Aller au contenu principal
Pour réparer ensemble - Je crée un compte
OnePlus 8 Screen Replacement
Ce dont vous avez besoin
  1. OnePlus 8 Screen Replacement, Heat the rear glass: étape 1, image 1 de 1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
    Demander à FixBot
  2. OnePlus 8 Screen Replacement, Insert an opening pick: étape 2, image 1 de 3 OnePlus 8 Screen Replacement, Insert an opening pick: étape 2, image 2 de 3 OnePlus 8 Screen Replacement, Insert an opening pick: étape 2, image 3 de 3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
    Demander à FixBot
  3. OnePlus 8 Screen Replacement, Slice the bottom edge adhesive: étape 3, image 1 de 3 OnePlus 8 Screen Replacement, Slice the bottom edge adhesive: étape 3, image 2 de 3 OnePlus 8 Screen Replacement, Slice the bottom edge adhesive: étape 3, image 3 de 3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    Demander à FixBot
  4. OnePlus 8 Screen Replacement: étape 4, image 1 de 3 OnePlus 8 Screen Replacement: étape 4, image 2 de 3 OnePlus 8 Screen Replacement: étape 4, image 3 de 3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    Demander à FixBot
  5. OnePlus 8 Screen Replacement, Slice the left edge adhesive: étape 5, image 1 de 3 OnePlus 8 Screen Replacement, Slice the left edge adhesive: étape 5, image 2 de 3 OnePlus 8 Screen Replacement, Slice the left edge adhesive: étape 5, image 3 de 3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Demander à FixBot
  6. OnePlus 8 Screen Replacement, Slice the top edge adhesive: étape 6, image 1 de 3 OnePlus 8 Screen Replacement, Slice the top edge adhesive: étape 6, image 2 de 3 OnePlus 8 Screen Replacement, Slice the top edge adhesive: étape 6, image 3 de 3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Demander à FixBot
  7. OnePlus 8 Screen Replacement, Slice the right edge adhesive: étape 7, image 1 de 3 OnePlus 8 Screen Replacement, Slice the right edge adhesive: étape 7, image 2 de 3 OnePlus 8 Screen Replacement, Slice the right edge adhesive: étape 7, image 3 de 3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
    Demander à FixBot
  8. OnePlus 8 Screen Replacement, Remove the rear glass: étape 8, image 1 de 3 OnePlus 8 Screen Replacement, Remove the rear glass: étape 8, image 2 de 3 OnePlus 8 Screen Replacement, Remove the rear glass: étape 8, image 3 de 3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
    Demander à FixBot
  9. OnePlus 8 Screen Replacement, Unfasten the loudspeaker: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    • A white sticker may coversa screw on the top right corner of the loudspeaker. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips driver to remove the seven 3.3 mm-long screws securing the loudspeaker.
    Demander à FixBot
  10. OnePlus 8 Screen Replacement, Pry up the loudspeaker: étape 10, image 1 de 2 OnePlus 8 Screen Replacement, Pry up the loudspeaker: étape 10, image 2 de 2
    • The loudspeaker is secured with plastic clips.
    • Insert an opening pick underneath the center of the loudspeaker's top edge.
    • Pry up to release the clips securing the loudspeaker, levering it up until you can grip it with your fingers.
    Demander à FixBot
  11. OnePlus 8 Screen Replacement, Remove the loudspeaker: étape 11, image 1 de 2 OnePlus 8 Screen Replacement, Remove the loudspeaker: étape 11, image 2 de 2
    • Remove the loudspeaker.
    Demander à FixBot
  12. OnePlus 8 Screen Replacement, Eject the SIM card tray: étape 12, image 1 de 3 OnePlus 8 Screen Replacement, Eject the SIM card tray: étape 12, image 2 de 3 OnePlus 8 Screen Replacement, Eject the SIM card tray: étape 12, image 3 de 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press firmly to eject the tray.
    Demander à FixBot
  13. OnePlus 8 Screen Replacement, Remove the SIM card tray: étape 13, image 1 de 2 OnePlus 8 Screen Replacement, Remove the SIM card tray: étape 13, image 2 de 2
    • Remove the SIM card tray from the phone.
    • A thin rubber gasket provides water and dust protection. If this gasket is damaged or missing, replace the gasket (or the entire tray) to maintain water resistance and protect your phone's internal components.
    • When inserting a SIM card into the tray, make sure it's oriented properly within the tray before reinserting the tray into the phone.
    Demander à FixBot
  14. OnePlus 8 Screen Replacement, Disconnect the antenna board cable: étape 14, image 1 de 2 OnePlus 8 Screen Replacement, Disconnect the antenna board cable: étape 14, image 2 de 2
    • Use a spudger to disconnect the antenna board cable from the daughterboard by prying the connector straight up from its socket.
    Demander à FixBot
  15. OnePlus 8 Screen Replacement, Disconnect the fingerprint reader cable: étape 15, image 1 de 2 OnePlus 8 Screen Replacement, Disconnect the fingerprint reader cable: étape 15, image 2 de 2
    • Use a spudger to disconnect the fingerprint reader cable from the daughterboard by prying the connector straight up from its socket.
    Demander à FixBot
  16. OnePlus 8 Screen Replacement, Disconnect the interconnect cable: étape 16, image 1 de 2 OnePlus 8 Screen Replacement, Disconnect the interconnect cable: étape 16, image 2 de 2
    • Use a spudger to disconnect the interconnect cable from the daughterboard by prying the connector straight up from its socket.
    Demander à FixBot
  17. OnePlus 8 Screen Replacement, Disconnect the black antenna cable: étape 17, image 1 de 2 OnePlus 8 Screen Replacement, Disconnect the black antenna cable: étape 17, image 2 de 2
    • Use the pointed end of a spudger to disconnect the black antenna cable by prying the connector straight up from its socket on the motherboard.
    • Pry only on the metal heads of the connectors. Avoid prying on the cables themselves.
    • To reconnect antenna cables, hold each one in place over its socket and press down with the flat end of your spudger. The connector will snap into place.
    Demander à FixBot
  18. OnePlus 8 Screen Replacement, Unclip the black antenna cable: étape 18, image 1 de 2 OnePlus 8 Screen Replacement, Unclip the black antenna cable: étape 18, image 2 de 2
    • Use a pair of tweezers or your fingers to lift the black antenna cable out of its clip on the daughterboard.
    Demander à FixBot
  19. OnePlus 8 Screen Replacement, Disconnect and unclip the white antenna cable: étape 19, image 1 de 3 OnePlus 8 Screen Replacement, Disconnect and unclip the white antenna cable: étape 19, image 2 de 3 OnePlus 8 Screen Replacement, Disconnect and unclip the white antenna cable: étape 19, image 3 de 3
    • Use the pointed end of a spudger to disconnect the white antenna cable by prying the connector straight up from its socket on the motherboard.
    • Use a pair of tweezers or your fingers to lift the white antenna cable out of its clip on the daughterboard.
    • During reassembly, make sure the antenna cables are pushed into their channels on the right edge of the phone before pressing them into their respective clips.
    Demander à FixBot
  20. OnePlus 8 Screen Replacement, Unfasten the daughterboard: étape 20, image 1 de 1
    • Use a Phillips driver to remove the single 3.3 mm-long screw securing the daughterboard.
    Demander à FixBot
  21. OnePlus 8 Screen Replacement, Pry up the daughterboard: étape 21, image 1 de 2 OnePlus 8 Screen Replacement, Pry up the daughterboard: étape 21, image 2 de 2
    • Insert the point of a spudger under the top right corner of the daughterboard.
    • Pry up the daughterboard.
    Demander à FixBot
  22. OnePlus 8 Screen Replacement, Remove the daughterboard: étape 22, image 1 de 3 OnePlus 8 Screen Replacement, Remove the daughterboard: étape 22, image 2 de 3 OnePlus 8 Screen Replacement, Remove the daughterboard: étape 22, image 3 de 3
    • Use a pair of tweezers or your fingers to remove the daughterboard.
    • Before reinstalling the daughterboard, make sure all cables that connect to it are out of the way.
    Demander à FixBot
  23. OnePlus 8 Screen Replacement, Disconnect the display cable: étape 23, image 1 de 2 OnePlus 8 Screen Replacement, Disconnect the display cable: étape 23, image 2 de 2
    • Use the pointed end of a spudger to disconnect the display cable by prying the connector straight up from its socket on the bottom right corner of the frame.
    Demander à FixBot
  24. OnePlus 8 Screen Replacement, Temporarily reinstall the back cover: étape 24, image 1 de 3 OnePlus 8 Screen Replacement, Temporarily reinstall the back cover: étape 24, image 2 de 3 OnePlus 8 Screen Replacement, Temporarily reinstall the back cover: étape 24, image 3 de 3
    • Place the back cover on the frame to protect your phone's internal components during the rest of the screen removal process.
    • Flip your phone over so the screen is facing up.
    Demander à FixBot
  25. OnePlus 8 Screen Replacement, Loosen the display adhesive: étape 25, image 1 de 1
    • Heat an iOpener and apply it to the screen for two minutes.
    Demander à FixBot
  26. OnePlus 8 Screen Replacement, Insert an iFlex: étape 26, image 1 de 3 OnePlus 8 Screen Replacement, Insert an iFlex: étape 26, image 2 de 3 OnePlus 8 Screen Replacement, Insert an iFlex: étape 26, image 3 de 3
    iFlex Opening Tool
    $11.99
    • Apply a suction handle to the center of the bottom edge of the screen, as close to the edge as possible.
    • Pull up on the suction handle with strong, steady force and insert an iFlex between the screen and frame.
    • Make sure to unsert the iFlex under the screen, not the plastic frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    Demander à FixBot
  27. OnePlus 8 Screen Replacement, Slice the bottom edge adhesive: étape 27, image 1 de 3 OnePlus 8 Screen Replacement, Slice the bottom edge adhesive: étape 27, image 2 de 3 OnePlus 8 Screen Replacement, Slice the bottom edge adhesive: étape 27, image 3 de 3
    • Insert an opening pick between the iFlex and the screen.
    • Slide the opening pick to the bottom right corner of the screen to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Demander à FixBot
  28. OnePlus 8 Screen Replacement: étape 28, image 1 de 3 OnePlus 8 Screen Replacement: étape 28, image 2 de 3 OnePlus 8 Screen Replacement: étape 28, image 3 de 3
    • Insert a second opening pick between the iFlex and the screen.
    • Slide the opening pick to the bottom left corner of the screen to slice the adhesive.
    • Remove the iFlex.
    Demander à FixBot
  29. OnePlus 8 Screen Replacement, Slice the left edge adhesive: étape 29, image 1 de 3 OnePlus 8 Screen Replacement, Slice the left edge adhesive: étape 29, image 2 de 3 OnePlus 8 Screen Replacement, Slice the left edge adhesive: étape 29, image 3 de 3
    • If the adhesive becomes hard to cut, it's most likely cooled down. Use your iOpener or heat gun to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick up the left edge of the screen to slice the adhesive.
    Demander à FixBot
  30. OnePlus 8 Screen Replacement, Slice the top edge adhesive: étape 30, image 1 de 3 OnePlus 8 Screen Replacement, Slice the top edge adhesive: étape 30, image 2 de 3 OnePlus 8 Screen Replacement, Slice the top edge adhesive: étape 30, image 3 de 3
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    Demander à FixBot
  31. OnePlus 8 Screen Replacement, Slice the right edge adhesive: étape 31, image 1 de 3 OnePlus 8 Screen Replacement, Slice the right edge adhesive: étape 31, image 2 de 3 OnePlus 8 Screen Replacement, Slice the right edge adhesive: étape 31, image 3 de 3
    • Insert a fifth opening pick underneath the top right corner of the screen and slide it down the right edge of the phone to slice the remaining adhesive.
    • Don't try to fully remove the display just yet—the display cables are still threaded through the midframe.
    Demander à FixBot
  32. OnePlus 8 Screen Replacement, Thread the display cable: étape 32, image 1 de 2 OnePlus 8 Screen Replacement, Thread the display cable: étape 32, image 2 de 2
    • Flip the phone over.
    • Remove the back cover.
    • Lift the bottom edge of the phone and carefully thread the display cable through its gap in the frame.
    • If the screen is still stuck to the frame, slide an opening pick around the entire perimeter until the screen separates completely.
    Demander à FixBot
  33. OnePlus 8 Screen Replacement, Remove the screen: étape 33, image 1 de 1
    • Remove the screen.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    Demander à FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it. The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
6 autres ont terminé cette réparation.
Manuel Haeussermann
Membre depuis le 07/13/22
25 496 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 805 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 45
30 derniers jours : 211
Total : 9,578
