Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nintendo Switch Lite Screen Replacement
Ce dont vous avez besoin
  1. Nintendo Switch Lite Screen Replacement, Remove the back panel screws: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
    Demander à FixBot
    Ajouter un commentaire
  2. Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: étape 2, image 1 de 2 Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: étape 2, image 2 de 2
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    Demander à FixBot
  3. Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: étape 3, image 1 de 2 Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: étape 3, image 2 de 2
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
    Demander à FixBot
  4. Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: étape 4, image 1 de 2 Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: étape 4, image 2 de 2
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
    Demander à FixBot
  5. Nintendo Switch Lite Screen Replacement, Twist to release the clips: étape 5, image 1 de 2 Nintendo Switch Lite Screen Replacement, Twist to release the clips: étape 5, image 2 de 2
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
    Demander à FixBot
  6. Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: étape 6, image 1 de 2 Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: étape 6, image 2 de 2
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
    Demander à FixBot
  7. Nintendo Switch Lite Screen Replacement: étape 7, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 7, image 2 de 2
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
    Demander à FixBot
  8. Nintendo Switch Lite Screen Replacement, Remove the back panel: étape 8, image 1 de 3 Nintendo Switch Lite Screen Replacement, Remove the back panel: étape 8, image 2 de 3 Nintendo Switch Lite Screen Replacement, Remove the back panel: étape 8, image 3 de 3
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
    Demander à FixBot
  9. Nintendo Switch Lite Screen Replacement, Remove the shield plate: étape 9, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the four screws securing the shield plate:
    • Three 3.1 mm screws
    • One 4.5 mm screw
    Demander à FixBot
  10. Nintendo Switch Lite Screen Replacement: étape 10, image 1 de 3 Nintendo Switch Lite Screen Replacement: étape 10, image 2 de 3 Nintendo Switch Lite Screen Replacement: étape 10, image 3 de 3
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
    Demander à FixBot
  11. Nintendo Switch Lite Screen Replacement, Disconnect the interconnect cable: étape 11, image 1 de 2 Nintendo Switch Lite Screen Replacement, Disconnect the interconnect cable: étape 11, image 2 de 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    Demander à FixBot
  12. Nintendo Switch Lite Screen Replacement: étape 12, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 12, image 2 de 2
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
    Demander à FixBot
  13. Nintendo Switch Lite Screen Replacement, Disconnect the battery: étape 13, image 1 de 2 Nintendo Switch Lite Screen Replacement, Disconnect the battery: étape 13, image 2 de 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    • During reassembly, wait until after you connect the interconnect cable (above) before connecting the battery.
    Demander à FixBot
  14. Nintendo Switch Lite Screen Replacement, Remove the heat sink: étape 14, image 1 de 1
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    Demander à FixBot
  15. Nintendo Switch Lite Screen Replacement: étape 15, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    Demander à FixBot
  16. Nintendo Switch Lite Screen Replacement: étape 16, image 1 de 3 Nintendo Switch Lite Screen Replacement: étape 16, image 2 de 3 Nintendo Switch Lite Screen Replacement: étape 16, image 3 de 3
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    Demander à FixBot
  17. Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: étape 17, image 1 de 2 Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: étape 17, image 2 de 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
    Demander à FixBot
  18. Nintendo Switch Lite Screen Replacement: étape 18, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
    Demander à FixBot
  19. Nintendo Switch Lite Screen Replacement: étape 19, image 1 de 3 Nintendo Switch Lite Screen Replacement: étape 19, image 2 de 3 Nintendo Switch Lite Screen Replacement: étape 19, image 3 de 3
    • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
    • Remove the game card reader and headphone jack.
    Demander à FixBot
  20. Nintendo Switch Lite Screen Replacement, Remove the right trigger button assembly: étape 20, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
    Demander à FixBot
  21. Nintendo Switch Lite Screen Replacement: étape 21, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 21, image 2 de 2
    • Remove the right trigger button assembly.
    Demander à FixBot
  22. Nintendo Switch Lite Screen Replacement: étape 22, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 22, image 2 de 2
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
    Demander à FixBot
  23. Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: étape 23, image 1 de 3 Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: étape 23, image 2 de 3 Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: étape 23, image 3 de 3
    • Use the point of a spudger to pry the black antenna cable coaxial connector straight up off its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
    Demander à FixBot
  24. Nintendo Switch Lite Screen Replacement, Disconnect the fan cable: étape 24, image 1 de 1
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
    Demander à FixBot
  25. Nintendo Switch Lite Screen Replacement: étape 25, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 25, image 2 de 2
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
    Demander à FixBot
  26. Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: étape 26, image 1 de 2 Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: étape 26, image 2 de 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
    Demander à FixBot
  27. Nintendo Switch Lite Screen Replacement: étape 27, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 27, image 2 de 2
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
    Demander à FixBot
  28. Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: étape 28, image 1 de 2 Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: étape 28, image 2 de 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
    Demander à FixBot
  29. Nintendo Switch Lite Screen Replacement: étape 29, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 29, image 2 de 2
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
    Demander à FixBot
  30. Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: étape 30, image 1 de 2 Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: étape 30, image 2 de 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
    Demander à FixBot
  31. Nintendo Switch Lite Screen Replacement: étape 31, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 31, image 2 de 2
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
    Demander à FixBot
  32. Nintendo Switch Lite Screen Replacement, Remove the motherboard assembly: étape 32, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
    Demander à FixBot
  33. Nintendo Switch Lite Screen Replacement: étape 33, image 1 de 3 Nintendo Switch Lite Screen Replacement: étape 33, image 2 de 3 Nintendo Switch Lite Screen Replacement: étape 33, image 3 de 3
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
    Demander à FixBot
  34. Nintendo Switch Lite Screen Replacement, Remove the right joystick: étape 34, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the two 3.5 mm screws securing the joystick.
    Demander à FixBot
  35. Nintendo Switch Lite Screen Replacement: étape 35, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 35, image 2 de 2
    • Use your fingers to remove the joystick.
    • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
    Demander à FixBot
  36. Nintendo Switch Lite Screen Replacement, Remove the left speaker module: étape 36, image 1 de 2 Nintendo Switch Lite Screen Replacement, Remove the left speaker module: étape 36, image 2 de 2
    • Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
    • Do not pull from the wires, or else you risk ripping the wires off the connector.
    Demander à FixBot
  37. Nintendo Switch Lite Screen Replacement: étape 37, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the 4.5 mm screw securing the left speaker module.
    Demander à FixBot
  38. Nintendo Switch Lite Screen Replacement: étape 38, image 1 de 3 Nintendo Switch Lite Screen Replacement: étape 38, image 2 de 3 Nintendo Switch Lite Screen Replacement: étape 38, image 3 de 3
    • Use your fingers to lift the speaker module up and out of its recess to remove it.
    • Part of the speaker module sits underneath a delicate ribbon cable. Take care not to snag the speaker module on the cable as you remove it.
    Demander à FixBot
  39. Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: étape 39, image 1 de 2 Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: étape 39, image 2 de 2
    Demander à FixBot
  40. Nintendo Switch Lite Screen Replacement: étape 40, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 40, image 2 de 2
    • Use a pair of tweezers to slide the motherboard interconnect cable out of its connector on the daughterboard.
    Demander à FixBot
  41. Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: étape 41, image 1 de 2 Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: étape 41, image 2 de 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flaps on the two ribbon cable ZIF connectors.
    Demander à FixBot
  42. Nintendo Switch Lite Screen Replacement: étape 42, image 1 de 3 Nintendo Switch Lite Screen Replacement: étape 42, image 2 de 3 Nintendo Switch Lite Screen Replacement: étape 42, image 3 de 3
    • Use a pair of tweezers to slide the daughterboard screen cable out of its connector on the motherboard.
    • Repeat this procedure for the volume buttons cable.
    Demander à FixBot
  43. Nintendo Switch Lite Screen Replacement, Remove the volume buttons: étape 43, image 1 de 2 Nintendo Switch Lite Screen Replacement, Remove the volume buttons: étape 43, image 2 de 2
    • Use a pair of tweezers or your fingers to remove the volume buttons.
    Demander à FixBot
  44. Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: étape 44, image 1 de 2 Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: étape 44, image 2 de 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the left joystick cable's ZIF connector.
    Demander à FixBot
  45. Nintendo Switch Lite Screen Replacement: étape 45, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 45, image 2 de 2
    • Use a pair of tweezers to slide the left joystick cable out of its connector on the daughterboard.
    Demander à FixBot
  46. Nintendo Switch Lite Screen Replacement, Remove the left trigger button assembly: étape 46, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the two 4.5 mm screws securing the left trigger button assembly.
    Demander à FixBot
  47. Nintendo Switch Lite Screen Replacement: étape 47, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 47, image 2 de 2
    • Remove the left trigger button assembly.
    Demander à FixBot
  48. Nintendo Switch Lite Screen Replacement, Remove the daughterboard: étape 48, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the following four screws:
    • Two 4.5 mm screws
    • Two 6 mm screws
    Demander à FixBot
  49. Nintendo Switch Lite Screen Replacement: étape 49, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 49, image 2 de 2
    • Use your fingers to lift the daughterboard up and out of its recess to remove it.
    Demander à FixBot
  50. Nintendo Switch Lite Screen Replacement, Remove the left joystick: étape 50, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH 000 driver to remove the two 3.5 mm screws securing the left joystick.
    Demander à FixBot
  51. Nintendo Switch Lite Screen Replacement: étape 51, image 1 de 3 Nintendo Switch Lite Screen Replacement: étape 51, image 2 de 3 Nintendo Switch Lite Screen Replacement: étape 51, image 3 de 3
    • Use the flat end of a spudger to lift the joystick up and out of its recess.
    Demander à FixBot
  52. Nintendo Switch Lite Screen Replacement, Unfasten the midframe assembly: étape 52, image 1 de 1
    • Use a JIS 000 driver or an iFixit PH000 driver to remove the four screws securing the midframe assembly:
    • Three 2.5 mm screws
    • One 6 mm screw
    Demander à FixBot
  53. Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: étape 53, image 1 de 3 Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: étape 53, image 2 de 3 Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: étape 53, image 3 de 3
    • Use a spudger to pry the midframe assembly up until you can grip it with your fingers.
    • Grip the midframe assembly and pull up to remove it.
    Demander à FixBot
  54. Nintendo Switch Lite Screen Replacement, Remove the remaining buttons: étape 54, image 1 de 2 Nintendo Switch Lite Screen Replacement, Remove the remaining buttons: étape 54, image 2 de 2
    • Remove any remaining buttons that are loose in the frame.
    Demander à FixBot
  55. Nintendo Switch Lite Screen Replacement, Heat the left edge: étape 55, image 1 de 1
    • Flip the frame over so the screen is facing up.
    • Heat an iOpener and apply it to the left edge of the screen for two minutes.
    • Alternatively, you can use a hair dryer on the Low heat setting.
    • If you're using a hair dryer, only heat the screen a few seconds at a time or you may warp the plastic shell.
    Demander à FixBot
  56. Nintendo Switch Lite Screen Replacement, Insert an opening pick: étape 56, image 1 de 3 Nintendo Switch Lite Screen Replacement, Insert an opening pick: étape 56, image 2 de 3 Nintendo Switch Lite Screen Replacement, Insert an opening pick: étape 56, image 3 de 3
    • Lightly bend the left side of the frame away from the screen to create a gap in the bottom left corner.
    • If you're having difficulty creating a gap, reapply a heated iOpener for two minutes and try again.
    • Insert an opening pick in the gap.
    • Don't insert your pick more than 3 mm to avoid damaging the screen.
    Demander à FixBot
  57. Nintendo Switch Lite Screen Replacement, Slice the left adhesive: étape 57, image 1 de 2 Nintendo Switch Lite Screen Replacement, Slice the left adhesive: étape 57, image 2 de 2
    • Throughout this repair, don't insert your pick more than 3 mm to avoid damaging the screen.
    • Slide the opening pick along the left edge.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
    Demander à FixBot
  58. Nintendo Switch Lite Screen Replacement, Heat the top edge: étape 58, image 1 de 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    • You can also use a hair dryer, but remember not to heat the screen more than a few seconds at a time.
    Demander à FixBot
  59. Nintendo Switch Lite Screen Replacement, Slice the top adhesive: étape 59, image 1 de 2 Nintendo Switch Lite Screen Replacement, Slice the top adhesive: étape 59, image 2 de 2
    • Rotate the opening pick around the top left corner.
    Demander à FixBot
  60. Nintendo Switch Lite Screen Replacement: étape 60, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 60, image 2 de 2
    • Slide the opening pick along the top edge.
    • Leave the opening pick inserted in the top right corner.
    Demander à FixBot
  61. Nintendo Switch Lite Screen Replacement, Heat the right edge: étape 61, image 1 de 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    Demander à FixBot
  62. Nintendo Switch Lite Screen Replacement, Slice the right adhesive: étape 62, image 1 de 2 Nintendo Switch Lite Screen Replacement, Slice the right adhesive: étape 62, image 2 de 2
    • Rotate the opening pick around the top right corner.
    Demander à FixBot
  63. Nintendo Switch Lite Screen Replacement: étape 63, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 63, image 2 de 2
    • Slide the opening pick along the right edge.
    • Leave the opening pick inserted in the bottom right corner.
    Demander à FixBot
  64. Nintendo Switch Lite Screen Replacement, Heat the bottom edge: étape 64, image 1 de 1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
    Demander à FixBot
  65. Nintendo Switch Lite Screen Replacement, Slice the bottom adhesive: étape 65, image 1 de 2 Nintendo Switch Lite Screen Replacement, Slice the bottom adhesive: étape 65, image 2 de 2
    • Rotate the opening pick around the bottom right corner.
    Demander à FixBot
  66. Nintendo Switch Lite Screen Replacement: étape 66, image 1 de 2 Nintendo Switch Lite Screen Replacement: étape 66, image 2 de 2
    • Slide the opening pick along the bottom edge.
    Demander à FixBot
  67. Nintendo Switch Lite Screen Replacement, Separate the adhesive: étape 67, image 1 de 2 Nintendo Switch Lite Screen Replacement, Separate the adhesive: étape 67, image 2 de 2
    • Grip the frame and push up on the underside of the screen's left edge to separate the adhesive securing it.
    Demander à FixBot
  68. Nintendo Switch Lite Screen Replacement, Remove the screen: étape 68, image 1 de 3 Nintendo Switch Lite Screen Replacement, Remove the screen: étape 68, image 2 de 3 Nintendo Switch Lite Screen Replacement, Remove the screen: étape 68, image 3 de 3
    • The digitizer cables prevent the screen from being lifted straight up from the frame.
    • Lift the left side of the screen to a 45-degree angle and remove it.
    • If the screen is still stuck to the frame, slide an opening pick around the perimeter and try again.
    • During reassembly, follow this guide to replace the screen adhesive.
    Demander à FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
29 autres ont terminé cette réparation.
Spencer Day
Membre depuis le 09/14/22
195 471 Réputation
1 243 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
27 498 tutoriels rédigés
2 commentaires de tutoriel
Thanks for your guide - it was very helpful, first time I took screen off without breaking it off :). I also bought the iFixit kit with the heat pad. I can now see that the trick was not so much a lot of heat, but heat evenly along the whole side
Angelo Felix - Réponse Partager
omg you are a lifesaver thank you so much
Adien Richards - Réponse Partager
Nombre de vues :
Dernières 24 heures : 91
7 derniers jours : 508
30 derniers jours : 2,287
Total : 70,055
