Aller au contenu principal
Pour réparer ensemble - Je crée un compte
JBL Go 4 Battery Replacement
Ce dont vous avez besoin
    1. JBL Go 4 Battery Replacement, Battery: étape 1, image 1 de 3 JBL Go 4 Battery Replacement, Battery: étape 1, image 2 de 3 JBL Go 4 Battery Replacement, Battery: étape 1, image 3 de 3
      • Insert an opening tool into the seam in between the grille and chassis, in the top corner opposite the strap.
      • Slide the tool along the edge of the housing until the grille releases.
      • Remove the grille.
      • Be sure that the battery has been drained completely before attempting this replacement.
      Demander à FixBot
      Ajouter un commentaire
    2. JBL Go 4 Battery Replacement: étape 2, image 1 de 3 JBL Go 4 Battery Replacement: étape 2, image 2 de 3 JBL Go 4 Battery Replacement: étape 2, image 3 de 3
      • Insert an opening tool in the opposite corner, lifting carefully.
      • Slide the tool along the edge until the cover pops off.
      • Gently pull the housing up and to the side.
      • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
      Demander à FixBot
    3. JBL Go 4 Battery Replacement: étape 3, image 1 de 2 JBL Go 4 Battery Replacement: étape 3, image 2 de 2
      • Find the connection between the motherboard and the battery cable as labeled.
      • Gently depress the plastic tabs and slowly wiggle the connector until it comes free.
      • Be incredibly gentle with this connector as any excessive force can damage the motherboard.
      Demander à FixBot
    4. JBL Go 4 Battery Replacement: étape 4, image 1 de 2 JBL Go 4 Battery Replacement: étape 4, image 2 de 2
      • Insert an opening tool beneath the battery, on the side opposite to the battery cable.
      • Using a lever motion, pry the battery out slowly, sliding it further under to break the adhesive up.
      • It's important to note that the battery is held on with a small adhesive pad, so more force than should feel necessary will be needed.
      Demander à FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jackosn Caron
Membre depuis le 03/20/25
255 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-1, Konn Spring 2025 Membre de l'équipe UMass Dartmouth, Team 4-1, Konn Spring 2025
UMASSD-KONN-S25S4G1
4 membres
17 tutoriels rédigés
2 commentaires de tutoriel
Great guide, thanks! Small point -
Typo - “Insert an opening into the seam”. I think you’re missing ‘tool’.
Alexander Dyas - Réponse Partager
Thanks for pointing that out, @alexanderdyas. We took care of the typo. In the future, feel free to go ahead and make the edit!
Connor Bassolino - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 38
30 derniers jours : 155
Total : 1,582
