Aller au contenu principal
Pour réparer ensemble - Je crée un compte
OnePlus 8 Loudspeaker Replacement
Ce dont vous avez besoin
  1. OnePlus 8 Loudspeaker Replacement, Heat the rear glass: étape 1, image 1 de 1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
    Demander à FixBot
  2. OnePlus 8 Loudspeaker Replacement, Insert an opening pick: étape 2, image 1 de 3 OnePlus 8 Loudspeaker Replacement, Insert an opening pick: étape 2, image 2 de 3 OnePlus 8 Loudspeaker Replacement, Insert an opening pick: étape 2, image 3 de 3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
    Demander à FixBot
  3. OnePlus 8 Loudspeaker Replacement, Slice the bottom edge adhesive: étape 3, image 1 de 3 OnePlus 8 Loudspeaker Replacement, Slice the bottom edge adhesive: étape 3, image 2 de 3 OnePlus 8 Loudspeaker Replacement, Slice the bottom edge adhesive: étape 3, image 3 de 3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    Demander à FixBot
  4. OnePlus 8 Loudspeaker Replacement: étape 4, image 1 de 3 OnePlus 8 Loudspeaker Replacement: étape 4, image 2 de 3 OnePlus 8 Loudspeaker Replacement: étape 4, image 3 de 3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    Demander à FixBot
  5. OnePlus 8 Loudspeaker Replacement, Slice the left edge adhesive: étape 5, image 1 de 3 OnePlus 8 Loudspeaker Replacement, Slice the left edge adhesive: étape 5, image 2 de 3 OnePlus 8 Loudspeaker Replacement, Slice the left edge adhesive: étape 5, image 3 de 3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Demander à FixBot
  6. OnePlus 8 Loudspeaker Replacement, Slice the top edge adhesive: étape 6, image 1 de 3 OnePlus 8 Loudspeaker Replacement, Slice the top edge adhesive: étape 6, image 2 de 3 OnePlus 8 Loudspeaker Replacement, Slice the top edge adhesive: étape 6, image 3 de 3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Demander à FixBot
  7. OnePlus 8 Loudspeaker Replacement, Slice the right edge adhesive: étape 7, image 1 de 3 OnePlus 8 Loudspeaker Replacement, Slice the right edge adhesive: étape 7, image 2 de 3 OnePlus 8 Loudspeaker Replacement, Slice the right edge adhesive: étape 7, image 3 de 3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
    Demander à FixBot
  8. OnePlus 8 Loudspeaker Replacement, Remove the rear glass: étape 8, image 1 de 3 OnePlus 8 Loudspeaker Replacement, Remove the rear glass: étape 8, image 2 de 3 OnePlus 8 Loudspeaker Replacement, Remove the rear glass: étape 8, image 3 de 3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
    Demander à FixBot
  9. OnePlus 8 Loudspeaker Replacement, Unfasten the motherboard cover: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    • A white sticker may cover a screw on the right edge of the motherboard cover. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
    Demander à FixBot
  10. OnePlus 8 Loudspeaker Replacement, Pry up the motherboard cover: étape 10, image 1 de 3 OnePlus 8 Loudspeaker Replacement, Pry up the motherboard cover: étape 10, image 2 de 3 OnePlus 8 Loudspeaker Replacement, Pry up the motherboard cover: étape 10, image 3 de 3
    • The motherboard cover is secured by tight clips.
    • Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
    • Twist the spudger to release the clips.
    • Lever the motherboard cover up until you can grip it with your fingers.
    Demander à FixBot
  11. OnePlus 8 Loudspeaker Replacement, Remove the motherboard cover: étape 11, image 1 de 2 OnePlus 8 Loudspeaker Replacement, Remove the motherboard cover: étape 11, image 2 de 2
    • Remove the motherboard cover.
    Demander à FixBot
  12. OnePlus 8 Loudspeaker Replacement, Disconnect the battery cable: étape 12, image 1 de 2 OnePlus 8 Loudspeaker Replacement, Disconnect the battery cable: étape 12, image 2 de 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Demander à FixBot
  13. OnePlus 8 Loudspeaker Replacement, Unfasten the loudspeaker: étape 13, image 1 de 1
    • A white sticker may coversa screw on the top right corner of the loudspeaker. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips driver to remove the seven 3.3 mm-long screws securing the loudspeaker.
    Demander à FixBot
  14. OnePlus 8 Loudspeaker Replacement, Pry up the loudspeaker: étape 14, image 1 de 2 OnePlus 8 Loudspeaker Replacement, Pry up the loudspeaker: étape 14, image 2 de 2
    • The loudspeaker is secured with plastic clips.
    • Insert an opening pick underneath the center of the loudspeaker's top edge.
    • Pry up to release the clips securing the loudspeaker, levering it up until you can grip it with your fingers.
    Demander à FixBot
  15. OnePlus 8 Loudspeaker Replacement, Remove the loudspeaker: étape 15, image 1 de 2 OnePlus 8 Loudspeaker Replacement, Remove the loudspeaker: étape 15, image 2 de 2
    • Remove the loudspeaker.
    Demander à FixBot
Manuel Haeussermann
Membre depuis le 07/13/22
25 496 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 805 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 62
Total : 808
