Aller au contenu principal
Remplacement de la batterie de l'iPhone 7 Plus
Anglais
Français
Traduction de l’étape 4
Étape 4
iPhone 7 Plus Battery Replacement: étape 0, image 1 de 3 iPhone 7 Plus Battery Replacement: étape 0, image 2 de 3 iPhone 7 Plus Battery Replacement: étape 0, image 3 de 3
  • If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s).
  • After about a minute, gently lift the battery.
  • Do not insert your spudger in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
  • Do not pry against the logic board or you may damage the phone.
  • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • If the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. It should be slightly too warm to touch comfortably.
  • Overheating the iPhone may ignite the battery.
  • A piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set. Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
Si une des bandes adhésive s'est cassée et que la batterie reste collée à la coque arrière, retirez la en déposant quelques goutes d'alcool isopropylique (90 % ou plus) sous la batterie, près de la ou des bandes adhésives déchirées.
Après environ une minute, soulevez délicatement la batterie.
N'insérez pas la carte entre le bouton moins (-) de volume et le coin supérieur de la batterie, ou vous risquez d'endommager la carte de contrôle du volume qui se trouve en dessous.
Ne vous appuyez pas contre la carte mère, ou vous risquez d'endommager le téléphone.
N'essayez pas de forcer sur la batterie. Si besoin, appliquez quelques gouttes d'alcool afin d'affaiblir encore l'adhésif. Ne déformez ni percez la batterie avec votre outil.
Si la batterie reste bloquée dans la coque arrière, préparez votre iOpener ou utilisez un sèche-cheveux afin de chauffer la coque arrière directement derrière la batterie. Elle devrait être légèrement trop chaude au toucher.
Surchauffer l'iPhone risque de faire prendre feu à la batterie.
Du fil dentaire peut être utilisé pour séparer la batterie. Une alternative plus forte est une corde de guitare déroulée, la corde 0.009 E d'une guitare à 12 cordes par exemple. Glissez le fil ou la corde derrière les coins supérieurs de la batterie, rapprochez les extrémités du segment, enroulez-les autour d'un morceau de tissu et tirez doucement.
