Aller au contenu principal
Nintendo Switch Lite Right Speaker Replacement
Ce dont vous avez besoin
  1. Nintendo Switch Lite Right Speaker Replacement, Remove the back panel screws: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  2. Nintendo Switch Lite Right Speaker Replacement, Remove the top and bottom back panel screws: étape 2, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement, Remove the top and bottom back panel screws: étape 2, image 2 de 2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  3. Nintendo Switch Lite Right Speaker Replacement, Release the clips securing the back panel: étape 3, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement, Release the clips securing the back panel: étape 3, image 2 de 2
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Right Speaker Replacement, Continue releasing the clips around the device: étape 4, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement, Continue releasing the clips around the device: étape 4, image 2 de 2
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Right Speaker Replacement, Twist to release the clips: étape 5, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement, Twist to release the clips: étape 5, image 2 de 2
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Right Speaker Replacement, Slide and pry around the corners: étape 6, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement, Slide and pry around the corners: étape 6, image 2 de 2
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Right Speaker Replacement: étape 7, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement: étape 7, image 2 de 2
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite Right Speaker Replacement, Remove the back panel: étape 8, image 1 de 3 Nintendo Switch Lite Right Speaker Replacement, Remove the back panel: étape 8, image 2 de 3 Nintendo Switch Lite Right Speaker Replacement, Remove the back panel: étape 8, image 3 de 3
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite Right Speaker Replacement, Remove the shield plate: étape 9, image 1 de 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  10. Nintendo Switch Lite Right Speaker Replacement: étape 10, image 1 de 3 Nintendo Switch Lite Right Speaker Replacement: étape 10, image 2 de 3 Nintendo Switch Lite Right Speaker Replacement: étape 10, image 3 de 3
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  11. Nintendo Switch Lite Right Speaker Replacement, Disconnect the battery: étape 11, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement, Disconnect the battery: étape 11, image 2 de 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  12. Nintendo Switch Lite Right Speaker Replacement: étape 12, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement: étape 12, image 2 de 2
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  13. Nintendo Switch Lite Right Speaker Replacement: étape 13, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement: étape 13, image 2 de 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  14. Nintendo Switch Lite Right Speaker Replacement, Remove the right speaker: étape 14, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement, Remove the right speaker: étape 14, image 2 de 2
    • Use a pair of tweezers or your fingers to pull the right speaker cable straight up and out of its socket on the motherboard.
    • Do not pull from the wires, or else you risk ripping the wires off the connector.
  15. Nintendo Switch Lite Right Speaker Replacement: étape 15, image 1 de 1
    • Three 2.5 mm screws
    • One 4.5 mm screw
  16. Nintendo Switch Lite Right Speaker Replacement: étape 16, image 1 de 2 Nintendo Switch Lite Right Speaker Replacement: étape 16, image 2 de 2
    • Use your fingers to lift and remove the right speaker module cover.
  17. Nintendo Switch Lite Right Speaker Replacement: étape 17, image 1 de 3 Nintendo Switch Lite Right Speaker Replacement: étape 17, image 2 de 3 Nintendo Switch Lite Right Speaker Replacement: étape 17, image 3 de 3
    • Insert a spudger into the gap at the top of the speaker.
    • Take care to avoid the speaker wires as you insert the spudger into the gap.
    • Pry the speaker up to lift it out of its recess.
    • The speaker is adhered with light adhesive inside the speaker module, so a bit of force is required.
    • Remove the right speaker.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
Craig Lloyd
Membre depuis le 02/10/16
38 614 Réputation
82 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 21
30 derniers jours : 87
Total : 4,298
