro Sensor Array Replacement, Remove the top strap: étape 4, image 2 de 2
      • Separate the top strap from itself where the Velcro secures it.
      Demander à FixBot
    2. HTC Vive Pro Sensor Array Replacement: étape 5, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 5, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 5, image 3 de 3
      • Peel back the Velcro securing the rear of the top strap.
      • Feed the top strap out through the head strap to partially remove it.
      Demander à FixBot
    3. HTC Vive Pro Sensor Array Replacement: étape 6, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 6, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 6, image 3 de 3
      • Feed the top strap through the clip near the front of headset to fully remove it.
      Demander à FixBot
    1. HTC Vive Pro Sensor Array Replacement, Remove the front side foam pads: étape 7, image 1 de 3 HTC Vive Pro Sensor Array Replacement, Remove the front side foam pads: étape 7, image 2 de 3 HTC Vive Pro Sensor Array Replacement, Remove the front side foam pads: étape 7, image 3 de 3
      • Peel off both front side foam pads to uncover the speaker wires.
      Demander à FixBot
    2. HTC Vive Pro Sensor Array Replacement, Remove the two rubber spacers: étape 8, image 1 de 3 HTC Vive Pro Sensor Array Replacement, Remove the two rubber spacers: étape 8, image 2 de 3 HTC Vive Pro Sensor Array Replacement, Remove the two rubber spacers: étape 8, image 3 de 3
      • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
      • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
      Demander à FixBot
    3. HTC Vive Pro Sensor Array Replacement, Disconnect the speaker wires: étape 9, image 1 de 3 HTC Vive Pro Sensor Array Replacement, Disconnect the speaker wires: étape 9, image 2 de 3 HTC Vive Pro Sensor Array Replacement, Disconnect the speaker wires: étape 9, image 3 de 3
      • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
      Demander à FixBot
    4. HTC Vive Pro Sensor Array Replacement, Remove the head strap: étape 10, image 1 de 2 HTC Vive Pro Sensor Array Replacement, Remove the head strap: étape 10, image 2 de 2
      • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
      • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
      • Four 3.9 mm screws (two on each side)
      • Two 4.1 mm screws (one on each side)
      Demander à FixBot
    5. HTC Vive Pro Sensor Array Replacement: étape 11, image 1 de 1
      • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
      Demander à FixBot
    6. HTC Vive Pro Sensor Array Replacement: étape 12, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 12, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 12, image 3 de 3
      • Thread the headphone speaker wires out through both ends of the head strap.
      Demander à FixBot
    1. HTC Vive Pro Sensor Array Replacement, Remove the outer shell: étape 13, image 1 de 3 HTC Vive Pro Sensor Array Replacement, Remove the outer shell: étape 13, image 2 de 3 HTC Vive Pro Sensor Array Replacement, Remove the outer shell: étape 13, image 3 de 3
      • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
      Demander à FixBot
    2. HTC Vive Pro Sensor Array Replacement: étape 14, image 1 de 2 HTC Vive Pro Sensor Array Replacement: étape 14, image 2 de 2
      • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
      Demander à FixBot
    3. HTC Vive Pro Sensor Array Replacement: étape 15, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 15, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 15, image 3 de 3
      • Insert an opening pick into the seam between the two halves of the outer shell.
      • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
      • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
      Demander à FixBot
    4. HTC Vive Pro Sensor Array Replacement: étape 16, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 16, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 16, image 3 de 3
      • Continue sliding the opening pick through each seam until all clips have been dislodged.
      Demander à FixBot
    5. HTC Vive Pro Sensor Array Replacement: étape 17, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 17, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 17, image 3 de 3
      • Carefully slide each half of the outer shell off of the sensor array.
      • Be careful not to snag any of the ribbon cables underneath.
      Demander à FixBot
    1. HTC Vive Pro Sensor Array Replacement, Remove the face rest cushion: étape 18, image 1 de 3 HTC Vive Pro Sensor Array Replacement, Remove the face rest cushion: étape 18, image 2 de 3 HTC Vive Pro Sensor Array Replacement, Remove the face rest cushion: étape 18, image 3 de 3
      • Use your fingers to gently peel the face rest cushion off of the headset.
      Demander à FixBot
    1. HTC Vive Pro Sensor Array Replacement, Remove the facerest: étape 19, image 1 de 2 HTC Vive Pro Sensor Array Replacement, Remove the facerest: étape 19, image 2 de 2
      • Partially separate the facerest and the sensor array to access the daughterboard.
      Demander à FixBot
    2. HTC Vive Pro Sensor Array Replacement: étape 20, image 1 de 2 HTC Vive Pro Sensor Array Replacement: étape 20, image 2 de 2
      Outil utilisé dans cette étape :
      • Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
      Demander à FixBot
    3. HTC Vive Pro Sensor Array Replacement: étape 21, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 21, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 21, image 3 de 3
      • Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
      • Use caution when disconnecting these wires. If you pry up too hard, they may pull out of the connector.
      Demander à FixBot
    4. HTC Vive Pro Sensor Array Replacement: étape 22, image 1 de 2 HTC Vive Pro Sensor Array Replacement: étape 22, image 2 de 2
      • Slide the facerest out of the front assembly.
      Demander à FixBot
    1. HTC Vive Pro Sensor Array Replacement, Remove the sensor array: étape 23, image 1 de 2 HTC Vive Pro Sensor Array Replacement, Remove the sensor array: étape 23, image 2 de 2
      • Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
      Demander à FixBot
    2. HTC Vive Pro Sensor Array Replacement: étape 24, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 24, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 24, image 3 de 3
      • Use the pointed end of a spudger to flip up the locking flap on the daughterboard ZIF connector.
      • Use a pair of tweezers to slide the ribbon cable out of its socket.
      Demander à FixBot
    3. HTC Vive Pro Sensor Array Replacement: étape 25, image 1 de 2 HTC Vive Pro Sensor Array Replacement: étape 25, image 2 de 2
      • Use a pair of tweezers to peel back the grey tape covering the ZIF connector on the motherboard underneath the sensor array.
      Demander à FixBot
    4. HTC Vive Pro Sensor Array Replacement: étape 26, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 26, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 26, image 3 de 3
      • Use the flat end of your spudger to flip up the locking flap for the ZIF connector on the motherboard.
      • Use the pointed end of your spudger to disconnect the ribbon cable from the motherboard.
      Demander à FixBot
    5. HTC Vive Pro Sensor Array Replacement: étape 27, image 1 de 2 HTC Vive Pro Sensor Array Replacement: étape 27, image 2 de 2
      • Use a T5 Torx screwdriver to remove the four 3.0 mm silver screws securing the sensor array to the lens and OLED assembly.
      • Use a T6 Torx screwdriver to remove the four black 3.8 mm screws securing the sensor array.
      Demander à FixBot
    6. HTC Vive Pro Sensor Array Replacement: étape 28, image 1 de 2 HTC Vive Pro Sensor Array Replacement: étape 28, image 2 de 2
      • Lift the sensor array straight up off of the lens and OLED assembly.
      Demander à FixBot
    1. HTC Vive Pro Sensor Array Replacement, Disconnect the motherboard from the sensor array: étape 29, image 1 de 3 HTC Vive Pro Sensor Array Replacement, Disconnect the motherboard from the sensor array: étape 29, image 2 de 3 HTC Vive Pro Sensor Array Replacement, Disconnect the motherboard from the sensor array: étape 29, image 3 de 3
      • Use a pair of tweezers or your fingers to remove the four pieces of Kapton tape covering the ZIF connectors.
      Demander à FixBot
    2. HTC Vive Pro Sensor Array Replacement: étape 30, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 30, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 30, image 3 de 3
      • Use the flat end of your spudger to flip up the locking flap on a ZIF connector on the sensor array.
      • Use the pointed end of your spudger to disconnect the ribbon cable from its ZIF connector.
      • Repeat this procedure for all four of the ZIF connectors.
      Demander à FixBot
    3. HTC Vive Pro Sensor Array Replacement: étape 31, image 1 de 2 HTC Vive Pro Sensor Array Replacement: étape 31, image 2 de 2
      • Use a pair of tweezers to remove the Kapton tape covering the two ZIF connectors on the back of the motherboard.
      Demander à FixBot
    4. HTC Vive Pro Sensor Array Replacement: étape 32, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 32, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 32, image 3 de 3
      • Use the point of your spudger to unlock the ZIF connector on the back of the motherboard.
      • Use the spudger, or your fingers, to slide the ribbon cable out of its socket.
      Demander à FixBot
    5. HTC Vive Pro Sensor Array Replacement: étape 33, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 33, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 33, image 3 de 3
      Demander à FixBot
    6. HTC Vive Pro Sensor Array Replacement: étape 34, image 1 de 2 HTC Vive Pro Sensor Array Replacement: étape 34, image 2 de 2
      • Use a pair of tweezers to remove the Kapton tape covering the remaining ZIF connector on the back of the motherboard.
      Demander à FixBot
    7. HTC Vive Pro Sensor Array Replacement: étape 35, image 1 de 3 HTC Vive Pro Sensor Array Replacement: étape 35, image 2 de 3 HTC Vive Pro Sensor Array Replacement: étape 35, image 3 de 3
      • Use the pointed end of your spudger to unlock the ZIF connector on the back of the motherboard.
      Demander à FixBot
    8. HTC Vive Pro Sensor Array Replacement, Remove the motherboard: étape 36, image 1 de 2 HTC Vive Pro Sensor Array Replacement, Remove the motherboard: étape 36, image 2 de 2
      • Reposition the long ribbon cable covering the back of the motherboard so it's out of the way.
      • Don't sharply crease or fold the ribbon cable.
      Demander à FixBot
    9. HTC Vive Pro Sensor Array Replacement: étape 37, image 1 de 2 HTC Vive Pro Sensor Array Replacement: étape 37, image 2 de 2
      • Use a T5 Torx screwdriver to remove the three 3.0 mm‑long screws securing the motherboard to the sensor array.
      Demander à FixBot
    10. HTC Vive Pro Sensor Array Replacement: étape 38, image 1 de 1
      • Apply a heated iOpener to the back of the motherboard for one minute to soften the light adhesive securing it to the sensor array.
      Demander à FixBot
    11. HTC Vive Pro Sensor Array Replacement: étape 39, image 1 de 1
      • Remove the motherboard from the sensor array.
      • There are several plastic clips lightly securing the perimeter of the motherboard to the sensor array.
      • During reassembly, don't forget to reinstall any Kapton tape that was removed during disassembly. This will prevent malfunction of the sensors.
      Demander à FixBot
    1. HTC Vive Pro Sensor Array Replacement, Only the sensor array remains: étape 40, image 1 de 1
      • Only the sensor array remains.
      Demander à FixBot
Sam Omiotek
Membre depuis le 02/25/19
99 846 Réputation
289 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 39
Total : 1,035
