Aller au contenu principal
iPad 6 Wi-Fi Left Speaker Replacement
Ce dont vous avez besoin
  1. iPad 6 Wi-Fi Left Speaker Replacement, Heat the left edge: étape 1, image 1 de 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 6 Wi-Fi Left Speaker Replacement, Screen removal information: étape 2, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Screen removal information: étape 2, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Screen removal information: étape 2, image 3 de 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 6 Wi-Fi Left Speaker Replacement, Anti-Clamp instructions: étape 3, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Anti-Clamp instructions: étape 3, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Anti-Clamp instructions: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Clamp
    $24.95
    J'achète
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 6 Wi-Fi Left Speaker Replacement: étape 4, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 4, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 4, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 6 Wi-Fi Left Speaker Replacement: étape 5, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 5, image 2 de 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 6 Wi-Fi Left Speaker Replacement, Insert an opening pick: étape 6, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Insert an opening pick: étape 6, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Insert an opening pick: étape 6, image 3 de 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 6 Wi-Fi Left Speaker Replacement, Separate the left adhesive: étape 7, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the left adhesive: étape 7, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the left adhesive: étape 7, image 3 de 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 6 Wi-Fi Left Speaker Replacement: étape 8, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 8, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 8, image 3 de 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 6 Wi-Fi Left Speaker Replacement: étape 9, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 9, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 9, image 3 de 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 6 Wi-Fi Left Speaker Replacement, Heat the top edge: étape 10, image 1 de 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 6 Wi-Fi Left Speaker Replacement, Separate the top left adhesive: étape 11, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the top left adhesive: étape 11, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the top left adhesive: étape 11, image 3 de 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 6 Wi-Fi Left Speaker Replacement, Separate the top adhesive: étape 12, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the top adhesive: étape 12, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the top adhesive: étape 12, image 3 de 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 6 Wi-Fi Left Speaker Replacement: étape 13, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 13, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 13, image 3 de 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 6 Wi-Fi Left Speaker Replacement: étape 14, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 14, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 14, image 3 de 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 6 Wi-Fi Left Speaker Replacement, Heat the right edge: étape 15, image 1 de 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 6 Wi-Fi Left Speaker Replacement, Separate the top right adhesive: étape 16, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the top right adhesive: étape 16, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the top right adhesive: étape 16, image 3 de 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 6 Wi-Fi Left Speaker Replacement, Separate the right adhesive: étape 17, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the right adhesive: étape 17, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the right adhesive: étape 17, image 3 de 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 6 Wi-Fi Left Speaker Replacement, Heat the bottom edge: étape 18, image 1 de 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 6 Wi-Fi Left Speaker Replacement, Separate the bottom left adhesive: étape 19, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the bottom left adhesive: étape 19, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the bottom left adhesive: étape 19, image 3 de 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 6 Wi-Fi Left Speaker Replacement, Separate the bottom adhesive: étape 20, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the bottom adhesive: étape 20, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the bottom adhesive: étape 20, image 3 de 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 6 Wi-Fi Left Speaker Replacement: étape 21, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 21, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 21, image 3 de 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 6 Wi-Fi Left Speaker Replacement: étape 22, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 22, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 22, image 3 de 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 6 Wi-Fi Left Speaker Replacement, Heat the right edge: étape 23, image 1 de 1
  24. iPad 6 Wi-Fi Left Speaker Replacement: étape 24, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 24, image 2 de 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 6 Wi-Fi Left Speaker Replacement: étape 25, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 25, image 2 de 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 6 Wi-Fi Left Speaker Replacement, Separate the right adhesive: étape 26, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the right adhesive: étape 26, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Separate the right adhesive: étape 26, image 3 de 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 6 Wi-Fi Left Speaker Replacement: étape 27, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 27, image 2 de 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 6 Wi-Fi Left Speaker Replacement, LCD: étape 28, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, LCD: étape 28, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, LCD: étape 28, image 3 de 3
    • Remove any tape obscuring the LCD screws.
  29. iPad 6 Wi-Fi Left Speaker Replacement: étape 29, image 1 de 1
    • Remove the four Phillips #00 4.3 mm screws securing the LCD.
  30. iPad 6 Wi-Fi Left Speaker Replacement: étape 30, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 30, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 30, image 3 de 3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
  31. iPad 6 Wi-Fi Left Speaker Replacement, Battery connector information: étape 31, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Battery connector information: étape 31, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Battery connector information: étape 31, image 3 de 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 6 Wi-Fi Left Speaker Replacement: étape 32, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 32, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 32, image 3 de 3
    • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 6 Wi-Fi Left Speaker Replacement: étape 33, image 1 de 1
    • Remove the three 1.4 mm Phillips #000 screws from the display cable bracket.
  34. iPad 6 Wi-Fi Left Speaker Replacement: étape 34, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 34, image 2 de 2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  35. iPad 6 Wi-Fi Left Speaker Replacement: étape 35, image 1 de 1
    • Remove the LCD.
  36. iPad 6 Wi-Fi Left Speaker Replacement, Front Panel Assembly: étape 36, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement, Front Panel Assembly: étape 36, image 2 de 2
    • Remove any tape covering the home button ribbon cable connector.
  37. iPad 6 Wi-Fi Left Speaker Replacement: étape 37, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 37, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 37, image 3 de 3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
  38. iPad 6 Wi-Fi Left Speaker Replacement: étape 38, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 38, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 38, image 3 de 3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    • During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
  39. iPad 6 Wi-Fi Left Speaker Replacement: étape 39, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 39, image 2 de 2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  40. iPad 6 Wi-Fi Left Speaker Replacement: étape 40, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 40, image 2 de 2
    Polyimide Tape
    $9.99
    J'achète
    • Remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  41. iPad 6 Wi-Fi Left Speaker Replacement, Left Antenna: étape 41, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement, Left Antenna: étape 41, image 2 de 2
    • Insert a spudger under the right antenna cable closest to the edge of the iPad and lift upward to disconnect the antenna cable connector.
  42. iPad 6 Wi-Fi Left Speaker Replacement: étape 42, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 42, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 42, image 3 de 3
    • There are two large pieces of tape wrapped around the right antenna cable, covering the left antenna cable's tape.
    • Peel the tape up from the rear case.
  43. iPad 6 Wi-Fi Left Speaker Replacement: étape 43, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 43, image 2 de 2
    • Insert a spudger under the left antenna cable, the connector farthest from the edge of the iPad. Lift upward to disconnect the antenna cable connector.
  44. iPad 6 Wi-Fi Left Speaker Replacement: étape 44, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 44, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 44, image 3 de 3
    • There are six pieces of tape wrapped around the left antenna cable, securing it to the rear case.
    • Use tweezers to gently peel up each piece of tape, freeing the antenna cable as you go.
  45. iPad 6 Wi-Fi Left Speaker Replacement: étape 45, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 45, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 45, image 3 de 3
    • There is a bracket crimped onto the antenna cable that is adhered to the speaker enclosure. The adhesive must be severed in order to extract the antenna.
    • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
    • Slide the pick to the right to cut the adhesive.
    • Push the bracket away from the speaker to clear it of the tape under it.
  46. iPad 6 Wi-Fi Left Speaker Replacement: étape 46, image 1 de 1
    • Remove the following Phillips #000 screws:
    • Two 1.4 mm screws
    • One 2.3 mm screw
  47. iPad 6 Wi-Fi Left Speaker Replacement: étape 47, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 47, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 47, image 3 de 3
    • Insert the flat end of a spudger between the antenna and the speaker assembly.
    • Slide the spudger toward the home button recess to cut the foam adhesive securing the antenna.
  48. iPad 6 Wi-Fi Left Speaker Replacement: étape 48, image 1 de 1
    • Remove the left antenna from the iPad.
  49. iPad 6 Wi-Fi Left Speaker Replacement, Left Speaker: étape 49, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Left Speaker: étape 49, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement, Left Speaker: étape 49, image 3 de 3
    • Peel the tape toward the home button to uncover the speaker cable connector.
    • Be sure to only peel the tape—not the speaker ribbon cable.
  50. iPad 6 Wi-Fi Left Speaker Replacement: étape 50, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 50, image 2 de 2
    • Use the pointed end of a spudger to flip up the retaining flap on the left speaker cable connector.
  51. iPad 6 Wi-Fi Left Speaker Replacement: étape 51, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 51, image 2 de 2
    • Slide the speaker cable straight out of its ZIF connector.
  52. iPad 6 Wi-Fi Left Speaker Replacement: étape 52, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 52, image 2 de 2
    • Remove the tape holding the speaker to the rear case.
  53. iPad 6 Wi-Fi Left Speaker Replacement: étape 53, image 1 de 1
    • Remove the 2.2 mm Phillips #000 screw securing the speaker to the rear case.
  54. iPad 6 Wi-Fi Left Speaker Replacement: étape 54, image 1 de 2 iPad 6 Wi-Fi Left Speaker Replacement: étape 54, image 2 de 2
    • Fold the speaker cable up slightly.
  55. iPad 6 Wi-Fi Left Speaker Replacement: étape 55, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 55, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 55, image 3 de 3
    • Insert a fingernail in the groove in the speaker housing near the corner of the rear case.
    • Pull the speaker down away from the corner of the case.
  56. iPad 6 Wi-Fi Left Speaker Replacement: étape 56, image 1 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 56, image 2 de 3 iPad 6 Wi-Fi Left Speaker Replacement: étape 56, image 3 de 3
    • Use a spudger to help pull the speaker out from under the edge of the rear case.
    • Remove the left speaker from the iPad.
Arthur Shi
Membre depuis le 01/03/18
253 452 Réputation
526 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 198 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 21
Total : 1,170
