Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Flip the laptop over: étape 2, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Flip the laptop over: étape 2, image 2 de 2
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
    Demander à FixBot
  3. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Feet removal information: étape 3, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Feet removal information: étape 3, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Feet removal information: étape 3, image 3 de 3
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
    Demander à FixBot
  4. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the feet: étape 4, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the feet: étape 4, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the feet: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
    Demander à FixBot
  5. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Reassembly information: étape 5, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Reassembly information: étape 5, image 2 de 2
    Tesa 61395 Tape
    $8.95
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
    Demander à FixBot
  6. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement: étape 6, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement: étape 6, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement: étape 6, image 3 de 3
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
    Demander à FixBot
  7. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Unfasten the upper case: étape 7, image 1 de 1
    FixMat
    $31.41
    • These screws strip easily. Apply constant, downward force to prevent stripping.
    • Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
    Demander à FixBot
  8. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Open the screen: étape 8, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Open the screen: étape 8, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Open the screen: étape 8, image 3 de 3
    • Flip your laptop over and fully open the screen.
    Demander à FixBot
  9. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Lift the upper case: étape 9, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Lift the upper case: étape 9, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Lift the upper case: étape 9, image 3 de 3
    • The upper case is secured by magnets.
    • Grip the top edge of the upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case, as it's still connected to the laptop by a cable.
    • Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the screen could damage the screen as it closes.
    Demander à FixBot
  10. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 3 de 3
    • The keyboard and touchpad cable connects the upper case to the laptop.
    • Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
    • To reconnect the cable, align the magnet connector over its socket with the cable facing the bottom of the laptop. Press down on the connector to secure it.
    Demander à FixBot
  11. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the upper case: étape 11, image 1 de 1
    • Remove the upper case and set it keyboard-side down on a clean surface.
    Demander à FixBot
  12. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Unfasten the SSD: étape 12, image 1 de 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • With the screw removed, the SSD pops up at a shallow angle.
    Demander à FixBot
  13. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the SSD: étape 13, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the SSD: étape 13, image 2 de 2
    • Removing the SSD also functions as a battery disconnect.
    • Pull the SSD out of its socket and remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
    • During reassembly, insert the SSD at a slight angle.
    Demander à FixBot
  14. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Unclip the heatsink shield: étape 14, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Unclip the heatsink shield: étape 14, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Unclip the heatsink shield: étape 14, image 3 de 3
    • Try not to deform the shield too much. You'll need to reinstall it during reassembly.
    • Insert the pointed end of a spudger in one of the gaps on the top edge of the heatsink shield.
    • Gently pry up to release the clips securing the shield.
    • Repeat this process along the right edge.
    • Insert one arm of your tweezers under the bottom right edge of the heatsink shield.
    • Gently pry up to release the remaining clips.
    Demander à FixBot
  15. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the heatsink shield: étape 15, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the heatsink shield: étape 15, image 2 de 2
    • Remove the heatsink shield.
    • To reinstall a shield, press down around its perimeter to engage the shield clips.
    Demander à FixBot
  16. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Disconnect the fan: étape 16, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Disconnect the fan: étape 16, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Disconnect the fan: étape 16, image 3 de 3
    • Use the pointed end of a spudger to flip up the locking flap on the fan cable ZIF connector.
    • Grip the fan cable pull-tab with tweezers and pull the cable straight out of the connector.
    Demander à FixBot
  17. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Unfasten the heatsink: étape 17, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Unfasten the heatsink: étape 17, image 2 de 2
    • Use a T3 Torx driver to remove the nine screws securing the heatsink:
    • Two 2.5 mm screws
    • Two 2 mm screws
    • One 3 mm screw
    • Two 4.1 mm screws
    • Two 3.4 mm screws
    Demander à FixBot
  18. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Reassembly information: étape 18, image 1 de 1
    • During reassembly:
    • Align the heatsink with the centering peg on the motherboard.
    • Tighten the four CPU tension screws in an "X" pattern: top left, bottom right, top right, bottom left.
    Demander à FixBot
  19. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Pry up the heatsink: étape 19, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Pry up the heatsink: étape 19, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Pry up the heatsink: étape 19, image 3 de 3
    • Thermal paste bonds the heatsink to the CPU.
    • Insert your spudger under the left heat pipe.
    • Pry up to release the left section of the heatsink.
    • This may take some force. Be careful not to bend the heat pipes.
    • Repeat this procedure for the right heat pipe and the CPU screw mounts until the heatsink is completely separated from the motherboard.
    Demander à FixBot
  20. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the heatsink: étape 20, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the heatsink: étape 20, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Remove the heatsink: étape 20, image 3 de 3
    • Lift the heatsink and fan over the alignment peg in the upper right corner.
    • Slide the heatsink and fan toward the front edge of the laptop and remove it.
    Demander à FixBot
  21. Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Reapply thermal paste: étape 21, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement, Reapply thermal paste: étape 21, image 2 de 2
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
    Demander à FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
Clay Eickemeyer
Membre depuis le 09/19/22
104 138 Réputation
476 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
10 membres
17 864 tutoriels rédigés
2 commentaires de tutoriel
Please add the cooler/fan part # as you seem to no longer be selling it. It would also be useful to know if the Laptop 5 13.5" cooler/fan is compatible as they appear to be extremely similar in dimensions.
Some1else - Réponse Partager
Den Kühler hochhebeln ist keine gute Idee. Besser ist es, den Lüfter ganz rechts anzufassen und zu sich zu ziehen. Der ist sowieso ein wenig unter die Metalllippe gesteckt und muss da rausgezogen werden. Ist wesentlich sicherer, als an den millimeter dicken heatpipes zu hebeln, die dabei fast sicher verbogen werden.
Andreas - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 51
30 derniers jours : 196
Total : 3,266
