Aller au contenu principal
Motorola Moto G Stylus 5G (2022) Battery Replacement
Ce dont vous avez besoin
  1. Motorola Moto G Stylus 5G (2022) Battery Replacement, Heat the edge: étape 1, image 1 de 1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the edge of the back cover with the SIM card slot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G Stylus 5G (2022) Battery Replacement, Insert an opening pick: étape 2, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Insert an opening pick: étape 2, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Insert an opening pick: étape 2, image 3 de 3
    • Apply a suction cup to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  3. Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the right adhesive: étape 3, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the right adhesive: étape 3, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the right adhesive: étape 3, image 3 de 3
    • Slide your opening pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick in at the bottom right corner to prevent the adhesive from resealing.
  4. Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the bottom adhesive: étape 4, image 1 de 2 Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the bottom adhesive: étape 4, image 2 de 2
    • Insert a second opening pick into the bottom right corner.
    • Slide this opening pick along the bottom edge to the bottom left corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
  5. Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the left adhesive: étape 5, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the left adhesive: étape 5, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the left adhesive: étape 5, image 3 de 3
    • Insert a third opening pick into the bottom right corner.
    • Slide this opening pick along the left edge to slice the adhesive.
    • Don't worry about slicing under the camera bezel. It's separate from the back cover and will be removed later.
    • Leave the pick inserted in the top left corner to prevent the left edge from resealing.
  6. Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the top adhesive: étape 6, image 1 de 2 Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the top adhesive: étape 6, image 2 de 2
    • Insert a fourth pick into the top left corner.
    • Slide the pick to the top right corner to slice the top adhesive.
  7. Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice around the camera bezel: étape 7, image 1 de 1
    • Slide an opening pick between the camera bezel and the back cover.
    • The back cover's adhesive is particularly strong around the camera bezel.
    • Slide the opening pick around the camera bezel to separate the back cover from the frame.
  8. Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the back cover: étape 8, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the back cover: étape 8, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the back cover: étape 8, image 3 de 3
    • Grab and remove the back cover by lifting it away from the phone.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  9. Motorola Moto G Stylus 5G (2022) Battery Replacement, Heat the camera bezel: étape 9, image 1 de 1
    • Heat an iOpener and apply it to the camera bezel for two minutes.
  10. Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the adhesive: étape 10, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the adhesive: étape 10, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Slice the adhesive: étape 10, image 3 de 3
    • Insert an opening pick under the camera bezel.
    • Slide the pick around the perimeter of the bezel to slice the adhesive.
    • If it feels stuck, apply more heat to further loosen the adhesive.
  11. Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the camera bezel: étape 11, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the camera bezel: étape 11, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the camera bezel: étape 11, image 3 de 3
    • Grab and remove the camera bezel.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the camera bezel with custom-cut adhesives, follow this guide.
    • To adhere the camera bezel with tape, follow this guide.
  12. Motorola Moto G Stylus 5G (2022) Battery Replacement, Unfasten the motherboard cover: étape 12, image 1 de 1
    • Use a Phillips screwdriver to remove the eleven 4.1 mm-long screws securing the motherboard cover.
    • If you can't find all the screws, check under any leftover adhesive residue.
  13. Motorola Moto G Stylus 5G (2022) Battery Replacement, Unclip the right edge: étape 13, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Unclip the right edge: étape 13, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Unclip the right edge: étape 13, image 3 de 3
    • Insert a spudger between the bottom right corner of the cover and the frame.
    • Pry up to release the clips securing the cover.
    • Slide the spudger toward the top of the cover and pry to release the right edge.
  14. Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the motherboard cover: étape 14, image 1 de 2 Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the motherboard cover: étape 14, image 2 de 2
    • Grip the right edge of the cover and pull it off the motherboard.
  15. Motorola Moto G Stylus 5G (2022) Battery Replacement, Disconnect the battery: étape 15, image 1 de 2 Motorola Moto G Stylus 5G (2022) Battery Replacement, Disconnect the battery: étape 15, image 2 de 2
    • Use the point of a spudger to pry up the battery's press connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  16. Motorola Moto G Stylus 5G (2022) Battery Replacement, Reposition the graphite film: étape 16, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Reposition the graphite film: étape 16, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Reposition the graphite film: étape 16, image 3 de 3
    • Grab the graphite heat dispersion film covering the battery.
    • Lift and fold the film over the motherboard to expose the battery.
  17. Motorola Moto G Stylus 5G (2022) Battery Replacement, Soften the adhesive with heat: étape 17, image 1 de 1
    • Heat an iOpener and apply it to the left edge of the screen for about two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  18. Motorola Moto G Stylus 5G (2022) Battery Replacement, Soften the adhesive with isopropyl alcohol: étape 18, image 1 de 2 Motorola Moto G Stylus 5G (2022) Battery Replacement, Soften the adhesive with isopropyl alcohol: étape 18, image 2 de 2
    • Additionally, you may use highly-concentrated isopropyl alcohol (over 90%) to further loosen the adhesive securing the battery.
    • Apply the isopropyl alcohol into the gaps between the sides of the battery and the frame.
  19. Motorola Moto G Stylus 5G (2022) Battery Replacement, Pry the battery: étape 19, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Pry the battery: étape 19, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Pry the battery: étape 19, image 3 de 3
    • Place a suction handle on the center of the battery.
    • Insert an opening pick between the right edge of the battery and the frame.
    • Use a steady force to pull on the suction handle and simultaneously pry with the pick.
    • Don't use excessive force on the battery. Slow, consistent pressure is all that is required to free it from the frame.
    • Apply more heat or isopropyl alcohol if the battery re-adheres.
  20. Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the battery: étape 20, image 1 de 1
    • Remove the battery from its recess.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Use this guide to install a battery with custom-cut adhesives, or use this guide to install a battery with an adhesive sheet.
  21. Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the foam strip: étape 21, image 1 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the foam strip: étape 21, image 2 de 3 Motorola Moto G Stylus 5G (2022) Battery Replacement, Remove the foam strip: étape 21, image 3 de 3
    • Peel and remove the foam strip from the bottom of the battery.
    • Apply the foam strip onto your new battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
2 autres ont terminé cette réparation.
Clay Eickemeyer
Membre depuis le 09/19/22
69 485 Réputation
453 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
141 membres
17 895 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 63
30 derniers jours : 332
Total : 7,210
