Aller au contenu principal
Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058
Ce dont vous avez besoin
Vidéo d'introduction
  1. Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058, Panneau arrière: étape 1, image 1 de 1
    • Posez l'iMac, côté écran, sur une surface plane et propre.
    • Desserrez les trois vis cruciformes qui fixent le panneau arrière à l'iMac.
    • Ces vis sont captives dans l'iMac. La vis centrale s'arrête de tourner après environ 3,5 tours et les vis extérieures après environ 5,5 tours. N'essayez pas de retirer ces vis de votre iMac.
    My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
    In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
    paulfrancoeur - Réponse
    The two outer screws each drive a locking bar that engage tabs on the rear panel.
    They definitely need to be unscrewed.
    Dale Stanbrough -
    That chick MJ is sexy!!!!!
    djmadcracker - Réponse
    Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
    Terry Mullane - Réponse
    Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
    James Janota - Réponse
    Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
    mary nicolazzo - Réponse
    These are the easiest way to resolve the Wireless connectivity at my home. Thanks ifixit for sharing this.
    Geek Squad - Réponse
  2. Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 2, image 1 de 3 Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 2, image 2 de 3 Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 2, image 3 de 3
    • Soulevez légèrement le panneau arrière depuis le bord inférieur de l'iMac.
    • Tirez le panneau arrière vers vous et retirez-le de l'iMac.
  3. Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058, Bloc d'alimentation: étape 3, image 1 de 2 Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058, Bloc d'alimentation: étape 3, image 2 de 2
    • Tournez la vis cruciforme centrale située au bas de l'iMac dans le sens des aiguilles d'une montre jusqu'à ce que le dispositif d'attache du panneau arrière entre en contact avec le bord du boîtier.
    • Sur notre machine, la partie filetée du dispositif s'est cassée du corps de la pince, ce qui fait que la vis centrale tourne sans déplacer le support. Si votre machine est cassée comme la nôtre, passez directement à l'étape suivante.
  4. Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 4, image 1 de 3 Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 4, image 2 de 3 Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 4, image 3 de 3
    • Tout en appuyant sur le verrou du connecteur, insérez l'extrémité plate d'une spatule solide (heavy duty spudger) dans l'espace entre le connecteur d'alimentation et son socle.
    • Tournez la spatule pour séparer légèrement le connecteur de son socle.
    • Il sera nécessaire de travailler en alternant les côtés jusqu'à ce que le connecteur soit libre.
    • Il se peut que le câble du capteur de luminosité ambiante soit relié à votre alimentation et à la carte mère. Si c'est le cas, utilisez avec précaution une spatule pour pousser le câble vers vous en utilisant alternativement les côtés du câble pour vous aider à le faire glisser.
  5. Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 5, image 1 de 1
    • Retirez le connecteur du bloc d'alimentation électrique de son socle sur la carte mère.
    • Cette étape est très simple si vous retirez d'abord l'alimentation électrique.
  6. Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 6, image 1 de 1
    • Retirez les trois vis cruciformes qui fixent le bloc d'alimentation au châssis.
    • Les trois vis sont captives dans le bloc d'alimentation.
    • Pour faciliter le retrait, il peut être utile de soulever légèrement la vis centrale pour la détacher du plan médian.
  7. Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 7, image 1 de 2 Remplacement du bloc d'alimentation de l'iMac G5 17" modèle A1058: étape 7, image 2 de 2
    • Plusieurs condensateurs sont montés sur la carte mère à proximité de l'alimentation. Essayez de ne pas les déranger, car ils sont délicats et peuvent se détacher de la carte.
    • Saisissez le bloc d'alimentation par les côtés et tournez son bord supérieur vers vous jusqu'à ce qu'il détache de la carte mère.
    • Soulevez le bloc d'alimentation pour le sortir du plan médian.
    • Le retrait du bloc d'alimentation nécessite une force importante. Vous devrez peut-être plier légèrement le bord du boîtier avant vers vous afin d'obtenir un espace suffisant pour retirer le bloc d'alimentation.
    Bend the case at the rear panel clamp enough to clear the panel clamp while lifting out the power supply using the two captive screws as handles.
    timothychilders - Réponse
    Rolling the power supply towards you while lifting using the captive screws helps get it past the captive back cover screw from step 4.
    themackey - Réponse
    My replacement power supply did not come with an Ambient Light Sensor. I thought I had gotten the wrong one, but in fact the ALS comes easily off the old power supply (using a small flathead screwdriver to pry it off) and attaches to the new one.
    Calion - Réponse
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
35 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Un commentaire
very clear instructions... will replace my ps and then repair the faulty one.
do you have an idea what components usually fail or is it a mix of things?
Thanks
r@boarman.net
Irene1545 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 11
Total : 33,719
