Aller au contenu principal
Pour réparer ensemble - Je crée un compte
OnePlus 8 Daughterboard Replacement
Ce dont vous avez besoin
  1. OnePlus 8 Daughterboard Replacement, Heat the rear glass: étape 1, image 1 de 1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
    Demander à FixBot
    Ajouter un commentaire
  2. OnePlus 8 Daughterboard Replacement, Insert an opening pick: étape 2, image 1 de 3 OnePlus 8 Daughterboard Replacement, Insert an opening pick: étape 2, image 2 de 3 OnePlus 8 Daughterboard Replacement, Insert an opening pick: étape 2, image 3 de 3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
    Demander à FixBot
  3. OnePlus 8 Daughterboard Replacement, Slice the bottom edge adhesive: étape 3, image 1 de 3 OnePlus 8 Daughterboard Replacement, Slice the bottom edge adhesive: étape 3, image 2 de 3 OnePlus 8 Daughterboard Replacement, Slice the bottom edge adhesive: étape 3, image 3 de 3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    Demander à FixBot
  4. OnePlus 8 Daughterboard Replacement: étape 4, image 1 de 3 OnePlus 8 Daughterboard Replacement: étape 4, image 2 de 3 OnePlus 8 Daughterboard Replacement: étape 4, image 3 de 3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    Demander à FixBot
  5. OnePlus 8 Daughterboard Replacement, Slice the left edge adhesive: étape 5, image 1 de 3 OnePlus 8 Daughterboard Replacement, Slice the left edge adhesive: étape 5, image 2 de 3 OnePlus 8 Daughterboard Replacement, Slice the left edge adhesive: étape 5, image 3 de 3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Demander à FixBot
  6. OnePlus 8 Daughterboard Replacement, Slice the top edge adhesive: étape 6, image 1 de 3 OnePlus 8 Daughterboard Replacement, Slice the top edge adhesive: étape 6, image 2 de 3 OnePlus 8 Daughterboard Replacement, Slice the top edge adhesive: étape 6, image 3 de 3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Demander à FixBot
  7. OnePlus 8 Daughterboard Replacement, Slice the right edge adhesive: étape 7, image 1 de 3 OnePlus 8 Daughterboard Replacement, Slice the right edge adhesive: étape 7, image 2 de 3 OnePlus 8 Daughterboard Replacement, Slice the right edge adhesive: étape 7, image 3 de 3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
    Demander à FixBot
  8. OnePlus 8 Daughterboard Replacement, Remove the rear glass: étape 8, image 1 de 3 OnePlus 8 Daughterboard Replacement, Remove the rear glass: étape 8, image 2 de 3 OnePlus 8 Daughterboard Replacement, Remove the rear glass: étape 8, image 3 de 3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
    Demander à FixBot
  9. OnePlus 8 Daughterboard Replacement, Unfasten the motherboard cover: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    • A white sticker may cover a screw on the right edge of the motherboard cover. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
    Demander à FixBot
  10. OnePlus 8 Daughterboard Replacement, Pry up the motherboard cover: étape 10, image 1 de 3 OnePlus 8 Daughterboard Replacement, Pry up the motherboard cover: étape 10, image 2 de 3 OnePlus 8 Daughterboard Replacement, Pry up the motherboard cover: étape 10, image 3 de 3
    • The motherboard cover is secured by tight clips.
    • Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
    • Twist the spudger to release the clips.
    • Lever the motherboard cover up until you can grip it with your fingers.
    Demander à FixBot
  11. OnePlus 8 Daughterboard Replacement, Remove the motherboard cover: étape 11, image 1 de 2 OnePlus 8 Daughterboard Replacement, Remove the motherboard cover: étape 11, image 2 de 2
    • Remove the motherboard cover.
    Demander à FixBot
  12. OnePlus 8 Daughterboard Replacement, Disconnect the battery cable: étape 12, image 1 de 2 OnePlus 8 Daughterboard Replacement, Disconnect the battery cable: étape 12, image 2 de 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Demander à FixBot
  13. OnePlus 8 Daughterboard Replacement, Unfasten the loudspeaker: étape 13, image 1 de 1
    • A white sticker may coversa screw on the top right corner of the loudspeaker. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips driver to remove the seven 3.3 mm-long screws securing the loudspeaker.
    Demander à FixBot
  14. OnePlus 8 Daughterboard Replacement, Pry up the loudspeaker: étape 14, image 1 de 2 OnePlus 8 Daughterboard Replacement, Pry up the loudspeaker: étape 14, image 2 de 2
    • The loudspeaker is secured with plastic clips.
    • Insert an opening pick underneath the center of the loudspeaker's top edge.
    • Pry up to release the clips securing the loudspeaker, levering it up until you can grip it with your fingers.
    Demander à FixBot
  15. OnePlus 8 Daughterboard Replacement, Remove the loudspeaker: étape 15, image 1 de 2 OnePlus 8 Daughterboard Replacement, Remove the loudspeaker: étape 15, image 2 de 2
    • Remove the loudspeaker.
    Demander à FixBot
  16. OnePlus 8 Daughterboard Replacement, Eject the SIM card tray: étape 16, image 1 de 3 OnePlus 8 Daughterboard Replacement, Eject the SIM card tray: étape 16, image 2 de 3 OnePlus 8 Daughterboard Replacement, Eject the SIM card tray: étape 16, image 3 de 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press firmly to eject the tray.
    Demander à FixBot
  17. OnePlus 8 Daughterboard Replacement, Remove the SIM card tray: étape 17, image 1 de 2 OnePlus 8 Daughterboard Replacement, Remove the SIM card tray: étape 17, image 2 de 2
    • Remove the SIM card tray from the phone.
    • A thin rubber gasket provides water and dust protection. If this gasket is damaged or missing, replace the gasket (or the entire tray) to maintain water resistance and protect your phone's internal components.
    • When inserting a SIM card into the tray, make sure it's oriented properly within the tray before reinserting the tray into the phone.
    Demander à FixBot
  18. OnePlus 8 Daughterboard Replacement, Disconnect the antenna board cable: étape 18, image 1 de 2 OnePlus 8 Daughterboard Replacement, Disconnect the antenna board cable: étape 18, image 2 de 2
    • Use a spudger to disconnect the antenna board cable from the daughterboard by prying the connector straight up from its socket.
    Demander à FixBot
  19. OnePlus 8 Daughterboard Replacement, Disconnect the fingerprint reader cable: étape 19, image 1 de 2 OnePlus 8 Daughterboard Replacement, Disconnect the fingerprint reader cable: étape 19, image 2 de 2
    • Use a spudger to disconnect the fingerprint reader cable from the daughterboard by prying the connector straight up from its socket.
    Demander à FixBot
  20. OnePlus 8 Daughterboard Replacement, Disconnect the interconnect cable: étape 20, image 1 de 2 OnePlus 8 Daughterboard Replacement, Disconnect the interconnect cable: étape 20, image 2 de 2
    • Use a spudger to disconnect the interconnect cable from the daughterboard by prying the connector straight up from its socket.
    Demander à FixBot
  21. OnePlus 8 Daughterboard Replacement, Disconnect the black antenna cable: étape 21, image 1 de 2 OnePlus 8 Daughterboard Replacement, Disconnect the black antenna cable: étape 21, image 2 de 2
    • Use the pointed end of a spudger to disconnect the black antenna cable by prying the connector straight up from its socket on the motherboard.
    • Pry only on the metal heads of the connectors. Avoid prying on the cables themselves.
    • To reconnect antenna cables, hold each one in place over its socket and press down with the flat end of your spudger. The connector will snap into place.
    Demander à FixBot
  22. OnePlus 8 Daughterboard Replacement, Unclip the black antenna cable: étape 22, image 1 de 2 OnePlus 8 Daughterboard Replacement, Unclip the black antenna cable: étape 22, image 2 de 2
    • Use a pair of tweezers or your fingers to lift the black antenna cable out of its clip on the daughterboard.
    Demander à FixBot
  23. OnePlus 8 Daughterboard Replacement, Disconnect and unclip the white antenna cable: étape 23, image 1 de 3 OnePlus 8 Daughterboard Replacement, Disconnect and unclip the white antenna cable: étape 23, image 2 de 3 OnePlus 8 Daughterboard Replacement, Disconnect and unclip the white antenna cable: étape 23, image 3 de 3
    • Use the pointed end of a spudger to disconnect the white antenna cable by prying the connector straight up from its socket on the motherboard.
    • Use a pair of tweezers or your fingers to lift the white antenna cable out of its clip on the daughterboard.
    • During reassembly, make sure the antenna cables are pushed into their channels on the right edge of the phone before pressing them into their respective clips.
    Demander à FixBot
  24. OnePlus 8 Daughterboard Replacement, Unfasten the daughterboard: étape 24, image 1 de 1
    • Use a Phillips driver to remove the single 3.3 mm-long screw securing the daughterboard.
    Demander à FixBot
  25. OnePlus 8 Daughterboard Replacement, Pry up the daughterboard: étape 25, image 1 de 2 OnePlus 8 Daughterboard Replacement, Pry up the daughterboard: étape 25, image 2 de 2
    • Insert the point of a spudger under the top right corner of the daughterboard.
    • Pry up the daughterboard.
    Demander à FixBot
  26. OnePlus 8 Daughterboard Replacement, Remove the daughterboard: étape 26, image 1 de 3 OnePlus 8 Daughterboard Replacement, Remove the daughterboard: étape 26, image 2 de 3 OnePlus 8 Daughterboard Replacement, Remove the daughterboard: étape 26, image 3 de 3
    • Use a pair of tweezers or your fingers to remove the daughterboard.
    • Before reinstalling the daughterboard, make sure all cables that connect to it are out of the way.
    Demander à FixBot
3 autres ont terminé cette réparation.
Manuel Haeussermann
Membre depuis le 07/13/22
25 565 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 949 tutoriels rédigés
1 commentaire de tutoriel
I have conducted small Board match main board and it shows " Board A" match failed. What is board A?
Kaushal Kharolia - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 20
30 derniers jours : 63
Total : 1,561
