Introduction
Follow this guide to remove or replace the rear camera in your iPad Air 4.
If your battery is swollen, take appropriate precautions.
Some photos in this guide show the screen disconnected and fully removed. This isn't necessary for the procedure, so this guide skips those steps. If you wish to remove the screen, follow this guide.
Ce dont vous avez besoin
Apply a heated iOpener to the left edge of the screen for two minutes.
Camera module and ambient light sensors
Display cables
Screen magnets
Display edges
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next step.
Apply a suction handle to the top left edge of the screen.
Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
Insert the tip of an opening pick into the gap.
Leave the pick in to prevent the adhesive from re-sealing.
Insert a new opening pick in the gap you just created.
Slide the opening pick along the left edge to separate the adhesive.
Leave the pick in the bottom left corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Insert a new opening pick in the bottom left corner.
Slide the opening pick along the bottom edge to separate the adhesive.
Leave the pick in the bottom right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the right edge of the screen for two minutes.
Insert a new opening pick in the bottom right corner and slide along the right edge to separate the adhesive. Make sure to note the following marked areas:
Don't insert an opening pick more than 2 mm or you'll damage the screen magnets.
Don't insert an opening pick more than 3 mm or you'll damage the display and digitizer cables.
Don't insert an opening pick more than 5 mm or you'll damage the display edges.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
Insert a new opening pick in the top right corner and slide along the top edge to separate the adhesive. Make sure to note the following:
Don't insert an opening pick more than 3 mm or you'll damage the ambient light sensors.
Don't insert an opening pick more than 2 mm or you'll damage the front camera module.
Leave the pick in the top left corner to prevent the adhesive from re-sealing.
Grip the left edge of the screen and fold it open like a book.
Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
Cut two 6 mm wide strips from a playing card or cardstock to use as a battery blocker.
Insert the card strips on each side of the battery connector until they stop.
Use a Phillips screwdriver to remove the 1.8 mm screw securing the rear camera cable bracket to the frame.
Use tweezers or your fingers to remove the rear camera cable bracket.
Use the flat end of a spudger to pry up and disconnect the rear camera press connector.
Lay the iPad screen side down.
Apply a heated iOpener to the rear camera for two minutes to weaken the adhesive.
Lay the iPad screen side up.
Use the flat end of a spudger to pry up the rear camera.
Remove the rear camera.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 4 answers community for help.
