Spilled tea on laptop
Hi all,
My girlfriend spilled tea on her macbook.
She turned it off soon after and let it dry for half a day before trying to start it.
It didn't work. Then she put it on the charger and first it didn't show it was charging (the light on the charger), but at a second attempt it did. It still wouldn't start though.
Here I took over. I removed the battery (like so: Remplacement de la batterie du MacBook Air 11" mi-2012) and let it dry for two more days. It was soaked when i took it apart.
After reassembling it it, it doesn't charge. When i try to start it, it however does show the 'no battery' sign on the screen (which i interpret as quite a good thing).
My question is, is it possible that the battery was damaged by the water and is it smart to buy a new battery? or is it more likely that something else was damaged and should i give up?
1 commentaire
thanks both of you.
I'll have a try
par Cees Gauw
