Aller au contenu principal
Microsoft Surface Pro X Volume Button Cover Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Pro X Volume Button Cover Replacement, Open the kickstand: étape 1, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Open the kickstand: étape 1, image 2 de 2
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X Volume Button Cover Replacement, Open the SSD and SIM card door: étape 2, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Open the SSD and SIM card door: étape 2, image 2 de 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the SSD and SIM card door: étape 3, image 1 de 1
  4. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the SSD screw: étape 4, image 1 de 1
    • Use a T3 Torx screwdriver to remove the 2.4 mm screw securing the SSD.
  5. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the SSD: étape 5, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the SSD: étape 5, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the SSD: étape 5, image 3 de 3
    • Use your finger or a spudger to lift the SSD just enough that it clears the edges of its recess.
    • Don't lift the SSD more than you have to—doing so may damage the SSD or its socket.
    • Gently pull the SSD straight out of its socket.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. Microsoft Surface Pro X Volume Button Cover Replacement, Tape the screen: étape 6, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Tape the screen: étape 6, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Tape the screen: étape 6, image 3 de 3
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    • Lay overlapping strips of clear packing tape over the Surface’s display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
  7. Microsoft Surface Pro X Volume Button Cover Replacement, Apply a suction cup to the screen: étape 7, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Apply a suction cup to the screen: étape 7, image 2 de 2
    • Wear safety glasses during the screen removal procedure in case the glass shatters while you're working.
    • There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to work slowly and be extremely careful while slicing through the adhesive.
    • Place your tablet on your work surface so that the screen is facing up.
    • Apply a suction cup to the screen next to the right speaker grille.
  8. Microsoft Surface Pro X Volume Button Cover Replacement, Secure the tablet: étape 8, image 1 de 1
    • Place your hand on the screen next to the suction cup to secure the Surface while you lift up the screen.
  9. Microsoft Surface Pro X Volume Button Cover Replacement, Create a gap between the screen and frame: étape 9, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Create a gap between the screen and frame: étape 9, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Create a gap between the screen and frame: étape 9, image 3 de 3
    • Don't insert the opening pick more than 3 mm while cutting through the adhesive on the right, bottom, and left edge.
    • Lift up on the suction cup to create a gap between the screen and the frame.
    • The gap only needs to be wide enough to slide in an opening pick.
    • Insert an opening pick about 2 mm into the gap. Leave the opening pick in the gap to prevent it from resealing.
  10. Microsoft Surface Pro X Volume Button Cover Replacement, Cut through the screen adhesive: étape 10, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Cut through the screen adhesive: étape 10, image 2 de 2
    • Insert a second opening pick into the gap between the screen and the frame.
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  11. Microsoft Surface Pro X Volume Button Cover Replacement: étape 11, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 11, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 11, image 3 de 3
    • Don't insert the pick more than 3 mm while cutting through the screen adhesive on the bottom edge or you may damage delicate components on the screen.
    • Insert a third opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
  12. Microsoft Surface Pro X Volume Button Cover Replacement: étape 12, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement: étape 12, image 2 de 2
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
  13. Microsoft Surface Pro X Volume Button Cover Replacement: étape 13, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 13, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 13, image 3 de 3
    • Insert a fourth opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  14. Microsoft Surface Pro X Volume Button Cover Replacement: étape 14, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 14, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 14, image 3 de 3
    • Don't insert the opening pick more than 10 mm while cutting through the adhesive on the top edge. Don't insert the pick more than 3 mm near the speaker grille.
    • Insert a fifth opening pick into the top left corner and slide it around the corner toward the top edge.
    • Slide the pick along the top edge of the Surface to cut through the screen adhesive.
  15. Microsoft Surface Pro X Volume Button Cover Replacement, Open the Surface: étape 15, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Open the Surface: étape 15, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Open the Surface: étape 15, image 3 de 3
    • Do not remove the screen yet. It is still connected to the motherboard by the display cable. Keep the screen as close as possible to the Surface's frame to avoid straining the display cable.
    • Avoid hitting the battery with the screen during this procedure. A punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Lift up the top edge of the screen so that it is at a 30° angle with the frame.
    • If you encounter any resistance, stop and check that all the adhesive is separated. Use an opening pick to cut through any remaining adhesive.
    • Rotate the screen so that its bottom edge is in the middle of the frame. The screen should be perpendicular to the frame.
    • Rotate the screen 90° so that it is facing down. Place the screen on the frame.
  16. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the display cable shield: étape 16, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the display cable shield: étape 16, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the display cable shield: étape 16, image 3 de 3
    Outil utilisé dans cette étape :
    • Insert a tine of a pair of pointed tweezers under the bottom right corner of the display cable shield (where the display cable is oriented down).
    • Lift up the corner to detach it from the screen.
  17. Microsoft Surface Pro X Volume Button Cover Replacement: étape 17, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement: étape 17, image 2 de 2
    • Repeat the previous step for the bottom right corner.
  18. Microsoft Surface Pro X Volume Button Cover Replacement: étape 18, image 1 de 1
    • Remove the display cable shield from the screen.
    • If the display cable shield isn't completely detached from the screen, pry up additional areas around the edges of the shield.
  19. Microsoft Surface Pro X Volume Button Cover Replacement, Disconnect the screen: étape 19, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Disconnect the screen: étape 19, image 2 de 2
    • Insert the pointed end of a spudger under the right side of the display cable press connector.
    • Lift up the right side of the press connector to detach it from the display cable socket on the screen.
  20. Microsoft Surface Pro X Volume Button Cover Replacement: étape 20, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement: étape 20, image 2 de 2
    • Repeat the previous step on the left side of the display cable connector to fully disconnect it from the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the screen: étape 21, image 1 de 1
    • Remove the screen from the frame.
  22. Microsoft Surface Pro X Volume Button Cover Replacement, Speaker grille information: étape 22, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Speaker grille information: étape 22, image 2 de 2
    • The left and right speaker grilles may be attached to the Surface's frame or the screen.
    • If you are going to replace a speaker grille that is attached to the frame, follow these steps to remove it:
    • Use an opening pick to cut through the adhesive under the grille.
    • Remove the speaker grille.
    • Repeat for the other speaker grille.
  23. Microsoft Surface Pro X Volume Button Cover Replacement: étape 23, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement: étape 23, image 2 de 2
    • If you are going to replace or transfer a speaker grille that is attached to the screen, follow these steps to remove it:
  24. Microsoft Surface Pro X Volume Button Cover Replacement, Screen adhesive information: étape 24, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Screen adhesive information: étape 24, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Screen adhesive information: étape 24, image 3 de 3
    • If you are going to replace the screen adhesive, follow these steps:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the adhesive.
    • Use a cotton swab or the flat end of a spudger to scrape away the adhesive.
    • Use a lint-free cloth or coffee filter to wipe away any remaining adhesive.
    • Allow the surface to dry completely before applying replacement adhesive.
    • Apply new adhesive strips or pre-cut adhesive to the frame where the old screen adhesive was located.
  25. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the heat sink sticker: étape 25, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the heat sink sticker: étape 25, image 2 de 2
    • If you are going to reinstall this sticker during reassembly, try to keep it as intact as possible.
    • Lift up the edge of the heat sink sticker closest to the bottom edge of the Surface.
  26. Microsoft Surface Pro X Volume Button Cover Replacement: étape 26, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement: étape 26, image 2 de 2
    • Lift up the center of the sticker.
  27. Microsoft Surface Pro X Volume Button Cover Replacement: étape 27, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 27, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 27, image 3 de 3
    • Lift up one side of the sticker attached to the heat sink.
    • Repeat for the other side. The sticker should now be fully detached.
    • Remove the sticker.
  28. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the screw stickers: étape 28, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the screw stickers: étape 28, image 2 de 2
    • If you are going to reinstall these stickers during reassembly, try to keep them as intact as possible. These stickers can tear easily during removal.
    • Use an opening tool to lift up the edge of one of the small black stickers covering the four screws in the center of the heat sink.
    • You only need to lift the edge enough to grip it with tweezers.
  29. Microsoft Surface Pro X Volume Button Cover Replacement: étape 29, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement: étape 29, image 2 de 2
    • Use a pair of blunt tweezers to remove the sticker covering the heat sink screw.
    • Repeat this process for the other three stickers.
  30. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the heat sink screws: étape 30, image 1 de 1
    • Remove the 14 screws securing the heat sink:
    • Eight 2.2 mm T3 Torx screws
    • One 2.0 mm T3 Torx screw
    • One 3.2 mm T3 Torx screw
    • Four 2.5 mm T6 screws
  31. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the heat sink: étape 31, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the heat sink: étape 31, image 2 de 2
    • The heat sink is adhered to the CPU with thermal paste.
    • Insert an opening pick about 2 mm under the heat sink at its bottom edge directly to the left of the display cable.
    • The opening pick should be between the heat sink and the frame surrounding the motherboard.
    • Slide the opening pick to the left toward the heat pipe to detach the heat sink from the CPU.
  32. Microsoft Surface Pro X Volume Button Cover Replacement: étape 32, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement: étape 32, image 2 de 2
    • Swing the bottom edge of the heat sink up so that it is at about a 10° angle with the frame.
  33. Microsoft Surface Pro X Volume Button Cover Replacement: étape 33, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 33, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 33, image 3 de 3
  34. Microsoft Surface Pro X Volume Button Cover Replacement, Disconnect the left speaker: étape 34, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Disconnect the left speaker: étape 34, image 2 de 2
    • Use the pointed end of a spudger to disconnect the left speaker's press connector from its socket.
  35. Microsoft Surface Pro X Volume Button Cover Replacement, Detach the left speaker's cable: étape 35, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Detach the left speaker's cable: étape 35, image 2 de 2
    • Use an opening pick to cut through the adhesive under the left speaker's cable and detach it from the frame.
  36. Microsoft Surface Pro X Volume Button Cover Replacement, Lift up the foam adhesive: étape 36, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Lift up the foam adhesive: étape 36, image 2 de 2
    • Use the flat end of a spudger to lift up the foam adhesive covering the left speaker's top left screw.
  37. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the left speaker screws: étape 37, image 1 de 1
    • Remove the three screws securing the left speaker:
    • One 2.2 mm T3 Torx screw
    • One 3.0 mm T3 Torx screw
    • One 2.9 mm T6 Torx screw
  38. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the left speaker: étape 38, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the left speaker: étape 38, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the left speaker: étape 38, image 3 de 3
    • Use the flat end of a spudger to lift the cable side of the left speaker enough to grab it with your fingers.
    • Remove the left speaker from the frame.
  39. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the volume button bracket screws: étape 39, image 1 de 1
    • Use a T3 screwdriver to remove the two 2.4 mm screws securing the volume button bracket.
  40. Microsoft Surface Pro X Volume Button Cover Replacement, Detach the volume button bracket: étape 40, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Detach the volume button bracket: étape 40, image 2 de 2
    • Use a pair of blunt tweezers to pull the right side of the volume button bracket straight out of the frame.
  41. Microsoft Surface Pro X Volume Button Cover Replacement: étape 41, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement: étape 41, image 2 de 2
    • Repeat the previous step for the left side of the volume button bracket.
  42. Microsoft Surface Pro X Volume Button Cover Replacement: étape 42, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement: étape 42, image 2 de 2
    • Flip the volume button bracket's top edge 90° away from the edge of the Surface.
  43. Microsoft Surface Pro X Volume Button Cover Replacement, Remove the volume button cover: étape 43, image 1 de 2 Microsoft Surface Pro X Volume Button Cover Replacement, Remove the volume button cover: étape 43, image 2 de 2
    • While holding the volume button bracket away from the edge of the Surface, use the pointed end of a spudger to push the volume button cover into the Surface.
  44. Microsoft Surface Pro X Volume Button Cover Replacement: étape 44, image 1 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 44, image 2 de 3 Microsoft Surface Pro X Volume Button Cover Replacement: étape 44, image 3 de 3
    • Remove the volume button cover from the Surface.
    • During reassembly, make sure the volume button cover is oriented correctly when you replace it. The long edge of the cover with the shorter tab should be facing up.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro X Answers community for help.
Kyle Smith
Membre depuis le 02/01/21
49 184 Réputation
123 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 374
