Aller au contenu principal
iPad 8 LTE Battery Replacement
Ce dont vous avez besoin
  1. iPad 8 LTE Battery Replacement, Heat the left edge: étape 1, image 1 de 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 8 LTE Battery Replacement, Screen removal information: étape 2, image 1 de 3 iPad 8 LTE Battery Replacement, Screen removal information: étape 2, image 2 de 3 iPad 8 LTE Battery Replacement, Screen removal information: étape 2, image 3 de 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 8 LTE Battery Replacement, Anti-Clamp instructions: étape 3, image 1 de 3 iPad 8 LTE Battery Replacement, Anti-Clamp instructions: étape 3, image 2 de 3 iPad 8 LTE Battery Replacement, Anti-Clamp instructions: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Clamp
    $24.95
    J'achète
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 8 LTE Battery Replacement: étape 4, image 1 de 3 iPad 8 LTE Battery Replacement: étape 4, image 2 de 3 iPad 8 LTE Battery Replacement: étape 4, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 8 LTE Battery Replacement: étape 5, image 1 de 2 iPad 8 LTE Battery Replacement: étape 5, image 2 de 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 8 LTE Battery Replacement, Insert an opening pick: étape 6, image 1 de 3 iPad 8 LTE Battery Replacement, Insert an opening pick: étape 6, image 2 de 3 iPad 8 LTE Battery Replacement, Insert an opening pick: étape 6, image 3 de 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 8 LTE Battery Replacement, Separate the left adhesive: étape 7, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the left adhesive: étape 7, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the left adhesive: étape 7, image 3 de 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 8 LTE Battery Replacement: étape 8, image 1 de 3 iPad 8 LTE Battery Replacement: étape 8, image 2 de 3 iPad 8 LTE Battery Replacement: étape 8, image 3 de 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 8 LTE Battery Replacement: étape 9, image 1 de 3 iPad 8 LTE Battery Replacement: étape 9, image 2 de 3 iPad 8 LTE Battery Replacement: étape 9, image 3 de 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 8 LTE Battery Replacement, Heat the top edge: étape 10, image 1 de 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 8 LTE Battery Replacement, Separate the top left adhesive: étape 11, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the top left adhesive: étape 11, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the top left adhesive: étape 11, image 3 de 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 8 LTE Battery Replacement, Separate the top adhesive: étape 12, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the top adhesive: étape 12, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the top adhesive: étape 12, image 3 de 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 8 LTE Battery Replacement: étape 13, image 1 de 3 iPad 8 LTE Battery Replacement: étape 13, image 2 de 3 iPad 8 LTE Battery Replacement: étape 13, image 3 de 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 8 LTE Battery Replacement: étape 14, image 1 de 3 iPad 8 LTE Battery Replacement: étape 14, image 2 de 3 iPad 8 LTE Battery Replacement: étape 14, image 3 de 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 8 LTE Battery Replacement, Heat the right edge: étape 15, image 1 de 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 8 LTE Battery Replacement, Separate the top right adhesive: étape 16, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the top right adhesive: étape 16, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the top right adhesive: étape 16, image 3 de 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 8 LTE Battery Replacement, Separate the right adhesive: étape 17, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the right adhesive: étape 17, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the right adhesive: étape 17, image 3 de 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 8 LTE Battery Replacement, Heat the bottom edge: étape 18, image 1 de 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 8 LTE Battery Replacement, Separate the bottom left adhesive: étape 19, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the bottom left adhesive: étape 19, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the bottom left adhesive: étape 19, image 3 de 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the corner before moving to the next step.
  20. iPad 8 LTE Battery Replacement, Separate the bottom adhesive: étape 20, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the bottom adhesive: étape 20, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the bottom adhesive: étape 20, image 3 de 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 8 LTE Battery Replacement: étape 21, image 1 de 3 iPad 8 LTE Battery Replacement: étape 21, image 2 de 3 iPad 8 LTE Battery Replacement: étape 21, image 3 de 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 8 LTE Battery Replacement: étape 22, image 1 de 3 iPad 8 LTE Battery Replacement: étape 22, image 2 de 3 iPad 8 LTE Battery Replacement: étape 22, image 3 de 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 8 LTE Battery Replacement, Heat the right edge: étape 23, image 1 de 1
  24. iPad 8 LTE Battery Replacement: étape 24, image 1 de 2 iPad 8 LTE Battery Replacement: étape 24, image 2 de 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 8 LTE Battery Replacement: étape 25, image 1 de 2 iPad 8 LTE Battery Replacement: étape 25, image 2 de 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 8 LTE Battery Replacement, Separate the right adhesive: étape 26, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the right adhesive: étape 26, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the right adhesive: étape 26, image 3 de 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 8 LTE Battery Replacement: étape 27, image 1 de 2 iPad 8 LTE Battery Replacement: étape 27, image 2 de 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 8 LTE Battery Replacement, Remove the screw covers: étape 28, image 1 de 3 iPad 8 LTE Battery Replacement, Remove the screw covers: étape 28, image 2 de 3 iPad 8 LTE Battery Replacement, Remove the screw covers: étape 28, image 3 de 3
    • Use tweezers, or your fingers, to remove any tape covering the LCD screws.
  29. iPad 8 LTE Battery Replacement, Unfasten the LCD screen: étape 29, image 1 de 2 iPad 8 LTE Battery Replacement, Unfasten the LCD screen: étape 29, image 2 de 2
    • Use a Phillips screwdriver to remove the four 4.3 mm screws securing the LCD screen.
  30. iPad 8 LTE Battery Replacement, Separate the LCD's adhesive: étape 30, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the LCD's adhesive: étape 30, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the LCD's adhesive: étape 30, image 3 de 3
    • The LCD is lightly adhered to the frame.
    • Insert a spudger between the frame and the top-right portion of the LCD.
    • Pry slowly with the spudger to separate the adhesive.
  31. iPad 8 LTE Battery Replacement: étape 31, image 1 de 2 iPad 8 LTE Battery Replacement: étape 31, image 2 de 2
    • Repeat the previous step for the top-left portion of the LCD.
  32. iPad 8 LTE Battery Replacement, Reposition the LCD screen: étape 32, image 1 de 3 iPad 8 LTE Battery Replacement, Reposition the LCD screen: étape 32, image 2 de 3 iPad 8 LTE Battery Replacement, Reposition the LCD screen: étape 32, image 3 de 3
    • Don't attempt to fully remove the LCD during this step, as it's still connected by a flex cable.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
    • Lay the LCD on a clean, soft, lint-free surface to allow access to the display cables.
  33. iPad 8 LTE Battery Replacement, Disconnect the battery: étape 33, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the battery: étape 33, image 2 de 2
    • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
  34. iPad 8 LTE Battery Replacement, Battery connector information: étape 34, image 1 de 3 iPad 8 LTE Battery Replacement, Battery connector information: étape 34, image 2 de 3 iPad 8 LTE Battery Replacement, Battery connector information: étape 34, image 3 de 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  35. iPad 8 LTE Battery Replacement, Disconnect the battery: étape 35, image 1 de 3 iPad 8 LTE Battery Replacement, Disconnect the battery: étape 35, image 2 de 3 iPad 8 LTE Battery Replacement, Disconnect the battery: étape 35, image 3 de 3
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
  36. iPad 8 LTE Battery Replacement, Unfasten the display cable bracket: étape 36, image 1 de 2 iPad 8 LTE Battery Replacement, Unfasten the display cable bracket: étape 36, image 2 de 2
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
  37. iPad 8 LTE Battery Replacement, Remove the display cable bracket: étape 37, image 1 de 2 iPad 8 LTE Battery Replacement, Remove the display cable bracket: étape 37, image 2 de 2
    • Use tweezers, or your fingers, to remove the display cable bracket.
  38. iPad 8 LTE Battery Replacement, Disconnect the LCD screen: étape 38, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the LCD screen: étape 38, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side.
    • Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  39. iPad 8 LTE Battery Replacement, Remove the LCD: étape 39, image 1 de 2 iPad 8 LTE Battery Replacement, Remove the LCD: étape 39, image 2 de 2
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
  40. iPad 8 LTE Battery Replacement, Disconnect the home button: étape 40, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the home button: étape 40, image 2 de 2
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
  41. iPad 8 LTE Battery Replacement: étape 41, image 1 de 2 iPad 8 LTE Battery Replacement: étape 41, image 2 de 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
  42. iPad 8 LTE Battery Replacement: étape 42, image 1 de 2 iPad 8 LTE Battery Replacement: étape 42, image 2 de 2
    • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
  43. iPad 8 LTE Battery Replacement, Disconnect the display cables: étape 43, image 1 de 3 iPad 8 LTE Battery Replacement, Disconnect the display cables: étape 43, image 2 de 3 iPad 8 LTE Battery Replacement, Disconnect the display cables: étape 43, image 3 de 3
    • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  44. iPad 8 LTE Battery Replacement, Remove the vibration isolator: étape 44, image 1 de 3 iPad 8 LTE Battery Replacement, Remove the vibration isolator: étape 44, image 2 de 3 iPad 8 LTE Battery Replacement, Remove the vibration isolator: étape 44, image 3 de 3
    • Use the flat end of a spudger to pry up the vibration isolator below the SIM card reader.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the vibration isolator.
  45. iPad 8 LTE Battery Replacement: étape 45, image 1 de 3 iPad 8 LTE Battery Replacement: étape 45, image 2 de 3 iPad 8 LTE Battery Replacement: étape 45, image 3 de 3
    • Use a pair of tweezers to peel the home button cable away from the rear case.
    • The cable is secured with some light adhesive.
  46. iPad 8 LTE Battery Replacement, Remove the front panel assembly: étape 46, image 1 de 3 iPad 8 LTE Battery Replacement, Remove the front panel assembly: étape 46, image 2 de 3 iPad 8 LTE Battery Replacement, Remove the front panel assembly: étape 46, image 3 de 3
    Polyimide Tape
    $9.99
    J'achète
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  47. iPad 8 LTE Battery Replacement, Eject the SIM card tray: étape 47, image 1 de 2 iPad 8 LTE Battery Replacement, Eject the SIM card tray: étape 47, image 2 de 2
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • Press firmly to eject the SIM card tray.
  48. iPad 8 LTE Battery Replacement: étape 48, image 1 de 2 iPad 8 LTE Battery Replacement: étape 48, image 2 de 2
    • Remove the SIM card tray from the iPad.
  49. iPad 8 LTE Battery Replacement, Remove the upper component bracket: étape 49, image 1 de 2 iPad 8 LTE Battery Replacement, Remove the upper component bracket: étape 49, image 2 de 2
    • Carefully peel the LCD buffer tape up off of the upper component bracket.
  50. iPad 8 LTE Battery Replacement: étape 50, image 1 de 1
    • Use a Phillips screwdriver to remove the five screws securing the upper component bracket:
    • Three 1.4 mm-long screws
    • Two 1.9 mm-long screws
  51. iPad 8 LTE Battery Replacement: étape 51, image 1 de 3 iPad 8 LTE Battery Replacement: étape 51, image 2 de 3 iPad 8 LTE Battery Replacement: étape 51, image 3 de 3
    • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
    • Remove the upper component bracket.
    • You may need to peel the upper component bracket off of some tape securing it to the logic board.
  52. iPad 8 LTE Battery Replacement, Disconnect the front camera: étape 52, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the front camera: étape 52, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the front camera cable press connector.
  53. iPad 8 LTE Battery Replacement, Remove the front camera: étape 53, image 1 de 3 iPad 8 LTE Battery Replacement, Remove the front camera: étape 53, image 2 de 3 iPad 8 LTE Battery Replacement, Remove the front camera: étape 53, image 3 de 3
    • Use a spudger to lift the front camera out of its recess until you can grip it with your fingers.
    • Use the spudger to pull the adhesive foam pad away from the front camera.
  54. iPad 8 LTE Battery Replacement: étape 54, image 1 de 3 iPad 8 LTE Battery Replacement: étape 54, image 2 de 3 iPad 8 LTE Battery Replacement: étape 54, image 3 de 3
    • Use a pair of tweezers to grip the front camera and rotate it clockwise to thread the cable through its slot in the frame.
    • Remove the front camera.
  55. iPad 8 LTE Battery Replacement, Disconnect the top connectors: étape 55, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the top connectors: étape 55, image 2 de 2
    • Use the flat end of a spudger to disconnect the headphone jack by lifting straight up on the press connector.
  56. iPad 8 LTE Battery Replacement: étape 56, image 1 de 2 iPad 8 LTE Battery Replacement: étape 56, image 2 de 2
    • Use a pair of tweezers to peel the headphone jack up from the logic board and reposition the cable.
  57. iPad 8 LTE Battery Replacement, Remove the right cellular antenna screws: étape 57, image 1 de 2 iPad 8 LTE Battery Replacement, Remove the right cellular antenna screws: étape 57, image 2 de 2
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the cellular antennas to the rear case.
  58. iPad 8 LTE Battery Replacement, Disconnect the cellular antennas: étape 58, image 1 de 3 iPad 8 LTE Battery Replacement, Disconnect the cellular antennas: étape 58, image 2 de 3 iPad 8 LTE Battery Replacement, Disconnect the cellular antennas: étape 58, image 3 de 3
    • Use the pointed end of a spudger to disconnect the right cellular antenna coaxial cable by prying up as close to the connector as possible.
    • Disconnect the left antenna cable.
  59. iPad 8 LTE Battery Replacement: étape 59, image 1 de 3 iPad 8 LTE Battery Replacement: étape 59, image 2 de 3 iPad 8 LTE Battery Replacement: étape 59, image 3 de 3
    • Peel the left cellular antenna coaxial cable away from the rear case.
    • Grip the antenna cable by the cable itself and not at its connector. Pulling coaxial cables by their connectors can break them.
  60. iPad 8 LTE Battery Replacement: étape 60, image 1 de 3 iPad 8 LTE Battery Replacement: étape 60, image 2 de 3 iPad 8 LTE Battery Replacement: étape 60, image 3 de 3
    • Use the flat end of a spudger to disconnect both cellular antennas by lifting straight up on their press connectors.
  61. iPad 8 LTE Battery Replacement, Disconnect the rear camera: étape 61, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the rear camera: étape 61, image 2 de 2
    • Use the flat end of a spudger to disconnect the rear camera by lifting straight up on the press connector.
  62. iPad 8 LTE Battery Replacement, Disconnect the microphone assembly: étape 62, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the microphone assembly: étape 62, image 2 de 2
    • Use the flat end of a spudger to disconnect the microphone assembly by lifting straight up on the press connector.
  63. iPad 8 LTE Battery Replacement, Disconnect the button control cable: étape 63, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the button control cable: étape 63, image 2 de 2
  64. iPad 8 LTE Battery Replacement: étape 64, image 1 de 2 iPad 8 LTE Battery Replacement: étape 64, image 2 de 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable ZIF connector.
  65. iPad 8 LTE Battery Replacement: étape 65, image 1 de 2 iPad 8 LTE Battery Replacement: étape 65, image 2 de 2
    • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
    • Grab the cable by the pull tab and not the cable itself.
  66. iPad 8 LTE Battery Replacement, Disconnect the Smart Cover sensor: étape 66, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the Smart Cover sensor: étape 66, image 2 de 2
    • Peel off any tape covering the Smart Cover sensor cable ZIF connector.
  67. iPad 8 LTE Battery Replacement: étape 67, image 1 de 2 iPad 8 LTE Battery Replacement: étape 67, image 2 de 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Smart Cover sensor cable ZIF connector.
  68. iPad 8 LTE Battery Replacement: étape 68, image 1 de 2 iPad 8 LTE Battery Replacement: étape 68, image 2 de 2
    • Use a pair of tweezers to carefully pull the Smart Cover sensor cable straight out of the ZIF connector.
  69. iPad 8 LTE Battery Replacement, Disconnect the SIM card reader: étape 69, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the SIM card reader: étape 69, image 2 de 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the SIM card reader cable ZIF connector.
  70. iPad 8 LTE Battery Replacement: étape 70, image 1 de 2 iPad 8 LTE Battery Replacement: étape 70, image 2 de 2
    • Use a pair of tweezers to carefully pull the SIM card reader cable straight out of the ZIF connector.
  71. iPad 8 LTE Battery Replacement, Disconnect the antennas: étape 71, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the antennas: étape 71, image 2 de 2
    • Insert the pointed end of a spudger under the right antenna cable and lift straight up to disconnect it.
  72. iPad 8 LTE Battery Replacement: étape 72, image 1 de 3 iPad 8 LTE Battery Replacement: étape 72, image 2 de 3 iPad 8 LTE Battery Replacement: étape 72, image 3 de 3
    • Peel up the right antenna cable.
  73. iPad 8 LTE Battery Replacement, Disconnect the left antenna: étape 73, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the left antenna: étape 73, image 2 de 2
    • Insert the pointed end of a spudger under the left antenna cable and lift straight up to disconnect it.
  74. iPad 8 LTE Battery Replacement: étape 74, image 1 de 3 iPad 8 LTE Battery Replacement: étape 74, image 2 de 3 iPad 8 LTE Battery Replacement: étape 74, image 3 de 3
    • Peel the left antenna cable away from the rear case, along the bottom edge of the iPad.
  75. iPad 8 LTE Battery Replacement, Remove the vibration isolator: étape 75, image 1 de 3 iPad 8 LTE Battery Replacement, Remove the vibration isolator: étape 75, image 2 de 3 iPad 8 LTE Battery Replacement, Remove the vibration isolator: étape 75, image 3 de 3
    • Use the flat end of a spudger to pry up the vibration isolator at the bottom left corner of the iPad.
    • Use a pair of tweezers to remove the vibration isolator.
  76. iPad 8 LTE Battery Replacement, Disconnect the speakers: étape 76, image 1 de 3 iPad 8 LTE Battery Replacement, Disconnect the speakers: étape 76, image 2 de 3 iPad 8 LTE Battery Replacement, Disconnect the speakers: étape 76, image 3 de 3
    • Use a pair of tweezers or your fingernail to peel up the tape covering the speaker connectors.
  77. iPad 8 LTE Battery Replacement: étape 77, image 1 de 3 iPad 8 LTE Battery Replacement: étape 77, image 2 de 3 iPad 8 LTE Battery Replacement: étape 77, image 3 de 3
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on both the left and right speaker cable ZIF connectors.
  78. iPad 8 LTE Battery Replacement: étape 78, image 1 de 3 iPad 8 LTE Battery Replacement: étape 78, image 2 de 3 iPad 8 LTE Battery Replacement: étape 78, image 3 de 3
    • Use a pair of tweezers to carefully pull the left and right speaker cables straight out of their respective ZIF connectors.
  79. iPad 8 LTE Battery Replacement, Disconnect the Smart Connector: étape 79, image 1 de 2 iPad 8 LTE Battery Replacement, Disconnect the Smart Connector: étape 79, image 2 de 2
    • Use the pointed end of a spudger to disconnect the Smart Connector coaxial cable by prying up as close to the connector as possible.
  80. iPad 8 LTE Battery Replacement: étape 80, image 1 de 2 iPad 8 LTE Battery Replacement: étape 80, image 2 de 2
    • Use a pair of tweezers to disconnect the Smart Connector cable connector by lifting straight up.
  81. iPad 8 LTE Battery Replacement: étape 81, image 1 de 2 iPad 8 LTE Battery Replacement: étape 81, image 2 de 2
    • Use a pair of tweezers to peel back the tape securing the Smart Connector cables to the rear case.
  82. iPad 8 LTE Battery Replacement, Reposition the Smart Connector cable: étape 82, image 1 de 3 iPad 8 LTE Battery Replacement, Reposition the Smart Connector cable: étape 82, image 2 de 3 iPad 8 LTE Battery Replacement, Reposition the Smart Connector cable: étape 82, image 3 de 3
    • Peel the Smart Connector cables away from the rear case.
  83. iPad 8 LTE Battery Replacement, Loosen the adhesive: étape 83, image 1 de 1
    • Heat an iOpener and apply it to the bottom left corner of the rear case to soften the SIM card tray's adhesive for thirty seconds.
  84. iPad 8 LTE Battery Replacement, Remove the SIM card reader: étape 84, image 1 de 2 iPad 8 LTE Battery Replacement, Remove the SIM card reader: étape 84, image 2 de 2
    • Use an opening tool to pry up on the bottom edge of the SIM card reader with a slow and steady force.
    • If the SIM card reader feels extra stuck, apply more heat and try again.
  85. iPad 8 LTE Battery Replacement: étape 85, image 1 de 2 iPad 8 LTE Battery Replacement: étape 85, image 2 de 2
    • Remove the SIM card reader.
  86. iPad 8 LTE Battery Replacement, Unfasten the charging port: étape 86, image 1 de 2 iPad 8 LTE Battery Replacement, Unfasten the charging port: étape 86, image 2 de 2
    • Use a Phillips screwdriver to remove the four screws securing the charging port to the frame:
    • Two 2.2 mm-long screws
    • Two 3.2 mm-long screws
  87. iPad 8 LTE Battery Replacement, Loosen the adhesive: étape 87, image 1 de 3 iPad 8 LTE Battery Replacement, Loosen the adhesive: étape 87, image 2 de 3 iPad 8 LTE Battery Replacement, Loosen the adhesive: étape 87, image 3 de 3
    • Heat an iOpener and apply it to the bottom, top, and logic board side of the iPad for thirty seconds in each location.
  88. iPad 8 LTE Battery Replacement, Separate the charging port cable's adhesive: étape 88, image 1 de 3 iPad 8 LTE Battery Replacement, Separate the charging port cable's adhesive: étape 88, image 2 de 3 iPad 8 LTE Battery Replacement, Separate the charging port cable's adhesive: étape 88, image 3 de 3
    • Insert an opening pick under the charging port cable near the charging port and slide it towards the logic board to cut the adhesive.
  89. iPad 8 LTE Battery Replacement, Remove the charging port: étape 89, image 1 de 2 iPad 8 LTE Battery Replacement, Remove the charging port: étape 89, image 2 de 2
    • Pull the charging port out of its slot in the frame.
  90. iPad 8 LTE Battery Replacement, Remove the logic board: étape 90, image 1 de 3 iPad 8 LTE Battery Replacement, Remove the logic board: étape 90, image 2 de 3 iPad 8 LTE Battery Replacement, Remove the logic board: étape 90, image 3 de 3
    • Insert an opening pick under the upper arm of the logic board and slide it toward the logic board to cut the adhesive securing it to the rear case.
    • Leave the opening pick inserted to keep the adhesive from re-adhering.
  91. iPad 8 LTE Battery Replacement: étape 91, image 1 de 2 iPad 8 LTE Battery Replacement: étape 91, image 2 de 2
    • Remove the battery blocker.
  92. iPad 8 LTE Battery Replacement: étape 92, image 1 de 2 iPad 8 LTE Battery Replacement: étape 92, image 2 de 2
    • Insert an opening tool near the bottom of the logic board and pry up with a slow and steady force to peel it away from the rear case.
    • Bending or warping the logic board could lead to permanent damage. If the adhesive feels extra stubborn, apply more heat and try again.
    • Slide an opening pick underneath the bottom edge of the logic board to slice some of the adhesive if your logic board won't budge.
  93. iPad 8 LTE Battery Replacement: étape 93, image 1 de 2 iPad 8 LTE Battery Replacement: étape 93, image 2 de 2
    • Insert an opening tool near the middle of the logic board and pry up with a slow and steady force to peel it away from the rear case.
    • Take care leveraging against the battery with the tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
  94. iPad 8 LTE Battery Replacement: étape 94, image 1 de 2 iPad 8 LTE Battery Replacement: étape 94, image 2 de 2
    • Insert an opening tool near the top of the logic board and pry up with a slow and steady force to peel it away from the rear case.
  95. iPad 8 LTE Battery Replacement: étape 95, image 1 de 3 iPad 8 LTE Battery Replacement: étape 95, image 2 de 3 iPad 8 LTE Battery Replacement: étape 95, image 3 de 3
    • Insert an opening tool near the middle of the logic board and pry up until you can grip it with your fingers.
  96. iPad 8 LTE Battery Replacement: étape 96, image 1 de 3 iPad 8 LTE Battery Replacement: étape 96, image 2 de 3 iPad 8 LTE Battery Replacement: étape 96, image 3 de 3
    • Use a halberd spudger or an opening pick to slice any remaining adhesive securing the logic board to the frame.
  97. iPad 8 LTE Battery Replacement: étape 97, image 1 de 1
    Tesa 61395 Tape
    $5.99
    J'achète
    • Remove the logic board.
    • During reassembly, ensure that there are no ribbon cables stuck under the logic board before gluing it down.
    • During reassembly, clean off any remaining adhesive with high-strength isopropyl alcohol (90% or greater) and apply strips of Tesa tape to secure the Logic Board to the chassis.
  98. iPad 8 LTE Battery Replacement, Protect the other components: étape 98, image 1 de 3 iPad 8 LTE Battery Replacement, Protect the other components: étape 98, image 2 de 3 iPad 8 LTE Battery Replacement, Protect the other components: étape 98, image 3 de 3
    • Before removing the battery, it's important to protect the other components in the rear case by covering them with tape.
    • Cut a strip of painter's tape or Scotch tape to the width of the iPad.
    • Press the bottom edge of the tape strip onto the rear case above the speakers and bottom antennas.
    • Run your finger along the bottom edge of tape strip to ensure a good seal.
    • Press the top edge of the tape strip over the bottom components to keep any cables from intruding on the battery removal.
  99. iPad 8 LTE Battery Replacement: étape 99, image 1 de 2 iPad 8 LTE Battery Replacement: étape 99, image 2 de 2
    • Repeat the taping procedure for the upper components.
  100. iPad 8 LTE Battery Replacement, Protect your eyes and skin: étape 100, image 1 de 2 iPad 8 LTE Battery Replacement, Protect your eyes and skin: étape 100, image 2 de 2
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover.
    • Do not wear contact lenses without eye protection.
    • Protective gloves are included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  101. iPad 8 LTE Battery Replacement, Open the adhesive remover: étape 101, image 1 de 3 iPad 8 LTE Battery Replacement, Open the adhesive remover: étape 101, image 2 de 3 iPad 8 LTE Battery Replacement, Open the adhesive remover: étape 101, image 3 de 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  102. iPad 8 LTE Battery Replacement, Adhesive location: étape 102, image 1 de 2 iPad 8 LTE Battery Replacement, Adhesive location: étape 102, image 2 de 2
    • The red boxes show the locations of the adhesive strips that secure the battery to the rear case.
  103. iPad 8 LTE Battery Replacement, Apply adhesive remover: étape 103, image 1 de 3 iPad 8 LTE Battery Replacement, Apply adhesive remover: étape 103, image 2 de 3 iPad 8 LTE Battery Replacement, Apply adhesive remover: étape 103, image 3 de 3
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the left edge of the battery.
  104. iPad 8 LTE Battery Replacement: étape 104, image 1 de 2 iPad 8 LTE Battery Replacement: étape 104, image 2 de 2
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the bottom edge of the battery.
  105. iPad 8 LTE Battery Replacement: étape 105, image 1 de 2 iPad 8 LTE Battery Replacement: étape 105, image 2 de 2
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol between the two battery cells.
  106. iPad 8 LTE Battery Replacement: étape 106, image 1 de 2 iPad 8 LTE Battery Replacement: étape 106, image 2 de 2
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the right edge of the battery.
  107. iPad 8 LTE Battery Replacement: étape 107, image 1 de 2 iPad 8 LTE Battery Replacement: étape 107, image 2 de 2
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the upper edge of the battery.
  108. iPad 8 LTE Battery Replacement, Cut the adhesive on the right edge: étape 108, image 1 de 2 iPad 8 LTE Battery Replacement, Cut the adhesive on the right edge: étape 108, image 2 de 2
    Plastic Cards
    $2.99
    J'achète
    • Insert a plastic card at the bottom right corner of the battery.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • If you're having trouble loosening the battery, apply some more adhesive remover, or apply a heated iOpener to the back case.
  109. iPad 8 LTE Battery Replacement: étape 109, image 1 de 3 iPad 8 LTE Battery Replacement: étape 109, image 2 de 3 iPad 8 LTE Battery Replacement: étape 109, image 3 de 3
    • Slide the plastic card underneath the right edge to reach the center.
    • Insert the plastic card as far as you can under the battery to cut the adhesive.
    • Remove the plastic card.
  110. iPad 8 LTE Battery Replacement: étape 110, image 1 de 2 iPad 8 LTE Battery Replacement: étape 110, image 2 de 2
    • Insert the plastic card below the battery connector as far as you can.
    • Leave the plastic card inserted.
  111. iPad 8 LTE Battery Replacement: étape 111, image 1 de 2 iPad 8 LTE Battery Replacement: étape 111, image 2 de 2
    • Insert another plastic card above the battery connector as far as you can.
  112. iPad 8 LTE Battery Replacement, Cut the adhesive on the bottom edge: étape 112, image 1 de 2 iPad 8 LTE Battery Replacement, Cut the adhesive on the bottom edge: étape 112, image 2 de 2
    • Remove the plastic card below the battery connector and insert it under the bottom edge of the battery.
  113. iPad 8 LTE Battery Replacement: étape 113, image 1 de 3 iPad 8 LTE Battery Replacement: étape 113, image 2 de 3 iPad 8 LTE Battery Replacement: étape 113, image 3 de 3
    • Slide the plastic card along the bottom edge of the battery to cut the adhesive strip.
    • When you reach the left corner of the bottom edge, insert the plastic card as far as you can.
  114. iPad 8 LTE Battery Replacement, Cut the adhesive on the upper edge: étape 114, image 1 de 2 iPad 8 LTE Battery Replacement, Cut the adhesive on the upper edge: étape 114, image 2 de 2
    • Remove the plastic card above the battery connector and insert it under the upper edge of the battery.
    • Slide the plastic card along the top edge of the battery to cut the adhesive strip.
  115. iPad 8 LTE Battery Replacement: étape 115, image 1 de 2 iPad 8 LTE Battery Replacement: étape 115, image 2 de 2
    • When you reach the left corner of the upper edge, insert the plastic card as far as you can.
  116. iPad 8 LTE Battery Replacement, Cut the adhesive on the left edge: étape 116, image 1 de 3 iPad 8 LTE Battery Replacement, Cut the adhesive on the left edge: étape 116, image 2 de 3 iPad 8 LTE Battery Replacement, Cut the adhesive on the left edge: étape 116, image 3 de 3
    • Insert the plastic card under the upper left corner of the battery.
    • Slide the plastic card down towards the bottom of the iPad.
    • When you reach the center edge of the battery, insert the plastic card as far as you can to cut the central adhesive strip.
  117. iPad 8 LTE Battery Replacement: étape 117, image 1 de 2 iPad 8 LTE Battery Replacement: étape 117, image 2 de 2
    • Insert the plastic card under the bottom left corner of the battery.
    • Slide the plastic card up towards the top of the iPad.
  118. iPad 8 LTE Battery Replacement: étape 118, image 1 de 2 iPad 8 LTE Battery Replacement: étape 118, image 2 de 2
    • When you reach the center edge, insert the plastic card as far as you can to cut the central adhesive strip.
  119. iPad 8 LTE Battery Replacement, Remove the battery: étape 119, image 1 de 1
    Tesa 61395 Tape
    $10.99
    J'achète
    • Remove the battery.
    • If you are still not able to remove the battery, repeat the process of cutting through the battery adhesive.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove the old battery adhesive from the rear case using tweezers and high concentration isopropyl alcohol with a lint-free cloth where needed.
    • If your battery doesn't come with preinstalled adhesive, use Tesa tape to reattach the battery to the rear case.
    • Before installing the new battery, test it by first reinserting the logic board, connecting the button control cable ZIF connector, and the LCD press connector. Then remove the battery blocker and reinstall the battery connector screw. Power on the device to ensure it still works. Go backwards through this step and then glue down the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 8 Answers community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
124 298 Réputation
581 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 207 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 80
Total : 1,521
