Aller au contenu principal
La batterie ne se recharge pas
L’appareil est connecté au chargeur et à une prise de courant, mais ne se recharge pas.
La batterie s’est dégradée avec le temps.
L’entrée micro USB est endommagée.
  • Suivez ce tutoriel pour remplacer le connecteur micro USB.
The speaker is blown out/has low sound quality.
The speaker produces fuzzy or broken audio.
The volume was too loud and vibrations created a crack in the speaker.
The device or speaker overheated, destroying the speaker.
Aux connection won’t play any sound at all.
Aux connections to other devices yield no audio.
The connector short-circuited due to water damage.
  • The white casing portion of the device will have to be replaced. Follow the Aux Replacement Guide to complete this task.
The connector was physically damaged or has debris in it.
  • Attempt to clean out the aux connection with a small q-tip. If that fails, then the device will have to be opened and cleaned or replaced. Follow the Aux Replacement Guide for a detailed walkthrough.
The device won’t connect to other devices via Bluetooth or won’t function properly overall.
The motherboard has a short circuit or other damage.
The motherboard has water damage.
The device was dropped and has internal physical damage.
The buttons are not operating properly.
When a button is pushed it gets stuck or the device does not properly respond to it.
Debris is lodged in the button membrane
Button membrane is damaged.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Je commence à traduire ›
338 commentaires
When I turn my jbl charge on, the power button starts blinking red,blue, red, blue and never connects. I need help
Chris sanchez - Réponse Partager
Im having the same problem.. Have you managed to find a fix?
Fadhillah Ibrahim - Réponse Partager
I am having the same problem! This is ridiculous. It's been just a month I have this headphones and barely used it. Not cheap either!
Manuela Simeonova - Réponse Partager
red blue/ red blue light means , it's ready to connect and is now visible as a bluetooth device
Cherokee Summer - Réponse Partager
There is a RESET available that fixed my flashing blue/red , no connect issue.
Hold down POWER and VOL DOWN until reset. There will be a light sequence, RED RED RED BLUE BLUE BLUE … RED RED BLUE BLUE .. RED BLUE … OFF.
Turn it back on and its reset. Thats if your buttons work.
Al Al - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 60
30 derniers jours : 206
Total : 843,645
