Introduction
This repair guide was authored by a member of the iFixit community and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to remove or replace the motherboard in a Google Pixel 2.
Some guide images will show the phone with the battery removed. You do not need to remove the battery for this procedure.
Ce dont vous avez besoin
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
Remove the following screws securing the midframe:
Eleven 3.7 mm Phillips screws
One 4 mm T5 Torx screw
Use the flat end of a spudger to disconnect the battery connector.
use the flat end of a spudger to disconnect the charging assembly connector from the motherboard.
6 autres ont terminé cette réparation.
Un commentaire
Rotated screen too far while removing it seems and the screen no longer turns on. Can't seem to get any signs of light/ sound out if the phone.
No way to shut down the phone without the screen either? So can't continue the repair until phone battery dies again.
