Aller au contenu principal
Pour réparer ensemble - Je crée un compte
LG Front Load Washing Machine Stator Replacement
Ce dont vous avez besoin
  1. LG Front Load Washing Machine Stator Replacement, Safety Precautions: étape 1, image 1 de 2 LG Front Load Washing Machine Stator Replacement, Safety Precautions: étape 1, image 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    Demander à FixBot
    Ajouter un commentaire
  2. LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: étape 2, image 1 de 3 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: étape 2, image 2 de 3 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: étape 2, image 3 de 3
    • Remove the screw(s) securing the rear panel.
    Demander à FixBot
  3. LG Front Load Washing Machine Stator Replacement, Remove the rear panel: étape 3, image 1 de 3 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: étape 3, image 2 de 3 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: étape 3, image 3 de 3
    • Unclip the rear panel from the chassis.
    Demander à FixBot
  4. LG Front Load Washing Machine Stator Replacement: étape 4, image 1 de 1
    • Remove the rear panel.
    Demander à FixBot
  5. LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: étape 5, image 1 de 2 LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: étape 5, image 2 de 2
    • Use an impact driver to remove the 17 mm nut securing the rotor.
    • Alternatively, you can use a wrench and a hammer to loosen the nut.
    • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
    Demander à FixBot
  6. LG Front Load Washing Machine Stator Replacement, Remove the rotor: étape 6, image 1 de 2 LG Front Load Washing Machine Stator Replacement, Remove the rotor: étape 6, image 2 de 2
    • The rotor is magnetically attracted to the stator.
    • Pull the rotor straight off the stator and drive shaft splines to remove it.
    • Wiggle the rotor as you pull to help disconnect it.
    • This may require significant force.
    • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
    Demander à FixBot
  7. LG Front Load Washing Machine Stator Replacement, Unfasten the motor harness: étape 7, image 1 de 1
    • Remove the screw(s) securing the motor harness.
    Demander à FixBot
  8. LG Front Load Washing Machine Stator Replacement, Unfasten the stator: étape 8, image 1 de 2 LG Front Load Washing Machine Stator Replacement, Unfasten the stator: étape 8, image 2 de 2
    • Hold the stator up as you unfasten the last few bolts, as it can fall over unexpectedly.
    • Remove the bolts securing the stator.
    • During reassembly, refasten the screws in a "star" pattern.
    Demander à FixBot
  9. LG Front Load Washing Machine Stator Replacement, Reposition the stator: étape 9, image 1 de 3 LG Front Load Washing Machine Stator Replacement, Reposition the stator: étape 9, image 2 de 3 LG Front Load Washing Machine Stator Replacement, Reposition the stator: étape 9, image 3 de 3
    • Don't pull the stator too far away from the device, as it's still connected by wires.
    • Pull the stator out of its slot on the drum, and flip it so its rear is facing upward.
    Demander à FixBot
  10. LG Front Load Washing Machine Stator Replacement, Disconnect the stator: étape 10, image 1 de 3 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: étape 10, image 2 de 3 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: étape 10, image 3 de 3
    • Disconnect the connectors attached to the stator.
    • Always grip cables by their connectors and not the wires themselves.
    Demander à FixBot
  11. LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: étape 11, image 1 de 3 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: étape 11, image 2 de 3 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: étape 11, image 3 de 3
    • Use your fingers to unclip the rotor position sensor from the stator.
    • Pull the sensor away from the stator to completely unclip it.
    • Remove the rotor position sensor.
    • You're left with the stator.
    Demander à FixBot
Repair didn’t go as planned? Ask our Answers community for help.
2 autres ont terminé cette réparation.
Bill Gilbert
Membre depuis le 06/30/22
40 143 Réputation
261 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
31 535 tutoriels rédigés
5 commentaires de tutoriel
I don’t have comment just question. Does this particular model have a drive belt? Mine is not spinning properly
Leilani Seymour - Réponse Partager
No it does not. It is a direct drive machine, meaning that the motor drives the wash basket directly. Take a look at this link for some help.
Bill Gilbert - Réponse Partager
I undertook this repair with the wd14071sd6 model to replace the hall sensor as I was getting the LE error code. I have noted on step 2 that the entire back panel had to be removed to access the rotor. This is very very awkward, as multiple electrics are also connected to the panel via plastic clips.
Despite this, the repair can be achieved without any major electric disconnection work just a matter or having enough space to carefully remove things.
Phill Birtles - Réponse Partager
Te alguns estator que não usam o sensor Hall a minha lava seca LG wd17vts6 está máquina tem sensor Hall no estator
Dúvidas, obrigado
ROMUALDO GUIMARAES - Réponse Partager
A máquina LG wd17vrs6 (modelo) usa sensor Hall no seu estator
Dúvida poderia me informar
Obrigado
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 20
30 derniers jours : 92
Total : 2,447
