Aller au contenu principal
Remplacement de la batterie de l'iPhone XS
Anglais
Français
Traduction de l’étape 11
Étape 11
iPhone XS Battery Replacement, Alternative method to unstick the battery from the case: étape 0, image 1 de 3 iPhone XS Battery Replacement, Alternative method to unstick the battery from the case: étape 0, image 2 de 3 iPhone XS Battery Replacement, Alternative method to unstick the battery from the case: étape 0, image 3 de 3
  • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
  • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
  • Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
  • Wear gloves to protect your fingers, or wrap each end of the string around a tool.
  • Pull the string from side to side in a sawing motion to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
  • Start from the top or bottom edge of the battery, and pull toward the middle. Don't pull the string through the middle third of the battery, or you may damage the ribbon cables or the wireless charging coil directly underneath.
  • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
Si une des bandes adhésives s'est déchirée et que la batterie reste coincée dans la coque arrière, préparez un iOpener ou servez-vous d'un sèche-cheveux afin de chauffer la coque arrière derrière la batterie.
Chauffez l'iPhone jusqu'à ce que la coque arrière soit légèrement trop chaude au toucher. Ne surchauffez par l'iPhone, la batterie risquerait de prendre feu.
Retournez l'iPhone et faites glisser une ficelle solide (du fil dentaire ou une fine corde de guitare par exemple) sous la batterie.
Portez des gants pour protéger vos doigts ou enroulez les extrémités de la ficelle autour d'un outil.
Tirez la ficelle d'un côté puis de l'autre avec un mouvement de scie pour faire céder l'adhésif. Cela risque de prendre du temps, car l'adhésif cède lentement. Soyez patient et vous en viendrez à bout. Ne déformez ni endommagez la batterie.
Commencez en haut ou en bas de la batterie et progressez vers le milieu. Ne faites pas passer la ficelle sous le tiers central de la batterie, vous pourriez endommager les nappes ou la bobine de recharge sans fil, qui se trouvent juste en dessous.
Si vous choisissez d'utiliser des outils à levier pour soulever la batterie hors de l'iPhone, faites extrêmement attention, car vous risquez d'endommager les nappes ou la bobine de recharge sans fil, qui se trouvent juste au-dessous de la batterie.
