Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Flip the laptop over: étape 2, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Flip the laptop over: étape 2, image 2 de 2
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
    Demander à FixBot
  3. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Feet removal information: étape 3, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Feet removal information: étape 3, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Feet removal information: étape 3, image 3 de 3
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
    Demander à FixBot
  4. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the feet: étape 4, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the feet: étape 4, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the feet: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
    Demander à FixBot
  5. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reassembly information: étape 5, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reassembly information: étape 5, image 2 de 2
    Tesa 61395 Tape
    $8.95
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
    Demander à FixBot
  6. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement: étape 6, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement: étape 6, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement: étape 6, image 3 de 3
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
    Demander à FixBot
  7. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unfasten the upper case: étape 7, image 1 de 1
    FixMat
    $36.95
    • These screws strip easily. Apply constant, downward force to prevent stripping.
    • Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
    Demander à FixBot
  8. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Open the screen: étape 8, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Open the screen: étape 8, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Open the screen: étape 8, image 3 de 3
    • Flip your laptop over and fully open the screen.
    Demander à FixBot
  9. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Lift the upper case: étape 9, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Lift the upper case: étape 9, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Lift the upper case: étape 9, image 3 de 3
    • The upper case is secured by magnets.
    • Grip the top edge of the upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case, as it's still connected to the laptop by a cable.
    • Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the screen could damage the screen as it closes.
    Demander à FixBot
  10. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 3 de 3
    • The keyboard and touchpad cable connects the upper case to the laptop.
    • Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
    • To reconnect the cable, align the magnet connector over its socket with the cable facing the bottom of the laptop. Press down on the connector to secure it.
    Demander à FixBot
  11. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the upper case: étape 11, image 1 de 1
    • Remove the upper case and set it keyboard-side down on a clean surface.
    Demander à FixBot
  12. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reassembly information: étape 12, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reassembly information: étape 12, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reassembly information: étape 12, image 3 de 3
    Microfiber Cleaning Cloths
    $3.99
    • Your SSD has thermal paste that forms a bond to the upper case.
    • During reassembly:
    • Use the flat end of your spudger to scrape away old thermal paste from the top of the SSD and the underside of the upper case.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the SSD and upper case. Wipe away the residue using a lint-free or microfiber cloth.
    • Replace the thermal pad with one that's the same size as the SSD sticker.
    • Alternatively, you can apply a bead of thermal paste directly to the SSD's label. Use the dot method with a bead slightly larger than the screw head securing the SSD.
    Demander à FixBot
  13. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unfasten the SSD: étape 13, image 1 de 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • With the screw removed, the SSD pops up at a shallow angle.
    Demander à FixBot
  14. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the SSD: étape 14, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the SSD: étape 14, image 2 de 2
    • Removing the SSD also functions as a battery disconnect.
    • Pull the SSD out of its socket and remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
    • During reassembly, insert the SSD at a slight angle.
    Demander à FixBot
  15. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the tape: étape 15, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the tape: étape 15, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the tape: étape 15, image 3 de 3
    • Remove the two pieces of black tape covering the bottom left and bottom right corners of the motherboard.
    • Set the tape aside. You'll use it during reassembly.
    Demander à FixBot
  16. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unclip the heatsink shield: étape 16, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unclip the heatsink shield: étape 16, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unclip the heatsink shield: étape 16, image 3 de 3
    • Try not to deform the shield too much. You'll need to reinstall it during reassembly.
    • Insert the pointed end of a spudger in one of the gaps on the top edge of the heatsink shield.
    • Gently pry up to release the clips securing the shield.
    • Repeat this process along the right edge.
    • Insert one arm of your tweezers under the bottom right edge of the heatsink shield.
    • Gently pry up to release the remaining clips.
    Demander à FixBot
  17. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the heatsink shield: étape 17, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the heatsink shield: étape 17, image 2 de 2
    • Remove the heatsink shield.
    • To reinstall a shield, press down around its perimeter to engage the shield clips.
    Demander à FixBot
  18. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the fan: étape 18, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the fan: étape 18, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the fan: étape 18, image 3 de 3
    • Use the pointed end of a spudger to flip up the locking flap on the fan cable ZIF connector.
    • Grip the fan cable pull-tab with tweezers and pull the cable straight out of the connector.
    Demander à FixBot
  19. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Separate the cable adhesive: étape 19, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Separate the cable adhesive: étape 19, image 2 de 2
    • Adhesive secures the fan cable to the frame.
    • Use tweezers or your fingers to peel the fan cable from the frame and separate its adhesive.
    Demander à FixBot
  20. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unfasten the heatsink: étape 20, image 1 de 1
    • Use a T3 Torx driver to remove the ten screws securing the heatsink:
    • Two 2.5 mm screws
    • Three 2.0 mm screws
    • One 3.0 mm screw
    • Two 4.1 mm screws
    • Two 3.4 mm screws
    Demander à FixBot
  21. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reassembly note: étape 21, image 1 de 1
    • Align the heatsink with the centering peg on the motherboard.
    • Tighten the four CPU tension screws in an “X” pattern. For example: top left, bottom right, top right, bottom left.
    Demander à FixBot
  22. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Lift the heatsink: étape 22, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Lift the heatsink: étape 22, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Lift the heatsink: étape 22, image 3 de 3
    • Thermal paste bonds the heatsink to the CPU.
    • Insert your spudger under the left heat pipe.
    • Pry up to release the left section of the heatsink.
    • This may take some force. Be careful not to bend the heat pipes.
    • Repeat this procedure for the right heat pipe and the CPU screw mounts until the heatsink is completely separated from the motherboard.
    Demander à FixBot
  23. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Clear the alignment peg: étape 23, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Clear the alignment peg: étape 23, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Clear the alignment peg: étape 23, image 3 de 3
    • Use your finger to lift the right edge of the heatsink up and over the alignment peg near the right side of the fan.
    • Lightly pull the right edge of the heatsink away from the screen to release it from its recess in the frame.
    Demander à FixBot
  24. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the heatsink: étape 24, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the heatsink: étape 24, image 2 de 2
    • Remove the heatsink.
    • Don't pull on the heatsink too hard, as the heat pipes bend easily. If you're having trouble, gently wiggle the heatsink.
    Demander à FixBot
  25. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reapply thermal paste: étape 25, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reapply thermal paste: étape 25, image 2 de 2
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
    Demander à FixBot
  26. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the display cable shields: étape 26, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the display cable shields: étape 26, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the display cable shields: étape 26, image 3 de 3
    • Insert one arm of your tweezers under the corner of the left display cable shield.
    • Repeat this process around the perimeter of the shield until you can remove it.
    Demander à FixBot
  27. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement: étape 27, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement: étape 27, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement: étape 27, image 3 de 3
    • Pull the left display cable shield way from the screen to free it from its recess.
    • Remove the shield.
    Demander à FixBot
  28. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement: étape 28, image 1 de 1
    Demander à FixBot
  29. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unclip the left motherboard shield: étape 29, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unclip the left motherboard shield: étape 29, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unclip the left motherboard shield: étape 29, image 3 de 3
    • Some motherboard screws are located under two of the metal shields, both of which need to be removed.
    • Insert one arm of your tweezers under the corner of the left touchpad shield.
    Demander à FixBot
  30. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the left motherboard shield: étape 30, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the left motherboard shield: étape 30, image 2 de 2
    • Remove the left motherboard shield.
    Demander à FixBot
  31. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Clean and reapply thermal paste: étape 31, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Clean and reapply thermal paste: étape 31, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Clean and reapply thermal paste: étape 31, image 3 de 3
    • There may be thermal paste between the motherboard and its left shield.
    • Before reinstalling the left motherboard shield, follow this guide to clean and reapply thermal paste.
    Demander à FixBot
  32. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the right motherboard shield: étape 32, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the right motherboard shield: étape 32, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the right motherboard shield: étape 32, image 3 de 3
    • Insert one arm of your tweezers under the corner of the right motherboard shield and pry around its perimeter up to release the clips.
    • Remove the right motherboard shield.
    Demander à FixBot
  33. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reassembly information: étape 33, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Reassembly information: étape 33, image 2 de 2
    • During reassembly, use the flat end of a spudger to gently push the display cables back into their cavity in the lower case after reconnecting the press connectors.
    Demander à FixBot
  34. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the display cables: étape 34, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the display cables: étape 34, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the display cables: étape 34, image 3 de 3
    • Use the flat end of a spudger to pry up and disconnect all four display cable press connectors.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Demander à FixBot
  35. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the right speaker: étape 35, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the right speaker: étape 35, image 2 de 2
    • Use the pointed end of a spudger to lift and disconnect the right speaker wire from its connector on the motherboard.
    Demander à FixBot
  36. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the Surface Connect port: étape 36, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the Surface Connect port: étape 36, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the Surface Connect port: étape 36, image 3 de 3
    • Use the flat end of a spudger to flip open the locking arm on the Surface Connect port connector.
    • Grip the Surface Connect port cable and pull it straight out of its socket.
    Demander à FixBot
  37. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the left speaker: étape 37, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the left speaker: étape 37, image 2 de 2
    • Use the pointed end of a spudger to lift and disconnect the left speaker wire from its connector near the left ports.
    Demander à FixBot
  38. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the black antenna cable: étape 38, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Disconnect the black antenna cable: étape 38, image 2 de 2
    • Slide one arm of your tweezers under the black antenna connector, as close to the head as possible.
    • Lift straight up to disconnect the cable.
    • To reattach antenna connectors, align the head of the connector over its socket and press down with the flat end of a spudger. The connector will snap into place.
    Demander à FixBot
  39. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unfasten the motherboard bracket: étape 39, image 1 de 1
    • Use a T3 Torx driver to remove the two 3 mm screws securing the motherboard bracket.
    Demander à FixBot
  40. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the motherboard bracket: étape 40, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the motherboard bracket: étape 40, image 2 de 2
    • Remove the motherboard bracket.
    Demander à FixBot
  41. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unfasten the left port cover: étape 41, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unfasten the left port cover: étape 41, image 2 de 2
    • Use a T3 Torx driver to remove the three 2.1 mm screws securing the left port cover.
    Demander à FixBot
  42. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the left port cover: étape 42, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the left port cover: étape 42, image 2 de 2
    • Remove the left port cover.
    Demander à FixBot
  43. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unfasten the motherboard: étape 43, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unfasten the motherboard: étape 43, image 2 de 2
    • Use a T3 Torx driver to remove the six 2 mm screws securing the motherboard.
    • If any of your screws have rubber covers, peel and remove them.
    Demander à FixBot
  44. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Lift the right edge: étape 44, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Lift the right edge: étape 44, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Lift the right edge: étape 44, image 3 de 3
    • The left edge of the motherboard is held tight by the port cutouts, the speaker, and the frame.
    • Lift the right edge of the motherboard slightly over the battery.
    • Hold the motherboard in place while you follow the step to free the left edge.
    Demander à FixBot
  45. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Pry the left edge: étape 45, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Pry the left edge: étape 45, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Pry the left edge: étape 45, image 3 de 3
    • A tab on the upper left of the motherboard presses against protrusions in the frame, preventing the left edge from coming free.
    • Insert the tip of a spudger against the tab in the upper left corner of the motherboard. Wedge the spudger between the frame and the screen hinge.
    • Pry up on the tab with your spudger while you lift the right edge of the motherboard toward the front of the laptop.
    • If the motherboard can't lift over the left speaker, the tab may still be stuck. Change the angle of your spudger and try again.
    Demander à FixBot
  46. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the motherboard: étape 46, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the motherboard: étape 46, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the motherboard: étape 46, image 3 de 3
    • Remove the motherboard.
    • Ensure the two screwpost braces underneath the motherboard don't get lost during removal.
    • Make sure none of the eight cables get trapped underneath.
    • Position the left ports in their recess before sliding the motherboard into place.
    Demander à FixBot
  47. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Unfasten the headphone jack: étape 47, image 1 de 1
    • Use a T3 Torx driver to remove the 2.4 mm screw securing the headphone jack.
    Demander à FixBot
  48. Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the headphone jack: étape 48, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the headphone jack: étape 48, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Headphone Jack Replacement, Remove the headphone jack: étape 48, image 3 de 3
    • Lift the headphone jack up and over its screw peg and remove it.
    Demander à FixBot
Spencer Day
Membre depuis le 09/14/22
190 922 Réputation
1 204 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 930 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 31
Total : 424
