Aller au contenu principal
Remplacement de la batterie de l'iPad 3 4G
Ce dont vous avez besoin
  1. Remplacement de la batterie de l'iPad 3 4G, Chauffer un iOpener: étape 1, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G, Chauffer un iOpener: étape 1, image 2 de 2
    • Nous recommandons de nettoyer le micro-ondes avant de commencer. D'éventuels restes au fond risquent d'adhérer à votre iOpener.
    • Placez l'iOpener au centre du micro-ondes.
    • Pour les micro-ondes à plateau tournant : assurez-vous que le plateau tourne bien. Si votre iOpener reste coincé, il risque de surchauffer et de brûler.
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - Réponse
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - Réponse
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - Réponse
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - Réponse
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - Réponse
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - Réponse
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - Réponse
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - Réponse
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - Réponse
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - Réponse
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - Réponse
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - Réponse
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - Réponse
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - Réponse
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - Réponse
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - Réponse
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - Réponse
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - Réponse
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - Réponse
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - Réponse
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - Réponse
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - Réponse
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - Réponse
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - Réponse
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - Réponse
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - Réponse
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - Réponse
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - Réponse
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - Réponse
    Can’t you just use a hair curler instead?
    Aspect22 - Réponse
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - Réponse
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - Réponse
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - Réponse
  2. Remplacement de la batterie de l'iPad 3 4G: étape 2, image 1 de 1
    • Chauffez l'iOpener pendant trente secondes.
    • Comme l'iOpener refroidit au cours de la réparation, rechauffez-le à nouveau au micro-ondes, mais ne dépassez pas les trente secondes à chaque fois.
    • Faites attention de ne pas surchauffer l'iOpener pendant la réparation. En cas de surchauffe, l'iOpener risque d'exploser. Ne le chauffez pas au-dessus de 100°C (212°F).
    • Ne touchez jamais l'iOpener s'il vous paraît gonflé.
    • Si le milieu de l'iOpener est encore trop chaud au toucher, continuez à l'utiliser jusqu'à ce qu'il soit assez froid pour le chauffer à nouveau. Un iOpener correctement chauffé devrait rester chaud pendant environ 10 minutes.
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - Réponse
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - Réponse
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - Réponse
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - Réponse
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - Réponse
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - Réponse
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - Réponse
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - Réponse
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - Réponse
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - Réponse
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - Réponse
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - Réponse
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - Réponse
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - Réponse
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - Réponse
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - Réponse
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - Réponse
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - Réponse
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - Réponse
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - Réponse
  3. Remplacement de la batterie de l'iPad 3 4G: étape 3, image 1 de 1
    • Sortez l'iOpener du micro-ondes en le tenant par l'une des deux extrémités plates, car le centre de l'outil risque d'être brûlant.
    • L'iOpener sera très chaud, alors soyez prudent en le manipulant. Utilisez une manique si nécessaire.
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - Réponse
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - Réponse
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - Réponse
    This thing melts when placed up side down in the microwave…
    Mark - Réponse
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - Réponse
  4. Remplacement de la batterie de l'iPad 3 4G, Méthode alternative pour chauffer un iOpener: étape 4, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G, Méthode alternative pour chauffer un iOpener: étape 4, image 2 de 2
    • Si vous n'avez pas de micro-ondes, suivez cette étape pour chauffer votre iOpener dans de l'eau bouillante.
    • Remplissez une casserole ou une poêle avec suffisamment d'eau pour immerger complètement un iOpener.
    • Faites chauffer l'eau jusqu'à ébullition. Puis éteignez le feu.
    • Placez un iOpener dans l'eau chaude pendant 2 à 3 minutes. Assurez-vous que l'iOpener est complètement immergé dans l'eau.
    • Utilisez des pinces pour extraire l'iOpener chauffé de l'eau chaude.
    • Séchez soigneusement l'iOpener avec une serviette.
    • L'iOpener sera très chaud, veillez donc à ne le tenir que par les languettes aux extrémités.
    • Votre iOpener est prêt à être utilisé ! Si vous devez réchauffer l'iOpener, portez l'eau à ébullition, éteignez le feu et placez l'iOpener dans l'eau pendant 2 à 3 minutes.
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - Réponse
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - Réponse
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - Réponse
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - Réponse
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - Réponse
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
  5. Remplacement de la batterie de l'iPad 3 4G, Panneau frontal: étape 5, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G, Panneau frontal: étape 5, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G, Panneau frontal: étape 5, image 3 de 3
    • Si la vitre de votre écran est fissurée, limitez la casse et évitez de vous blesser au cours de la réparation en collant de la bande adhésive sur la vitre.
    • Posez des bandes adhésives transparentes se chevauchant sur la vitre de l'iPad jusqu'à ce que toute la surface soit couverte.
    • Ainsi les éclats de verre seront maintenus en place et la structure restera stable lorsque vous ferez levier et soulèverez l'écran.
    • Faites de votre mieux en suivant le reste des instructions du tutoriel. Toutefois, si la vitre est cassée, elle continuera à se fissurer pendant que vous travaillerez. Vous aurez besoin d'un outil en métal pour mettre les éclats de verre de côté.
    • Portez des verres de sécurité pour protéger l'écran et veillez à ne pas abîmer l'écran LCD.
    Yes...wear safety glasses for sure when doing this!
    Josh West - Réponse
    If you have ANY cracks FOR SURE do the tape. I would also make sure to wear safety glasses as it can fly all over even with the tape. And do it somewhere that you don't mind tiny glass shards going everywhere. I had one 3 inch crack in the glass in the lower right corner and it started spidering. The plastic pics don't work once well once they hit a broken point in the glass so you better have a lot of heat to loosen the adhesive, or you end up using an exacto knife to get around the cracked spots.
    jesseokerlund - Réponse
    On a few occasions I had an unexpected pop as the glass shattered and little shards struck me in the face. I had taped the surface but pieces at the edge still managed to break free. My advice: definitely wear the safety glasses, and definitely tape the entire glass surface.
    robertmhussey - Réponse
    Echo jesseokerlund's comments that you will have glass flying. I made the mistake of doing the repair at my kitchen table and had a lot of cleanup to do. The job would be much easier if there was no broken glass, and the hardest part is where the glass is broken right next to the bezel. I used the metal spudger to work those pieces free, but it takes some time.
    + 1 on the safety glass, I almost got hurt while doing this.
    alexisfogel - Réponse
    I followed all the safety precautions mentioned: tape, safety glasses… The best advice I saw on this is to put the iPad in the sun for a few minutes. I placed mine on the windshield of my car in direct sunlight for about 5 minutes. I also used the iOpener to keep heat on the edges I wasn’t working on. I was able to easily remove the glass without any shards flying in about 30-40 minutes total. Great advice and safest way I’ve seen to remove broken glass.
    Robert Jenkins - Réponse
  6. Remplacement de la batterie de l'iPad 3 4G: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    Safety Glasses
    $3.19
    J'achète
    • Encore une fois, comme vous risquez de travailler sur du verre brisé au cours de cette procédure, nous vous recommandons vivement de porter des lunettes de sécurité pour vous protéger contre les éclats de verre.
    • Posez l'iOpener à plat sur le bord droit de l'iPad, en le lissant de sorte à assurer un bon contact entre la surface de l'iPad et l'iOpener.
    • Laissez le sac posé sur l'iPad pendant environ 90 secondes avant d'essayer d'ouvrir le panneau frontal.
    It is ver likely that the glass you are trying to replace is broken, and this is tempered glass therefore it will chatter in many small pieces while you are working on it. Take this safety advice very seriously and protect your eyes!!! The glass pieces fly everywhere. AGAIN: PROTECT YOUR EYES!!!! BE SAFE!!!
    McGiord - Réponse
    This last statement cannot be underemphasized! I got two shards of very fine glass into my right eye, luckily got them out right away, before reaching for the safety goggles! Later on, I removed them again because working w/ the small parts was easier. Protect your eyes, people!
    Lou Bomski -
    Just use some scotch wide transparent tape and cover the broken screen BEFORE you start to taking it apart. It will hold all the shards together and nothing will fly around.
    Vatevaaa -
    I covered the screen in clear packing tape to control glass particles.
    I placed the ipad outside in direct afternoon sunlight for an hour and all of the adhesive was softened quite well.....the screen was off in just a few minutes !
    John - Réponse
    This is a very good idea John, I wish I'd seen this comment before I spent hours picking tiny bits of glass off the glue!
    Tom Scott -
    Thumbs up for this tip. I left it out in the sun for 15 min only and it worked a treat. I used a razor blade. The plastic tools are next to useless.
    olafgoy -
    I had some issues after replacing this cable.
    Once I had it in and back together only the down volume was working, and shortly after the gyro gave out.
    I ended up going to where the new cable connects to the board, removing it, then replacing it as gently as possible. Not too firm.
    I also removed a foam spacer in that area because it was pushed out over the gyro board.
    Now I'm back to full functionality!
    clatekeen - Réponse
    me 2 my volumen up doesn't work and the switch sound/silent any fix?
    Zadd -
    Badly broken screen, taped and warmed about 15 minutes on heating pad set on high. Perfect, gentle, overall warming! Mark the front with Sharpie, ie WiFi, cable, etc. Used thin metal iSes... type tool and guitar pics. BUY NEW Plastic bezel!!! So super cheap. Rewarm on heating pad as necessary. Compressed air helpful to blow away tiny glass bits. Wear glasses! Take breaks! This is easy if you warm carefully and are patient!
    Max - Réponse
    I am in the process of replacing a shattered screen on an iPad 3 wifi, and I literally was removing glass piece by piece! I do recommend having a roll of wide clear sealing tape at hand. Then, when you see loose glass shards, pull off about 4 to 5 inches, and stick the tape to pick up the loose glass, and once in a while, fold the tape onto itself (sticky to sticky side), and set it aside. This helps keep it from getting everywhere. Also, spread news paper under your work. Some people don't really think of these things, but the fact is, hardened glass will find its way into your skin very easily. Extremely sharp!
    dbrown900 - Réponse
    Have not attempted this repair on my wife's iPad 2, but is there a reason that you put the iOpener on top of the device rather than putting the device on top of the iOpener? After all, heat rises.
    Stephen Weber - Réponse
    Can someone please explain which is the right side of the ipad?
    padeacon - Réponse
    loll... that's a good one.
    Alex -
  7. Remplacement de la batterie de l'iPad 3 4G: étape 7, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 7, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 7, image 3 de 3
    • Il y a un petit espace dans l'anneau adhésif de l'iPad, dans le coin supérieur droit de l'iPad à environ 2,0 pouces (~ 5 cm) du haut de l'iPad. Vous allez exploiter cette faiblesse.
    • Alignez l'outil avec le bouton du silencieux. Insérez la pointe d'un outil d'ouverture en plastique dans l'espace entre la vitre frontale et le joint en plastique. Insérez juste la pointe de l'outil d'ouverture, juste assez pour élargir la fissure.
    • Il faudra un peu forcer pour arriver à coincer la pointe de l'outil d'ouverture entre le verre et le plastique. Travaillez patiemment et avec précaution, en agitant l'outil d'ouverture en plastique d'avant en arrière si nécessaire.
    there is the power flex cable near the top right side of the screen. It could be damaged is not careful.
    cli168 - Réponse
    Yes, I severed this one on my first attempt. Might note that you want to start prying open below the sound controls. Additionally I found that a razor was helpful in getting the first pic into the device. Obviously you want to be careful as a razor could cause some serious damage, but I just used the tip of the metal to get some space to fit a pick.
    Nick Dresang - Réponse
    Maybe I was doing it wrong, but the plastic opening tool I was using kept bending before it was prying anything apart. Therefore I suggest using either a metal spudger or a razor blade to make the very first opening but being VERY careful. My assistant/wife later scratched the LCD going overboard with the metal tools.
    Logan Kennedy - Réponse
    There is a way of making the Wifi/Bluetooth Antenna replacement much easier. If you have a steady hand and a soldering iron simply desolder the connecting cable from the bottom of the antenna and solder it back onto the new antenna. This means there is no need to dismantle the iPad and the repair is much faster. Hope this helps :-)
    Richard - Réponse
    The process was pretty straightforward, you do need to be careful in a few spots (like the wifi antenna in the lower right) but overall I found it to be of medium level of difficulty.
    It took me 2.5hrs to slowly dismantle and replace the broken screen.
    Here are some tips I learned while doing it:
    - instead of plastic spudger, better to use kit knife or razor blade. I found plastic to bend and malform quite easily.
    - watch out for lower right corner where wifi antenna sits, it's easy to damage it
    - if you have a cracked screen, use protective goggles - i used tape to secure broken glass pieces together, but that didn't quite work and lots of glass was flying as I was prying the screen off the ipad
    - opening tool you put in the microwave sold here is not worth it - didn't do that great for me. I mostly used a hair drier and was very successful melting adhesive
    - tools I'd only need again to do it again - guitar picks, kit knife, phillips screwdriver, hair drier :D
    Overall, I found it to be quite interesting project!
    michalmotykiewicz - Réponse
    Seconding the problem about plastic components. They just aren't strong / precise enough to fight this glass. Save them for the really nasty bits like the wifi cable, and use an X-Acto or equivalent everywhere else.
    Golden Neckbeard -
    Wish I would have seen your comment before I went through it. Switched to a razor blade and that helped for sure. Thought about a hair dryer as well but stuck with the micro heating tool. Probably should have done the dryer. :-/
    Josh West -
    Had much more success using the metal spudger versus the plastic opening tool that came with the front panel kit.
    Paul Boyer - Réponse
    I had success using Paddle Pop sticks instead of guitar picks. (not sure what they are called in the US). The guitar picks tended to deform and melt with the heat of my hot gun. The glue used to attach the screen is just amazingly strong! It takes a lot of patience to remove all the fragments. I have done about 6 screens now and it is a turdful job!
    Jack - Réponse
    I think we call those popsicle sticks. They seem kind of thick for this, at least a lot thicker than a guitar pick.
    John -
    It is not glue, they use a very strong double sided 3M tape
    Odus182 -
    Pay attention to the Power Button cable located in the upper right corner !!!
    Nathan - Réponse
    Successful battery change but I did sever the cord/ribbon to the power/sleep button. As my iPad had been opened before at a repair shop, I think they put adhesive over the cord as the small section was stuck underneath the LCD, barely visible. So be careful not to put adhesive above that exposed ribbon/cord to the power/sleep button or the next time you open it up, it's severed.
    Breadman - Réponse
    On the iPad 2 I repaired, the opening started at 1 inch and ended at 3mm.
    Justin H - Réponse
    Like others i found the plastic tool pretty useless. Exacto, razor blade, or small metal pick/pry tool works much better to get that first guitar pick inserted. Be careful not to damage the bezel too much. Unless to plan to replace it.
    B Kirkham - Réponse
    If you have an iPAD that has been repaired before note that the adhesive strip might not have an opening by the volume control as shown. I replaced the glass and the new glass had a 2" gap to the left of the Home button only.
    winwoodc - Réponse
    The glass is much thinner than you'd think and I broke mine trying to lever it off before the adhesive has softened enough. Be VERY gentle!
    winwoodc - Réponse
    My plastic opening tool broke in no time flat. Perhaps I was pressing down too hard and not wiggling it enough. But for me I found that the metal spudger was the best tool for the job. I was able to wiggle it while slowly prying up the glass and once it was under the surface of the glass I was able to work it along the edge quite easily. I saw that some people used a razor blade but I would be afraid the blade would break. The metal spudger was just thin enough to do the job well.
    !!!!!!razor-blade & hair-dryer !!!!!!!
    sean blanche - Réponse
    I have found that using these plastic picks, spudgers and edge tools are ineffective as tools for inserting or creating a gap and glue separation action.
    They are just too soft and too thick for this, causing cracks and not able to reach underneath without causing stresses.
    After heating the adhesive with a heat gun (and using cardboard to shield the lcd screen) I have been using a metal round headed scalpel to insert between the glass and bezel, and to very carefully use as an adhesive separation tool at a very oblique angle so as to miss any sensitive cables or components.
    Also, instead of this iTool heating pad and a microwave, they should create an electrically heated shaped pad, this would avoid the constant cooling and reheating and maintain the right temperature.
    G Trieste - Réponse
    Addendum, I have a temperature controlled heat gun, and set it to 180F for this.
    G Trieste - Réponse
    The iOpener works fine, I'm not sure what y'all are talking about. To be fair, you have to press the iOpener into the iPad in order for it to work, which isn't explained well in this tutorial. Wear heat-resistant gloves when you do this, the center portion of the iOpener gets VERY hot. I use a pair of gloves from ACE Hardware. While it takes a bit more effort with the picks, I was able to heat up one side of the iPad, then seperate the adhesive with the picks the rest of the way through.
    I do not recommend using the little blue tool they show above, the part you're supposed to wedge in is way too thick. I use the Jimmy and some opening picks.
    Third image is slightly misleading, you want to go about a centimeter below the volume button.
    Emrys Quick - Réponse
  8. Remplacement de la batterie de l'iPad 3 4G: étape 8, image 1 de 1
    • Assurez-vous de placer l'outil à l'endroit approprié entre le joint de l'écran en plastique et la vitre tactile.
    This visual is helpful. It would be great also to have a diagram of the top of the ipad, marked with "top," "bottom," "left," "right," and then an arrow pointing to each of the problematic areas, such as wifi cable, digitizer cable, etc. It would be easier to see the whole schematic while working rather than scrolling through the instructions and trying to visualize each piece separately. Good to see where to be careful...
    Christa - Réponse
  9. Remplacement de la batterie de l'iPad 3 4G: étape 9, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 9, image 2 de 2
    • En maintenant la pointe de l'outil en plastique coincée entre la vitre frontale et le joint en plastique, glissez un médiator en plastique dans la fente, juste à droite de l'outil en plastique.
    My screen was too broken for this "heat, cut with picks, and leave in place" method to work anywhere but the top, where it was essentially undamaged.
    I wound up using a spudger through all the cracked sections to pry upwards just *inside* the perimeter of the adhesive, intentionally breaking the digitizer and the glass further, until I could remove the entire front panel except for the adhered portions - about half the perimeter in my case.
    I then used tools to pry up the glass from the *opposite* direction, that is the broken interior edge I had earlier created, thus not having to fight the bezel and also having a clear line of sight to any interior components I might be damaging.
    Of course, doing it this way made it much easier to drop tiny shards of glass all over the interior, but I found a little diligent cleaning much easier than trying to keep the glass intact while breaking the glue, as in this guide.
    Golden Neckbeard - Réponse
    I found that using a scraper blade was the easiest way to get under the glass, both for broken and unbroken areas.
    Jeff Snider - Réponse
  10. Remplacement de la batterie de l'iPad 3 4G: étape 10, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 10, image 2 de 2
    • Retirez de l'iPad l'outil en plastique et poussez le médiator plus en avant sous la vitre frontale, à environ 0,5 inches (1,2 cm) du bord.
    It should be noted that the glass can be much more difficult to remove when it is cracked and shattered (as is usually the reason for replacement) . Depending on the location and severity of the cracks, the order and technique of removal requires modification.
    I have found that putting a layer of clear packing tape over the entire screen is helpful, wether it's cracked or not. It will prevent the spraying of glass shards, should the glass break while separating the adhesive; with a broken screen, it should eliminate the risk of cutting yourself during removal, as well as hold all the pieces together. Unfortunately, it also makes the iOpener slightly less effective, so peel it back when applying it. Suction cups can also be helpful during final removal of the glass.
    Having a hot air gun/pencil can be helpful in removing smaller pieces if broken glass that remain once the bulk of it is removed.
    Nick V - Réponse
    Just trashed an I pad... Not an electronics person. Did an iphone 5 battery with no problems was following instructions and once I hit the next step I realized I had already screwed up the screen... Moving forward tring to unhook LCD pictures are not very clear on which direction to push or pull so broke that... Now writing a review on it... Take it to a pro if you aren't certain!
    rondiedonelson - Réponse
    I found that the adhesive could be separated when the pick or spudger was in at a depth of between 1/4" (6.4 mm) and 3/8" (9.5 mm). You can always go back and work it in deeper if you are having trouble separating.
    Yoh but this is not so simple of your screen is shattered to the edges. Basically I had to lift, shatter more, and then pick off the splintered glass with tweezers bit by bit. Patience is a virtue here. I gave up on saving the adhesive and used it to help remove the splinters. I basically removed the edges of the iPad like that and then lift glass off. WEAR SAFETY GLASSES. I would be blind now if I didn’t. wifi antenna -Go slow make sure it’s hot +check what you are doing in the crack. Remove all splinters fromiPad when it’s open. Clean LCD with a microfibre cloth and inside of your new digitizer. When I first reassembled, the home button didn’t work. I reopened and made sure the two gold connectors align with the two spikes on the body. I placed the home button board face down onto the connector spikes with adhesive on the other side, then lowered the digitiser onto it so the board would stick to the digitiser. Notes: forget plastic spudger they’re only place holders, I used a blade knife and metal Spudgers
    Sarah Pegden - Réponse
  11. Remplacement de la batterie de l'iPad 3 4G: étape 11, image 1 de 1
    • Pendant que vous travaillez à ôter l'adhésif sur le côté droit de l'iPad, faites à nouveau chauffer l'iOpener et placez-le sur le bord inférieur de l'iPad.
    I have found that its better to put more than one pick down the side of the screen to keep it open and prevent it from sticking back down.
    Roberto Enrieu - Réponse
    I had a pick in and used the spudger to make some headway but after 10cm the screen cracked. Be very slow and reheat the glue often.
    Alex - Réponse
  12. Remplacement de la batterie de l'iPad 3 4G: étape 12, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 12, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 12, image 3 de 3
    • Pendant que l'iOpener chauffe le bord inférieur, commencez à décoller l'adhésif du bord droit de l'iPad.
    • Faites glisser le médiator vers le bas le long du bord de l'iPad et décollez l'adhésif au fur et à mesure.
    • L'adhésif est très fort et vous devrez forcer autant que nécessaire. Travaillez soigneusement.
    • Si vous voyez que le bout du médiator dépasse du côté de la vitre, tirez-le un peu en arrière. En utilisant le médiator à ce niveau, vous n'endommagerez rien et vous enlèverez les restes de colle sur tout le LCD.
  13. Remplacement de la batterie de l'iPad 3 4G: étape 13, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 13, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 13, image 3 de 3
    • Il sera peut-être nécessaire de reposer l'iOpener chauffé sur le bord droit de l'iPad au cours de la procédure. Cela dépend du temps que l'iPad a pu refroidir pendant que travaillez dessus.
    • Si le médiator reste pris dans l'adhésif, faites-le "pivoter" le long du bord de l'iPad, en continuant ainsi à enlever l'adhésif.
    The volume power button cable is really close to the edge and is frequently loose and non adherent to the frame. If your pick is deep into the iPad, you are almost sure to cut the cable. Be very cautious around the top right corner of the iPad.
    silvain1038 - Réponse
    I absolutely severed this cable when loosening the adhesive around the volume button area. There is really no way of knowing if this cable somewhat elevated from the frame and therefore susceptible to being cut, and it happens to be right where one starts to remove the face with the guitar picks. The cable is directly in from the down volume button, so be extra careful not to put the guitar pick in too far in this area. I recommend buying a power/volume button cable just in case. Replacing this cable is also not easy, but doable. Just try to avoid doing it.
    nickmalmquist - Réponse
    Why not work in reverse to the top edge, and back around to the area where that cable may be unsecured? Haven't don't an iPad (yet, staring one in the face right now) but that would be my alternative so the screen is mostly loose and you could possibly see the cable looking from the now open left side of the glass?
    Matt Needham - Réponse
  14. Remplacement de la batterie de l'iPad 3 4G: étape 14, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 14, image 2 de 2
    • Avant d'enlever le premier médiator du bord inférieur de l'iPad, insérez un deuxième médiator sous le bord droit de la vitre frontale pour l'empêcher de se recoller à l'adhésif.
    • Faites à nouveau chauffer l'iOpener et posez-le sur le bord supérieur de l'iPad.
  15. Remplacement de la batterie de l'iPad 3 4G: étape 15, image 1 de 1
    • Les prochaines étapes nécessitent d'extrêmes précautions.
    • L'antenne Wi-Fi est attachée au bord droit inférieur du boîtier arrière de l'iPad par des vis et un câble. En raison de l'orientation de l'antenne Wi-Fi, il est impératif de procéder avec précaution sous peine d'endommager irréversiblement l'antenne Wi-Fi.
    • Vous devez enlever l'adhésif fixant l'antenne au panneau frontal sans endommager les pièces délicates attachant l'antenne au bas de l'iPad. Suivez soigneusement les prochaines étapes.
    I cut through my wifi cable partially, but it still works (surprisingly). I'd recommend staying well clear of this with the pick. When you go to lift the screen (future step, NOT NOW), use a really good light, start to lift the glass slightly at the corner and you will be able to see the cable. Then you can heat it more and watch the cable as you pull through the adhesive there making sure your not catching the cable.
    B Kirkham - Réponse
    If you heat the sides and top, releasing the adhesive, you can peel the broken glass front panel up from the body and with a little force the bottom comes loose. This avoids working around and damaging the Wi-Fi Antennae.
    Michael Vovaris - Réponse
    I know it is hard to tell from the photo, but the Wi-Fi antenna is kind of like a flap that opens on the right and is attached on the left. So if you use a pick to slide from right to left, the pick might slide under the flap and then sever how it is attached. When I had my pick just to the right of where the Wi-Fi antenna is, I was able to twist my pick a little (like you are tightening a screw) and pry the screen up where the antenna is located. Then I just moved my pick to the left of the antenna and could continue loosening the screen.
    Irreversible damage to the Wi-Fi antenna is nearly unavoidable, but this is not the end of the world since you can pick up a perfectly fine replacement on-line for a few bucks. Many digitizer screen replacement kits include a new WiFi antenna and new bezel since removing the screen without damage to these is also nearly impossible. If your iPad is old enough to need a new battery, and you plan on keeping it thru at least another battery's expected life span, then I would plan on replacing the digitizer screen, bezel, and WiFi antenna as part of the battery replacement. The battery is going to be the most expensive of the set, say around $15 (US), and adding the other three will only add about another $15 (check the prices in ebay, amazon, etc.). Removing the screen often results in damage to the on/off and volume control cable since it too runs along the upper right hand edge of the base right under the screen. If you cut thru this then add another $1 to replace it too.
    Jerry - Réponse
    Based on my experience just (nearly) completing this job on an iPad 2, CDMA, is that the trickiest step is reconnecting the three CDMA antenna cables on the underside of the CDMA chip that is part of the logic board assembly. These are nearly microscopic button connectors (maybe 0.5 mm in diameter). I needed 8X magnification glasses, very bright light, tweezers, and incredible luck to get these reattached. They pop off no problem, but getting them positioned to apply pop-on force takes a LOT of patients! Maybe someone knows a trick to doing this? There’s a similar connector on the WiFi cable but the chip it attaches to can be removed from the logic board so you’re able to manage positioning them interdependently. The CDMA chip is attached (soldered?) to the logic board and the three button connectors are on the underside, and pretty close to one another, so getting all THREE attached and then the logic board in place is a miracle.
    Jerry - Réponse
  16. Remplacement de la batterie de l'iPad 3 4G: étape 16, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 16, image 2 de 2
    • Glissez le médiator dans le coin inférieur droit de l'iPad pour y décoller l'adhésif.
    • Ne glissez pas le médiator plus loin que le coin inférieur droit. Vous endommageriez l'antenne Wi-Fi.
    Be sure to have a replacement Bluetooth Wi-Fi antenna because it is very likely to get the cable broken at this step.
    McGiord - Réponse
    Be extremely careful and patient at this step. Proceed slowly with only the tip ( 1/16th in. - 2mm max.) of the pick. There are two tinny screws that attach the bottom of the antenna to the iPad frame. This antenna part is easly severed if the pick goes too far.
    Happenned to me and had to replace the antenna.
    Marc Bouchard - Réponse
  17. Remplacement de la batterie de l'iPad 3 4G: étape 17, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 17, image 2 de 2
    • Pendant cette étape, vous devez faire glisser le médiator le long du bord inférieur droit du panneau frontal. L'antenne Wi-Fi est très proche du coin et se coupe facilement, si l'adhésif est décollé de façon incorrecte.
    • Ne retirez pas complètement le médiator sous la vitre tactile, mais seulement jusqu'à ce que environ 1/8ème de sa pointe reste en dessous de la vitre tactile.
    • Faites glisser la pointe du médiator le long du bord inférieur de l'iPad pour décoller l'adhésif de l'antenne Wi-Fi.
    I nearly broke my wifi antenna because I didn't read this whole step clearly and didn't go backwards and release the antenna from the front panel. Admittedly, this is my own fault but I've edited the step to make this point more clear.
    My screen was way too shattered for me to be able to use the screen instructions as suggested, so I followed the general principal but ignored the order around, because that simply wouldn't have worked...and destroyed the antenna.
    Maybe step one should be "BE CAREFUL IN THIS CORNER OR YOU WILL BREAK THE ANTENNA!" A diagram highlighting where all the cables (antenna, digitiser, volume, toggle switch) lie with the screen still attached would be helpful too.
    HRB - Réponse
    Or maybe you should have read the entire thing before starting if you were not planing on following it step by step
    Hawesg Garrett -
    I Broke my antenna like many others. It is glued to the glass and has 1mm thick foam backing that is also glued to the inner case. Then there is a tiny grounding connector screwed at the lower edge of the case. Once you can get things loosened up around this antenna, you will need to detach this antenna from the glass. Work at it with your picks or spudger until you get it free, if you do not get it to release from the glass you will break the grounding ribbon. I bought a cheap aftermarket antenna on amazon for $3. turns out it has a bad cable coming from it. I was able to unsolder the cable from the one I broke and solder it to the new antenna.
    chrisnewitt - Réponse
    This BEGS for an Archer "Just The Tip" reference.
    Christian - Réponse
    It wasn't obvious to me at first that I'd broken the antenna. A picture of the antenna that works compared with one that is broken would be useful. Fortunately I'd ordered the replacement part just in case, as suggested.
    I think using extra heat on this spot may make it easier to unstick without breaking the antenna?
    A diagram of what the antenna looks like, from the side, would make it clearer what to do with the pick. You are trying to detach the antenna from the glass, without ripping it off where it's screwed into the bottom of the ipad. Since you can't see what you are doing, and the antenna is quite fragile, that's tricky.
    I think once you've broken one you would know better how to do it. When you slide the pick to the right you need to be sure the pick is moving above the antenna and not snagging on it in any way, and you need to be sure the antenna is completely detached from the glass, so you don't tear it when you lift the glass up.
    Chris Jordan - Réponse
    Can anybody give me a clue as to what the exact part is in step 57, As there are slightly different cables for the ipad 2, Mine is A1395, Thanks.
    Jasper - Réponse
    Another lesson learned while removing the WiFi antenna. The photo shows the iPad laying face up on the table, but to see what you’re doing when detaching the antenna you ‘re better off with the iPad edge up so you can see how the antenna is attached. The antenna is very, very easily broken. To be honest, it’s a lot easier to replace a broken antenna than to try to pry it loose.
    nigel - Réponse
    Please mind that the GSM model has on the upper side left and right from the front camera the 3G antennas. When I removed the broken glass I cut the right one off which I have to fix now.
    st mo - Réponse
  18. Remplacement de la batterie de l'iPad 3 4G: étape 18, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 18, image 2 de 2
    • Une fois que vous avez dépassé l'antenne Wi-Fi (à peu près 7 cm à partir du bord droit ou directement à côté du bouton home), réinsérez complètement le médiator.
    • Faites glisser le médiator vers la droite, pour décoller l'adhésif fixant l'antenne Wi-Fi à la vitre frontale.
    • L'antenne est attachée au bas de l'iPad par des vis et un câble. Au cours de cette étape, vous détachez l'antenne de la vitre frontale. Ainsi vous ne risquerez pas d'endommager l'antenne lorsque vous enlèverez le panneau.
    Be extremely cautious on this step! I did it wrong and my antenna went to !@#$.
    Lars Lien Ankile - Réponse
    Also once it is unattached from the front panel, if the antennas adhesive touches the glass again it can re-adhere to front panel and may rip apart after all. Keep a close eye on it or leave a pick or card in there to prevent it from re-sticking.
    Danny Hartley - Réponse
    Ordering a replacement antenna to anticipate the one you will brake(I should say shred) is probably your smartest move to have a successful repair
    Sebastien CHAPUIS - Réponse
  19. Remplacement de la batterie de l'iPad 3 4G: étape 19, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 19, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 19, image 3 de 3
    • Continuez à décoller l'adhésif le long du bord inférieur de l'iPad, en tirant le médiator vers l'arrière de façon à contourner le bouton home, puis en le réinsérant sur à peu près 1,2 cm de sa longueur une fois le bouton home dépassé.
    • Si l'adhésif s'est trop refroidi le long du bord inférieur, faites à nouveau chauffer l'iOpener pour pouvoir travailler l'adhésif ramolli.
    • Ne faites jamais chauffer l'iOpener plus d'une minute à la fois et attendez toujours au moins deux minutes avant de le remettre à chauffer.
  20. Remplacement de la batterie de l'iPad 3 4G: étape 20, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 20, image 2 de 2
    • Continuez à décoller l'adhésif tout le long du bord inférieur de l'iPad.
    • Si vous avez un iPad 4, insérez au maximum 1,2 cm du médiator dans cette zone pour éviter d'endommager la nappe du bouton home.
    • Laissez le médiator coincé sous la vitre frontale à côté du bouton home.
    This should include details about the Home Button Ribbon Cable. Unlike an iPad 3 (which doesn't have this cable) the iPad 4 has a Home Button Ribbon Cable that runs along the left side of the Home Button and is adhered to the glass. If the guitar pick is inserted too far (more than 0.5") it is possible to damage or sever this cable.
    robjpete - Réponse
    There is a reason this is an iPad 2 Wi-Fi EMC-2560 repair guide. This guide isn't for iPad 3 or 4...
    Christian -
    I think the guides carry common steps between them. I'm reading this string of comments on multiple ipad 3/4 repair guides.
    Anticept - Réponse
    Can I suggest putting the warning in red at the top of the instruction rather than half-way through it? I work from these guides by scrolling through them as I go, and I'd already put the spudger through the ribbon cable before I read the warning!
    spl23 - Réponse
  21. Remplacement de la batterie de l'iPad 3 4G: étape 21, image 1 de 1
    • Faites à nouveau chauffer l'iOpener au micro-ondes et posez-le sur le bord gauche de l'iPad pour faire ramollir l'adhésif à cet endroit.
    I believe this should say to place the iOpener on the top edge, since the instructions go there next.
    lizgoldnm - Réponse
  22. Remplacement de la batterie de l'iPad 3 4G: étape 22, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 22, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 22, image 3 de 3
    • Faites glisser le médiator le long du bord supérieur de l'iPad en le tirant légèrement vers l'extérieur pour contourner le support de la caméra avant.
    • L'adhésif est très épais cet endroit et vous devrez forcer un peu. Progressez soigneusement et lentement en veillant à ni glisser, ni vous blesser, ni endommager votre iPad.
    • Si l'adhésif a trop refroidi, reposez l'iOpener le long du bord supérieur et continuez votre travail. Si l'iOpener a trop refroidi, faites-le à nouveau chauffer.
    • Si le médiator reste coincé dans l'adhésif, faites-le "pivoter" comme expliqué dans l'étape 9.
    In my case I damaged the right GSM antenna which was somehow sticked to the front panel... Be really careful as I really didn't felt that I was damaging anything...
    MattLise Gaillzik - Réponse
    +1 on the right 3g antenna - it is adhered to the glass and I cut right through it with the opening pick. The replacement included adhesive to re-stick it to the glass, so this is a definite feature of this antenna. This is a thin film similar to the wifi antenna, so maybe going around it at a shallow depth from the corner to the camera and then returning to the corner slightly deeper would allow you to separate the antenna from the glass without damaging it.
    doog - Réponse
    Be very careful when going around the front camera, I cracked my screen by prying up too much and causing too much stress!
    Rowdydtk - Réponse
    The GSM component is glued to the screen with different adhesive (more like glue). I managed to not damage this but it was really tricky. The guitar pick is too thick and weak to release this from the screen. Id recommend you wait until you lift the glass (future step, NOT NOW). Then, with a good light you'll see the white plastic adhered to the glass. A thin metal pick or exacto is needed to patiently cut & pry your way through the adhesive. Careful of the camera as your pulling in that direction.
    B Kirkham - Réponse
  23. Remplacement de la batterie de l'iPad 3 4G: étape 23, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 23, image 2 de 2
    • Continuez à décoller l'adhésif le long du bord supérieur de l'iPad et faites glisser le médiator autour du coin supérieur gauche.
    • Si l'adhésif a suffisamment ramolli, enlevez l'iOpener de l'iPad ; ce sera plus pratique. Toutefois, si l'adhésif est encore plutôt visqueux, faites à nouveau chauffer l'iOpener et posez-le sur le bord gauche pendant que vous travaillez.
  24. Remplacement de la batterie de l'iPad 3 4G: étape 24, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 24, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 24, image 3 de 3
    • Faites glisser le médiator le long du bord gauche de l'iPad pour décoller l'adhésif. Tout le long du côté gauche, l'adhésif est mince à cause du numériseur. Assurez-vous que le médiateur ne rentre pas trop profond (1,2 cm max) pour éviter d'endommager le numériseur.
    • La nappe du numériseur est située à environ 5 cm du bas de l'iPad. Arrêtez de glisser le médiator un peu moins de 6 cm avant le bas de l'iPad.
    The second photo does not show the iPad 4's Home Button Ribbon Cable.
    robjpete - Réponse
    Because this is for an iPad 2
    Odus182 -
    @odus182 It says clear as day that this is an iPad 4 guide!
    Mike Enos -
    This is the hardest part the digitizer cable runs the length of this side and u have to be very carefull with the pick . Only go in an 1/8 inch I severed it by going the half (recommended) luckily I had a new screen standing by . I used I opener for heating and it was slow but ok.
    wperrin623 - Réponse
    How do i fix my digitiser if it's broken? Do i need to buy a new iPad screen with digitiser?
    Jenny Le - Réponse
    just ruined my digitiser..any ideas how to fix it?
    dleimonis -
    There is an error in the red text in this step. It says ‘The digitizer cable is located approximately 2" from the bottom of the iPad’. The next sentence says .. ‘Stop sliding the pick when you get ~2.25" from the bottom of the iPad.. This will slice and ruin that cable. The last sentence should read ‘Stop sliding the pick when you get ~1.75" from the bottom of the iPad.’ so you stop cutting glue before you get to the digitizer cable.
    @Jenny & @dleimonis - you can buy the digitizer and new cable by itself if you do not need an LCD also. They are separate parts.
    Jon Lucenius - Réponse
  25. Remplacement de la batterie de l'iPad 3 4G: étape 25, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 25, image 2 de 2
    • Avec le médiator toujours placé sous le bord inférieur de l'iPad, décollez l'adhésif le long du coin inférieur gauche.
    • Le bas de la nappe du numériseur se trouve à seulement ~2,5 cm du bas de l'iPad. Progressez soigneusement et lentement en veillant à ne pas couper la nappe.
    If your screen is broken or shattered there are no worries with the digitizer cable, It is all on the new screen.
    Exactly. I purposely severed mine as it was a complete screen replacement and made the LCD removal easier.
  26. Remplacement de la batterie de l'iPad 3 4G: étape 26, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 26, image 2 de 2
    • Avec un des médiators, soulevez le coin inférieur gauche de l'iPad et saisissez-le de vos doigts.
    • Il est possible que l'adhésif se soit recollé en partie le long du périmètre de l'iPad. Si c'est le cas, faites glisser un médiator sous le bord de l'iPad à l'endroit où la vitre frontale s'est recollée et "coupez" l'adhésif.
    Should be right-hand corner
    longg - Réponse
    Be very careful when pushing the guitar pick around the corner of the power/volume buttons. The ribbon cable for these buttons may be stuck to the adhesive and break when lifting the screen or when sliding the pick along this area. I have done 4 iPad 2 repairs and at least one of the delicate components do not make it. I would recommend ordering a wi-fi/bluetooth antenna, bezel with strips, and a power/volume cable. It is nice to have a "just-in-case" part or two, they are very inexpensive. I noticed that the I tended to break one of these delicate components when the screen was shattered in the area of those components.
    thetechandtutor - Réponse
    At this point it is a good idea to get the packing tape back out and wrap it around 2 or 3 of your fingers making a circle with the sticky on the outside. Make it loose enough you can place your fingers on the table surface to the side and pull your fingers out. When you remove all the tiny parts/screws in the next steps put them on top of the tape so you know exactly where they are when you need them
    windizy - Réponse
  27. Remplacement de la batterie de l'iPad 3 4G: étape 27, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 27, image 2 de 2
    • Saisissez l'iPad par les coins droits inférieur et supérieur et faites pivoter la vitre frontale pour l'éloigner de l'iPad.
    • Vérifiez qu'il n'y ait plus d'adhésif qui colle et coupez avec un médiator tout adhésif maintenant encore la vitre frontale.
    Check to the right of the Home button to see if the wifi/bluetooth antenna is still stuck to the glass side or has released. If it is still stuck to the glass use the guitar pick to carefully scrape it off. If your goal is to replace the antenna, then you needn't be so careful.
    jerry81 - Réponse
    Be very careful not to touch the LCD. It's a pain to remove smudges. One thing that might help when you need to hold it while reattaching it during reassembly: attach a small suction cup to the metal side. That way you can avoid touching the sides where your hand might slip to the LCD side.
    patjmccarthy - Réponse
    Do you need to use some adhesive strips to remount the plastic bezel? The bezel I ordered didn't come with any and the ones you can order only seem to have strips for mounting the glass and not the bezel.
    James - Réponse
    You'd better. The original bezel is glued. You can find 3mm fine/double-sided (black) tape on Amazon. I use it when I replace the bezel because they fit perfectly under the bezel. I use for all sorts of repairs on iPhones, Samsungs, etc. Such as this [one|http://www.amazon.com/gp/product/B005GIS...]
    Rany -
    In order to prevent touching the LCD screen with your finger(s), I use the thin plastic food wrapper to cover it. It will temporary stick to the LCD screen and provide excellent protection from fingerprints.
    Th Th - Réponse
    Very good suggestion. It worked like a charm.
    Laurie Higgins -
    you can use latex gloves to keep smudges and finger prints from the screen. I'm getting ready to repair mine, thanks for all the comments and tips. Btw, I wonder if a vacuum cleaner would work for removing small pieces of glass.
    De Dios sept.10 2014
    dediosjon - Réponse
    where is the connecotr for home button at the ipad 3....i have nothin where i can plug in the flex cable comin from the button
    Georg Heinze - Réponse
    Go slowly as you lift up the glass and be sure that you are not tearing a ribbon cable. When I lifted the glass the digitizer cable was torn and unusable. Perhaps I had cut it with the pick/spudger but it tore completely off when I lifted the glass. Good thing I had purchased the full front panel assembly with the digitizer (IF116-018-3).
    When reassembling I used canned air to blow off dust on the LCD before closing it up.
    You can use a clean soft brush like a make-up brush or small paint brush to brush off the LCD.
    Laurie Higgins - Réponse
    I like how the pictures show an intact screen being removed (although the one in step 4 has a couple of cracks in). I don’t know if anyone would have the luxury of being able to remove a screen in one piece, the ipads I've fixed have been completely smashed pretty much all the way around the outside of the lcd underneath. I used this guide to know where to watch for cables etc - very helpful. I end up using a window scraper/razor to scrape off the glass shards/adhesive around the edge. Glass shards/dust all over the lcd is easy enough to get off but cleaning the lcd after that is a real pain. Does anyone have any suggestions how to clean the lcd properly?
    jmzaj - Réponse
    When reassembling the glass, align the camera first. On the back of the glass there are two pins on the metal camera frame.
    Align them to the camera first, in order to avoid to get a ‘bulge’ visible on the glass or on the back of the iPad.
    Luca Forti - Réponse
    +1 to Luca’s comment. This deserves a RED NOTE for reassembly. I probably just destroyed my new wifi antenna due to not having a reassembly call out for alignment of the screen. Had to pry things back apart and wifi antenna looks like it may have bit the dust. So this is a VERY important bit to know for a first timer.
    Benjamin Pappas - Réponse
    When reinstalling the front panel check the home button’s ribbon cable doesn’t get trapped. If it gets folded back on itself, the cable will break and you’ll have a reassembled iPad with a non-functioning home button.
    nigel - Réponse
  28. Remplacement de la batterie de l'iPad 3 4G, Panneau frontal complet: étape 28, image 1 de 1
    • Retirez les quatre vis cruciformes #00 de 2 mm fixant le LCD au cadre en aluminium.
    End of teardown. Start of disassembling.
    Dorothy Simler - Réponse
    The top left screw may be covered by black adhesive tape.
    Chat Pat - Réponse
    The ribbon cable on my unit was too short to lay it all the way down. I had to let it sit sideways.
    Petabyte Studios - Réponse
  29. Remplacement de la batterie de l'iPad 3 4G: étape 29, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 29, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 29, image 3 de 3
    • A l'aide d'un outil en plastique ou d'une spatule (spudger), soulevez le côté droit du LCD de l'iPad.
    • Faites pivotez le LCD le long de son côté gauche et posez-le sur le panneau frontal.
    • Faites très attention lorsque vous déplacez le LCD. La nappe est fragile et risque de se déchirer si elle est trop fléchie.
    I skipped everything beyond this point and proceeded with the detachment of the battery starting from the right side, one section at a time, with a credit card and a glue remover. I then removed the three screws around the battery connector (on both logic boards) and the one of the battery connector itself. I then lifted the boards up jointly just enough to free the battery connector from the screw hole cylinder that keeps it in place. I then cleaned up and removed all the adhesive from the base, inserted the new battery and glued it to the base. I then put the screws back, mounted the LCD, closed the glass with new adhesive, and powered on. The iPad booted normally and I proceeded with the calibration. I am aware that removing the boards is safer, but if you are careful you save a lot of time disconnecting and reconnecting fragile connectors from the boards.
    Ermanno Bellini - Réponse
  30. Remplacement de la batterie de l'iPad 3 4G, Écran LCD: étape 30, image 1 de 1
    • À l'aide de la pointe d'un spudger, retirez le morceau de ruban adhésif recouvrant le connecteur de la nappe de l'ecran LCD.
    You can actually skip this and go directly to step 37.
    ilconte - Réponse
  31. Remplacement de la batterie de l'iPad 3 4G: étape 31, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 31, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 31, image 3 de 3
    • Retournez le clapet de retenue sur le connecteur ZIF de la nappe de l'écran LCD.
    • Avec vos doigts ou une pincette, tirez la nappe de l'écran LCD tout droit hors de sa prise sur la carte mère.
    • Vous devrez peut-être forcer l'iPad à redémarrer en maintenant enfoncé le bouton de marche et le bouton home pendant au moins dix secondes jusqu'à ce que vous voyiez le logo Apple, si l'écran LCD ne s'allume pas après que vous ayez connecté le connecteur ZIF de l'écran LCD lorsque vous remontez le tout.
    I killed my iPad permanently on this step. The black flap snapped off. The ribbon will not seat in there apparently because now my display is just black. I can hold the Home button down and hear a beep/tone, but there's nothing at all on the display. It's a brick now.
    jimdelrio - Réponse
    x2
    My retainer flap broke before it would move, tried to tape the cable back in place, LCD is totally dead now (wasn't before) even though I heard sounds...
    mikemiller73 - Réponse
    I ran into similar problem and was able to fix it.
    I used a thin mylar piece, cut to the size of the ribbon cable and push it in, on top of the ribbon cable to thicken it.
    Digitizer(Touch screen), Not responding after Tear down.
    Instead of the mylar tape, I re-used the screen protector from an old Nintendo DS and cut it to size. I did not think it would work but it did for me after 4,5 tries. Good luck.
    Th Th - Réponse
    The pictures here are very misleading. The ZIF lock tab is towards the back of the connector - opposite to where the cable comes in. you flip it up and over. The picture here does NOT show the lock tab released! when replacing make sure the white lines go right into the connector - you should almost not see them anymore.
    Mark Smith - Réponse
    As Mark Smith noted the lock on the ZIF connector is at the BACK of the connector, the side FARTHEST from the cable. Put your spudger or opener at the back of the connector and gently pull up while pushing toward the connector. The black bar at the back of the connector will pop up and release pressure on the cable.
    Awfki - Réponse
    The ZIF connector lock is almost impossible to see in the pictures, and even tough to see when you're looking at it. It is a really thin black bar with a hinge on the long edge. As Mark Smith and Awfki stated, pull up gently on the long edge that is opposite the ribbon cable. When inserting the new ribbon cable be sure to get the cable lined up, then push in straight and evenly.
    It IS possible to replace these connectors through a combination of hot air, microsoldering, experience, and talent (full disclosure:I sell replacements on eBay) but quite frankly, it’s a…it’s very difficult. Hiring a technician experienced enough to do it confidently and well will (should) cost you almost as much as the device is worth.
    So try the methods (like tape) that thicken the cable slightly at the point of insertion, so its contacts will make strong downward contact with the connector’s. Then tape the cable down well to keep it from pulling out.
    These solutions rely on recognizing the latch and breaking only it, so the above comments noting the latch’s location are essential.
    Bonnie Baxter - Réponse
    FWIW, the second picture does show the connector’s latch in the “open” position. If what you see at the edge of the connector farthest from where the cable inserts is black, (first picture), the latch is still closed. If instead you can begin to see the metal pins (second picture), it is open. When open it is not even straight up—it is at perhaps 75 degrees from the closed position. Don’t open it too far or with too much force, or the latch will break off.
    The same happened to me. While unplugging the cable I have broken the lock. I realized it only when putting everything back in place. After several attempts I noticed that if I pressed with a finger where the lock was the LCD worked.
    So, I inserted the cable and taped it so that it doesn’t slip out. In the iOpener kit you get some transparent plastic cards (not sure what are they meant for). I cut 2 small pieces the size of the connection and taped them down firmly.
    put everything back in and it worked.
    The lock is there just to make pressure on the connection.
    ronald radioni - Réponse
    Have a look at the iPad 3 WIFI Battery Replacement Video Overview before you try this step. Actually seeing how to flip up the lock before attempting it myself was very helpful.
    Andrew Lusted - Réponse
  32. Remplacement de la batterie de l'iPad 3 4G: étape 32, image 1 de 1
    • Sans toucher l'avant de l'écran LCD, soulevez l'écran LCD du panneau frontal.
  33. Remplacement de la batterie de l'iPad 3 4G, Panneau frontal complet: étape 33, image 1 de 1
    • En utilisant la pointe d'une spatule (spudger), décollez le morceau de ruban adhésif qui fixe la nappe de la vitre tactile à la carte mère.
  34. Remplacement de la batterie de l'iPad 3 4G: étape 34, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 34, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 34, image 3 de 3
    • Retournez le clapet de retenue sur les connecteurs ZIF de la nappe de la vitre tactile.
  35. Remplacement de la batterie de l'iPad 3 4G: étape 35, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 35, image 2 de 2
    • Utilisez l'extrémité plate d'un spudger pour décoller l'adhésif en dessous de la nappe de la vitre tactile.
    • Retirez la nappe de la vitre tactile hors de sa prise sur la carte mère.
  36. Remplacement de la batterie de l'iPad 3 4G: étape 36, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 36, image 2 de 2
    • Décollez la nappe de la vitre tactile et utilisez l'extrémité plate d'un spudger pour retirer l'adhésif qui fixe la nappe à la coque arrière en aluminium.
  37. Remplacement de la batterie de l'iPad 3 4G: étape 37, image 1 de 1
    • Avec vos doigts, ôtez la nappe de la vitre tactile du châssis en aluminium.
    • Retirez le panneau frontal de l'iPad.
    Cheers for the guide.
    After replacing components, when reassembling dose the glue need some heating to bond properly or will a firm squeeze do the trick? Noticed none of the guides have any reassembly tips.
    I had to open mine up again as I had left a protective film on the inside of the new digitiser panel.
    Paul - Réponse
  38. Remplacement de la batterie de l'iPad 3 4G, Nappe de la prise casque: étape 38, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G, Nappe de la prise casque: étape 38, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G, Nappe de la prise casque: étape 38, image 3 de 3
    • Décollez et retirez le morceau de ruban adhésif isolant recouvrant le connecteur de la nappe de la prise casque.
    • En utilisant la pointe d'un spudger, retournez le clapet de retenue de chacun des deux connecteurs ZIF fixant la nappe de la prise casque à la carte mère.
  39. Remplacement de la batterie de l'iPad 3 4G: étape 39, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 39, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 39, image 3 de 3
    • Faites glisser l'extrémité plate d'un spudger sous la nappe de la prise casque, pour décoller l'adhésif la fixant sur le cadre arrière en aluminium.
    • Tirez la nappe de la prise casque tout droit hors de sa prise sur la carte mère.
  40. Remplacement de la batterie de l'iPad 3 4G, Nappe du circuit de la carte SIM: étape 40, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G, Nappe du circuit de la carte SIM: étape 40, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G, Nappe du circuit de la carte SIM: étape 40, image 3 de 3
    • Décollez et retirez le morceau de ruban adhésif recouvrant le connecteur ZIF de la nappe du circuit de la carte SIM.
    • Retournez le clapet de retenue du connecteur ZIF de la nappe du circuit de la carte SIM.
    • En utilisant la pointe d'un spudger, tirez la nappe du circuit de la carte SIM tout droit hors de sa prise sur la carte mère.
    I found it easier to remove the 7 screws first in step 42 then gently pull the logic board towards you freeing the SIM board cable.
    Rich1981 - Réponse
    This cable is really fragile, I found it easier to flip the retaining flap then remove all 7 screws in step 42 then gently pull the logic board toward you freeing the SIM board cable.
    Rich1981 - Réponse
    For me, it was impossible to accomplish this step without first removing the 7 screws from the Logic Board and disconnecting the Logic Board connectors (Wi-Fi, Speaker, Dock/Lightning) at the bottom. Then, I could slide the Logic Board downward just enough to pull free the SIM cable. When reassembling, I attached the 3 antenna connectors first, then the SIM cable, before installing the 7 screws and Logic Board connectors (Wi-Fi, Speaker, Dock/Lightning) at the bottom. Went a bit easier.
    robk64 - Réponse
    Thanks for your advice! Definitely best doing it during step 43!
    coccia.stefano - Réponse
  41. Remplacement de la batterie de l'iPad 3 4G, Ruban adhésif isolant: étape 41, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G, Ruban adhésif isolant: étape 41, image 2 de 2
    • Si présent, retirez les morceaux de ruban adhésif isolant, recouvrant l'antenne Wi-Fi, la nappe du haut-parleur et la nappe du connecteur de dock.
    No, you just need to remove the other piece of electrical tape - the L-shaped to the right of the thumb.
    ilconte - Réponse
  42. Remplacement de la batterie de l'iPad 3 4G, Connecteurs de la carte mère: étape 42, image 1 de 1
    • Débranchez les connecteurs suivants de leur prise respective sur la carte mère :
    • Câble d'antenne Wi-Fi
    • Câble du connecteur du haut-parleur
    • Nappe du connecteur de dock
    • Assurez-vous de faire levier sous le connecteur et non sous la prise même. Le faire sous la prise risque d'endommager gravement votre tablette.
    It is very sensitive the Logic Board Connectors of the Speakers... So it came off to me... So I need some advise to put it back... I am not sure if it was soldier to two points or it is just glue to the main board with the contacts aligned to the mother board contacts... Please I need some advise or help... Thanks
    Eduardo - Réponse
    DO NOT PRY under the speaker connector (under the orange rectangle in the photo). Doing so will pry off the motherboard speaker connector as I and poster above did. The instructions for step is very misleading, telling you to pry EVERYTHING. My motherboard is shot, and now I need to buy another speaker. :-(
    Robert Tau - Réponse
    *EDIT* The proper place to pry is from under the speaker plug, from the edge of the motherboard. I pried under the motherboard speaker connector, which lifted the socket off the motherboard. When in doubt, view the video from iFixit on YouTube. This will show you where to pry. Good luck!
    Robert Tau -
    I ended up prying up the connector, too. Is there any way this can be repaired?
    dave - Réponse
  43. Remplacement de la batterie de l'iPad 3 4G, Carte mère: étape 43, image 1 de 1
    • Retirez les sept vis suivantes, fixant la carte mère à la coque arrière en aluminium.
    • Six vis cruciformes #00 de 2,1 mm
    • Une de ces vis, en haut de la carte mère, est repliée sous la nappe de la prise casque. Veillez à ce que la nappe soit de côté quand vous retirez et remplacez cette vis.
    • Une vis cruciforme #00 de 2,5 mm
    Be sure you follow step 37 and free the headphone jack ribbon cable. I missed that step and found myself puzzling how to get the rightmost screw on the logicboard.
    Haig Keshishian - Réponse
  44. Remplacement de la batterie de l'iPad 3 4G: étape 44, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 44, image 2 de 2
    • En tenant la carte mère par le côté le plus proche du connecteur de dock, tirez soigneusement la carte mère vers le bas de l'iPad.
  45. Remplacement de la batterie de l'iPad 3 4G: étape 45, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 45, image 2 de 2
    • Retournez la carte mère, en faisant attention à tous les câbles susceptibles de rester accrochés.
    • En utilisant la pointe d'un spudger, retirez les trois connecteurs d'antenne de leur prise sur la carte mère.
    Follow these steps for both a speaker replacement, and then a touch screen replacement later on. However when I had to replace the battery, the cable between the main part of the logic board, and the LTE cellular component got ripped. Now the ipad will only stay booted for 1m30s before it reboots itself in a continuous loop. Has anyone seen this problem before?
    bihnx99 - Réponse
    I followed all the steps and I was able to replace a battery and a the screen on my daughter ipad3 but when plugged back in, the ipad goes in a resetting loop. turns on for 7-8 sec turns off for 7-8 sec. I tryed to do a hard reset but the ipad will not stay on to be able to move it fro the wall to the computer.
    I did not shattered or destroyed any cable (as far as I know) and I opened and checked the connections 3 times now and nothing changed. The old battery got destryed in the process so I cant try it on to see id the same things happening. Please somebody help me!
    laura - Réponse
    This same thing happened to me. I ended up holding the power button and home button down until the iPad rebooted. When it powered back up, it was working correctly.
    boboswell -
    If new battery was criticality low in charge, it will boot loop. Put iPad in freezer for 30m and immediately plug to charger when you remove it. Reason: too low % on battery after repairs won't allow to boot so loop occurs and you can't charge a device in a boot loop. Freezer forces an emergency shutdown and will stay off till temperature is normal by then you should have enough charge to boot. Hopefully this helps!
    Danny Hartley -
    The 3 wire connections to the underside of the system board are identical, so you might want to color code them before removal ... get them back in the right place, I think they are for the left and right GSM antennas and maybe the front camera?
    Peter Dearnley - Réponse
    I did not have to remove any of the three antenna connectors while removing the battery just take your time and you can leave the connectors connected.
    Rich1981 - Réponse
    I wish I did what you did.
    Harvey H -
    Dear Peter, does it really matter which socket the 3 wire connections were connected to? I did not mark/color them with any sign!
    Alexandre Bernier - Réponse
    Well…. i am at this stage now, i have lifted the 3 x wire connectors…and have not colored them… I am noticing that the cables leading to the connectors are of different lenghts : the shortest can obviously only fit on the connector which is the closest to the edge of the small board… and the longest should be for the connector which is the furthest away from the edge….
    ptouboul - Réponse
    When reconnecting, getting them to stay in place is a pain. Any suggestions?
    Harvey H - Réponse
  46. Remplacement de la batterie de l'iPad 3 4G, Batterie: étape 46, image 1 de 1
    • La batterie est très fortement collée sur le châssis en aluminium par de l'adhésif puissant et en grande quantité.
    • Dans les étapes suivantes, vous retirerez l'adhésif de dessous la batterie, 5 cm à la fois. Cela empêchera de forcer la batterie.
    • Veillez à ne pas percer ou endommager la batterie lorsque vous l'enlevez de l'iPad. Les piles contiennent des produits chimiques toxiques qui, ingérés ou inhalés, peuvent se révéler nocifs.
    Ifixit please make a better quality metal spudger mine took a beating in this process.
    Rich1981 - Réponse
    The danger of puncturing or breaking open a Lithium Ion battery cannot be emphasized strongly enough. I have first hand experience of trying to leaver out a battery from an iphone 7+ and it literally combusted on the desk I was working on. It was still in the case and fell onto the floor burning like a flare and filling the room and then the house with toxic smoke. I could not believe what I was seeing. Fortunately it burned out very quickly and I wasn’t burned, which was a miracle, unfortunately it destroyed the phone. I hate to think what would happen if you punctured a battery in an iPad . In short be very, very, very careful when trying to remove one of these batteries, take your time, be patient, and use a lot of heat and often to soften the glue
    Sean Wren - Réponse
  47. Remplacement de la batterie de l'iPad 3 4G: étape 47, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 47, image 2 de 2
    • Insérez l'extrémité plate d'un spudger métallique sous la batterie près du fond de l'iPad.
    • Faites glisser le spudger métallique d'environ 3 cm sous la batterie, pour décoller l'adhésif.
    • L'adhésif est très fort. Le faire céder nécessite une force considérable. Travaillez lentement et soigneusement, en veillant à ce que le spudger métallique ne glisse pas.
    I do not recommend to remove the battery with the metal spudger.
    A used credit or customer card is the better way
    Andre Pankalla - Réponse
    we here at pctechnologygroup use a 12” steel ruler to slide under the battery it helps to put iPad on heating mat to soften adhesive, we also put label remover on the ruler to cut through the tape
    richardjgreen - Réponse
    using a spatula is also a good option
    Jonas Fischer - Réponse
    I agree about the spatula—it’s strong and rigid. The long narrow ones that short-order cooks use are thinner and have a sharp edge. Also, you can use the iOpener, the heating pad you used to open the touchscreen. Put the iPad on top of the iOpener, so that it lies under whichever strip of glue you’re currently prying apart. It’s much more effective than it was with the glass screen, because the metal case conducts heat right to the glue.
    Brian Pickrell - Réponse
  48. Remplacement de la batterie de l'iPad 3 4G: étape 48, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 48, image 2 de 2
    • De la même manière que décrit ci-dessus, faites glisser le spudger d'environ 5 cm sous les autres bandes adhésives.
  49. Remplacement de la batterie de l'iPad 3 4G: étape 49, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 49, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 49, image 3 de 3
    • Faites glisser soigneusement le spudger métallique sous le connecteur de la batterie, pour décoller l'adhésif le fixant en place.
  50. Remplacement de la batterie de l'iPad 3 4G: étape 50, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 50, image 2 de 2
    • Continuez à décoller l'adhésif près du haut de la batterie.
  51. Remplacement de la batterie de l'iPad 3 4G: étape 51, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 51, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 51, image 3 de 3
    • À l'endroit où vous vous êtes arrêté, insérez le spudger métallique de 5 cm sous la batterie.
    • Quand vous poussez le spudger plus loin sous la batterie, maintenez-le à plat contre la coque arrière pour éviter de plier la batterie.
    • Répétez ce processus pour les autres bandes adhésives.
  52. Remplacement de la batterie de l'iPad 3 4G: étape 52, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 52, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 52, image 3 de 3
    • De la même manière que décrit précédemment, continuez à décoller l'adhésif de toutes les bandes jusqu'à une profondeur d'environ 10 cm.
  53. Remplacement de la batterie de l'iPad 3 4G: étape 53, image 1 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 53, image 2 de 3 Remplacement de la batterie de l'iPad 3 4G: étape 53, image 3 de 3
    • Pour décoller la dernière section, poussez le spudger métallique jusqu'au bord droit de l'iPad.
    • Continuez de le faire pour toutes les bandes adhésives.
  54. Remplacement de la batterie de l'iPad 3 4G: étape 54, image 1 de 2 Remplacement de la batterie de l'iPad 3 4G: étape 54, image 2 de 2
    • Assurez-vous que toute la colle adhésive a été détachée de la batterie.
    • Soulevez doucement le côté gauche de la batterie, en la faisant pivoter vers le côté droit de l'iPad.
    • Utilisez le spudger métallique pour enlever tout adhésif qui pourrait toujours retenir la batterie en place.
    • Retirez la batterie de l'iPad.
    Hello, just wondering, what type of glue or adhesive should I use when puttion it back to new housing? Thanks
    pendejo - Réponse
    Just completed ipad 3 battery replacement. I might have killed the cellular connectivity because I got a missing sim card warning, which is no big deal because I never use it. I would put this as one of the most difficult fix it jobs I have done. During screen removal, I killed the super thin, black plastic bezel, and put a tiny micro crack in the front glass. After inflicting this damage, I decided, in for a penny in for a pound, and purchased both from iFixit and got quick delivery. Now I have an iPad with a decent battery and will try to get a couple more years out of it. If I had this job to do over and someone was willing to do it for $100, I would pay, but it always fun to fix something yourself.
    chuckcappetta - Réponse
    That’s a nasty and still potentially hazardous battery to dispose of. A word here about what to do with it for disposal would be a nice addition.
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
82 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Brett Hartt
Membre depuis le 04/12/10
127 941 Réputation
143 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 299 tutoriels rédigés
9 commentaires
Finally finished the battery replacement successfully. I had bought a replacement battery someone other the ifixit. (mistake). After finally finishing the replacement, the battery would not charge. So I took the whole ipad apart again to assure the battery was making contact with the circuit board. Reassembled....same problem. Installed a new and different battery and now all is working. So, I disassembled and re-assembled 3 times. I can do it easily now.
Here are some lessons learned:
1.) To remove the screen, the best advice is it set the ipad in the sun for about 10 minutes. This really does most of the hard work for you removing the adhesive. DON'T leave it too long! It really absorbs the heat. Then use the IOpener
2.) Re-assembly the 4G model step 44 is really difficult! I wish I had some advise before doing the work.
3.) Don't SEAL the screen back in place UNTIL you have tried to recharge the battery and assure all is working.
Timothy Wills - Réponse
Thanks !
I wish i had looked at this post before :).
I’m half-way into the process , and i have already a lesson learned : beware of the bottom left corner of the scree : be VERY cautious when detaching the screen at this very point, as there are high chances to cut the connector to the motherboard…
ptouboul -
Is the original adhesive still strong enough after the screen has been removed or do you need to remove the old adhesive and apply new adhesive?
Simon Vandenberghe - Réponse
Did you get a response to this question ?
ptouboul -
Did this repair along with a new wifi antenna and digitizer screen. Guides were all excellent!
What do we need to glue the New battery down how much should we use
Jeremy cortese - Réponse
i replaced the battery and now nothing works
dsookoo - Réponse
i tried holding the home and power button no success..i tried connecting it to my mac book pro it is not coming up
dsookoo - Réponse
It worked!! Just followed the guide, took my time and was patient. Realized half way through that I had the 4G version instead of the Wi-Fi version of the iPad 3 (thanks mom…sheesh) Took a bit of doing but got everything out, got the new battery in…had to remove the headphone jack board along the top of the iPad to get the 3 connector pins to fit back into the logic board and futzed for half an hour to get one screw back in…but it worked. Everything came back together easily and plugged it in and it powered up no problem!!! So jazzed!!
Lawrence Lee - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 28
30 derniers jours : 175
Total : 98,309
