Aller au contenu principal
iPhone Battery Adhesive Strips Replacement
Ce dont vous avez besoin
  1. iPhone Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: étape 1, image 1 de 3 iPhone Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: étape 1, image 2 de 3 iPhone Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: étape 1, image 3 de 3
    • If your new battery came with adhesive strips already installed, skip to Step 8.
    • Otherwise, peel off the large blue plastic liner from your new set of adhesive strips, and discard it.
    • Once the adhesive is exposed, be careful not to touch it.
  2. iPhone Battery Adhesive Strips Replacement: étape 2, image 1 de 2 iPhone Battery Adhesive Strips Replacement: étape 2, image 2 de 2
    • Once the adhesive sticks to the battery, you can't peel it off or reposition it—if you make a mistake, you'll have to start over with fresh adhesive strips.
    • Double-check the orientation of the adhesive strips, and then stick them to the back side of your new battery.
    • Make sure the two shorter strips are nearest the battery cable connector.
    • Center the strips so that the two pairs of black tabs protrude evenly from each side of the battery.
  3. iPhone Battery Adhesive Strips Replacement: étape 3, image 1 de 3 iPhone Battery Adhesive Strips Replacement: étape 3, image 2 de 3 iPhone Battery Adhesive Strips Replacement: étape 3, image 3 de 3
    • Use your fingers or a cloth to press the strips firmly into place on the battery.
  4. iPhone Battery Adhesive Strips Replacement: étape 4, image 1 de 3 iPhone Battery Adhesive Strips Replacement: étape 4, image 2 de 3 iPhone Battery Adhesive Strips Replacement: étape 4, image 3 de 3
    • Flip the battery over, then peel away and discard the two blue plastic liners covering the ends of the adhesive strips.
  5. iPhone Battery Adhesive Strips Replacement: étape 5, image 1 de 3 iPhone Battery Adhesive Strips Replacement: étape 5, image 2 de 3 iPhone Battery Adhesive Strips Replacement: étape 5, image 3 de 3
    • Grab the pink plastic liner at the bottom edge of the battery, and gently pull it taut.
    • Fold the liner over onto the battery and press down.
    • Let go of the liner, and the two black ends of the adhesive strips should remain stuck to the bottom edge of the battery.
  6. iPhone Battery Adhesive Strips Replacement: étape 6, image 1 de 3 iPhone Battery Adhesive Strips Replacement: étape 6, image 2 de 3 iPhone Battery Adhesive Strips Replacement: étape 6, image 3 de 3
    • Repeat the previous step to adhere the ends of the two remaining strips at the top edge of the battery.
  7. iPhone Battery Adhesive Strips Replacement: étape 7, image 1 de 2 iPhone Battery Adhesive Strips Replacement: étape 7, image 2 de 2
    • Peel away and discard the small orange release liner covering the ends of the adhesive strips at the top of the battery.
  8. iPhone Battery Adhesive Strips Replacement: étape 8, image 1 de 1
    • With the large pink release liner still in place, set the battery into your iPhone.
  9. iPhone Battery Adhesive Strips Replacement: étape 9, image 1 de 3 iPhone Battery Adhesive Strips Replacement: étape 9, image 2 de 3 iPhone Battery Adhesive Strips Replacement: étape 9, image 3 de 3
    • Line up the battery connector and press it into place.
  10. iPhone Battery Adhesive Strips Replacement: étape 10, image 1 de 2 iPhone Battery Adhesive Strips Replacement: étape 10, image 2 de 2
    • Lifting from the outside edge, tilt the battery onto its side so you can access the final release liner.
    • Leave the battery connected to the logic board to help keep it positioned correctly.
  11. iPhone Battery Adhesive Strips Replacement: étape 11, image 1 de 3 iPhone Battery Adhesive Strips Replacement: étape 11, image 2 de 3 iPhone Battery Adhesive Strips Replacement: étape 11, image 3 de 3
    • Peel away the final, large, pink release liner and discard it.
  12. iPhone Battery Adhesive Strips Replacement: étape 12, image 1 de 2 iPhone Battery Adhesive Strips Replacement: étape 12, image 2 de 2
    • Carefully position the battery and set it into the iPhone.
  13. iPhone Battery Adhesive Strips Replacement: étape 13, image 1 de 2 iPhone Battery Adhesive Strips Replacement: étape 13, image 2 de 2
    • Press the top and bottom areas of the battery firmly into place, allowing the adhesive strips to stick to the rear case.
  14. iPhone Battery Adhesive Strips Replacement: étape 14, image 1 de 1
    • Be sure to disconnect the battery again before reassembling your iPhone.
    • Working on your phone with the battery connected can destroy sensitive components.
Jeff Suovanen
Membre depuis le 08/06/13
428 713 Réputation
259 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 299 tutoriels rédigés
3 commentaires
Can I make my own adhesive strips from 3M double-sided tape?
Joel - Réponse
No. While the 3M has quality tapes, their product is too thick. Purchase the item here and do the job correctly. You'll be happy that you used the correct adhisive.
gregdidier - Réponse
First time Do-It-Yourself-er here so I want to ask, do you need to replace/add the adhesive strips (adhesive in general)? If so, why?
It feels like it would be more convenient for the next time you need to replace your battery.
Again, just looking for a little clarification & insight.
Christopher Mali-Martinez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 24
7 derniers jours : 180
30 derniers jours : 972
Total : 40,688
