Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Core Duo Logic Board Replacement
Ce dont vous avez besoin
  1. MacBook Core Duo Logic Board Replacement, Battery: étape 1, image 1 de 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    Demander à FixBot
    Ajouter un commentaire
  2. MacBook Core Duo Logic Board Replacement: étape 2, image 1 de 1
    • Lift the battery out of the computer.
    Demander à FixBot
  3. MacBook Core Duo Logic Board Replacement, Memory Cover: étape 3, image 1 de 1
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
    Demander à FixBot
  4. MacBook Core Duo Logic Board Replacement: étape 4, image 1 de 1
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
    Demander à FixBot
  5. MacBook Core Duo Logic Board Replacement, Upper Case: étape 5, image 1 de 1
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
    Demander à FixBot
  6. MacBook Core Duo Logic Board Replacement: étape 6, image 1 de 1
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
    Demander à FixBot
  7. MacBook Core Duo Logic Board Replacement: étape 7, image 1 de 1
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    Demander à FixBot
  8. MacBook Core Duo Logic Board Replacement: étape 8, image 1 de 1
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    Demander à FixBot
  9. MacBook Core Duo Logic Board Replacement: étape 9, image 1 de 1
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
    Demander à FixBot
  10. MacBook Core Duo Logic Board Replacement: étape 10, image 1 de 1
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
    Demander à FixBot
  11. MacBook Core Duo Logic Board Replacement: étape 11, image 1 de 1
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
    Demander à FixBot
  12. MacBook Core Duo Logic Board Replacement: étape 12, image 1 de 1
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    Demander à FixBot
  13. MacBook Core Duo Logic Board Replacement, Left I/O Frame: étape 13, image 1 de 1
    • Disconnect the MagSafe board cable from the logic board.
    Demander à FixBot
  14. MacBook Core Duo Logic Board Replacement: étape 14, image 1 de 1
    • Remove the single Phillips screw securing the left speaker to the lower case.
    • Lift the left speaker out of its housing and set it to the side.
    Demander à FixBot
  15. MacBook Core Duo Logic Board Replacement: étape 15, image 1 de 1
    • Two 7.5 mm Phillips from either end of the left I/O frame.
    • One 9 mm Phillips from the middle of the left I/O frame.
    • Remove the small black plastic spacer at the bottom of the left I/O frame.
    Demander à FixBot
  16. MacBook Core Duo Logic Board Replacement: étape 16, image 1 de 1
    • Lift the left I/O frame up and out of the computer. Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
    Demander à FixBot
  17. MacBook Core Duo Logic Board Replacement, Logic Board: étape 17, image 1 de 1
    • Peel up the foil tape between the fan and the optical drive.
    Demander à FixBot
  18. MacBook Core Duo Logic Board Replacement: étape 18, image 1 de 1
    • Use a spudger to move the gray display data and black speaker cables to the right. This will reveal a silver screw securing the fan housing to the lower case.
    Demander à FixBot
  19. MacBook Core Duo Logic Board Replacement: étape 19, image 1 de 1
    • Disconnect the orange optical drive ribbon cable from the logic board.
    Demander à FixBot
  20. MacBook Core Duo Logic Board Replacement: étape 20, image 1 de 1
    • Peel up the small black rubber cover from the right side of the heat sink.
    Demander à FixBot
  21. MacBook Core Duo Logic Board Replacement: étape 21, image 1 de 1
    • Disconnect the black fan connector and two white temperature sensor connectors from the logic board.
    Demander à FixBot
  22. MacBook Core Duo Logic Board Replacement: étape 22, image 1 de 1
    • Remove the following 6 screws:
    • One 3 mm Phillips on the right side of the fan.
    • One 6 mm Phillips on the left side of the fan.
    • Four 9 mm Phillips securing the heat sink to the lower case.
    Demander à FixBot
  23. MacBook Core Duo Logic Board Replacement: étape 23, image 1 de 1
    • Hold the heat sink with one hand and the fan with your other hand, and lift the heat sink and fan assembly out of the computer. The fan is attached to the heat sink only with a strip of black felt tape, so be sure to remove both parts as a unit
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Demander à FixBot
  24. MacBook Core Duo Logic Board Replacement: étape 24, image 1 de 1
    • Disconnect the two antenna cables from the Airport card, and the black inverter cable from the logic board.
    Demander à FixBot
  25. MacBook Core Duo Logic Board Replacement: étape 25, image 1 de 1
    • Remove the following 2 screws from the Airport card:
    • One 3 mm Phillips from the left side.
    • One 8 mm Phillips from the right side.
    Demander à FixBot
  26. MacBook Core Duo Logic Board Replacement: étape 26, image 1 de 1
    • Grasp the Airport card at its top and slide it toward the screen and out of the computer.
    Demander à FixBot
  27. MacBook Core Duo Logic Board Replacement: étape 27, image 1 de 1
    • Use a spudger to disconnect the left speaker connector from the logic board.
    • Lift the left speaker out of the computer.
    Demander à FixBot
  28. MacBook Core Duo Logic Board Replacement: étape 28, image 1 de 1
    • Disconnect the display data cable by pulling up on the black plastic pull-tab. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
    Demander à FixBot
  29. MacBook Core Duo Logic Board Replacement: étape 29, image 1 de 1
    • Disconnect the newly-revealed hard drive cable from the logic board.
    Demander à FixBot
  30. MacBook Core Duo Logic Board Replacement: étape 30, image 1 de 1
    • Use a spudger to disconnect the two speaker connectors from the logic board.
    Demander à FixBot
  31. MacBook Core Duo Logic Board Replacement: étape 31, image 1 de 1
    • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
    Demander à FixBot
  32. MacBook Core Duo Logic Board Replacement: étape 32, image 1 de 1
    • Deroute the silver microphone cable from the silver metal clip just above the right RAM slot.
    Demander à FixBot
  33. MacBook Core Duo Logic Board Replacement: étape 33, image 1 de 1
    • Use a spudger to carefully pry the battery connector up and disconnect it from the logic board.
    Demander à FixBot
  34. MacBook Core Duo Logic Board Replacement: étape 34, image 1 de 1
    • Remove the three 3 mm Phillips screws securing the logic board to the lower case.
    Demander à FixBot
  35. MacBook Core Duo Logic Board Replacement: étape 35, image 1 de 1
    • Lift the logic board up from the right side, and slide it up and out of the computer.
    Demander à FixBot
  36. MacBook Core Duo Logic Board Replacement, Logic Board: étape 36, image 1 de 1
    • Turn the logic board over.
    • Peel the PRAM battery up from its location on the logic board, removing tape as necessary.
    Demander à FixBot
  37. MacBook Core Duo Logic Board Replacement: étape 37, image 1 de 1
    • Disconnect the PRAM battery cable from the logic board. Pull the connector horizontally out of the socket with the two battery wires.
    • Remove the PRAM battery from the computer.
    Demander à FixBot
  38. MacBook Core Duo Logic Board Replacement: étape 38, image 1 de 1
    • Pull back on the metal lever and slide the RAM chip out of the logic board.
    • Repeat this process for the other RAM chip if there are two RAM chips currently installed in your computer.
    Demander à FixBot
82 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
2 commentaires de tutoriel
is it possible to swap macbook 1,1 logic board (32bit) to macbook 4,1 (64bit) logic board? both model numbers are A1181.
I have black macbook 1,1 eating dust in the closet, but I would like to revive it to use it as an interior/music play machine.
Unfortunately, as my black macbook 1,1 has only 32bit CPU, it won’t upgrade above Snow Leopard.
I’d like to at least be able to upgrade where iTunes with Apple music is enabled, which probably is iTunes 12.
Thank you
SHIM Jihyun - Réponse Partager
So…. Damaged one of the temperature connections. But Got the pram out. How can I check if its working. First time I've stripped one down. The instructions were top class
John Morecroft - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 112
Total : 225,538
