Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPhone 15 Logic Board Replacement
Ce dont vous avez besoin
  1. iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: étape 1, image 1 de 2 iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: étape 1, image 2 de 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Logic Board Replacement, Tape over any cracks: étape 2, image 1 de 2 iPhone 15 Logic Board Replacement, Tape over any cracks: étape 2, image 2 de 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Logic Board Replacement, Mark your opening picks: étape 3, image 1 de 3 iPhone 15 Logic Board Replacement, Mark your opening picks: étape 3, image 2 de 3 iPhone 15 Logic Board Replacement, Mark your opening picks: étape 3, image 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Logic Board Replacement, Remove the pentalobe screws: étape 4, image 1 de 2 iPhone 15 Logic Board Replacement, Remove the pentalobe screws: étape 4, image 2 de 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Logic Board Replacement, Heat the bottom edge: étape 5, image 1 de 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Logic Board Replacement, Insert an opening pick: étape 6, image 1 de 3 iPhone 15 Logic Board Replacement, Insert an opening pick: étape 6, image 2 de 3 iPhone 15 Logic Board Replacement, Insert an opening pick: étape 6, image 3 de 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Logic Board Replacement, Screen information: étape 7, image 1 de 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: étape 8, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: étape 8, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: étape 8, image 3 de 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Logic Board Replacement, Heat the right edge: étape 9, image 1 de 1
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Logic Board Replacement, Position the opening pick: étape 10, image 1 de 3 iPhone 15 Logic Board Replacement, Position the opening pick: étape 10, image 2 de 3 iPhone 15 Logic Board Replacement, Position the opening pick: étape 10, image 3 de 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  11. iPhone 15 Logic Board Replacement, Release the right clip: étape 11, image 1 de 3 iPhone 15 Logic Board Replacement, Release the right clip: étape 11, image 2 de 3 iPhone 15 Logic Board Replacement, Release the right clip: étape 11, image 3 de 3
    • Hold the pick with one hand and twist it to increase the gap between the screen and the frame and release the right clip.
    • Insert a second opening pick to the right of the first one.
  12. iPhone 15 Logic Board Replacement, Separate the right edge adhesive: étape 12, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the right edge adhesive: étape 12, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the right edge adhesive: étape 12, image 3 de 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  13. iPhone 15 Logic Board Replacement, Heat the top edge: étape 13, image 1 de 1
    • Heat the top edge of the screen until it's hot to the touch.
  14. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: étape 14, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: étape 14, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: étape 14, image 3 de 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Insert a third opening pick in the top right corner, just above the previous pick.
    • Slide your pick around the top right corner and along the top edge until you feel it stop against the top left screen clip.
  15. iPhone 15 Logic Board Replacement, Release the top edge clips: étape 15, image 1 de 3 iPhone 15 Logic Board Replacement, Release the top edge clips: étape 15, image 2 de 3 iPhone 15 Logic Board Replacement, Release the top edge clips: étape 15, image 3 de 3
    • Rotate your pick so its flat edge is under the screen.
    • Twist your pick to release the top left screen clip.
    • Slide your pick to the top left corner.
  16. iPhone 15 Logic Board Replacement, Heat the left edge: étape 16, image 1 de 1
    • Heat the left edge of the screen until it's hot to the touch.
  17. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: étape 17, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: étape 17, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: étape 17, image 3 de 3
    • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
  18. iPhone 15 Logic Board Replacement, Swing open the screen: étape 18, image 1 de 3 iPhone 15 Logic Board Replacement, Swing open the screen: étape 18, image 2 de 3 iPhone 15 Logic Board Replacement, Swing open the screen: étape 18, image 3 de 3
    • Gently swing open the screen over the left edge of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
  19. iPhone 15 Logic Board Replacement, Unfasten the front sensor connector cover: étape 19, image 1 de 1
    • Use a tri-point Y000 driver to remove the 0.9 mm-long screw securing the front sensor connector cover.
  20. iPhone 15 Logic Board Replacement, Remove the cover: étape 20, image 1 de 3 iPhone 15 Logic Board Replacement, Remove the cover: étape 20, image 2 de 3 iPhone 15 Logic Board Replacement, Remove the cover: étape 20, image 3 de 3
    Outil utilisé dans cette étape :
    • Use tweezers to lift the cover to a 90-degree angle.
    • Unhook the cover from its slot in the logic board.
    • Remove the cover.
  21. iPhone 15 Logic Board Replacement, Disconnect the front sensor: étape 21, image 1 de 2 iPhone 15 Logic Board Replacement, Disconnect the front sensor: étape 21, image 2 de 2
    • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
  22. iPhone 15 Logic Board Replacement, Unfasten the screen connector cover: étape 22, image 1 de 1
    • Use your tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
  23. iPhone 15 Logic Board Replacement, Remove the cover: étape 23, image 1 de 2 iPhone 15 Logic Board Replacement, Remove the cover: étape 23, image 2 de 2
    • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
    • Remove the cover.
  24. iPhone 15 Logic Board Replacement, Disconnect the screen: étape 24, image 1 de 2 iPhone 15 Logic Board Replacement, Disconnect the screen: étape 24, image 2 de 2
    • Use the tip of an opening pick to pry up and disconnect the screen press connector.
  25. iPhone 15 Logic Board Replacement, Remove the screen: étape 25, image 1 de 1
    • Remove the screen.
  26. iPhone 15 Logic Board Replacement, Flip your iPhone over: étape 26, image 1 de 1
    Microfiber Cleaning Cloths
    $3.99
    • Flip your phone over and lay it on a soft surface, such as a microfiber cloth, to protect its internals as you work.
  27. iPhone 15 Logic Board Replacement, Heat the bottom edge: étape 27, image 1 de 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
  28. iPhone 15 Logic Board Replacement, Insert an opening pick: étape 28, image 1 de 3 iPhone 15 Logic Board Replacement, Insert an opening pick: étape 28, image 2 de 3 iPhone 15 Logic Board Replacement, Insert an opening pick: étape 28, image 3 de 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
  29. iPhone 15 Logic Board Replacement, Back glass information: étape 29, image 1 de 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  30. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: étape 30, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: étape 30, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: étape 30, image 3 de 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
  31. iPhone 15 Logic Board Replacement, Heat the right edge: étape 31, image 1 de 1
    • Heat the right edge of the back glass until it's hot to the touch.
  32. iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: étape 32, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: étape 32, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: étape 32, image 3 de 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  33. iPhone 15 Logic Board Replacement, Heat the left edge: étape 33, image 1 de 1
    • Heat the left edge of the back glass until it's hot to the touch.
  34. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: étape 34, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: étape 34, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: étape 34, image 3 de 3
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  35. iPhone 15 Logic Board Replacement, Heat the top edge: étape 35, image 1 de 1
    • Heat the top edge of the back glass until it's hot to the touch.
  36. iPhone 15 Logic Board Replacement, Separate the top edge adhesive: étape 36, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the top edge adhesive: étape 36, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the top edge adhesive: étape 36, image 3 de 3
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  37. iPhone 15 Logic Board Replacement, Heat the top right corner: étape 37, image 1 de 1
    • Heat the top right corner of the back glass until it's hot to the touch.
  38. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: étape 38, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: étape 38, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: étape 38, image 3 de 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  39. iPhone 15 Logic Board Replacement, Open the back glass: étape 39, image 1 de 3 iPhone 15 Logic Board Replacement, Open the back glass: étape 39, image 2 de 3 iPhone 15 Logic Board Replacement, Open the back glass: étape 39, image 3 de 3
    • Gently lift and swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  40. iPhone 15 Logic Board Replacement, Unfasten the lower connector cover: étape 40, image 1 de 1
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  41. iPhone 15 Logic Board Replacement, Remove the lower connector cover: étape 41, image 1 de 3 iPhone 15 Logic Board Replacement, Remove the lower connector cover: étape 41, image 2 de 3 iPhone 15 Logic Board Replacement, Remove the lower connector cover: étape 41, image 3 de 3
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
  42. iPhone 15 Logic Board Replacement, Disconnect the battery: étape 42, image 1 de 3 iPhone 15 Logic Board Replacement, Disconnect the battery: étape 42, image 2 de 3 iPhone 15 Logic Board Replacement, Disconnect the battery: étape 42, image 3 de 3
    • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
    • A plus and minus sign is printed on the head of this connector.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
  43. iPhone 15 Logic Board Replacement, Unfasten the middle connector cover: étape 43, image 1 de 2 iPhone 15 Logic Board Replacement, Unfasten the middle connector cover: étape 43, image 2 de 2
    • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
  44. iPhone 15 Logic Board Replacement, Remove the cover: étape 44, image 1 de 3 iPhone 15 Logic Board Replacement, Remove the cover: étape 44, image 2 de 3 iPhone 15 Logic Board Replacement, Remove the cover: étape 44, image 3 de 3
    • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
    • Remove the cover.
  45. iPhone 15 Logic Board Replacement, Disconnect the wireless charging coil: étape 45, image 1 de 2 iPhone 15 Logic Board Replacement, Disconnect the wireless charging coil: étape 45, image 2 de 2
    • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
  46. iPhone 15 Logic Board Replacement, Remove the back glass: étape 46, image 1 de 1
    • Remove the back glass.
  47. iPhone 15 Logic Board Replacement, Remove the upper connector cover: étape 47, image 1 de 3 iPhone 15 Logic Board Replacement, Remove the upper connector cover: étape 47, image 2 de 3 iPhone 15 Logic Board Replacement, Remove the upper connector cover: étape 47, image 3 de 3
    • Use your tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the upper connector cover.
    • Remove the cover.
  48. iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: étape 48, image 1 de 3 iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: étape 48, image 2 de 3 iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: étape 48, image 3 de 3
    • Use the tip of an opening pick to pry up and disconnect the antenna, front sensors, and front camera press connectors (three connectors in total).
  49. iPhone 15 Logic Board Replacement, Remove the front camera and sensors: étape 49, image 1 de 2 iPhone 15 Logic Board Replacement, Remove the front camera and sensors: étape 49, image 2 de 2
    • Use tweezers or your fingers to pull the front camera and sensors out of their recess in the frame and remove them.
  50. iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: étape 50, image 1 de 2 iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: étape 50, image 2 de 2
    • Use the tip of an opening pick to pry up and disconnect the earpiece speaker press connector.
  51. iPhone 15 Logic Board Replacement, Unfasten the earpiece speaker: étape 51, image 1 de 1
    • Use a Phillips #000 driver to remove the five screws securing the earpiece speaker:
    • Two 1.1 mm‑long screws
    • Three 1.6 mm‑long screws
  52. iPhone 15 Logic Board Replacement, Remove the earpiece speaker: étape 52, image 1 de 3 iPhone 15 Logic Board Replacement, Remove the earpiece speaker: étape 52, image 2 de 3 iPhone 15 Logic Board Replacement, Remove the earpiece speaker: étape 52, image 3 de 3
    • Use tweezers or your fingers to lift and pull the earpiece speaker away from the top of the phone to free the gasket from the frame.
    • Remove the earpiece speaker.
  53. iPhone 15 Logic Board Replacement, Separate the battery cable: étape 53, image 1 de 3 iPhone 15 Logic Board Replacement, Separate the battery cable: étape 53, image 2 de 3 iPhone 15 Logic Board Replacement, Separate the battery cable: étape 53, image 3 de 3
    • Light adhesive secures the battery cable to the logic board.
    • Slide an opening pick under the battery cable to separate it from the logic board.
    • Be careful not to crease the cable or dent the battery with your tool.
  54. iPhone 15 Logic Board Replacement, Disconnect the volume buttons: étape 54, image 1 de 2 iPhone 15 Logic Board Replacement, Disconnect the volume buttons: étape 54, image 2 de 2
    • Use the tip of an opening pick to pry up and disconnect the volume buttons press connector.
  55. iPhone 15 Logic Board Replacement, Disconnect the power button: étape 55, image 1 de 2 iPhone 15 Logic Board Replacement, Disconnect the power button: étape 55, image 2 de 2
    • Disconnect the power button press connector.
  56. iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: étape 56, image 1 de 3 iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: étape 56, image 2 de 3 iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: étape 56, image 3 de 3
    • Disconnect the rear cameras and antenna press connectors (three connectors in total).
  57. iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: étape 57, image 1 de 3 iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: étape 57, image 2 de 3 iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: étape 57, image 3 de 3
    • Disconnect the eSIM, Taptic Engine, and charging port press connectors (three connectors in total).
  58. iPhone 15 Logic Board Replacement, Unfasten the logic board: étape 58, image 1 de 2 iPhone 15 Logic Board Replacement, Unfasten the logic board: étape 58, image 2 de 2
    Standoff Screwdriver for iPhones
    $5.49
    • Use your standoff driver to remove the five standoff screws securing the logic board:
    • One 2.9 mm‑long screw
    • One 3.9 mm‑long screw
    • Three 3.5 mm‑long screws
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
  59. iPhone 15 Logic Board Replacement, Remove the logic board: étape 59, image 1 de 3 iPhone 15 Logic Board Replacement, Remove the logic board: étape 59, image 2 de 3 iPhone 15 Logic Board Replacement, Remove the logic board: étape 59, image 3 de 3
    • Grip the top edge of the logic board and gently pull it out from under the cables.
    • Remove the logic board.
    • During reassembly, make sure all nine press connectors (including the small volume buttons cable) are above the logic board.
  60. iPhone 15 Logic Board Replacement, End of disassembly: étape 60, image 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  61. iPhone 15 Logic Board Replacement, Place the logic board: étape 61, image 1 de 2 iPhone 15 Logic Board Replacement, Place the logic board: étape 61, image 2 de 2
    • Slide the logic board into its slot in the frame, making sure the nine press connectors are above the logic board.
  62. iPhone 15 Logic Board Replacement, Install the logic board screws: étape 62, image 1 de 2 iPhone 15 Logic Board Replacement, Install the logic board screws: étape 62, image 2 de 2
    $5.49
    • Use your standoff driver to install the five standoff screws securing the logic board:
  63. iPhone 15 Logic Board Replacement, Connect the press connectors: étape 63, image 1 de 3 iPhone 15 Logic Board Replacement, Connect the press connectors: étape 63, image 2 de 3 iPhone 15 Logic Board Replacement, Connect the press connectors: étape 63, image 3 de 3
    • Use your spudger or your fingers to connect the eight press connectors:
    • The power button
    • The volume button
    • The rear cameras and antenna (three connectors in total)
    • The eSIM
    • The Taptic Engine
    • The charging port
    • Don't connect the battery press connector yet.
  64. iPhone 15 Logic Board Replacement, Place the earpiece speaker: étape 64, image 1 de 2 iPhone 15 Logic Board Replacement, Place the earpiece speaker: étape 64, image 2 de 2
    • Align the gasket on the earpiece speaker with its sound channel.
    • Press the earpiece speaker onto the frame so it lies flat.
  65. iPhone 15 Logic Board Replacement, Install the earpiece speaker screws: étape 65, image 1 de 1
    • Use a Phillips #000 driver to install the five screws securing the earpiece speaker:
  66. iPhone 15 Logic Board Replacement, Install the front camera assembly: étape 66, image 1 de 3 iPhone 15 Logic Board Replacement, Install the front camera assembly: étape 66, image 2 de 3 iPhone 15 Logic Board Replacement, Install the front camera assembly: étape 66, image 3 de 3
    • Slide the front camera assembly into its recess in the frame.
    • Set the assembly down so it lies flat.
  67. iPhone 15 Logic Board Replacement, Connect the assemblies: étape 67, image 1 de 3 iPhone 15 Logic Board Replacement, Connect the assemblies: étape 67, image 2 de 3 iPhone 15 Logic Board Replacement, Connect the assemblies: étape 67, image 3 de 3
    • Use the flat end of a spudger or your finger to connect the front camera and earpiece speaker press connectors.
    • If the iPhone has a mmWave antenna, connect it as well.
  68. iPhone 15 Logic Board Replacement, Install the upper connector cover: étape 68, image 1 de 3 iPhone 15 Logic Board Replacement, Install the upper connector cover: étape 68, image 2 de 3 iPhone 15 Logic Board Replacement, Install the upper connector cover: étape 68, image 3 de 3
    • Place the cover over the logic board and align its screw holes.
    • Use your tri-point Y000 driver to install the two 1.3 mm‑long screws securing the upper connector cover.
  69. iPhone 15 Logic Board Replacement, Remove the back glass adhesive: étape 69, image 1 de 2 iPhone 15 Logic Board Replacement, Remove the back glass adhesive: étape 69, image 2 de 2
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
    • Use the tweezers to pull the adhesive off of the phone.
  70. iPhone 15 Logic Board Replacement: étape 70, image 1 de 3 iPhone 15 Logic Board Replacement: étape 70, image 2 de 3 iPhone 15 Logic Board Replacement: étape 70, image 3 de 3
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
  71. iPhone 15 Logic Board Replacement, Orient the adhesive: étape 71, image 1 de 3 iPhone 15 Logic Board Replacement, Orient the adhesive: étape 71, image 2 de 3 iPhone 15 Logic Board Replacement, Orient the adhesive: étape 71, image 3 de 3
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the rear camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
  72. iPhone 15 Logic Board Replacement, Apply the adhesive: étape 72, image 1 de 3 iPhone 15 Logic Board Replacement, Apply the adhesive: étape 72, image 2 de 3 iPhone 15 Logic Board Replacement, Apply the adhesive: étape 72, image 3 de 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
    • Hold the liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
  73. iPhone 15 Logic Board Replacement: étape 73, image 1 de 3 iPhone 15 Logic Board Replacement: étape 73, image 2 de 3 iPhone 15 Logic Board Replacement: étape 73, image 3 de 3
    • When the adhesive is aligned, use the flat end of a spudger or your finger to press it down firmly along the bottom edge.
  74. iPhone 15 Logic Board Replacement: étape 74, image 1 de 3 iPhone 15 Logic Board Replacement: étape 74, image 2 de 3 iPhone 15 Logic Board Replacement: étape 74, image 3 de 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
  75. iPhone 15 Logic Board Replacement, Press the adhesive into place: étape 75, image 1 de 3 iPhone 15 Logic Board Replacement, Press the adhesive into place: étape 75, image 2 de 3 iPhone 15 Logic Board Replacement, Press the adhesive into place: étape 75, image 3 de 3
    • Make sure the liner is aligned properly by checking that all spring contacts and the rear camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
  76. iPhone 15 Logic Board Replacement, Remove the top liner: étape 76, image 1 de 3 iPhone 15 Logic Board Replacement, Remove the top liner: étape 76, image 2 de 3 iPhone 15 Logic Board Replacement, Remove the top liner: étape 76, image 3 de 3
    • Remove the top adhesive liner.
    • Depending on your adhesive, your liner might be split into multiple parts or be a single piece.
  77. iPhone 15 Logic Board Replacement, Prop up the back glass: étape 77, image 1 de 3 iPhone 15 Logic Board Replacement, Prop up the back glass: étape 77, image 2 de 3 iPhone 15 Logic Board Replacement, Prop up the back glass: étape 77, image 3 de 3
    • Prop up the back glass along the right edge of the iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the wireless charging coil press connector, then the battery press connector.
  78. iPhone 15 Logic Board Replacement, Place the middle connector cover: étape 78, image 1 de 2 iPhone 15 Logic Board Replacement, Place the middle connector cover: étape 78, image 2 de 2
    • Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
  79. iPhone 15 Logic Board Replacement: étape 79, image 1 de 2 iPhone 15 Logic Board Replacement: étape 79, image 2 de 2
    • Use your finger to press the cover down on the logic board.
    • While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
  80. iPhone 15 Logic Board Replacement, Place the lower connector cover: étape 80, image 1 de 3 iPhone 15 Logic Board Replacement, Place the lower connector cover: étape 80, image 2 de 3 iPhone 15 Logic Board Replacement, Place the lower connector cover: étape 80, image 3 de 3
    • Use tweezers to hook the top of the lower connector cover into its slot on the logic board.
    • Lay the lower connector cover over the press connectors.
  81. iPhone 15 Logic Board Replacement, Install the cover screws: étape 81, image 1 de 2 iPhone 15 Logic Board Replacement, Install the cover screws: étape 81, image 2 de 2
    • Use a tri-point Y000 screwdriver to install the 0.9 mm‑long screw securing the middle connector cover.
    • Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
  82. iPhone 15 Logic Board Replacement, Remove the final adhesive liners: étape 82, image 1 de 2 iPhone 15 Logic Board Replacement, Remove the final adhesive liners: étape 82, image 2 de 2
    • Use tweezers or your fingers to separate the pull tabs at the bottom of the frame, near the charging port.
  83. iPhone 15 Logic Board Replacement: étape 83, image 1 de 3 iPhone 15 Logic Board Replacement: étape 83, image 2 de 3 iPhone 15 Logic Board Replacement: étape 83, image 3 de 3
    • Remove the narrow liner covering the adhesive along the left and top edges of the frame.
  84. iPhone 15 Logic Board Replacement: étape 84, image 1 de 3 iPhone 15 Logic Board Replacement: étape 84, image 2 de 3 iPhone 15 Logic Board Replacement: étape 84, image 3 de 3
    • Hold the back glass over the phone without letting it touch the adhesive, so you can access the remaining liners along the right edge of the phone.
    • Use a pair of tweezers or your fingers to remove the remaing liners along the right edge of the phone.
  85. iPhone 15 Logic Board Replacement, Install the back glass: étape 85, image 1 de 3 iPhone 15 Logic Board Replacement, Install the back glass: étape 85, image 2 de 3 iPhone 15 Logic Board Replacement, Install the back glass: étape 85, image 3 de 3
    • Lay the back glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all the clips.
  86. iPhone 15 Logic Board Replacement, Heat the back glass: étape 86, image 1 de 2 iPhone 15 Logic Board Replacement, Heat the back glass: étape 86, image 2 de 2
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass.
  87. iPhone 15 Logic Board Replacement, Remove the screen adhesive: étape 87, image 1 de 3 iPhone 15 Logic Board Replacement, Remove the screen adhesive: étape 87, image 2 de 3 iPhone 15 Logic Board Replacement, Remove the screen adhesive: étape 87, image 3 de 3
    • This is a good point to test your repair before sealing up your phone. Connect the screen, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
  88. iPhone 15 Logic Board Replacement: étape 88, image 1 de 3 iPhone 15 Logic Board Replacement: étape 88, image 2 de 3 iPhone 15 Logic Board Replacement: étape 88, image 3 de 3
  89. iPhone 15 Logic Board Replacement, Orient the adhesive: étape 89, image 1 de 3 iPhone 15 Logic Board Replacement, Orient the adhesive: étape 89, image 2 de 3 iPhone 15 Logic Board Replacement, Orient the adhesive: étape 89, image 3 de 3
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
  90. iPhone 15 Logic Board Replacement, Apply the adhesive: étape 90, image 1 de 3 iPhone 15 Logic Board Replacement, Apply the adhesive: étape 90, image 2 de 3 iPhone 15 Logic Board Replacement, Apply the adhesive: étape 90, image 3 de 3
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
  91. iPhone 15 Logic Board Replacement: étape 91, image 1 de 3 iPhone 15 Logic Board Replacement: étape 91, image 2 de 3 iPhone 15 Logic Board Replacement: étape 91, image 3 de 3
    • When the adhesive is aligned, use the flat end of a spudger, or your finger, to press it down firmly along the bottom edge.
  92. iPhone 15 Logic Board Replacement: étape 92, image 1 de 3 iPhone 15 Logic Board Replacement: étape 92, image 2 de 3 iPhone 15 Logic Board Replacement: étape 92, image 3 de 3
  93. iPhone 15 Logic Board Replacement, Press the adhesive into place: étape 93, image 1 de 3 iPhone 15 Logic Board Replacement, Press the adhesive into place: étape 93, image 2 de 3 iPhone 15 Logic Board Replacement, Press the adhesive into place: étape 93, image 3 de 3
    • Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
  94. iPhone 15 Logic Board Replacement, Remove the top liner: étape 94, image 1 de 2 iPhone 15 Logic Board Replacement, Remove the top liner: étape 94, image 2 de 2
    • Insert the point of a spudger under the top liner's hole at the bottom of the frame.
    • Pry up to separate the liner from the frame—enough to grip it with your fingers.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners under it.
  95. iPhone 15 Logic Board Replacement: étape 95, image 1 de 3 iPhone 15 Logic Board Replacement: étape 95, image 2 de 3 iPhone 15 Logic Board Replacement: étape 95, image 3 de 3
    • Peel back the top liner and remove it.
  96. iPhone 15 Logic Board Replacement, Prop up the screen: étape 96, image 1 de 1
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
  97. iPhone 15 Logic Board Replacement, Connect the screen: étape 97, image 1 de 2 iPhone 15 Logic Board Replacement, Connect the screen: étape 97, image 2 de 2
    • Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
  98. iPhone 15 Logic Board Replacement: étape 98, image 1 de 3 iPhone 15 Logic Board Replacement: étape 98, image 2 de 3 iPhone 15 Logic Board Replacement: étape 98, image 3 de 3
    • Insert the top of the screen connector cover into its slot in the frame and lay it over the press connector.
  99. iPhone 15 Logic Board Replacement: étape 99, image 1 de 3 iPhone 15 Logic Board Replacement: étape 99, image 2 de 3 iPhone 15 Logic Board Replacement: étape 99, image 3 de 3
    • Insert the front sensor connector cover into its slot in the frame at a 90‑degree angle vertically.
    • Lay the cover over the press connector.
  100. iPhone 15 Logic Board Replacement, Install the cover screws: étape 100, image 1 de 2 iPhone 15 Logic Board Replacement, Install the cover screws: étape 100, image 2 de 2
    • Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
  101. iPhone 15 Logic Board Replacement, Remove the final adhesive liners: étape 101, image 1 de 2 iPhone 15 Logic Board Replacement, Remove the final adhesive liners: étape 101, image 2 de 2
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use a spudger, or your fingers, to separate the pull tabs at the bottom right corner of the frame.
  102. iPhone 15 Logic Board Replacement: étape 102, image 1 de 3 iPhone 15 Logic Board Replacement: étape 102, image 2 de 3 iPhone 15 Logic Board Replacement: étape 102, image 3 de 3
    • Remove the narrow liner covering the adhesive along the right and top edges of the frame.
  103. iPhone 15 Logic Board Replacement: étape 103, image 1 de 3 iPhone 15 Logic Board Replacement: étape 103, image 2 de 3 iPhone 15 Logic Board Replacement: étape 103, image 3 de 3
    • Remove the liner along the bottom edge of the frame.
  104. iPhone 15 Logic Board Replacement: étape 104, image 1 de 3 iPhone 15 Logic Board Replacement: étape 104, image 2 de 3 iPhone 15 Logic Board Replacement: étape 104, image 3 de 3
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
  105. iPhone 15 Logic Board Replacement, Place the screen: étape 105, image 1 de 3 iPhone 15 Logic Board Replacement, Place the screen: étape 105, image 2 de 3 iPhone 15 Logic Board Replacement, Place the screen: étape 105, image 3 de 3
    • Lay the screen straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the screen to engage all clips.
  106. iPhone 15 Logic Board Replacement, Heat the screen: étape 106, image 1 de 2 iPhone 15 Logic Board Replacement, Heat the screen: étape 106, image 2 de 2
    • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
  107. iPhone 15 Logic Board Replacement, Press the screen: étape 107, image 1 de 3 iPhone 15 Logic Board Replacement, Press the screen: étape 107, image 2 de 3 iPhone 15 Logic Board Replacement, Press the screen: étape 107, image 3 de 3
    • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
  108. iPhone 15 Logic Board Replacement: étape 108, image 1 de 2 iPhone 15 Logic Board Replacement: étape 108, image 2 de 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
  109. iPhone 15 Logic Board Replacement: étape 109, image 1 de 3 iPhone 15 Logic Board Replacement: étape 109, image 2 de 3 iPhone 15 Logic Board Replacement: étape 109, image 3 de 3
    • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Stack them to a consistent height taller than the camera bump.
  110. iPhone 15 Logic Board Replacement: étape 110, image 1 de 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
  111. iPhone 15 Logic Board Replacement, Install the pentalobe screws: étape 111, image 1 de 2 iPhone 15 Logic Board Replacement, Install the pentalobe screws: étape 111, image 2 de 2
    • Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
3 autres ont terminé cette réparation.
Clay Eickemeyer
Membre depuis le 09/19/22
102 852 Réputation
472 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
10 membres
17 675 tutoriels rédigés
1 commentaire de tutoriel
You can remove the logic board without removing the screen if you carefully flip the logic board over during removal.
Finn Hagard - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 36
7 derniers jours : 312
30 derniers jours : 1,360
Total : 22,187
