Introduction
Consultez ce tutoriel pour retirer et remplacer le haut-parleur de votre iPhone 13 Pro Max.
Ce dont vous avez besoin
Éteignez votre iPhone avant de commencer à le démonter.
Dévissez les deux vis Pentalobe P2 de 6,8 mm de long en bas de l'écran de l'iPhone.
Mesurez 3 mm à partir de la pointe et tracez une ligne sur le médiator avec un marqueur permanent.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
Déposez des couches de ruban adhésif se superposant les unes les autres sur l'écran de l'iPhone, jusqu'à le recouvrir entièrement.
Si vous ne parvenez pas à faire adhérer la ventouse pendant les étapes suivantes, pliez un morceau du ruban adhésif robuste (de l'adhésif entoilé p.e.) pour en faire une poignée et soulevez l'écran avec, à la place de la ventouse.
Outil utilisé dans cette étape :Clampy - Anti-Clamp$24.95
Tirez la poignée bleue vers l'arrière pour déverrouiller les bras de l'Anti-Clamp.
Faites glisser les bras autour du bord droit ou gauche de votre iPhone.
Positionnez les ventouses près du bord inférieur de l'iPhone - une à l'avant et une à l'arrière.
Appuyez sur les ventouses pour appliquer la pression sur la zone souhaitée.
Éloignez la poignée bleue de la charnière pour enclencher le mode d'ouverture.
Tournez la poignée dans le sens des aiguilles d'une montre jusqu'à ce que les ventouses commencent à s'étirer.
Assurez-vous que les ventouses restent alignées. Si elles commencent à se désaligner en glissant, relâchez un peu la tension sur les ventouses et réalignez-les.
Posez votre iPhone à plat sur un objet stable comme un livre à couverture rigide. Ainsi, il sera plus facile à manipuler au cours des étapes suivantes.
Avec un sèche-cheveux, chauffez le long du bord inférieur de l'iPhone. L'écran doit être légèrement trop chaud au toucher.
Attendez une minute pour laisser à l'adhésif le temps de céder et d'ouvrir un espace.
Insérez un médiator sous l'écran lorsque l'Anti-Clamp a créé un espace assez large.
Sautez les trois étapes suivantes.
À l'aide d'un sèche-cheveux ou d'un pistolet à air chaud, chauffez le bord inférieur de l'iPhone pendant 90 secondes, ou jusqu'à ce que l'écran soit légèrement trop chaud pour être touché.
Appliquez une ventouse sur le bord inférieur du téléphone, en évitant le bord du verre.
Tirez sur la ventouse en exerçant une pression ferme et constante, pour créer un léger espace entre l'écran et le châssis.
Insérez un médiator dans l'espace sous le joint en plastique de l'écran.
Utilisez un sèche-cheveux pour chauffer le bord droit de l'iPhone (le bord avec le bouton de marche) pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud pour être touché.
Faites glisser le médiator autour du coin inférieur droit de l'iPhone, pour séparer son adhésif.
Progressez le long du bord droit de l'iPhone jusqu'à atteindre le coin supérieur droit.
Laissez le médiator dans le coin supérieur droit avant de continuer.
Utilisez un sèche-cheveux pour chauffer le bord supérieur de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud pour être touché.
Faites glisser le médiator autour du coin supérieur droit de l'iPhone, pour séparer son adhésif.
Laissez le médiator dans le coin supérieur gauche avant de continuer.
Utilisez un sèche-cheveux pour chauffer le bord gauche de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud pour être touché.
Insérez un second médiator dans le coin inférieur gauche de l'iPhone.
Faites tourner les deux médiators simultanément, jusqu'à ce que les clips du bord gauche se détachent.
Retirez la ventouse de l'écran.
Tournez l'iPhone de façon que le bord droit est face à vous.
Ouvrez votre iPhone en faisant pivoter le côté droit de l'écran vers le haut, comme la couverture d'un livre.
Appuyez l'écran contre quelque chose pour le maintenir en hauteur pendant que vous travaillez sur le téléphone.
Utilisez un tournevis Y000 pour retirer les trois vis de 1,3 mm qui fixent le cache du connecteur de la batterie.
Utilisez l'extrémité pointue d'une spatule (spudger) ou un ongle propre pour soulever le connecteur de la batterie de sa prise sur la carte mère.
Pliez légèrement le connecteur pour l'éloigner de la carte mère, afin d'éviter qu'il n'entre accidentellement en contact avec la prise et qu'il n'alimente le téléphone pendant votre réparation iPhone.
Utilisez l'extrémité pointue d'une spatule ou un ongle propre pour soulever le connecteur de l'écran de sa prise sur la carte mère.
Utilisez un tournevis Y000 pour retirer les deux vis de 1,1 mm du cache du connecteur des capteurs frontaux.
Utilisez un tournevis cruciforme pour retirer les deux vis restantes du cache des capteurs frontaux :
Une vis de 1,5 mm
Une vis de 1,8 mm
Prenez un tournevis cruciforme pour dévisser les quatre vis de 1,5 mm qui fixent le haut-parleur :
Deux vis à tête moyenne
Deux vis à petite tête
Faites glisser un médiator entre le bord supérieur du Taptic Engine et la bande en plastique recouverte d'adhésif.
Décollez délicatement la bande en plastique recouverte d'adhésif du haut-parleur.
Comparez votre nouvelle pièce de rechange à la pièce d'origine, il se peut que vous ayez besoin de transférer des composants restants ou de retirer des films adhésifs de la nouvelle pièce avant l'installation.
Pour remonter votre appareil, suivez les étapes ci-dessus dans l'ordre inverse.
Déposez vos déchets électroniques dans un centre de recyclage certifié.
Consultez nos conseils basiques de diagnostic ou la section iPhone 13 Pro Max de notre Forum pour obtenir de l'aide.
6 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Claire Miesch nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
your website is really useful. Thanks a million :)
Sam, great detail and clear photos but I wanted to see all sides of the loudspeaker and didn’t see them. Could you add more loudspeaker pictures to your post?
Are waterproof seals part of the replacement kit, if not why?
Jim Langston - Réponse
I ordered the screwdriver for the 13 ProMax (Y000) as well as the full kit which has this Y000 head. Neither tip works to remove the screws. Any suggestions?
Barbara Nuckles - Réponse
