Aller au contenu principal
Remplacement du haut-parleur inférieur de l'iPhone X
Ce dont vous avez besoin
  1. Remplacement du haut-parleur inférieur de l'iPhone X, Vis Pentalobe: étape 1, image 1 de 1
    • Avant de commencer, déchargez votre iPhone en dessous de 25 %. Une batterie lithium-ion chargée peut prendre feu et/ou exploser si elle est accidentellement percée.
    • Éteignez votre iPhone avant de commencer à le démonter.
    • Dévissez les deux vis Pentalobe de 6,9 mm en bas de l'iPhone.
    • Si les vis sont dénudées ou endommagées, remplacez-les.
    • Ouvrir votre écran iPhone X va endommager ses joints étanches. Pensez à vous procurer des joints de remplacement avant de vous lancer dans une réparation iPhone, ou bien faites attention à ne plus exposer votre iPhone à des liquides si vous le remontez sans changer les joints.
    There are 6.81mm long screws!
    Daniel - Réponse
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - Réponse
    same situation here
    kaunomarcius - Réponse
    Same issue for me too, how do I get the stripped screw out?
    patronics - Réponse
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    patronics - Réponse
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    cgtyoder - Réponse
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - Réponse
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - Réponse
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - Réponse
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
    @Dan Long is right
    Uri -
    Clean out the pentalobe screw heads first so the tool goes all the way in. A small sewing needle works well to loosen any build up and then press some putty/chewing gum into the screw head and pull away quickly for a final clean out.
    William Olstad - Réponse
    The this kit should include screws because you’re going to strip them. Can’t even get past step one. Did anybody figure this out
    justin - Réponse
    Never opened my phone ever, when I went to look at the first step.. I noticed one of my screws was stripped. I thought it was impossible, but I removed the non stripped one, then once I got to the stripped one.. I learned my assumptions were correct. I bought this one straight from the apple site years ago ahaha Any tips to remove the stripped screw?
    Clarence Williams - Réponse
    William Olstad's tip about cleaning the screws with a needle and a bit of poster putty worked well for me. There was a lot of crud in there! The opening is shallow, so it's easy to see how the screwdriver wouldn't catch with even a bit of grit in the way, No problem getting the pentalobe screws out with the ifixit screwdriver.
    punkinann - Réponse
    If all else fails, very carefully cut a slot across the head of the screw with a Dremel tool using a diamond bit that dentist will gladly give you - I ask my dentist for used bits; and chuck them in a drill bit chuck designed for Dremel. The slot allows you to use a tiny, straight blade screwdriver. You can reuse the screw or replace it with a new pentalobe screw.
    Dan Smith - Réponse
  2. Remplacement du haut-parleur inférieur de l'iPhone X, Recouvrir toutes les fissures: étape 2, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X, Recouvrir toutes les fissures: étape 2, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X, Recouvrir toutes les fissures: étape 2, image 3 de 3
    • Si votre écran iPhone X est fissuré, empêchez les fissures de s'aggraver et les éclats de vous blesser en le recouvrant de ruban adhésif.
    • Recouvrez l'écran de bandes de ruban adhésif, qui se chevauchent, jusqu'à ce que toute la surface soit couverte.
    • Portez des lunettes de sécurité pour vous protéger les yeux des éclats de verre tout au long de la réparation iPhone.
    • Si la ventouse n'adhère pas au cours des étapes suivantes, pliez un morceau de ruban adhésif épais (du ruban adhésif toilé p.e.) pour former une poignée et soulevez l'écran de cette façon.
    • Si tout cela échoue, vous pouvez coller la ventouse à l'écran avec de la superglue.
  3. Remplacement du haut-parleur inférieur de l'iPhone X, Instructions Anti-Clamp: étape 3, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X, Instructions Anti-Clamp: étape 3, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X, Instructions Anti-Clamp: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Clamp
    $24.95
    J'achète
    • Les trois étapes suivantes sont consacrées à la procédure avec l'Anti-Clamp, un outil facilitant les procédures d'ouverture. Si vous n'avez pas d'Anti-Clamp, passez à la procédure alternative trois étapes plus loin.
    • Pour des instructions complètes sur comment utiliser l'Anti-Clamp, jetez un œil à ce tutoriel.
    • Tirez la poignée bleue vers l'arrière pour débloquer les bras de l'Anti-Clamp.
    • Insérez le côté droit ou gauche de votre iPhone entre les bras.
    • Positionnez les ventouses en bas de l'iPhone, une sur le dessus, l'autre en dessous.
    • Appuyez sur les deux ventouses pour qu'elles adhèrent bien.
    • Si vous trouvez que la surface de votre appareil est trop glissante pour que l'Anti-Clamp puisse adhérer, vous pouvez utiliser du ruban adhésif pour créer une surface plus adhérente.
  4. Remplacement du haut-parleur inférieur de l'iPhone X: étape 4, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 4, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 4, image 3 de 3
    • Tirez la poignée vers l'avant pour bloquer les bras.
    • Tournez la poignée dans le sens des aiguilles d'une montre, de 360 degrés ou jusqu'à ce que les ventouses commencent à s'étirer.
    • Vérifiez que les ventouses restent bien alignées entre elles. Si elles commencent à se décaler, détachez-les pour les réaligner.
  5. Remplacement du haut-parleur inférieur de l'iPhone X: étape 5, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 5, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 5, image 3 de 3
    • Chauffez un iOpener et faites-le passer à travers les bras de l'Anti-Clamp.
    • Vous pouvez également utiliser un sèche-cheveux, un pistolet à air chaud ou une plaque chauffante. Mais gare à la surchauffe, l'écran et la batterie sont sensibles à la chaleur. Faites donc bien attention.
    • Pliez l'iOpener de façon qu'il repose sur le bord inférieur de l'iPhone.
    • Attendez une minute que l'adhésif se ramollisse et qu'un espace s'ouvre.
    • Insérez un médiator sous l'écran et le joint en plastique, et non dans l'écran.
    • Si l'Anti-Clamp n'a pas créé un écart suffisamment large, appliquez plus de chaleur sur la surface et tournez la poignée d'un demi-tour de plus.
    • Ne tournez pas plus d'un demi-tour à la fois, et attendez une minute entre chaque rotation. Laissez l'Anti-Clamp et le temps faire le travail pour vous.
    • Passez les trois étapes suivantes.
    DO NOT separate the glass from the plastic bumper or rim around it. These instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body. It is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - Réponse
    Thanks for pointing this out! I'll revise this step to clarify this point.
    Arthur Shi -
  6. Remplacement du haut-parleur inférieur de l'iPhone X: étape 6, image 1 de 1
    • Chauffer le bord inférieur de l'iPhone va aider à ramollir l'adhésif qui fixe l'écran, et donc faciliter l'ouverture.
    • Utilisez un sèche-cheveux ou un pistolet à air chaud ou préparez un iOpener et appliquez-le sur le bord inférieur de l'iPhone pendant environ une minute afin de ramollir l'adhésif qui se trouve en dessous.
    • Si vous utilisez un sèche-cheveux ou un pistolet à air chaud, ne chauffez pas trop, car vous risqueriez de détériorer l'écran.
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    Uri - Réponse
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - Réponse
    When opening a device that has previously been worked on, and on which the adhesive might not have been replaced, be extremely carful when opening the phone. It will open much more easily than expected. If you’re not careful you might rip a cable.
    jonpol - Réponse
    Is this tool required or can I just use the Anti-Clamp by itself.
    Mikail - Réponse
    If you have a 3d printer, heat the bed to 80c and put the phone screen side down on it for 30 secs
    philip.joseph123 - Réponse
  7. Remplacement du haut-parleur inférieur de l'iPhone X: étape 7, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 7, image 2 de 2
    • Si vous utilisez une ventouse simple, posez-la au niveau du bord inférieur du téléphone tout en évitant la partie incurvée du verre.
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - Réponse
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - Réponse
  8. Remplacement du haut-parleur inférieur de l'iPhone X: étape 8, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 8, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 8, image 3 de 3
    • Tirez fermement sur la poignée de la ventouse en appliquant une pression constante, pour ouvrir une petite fente entre l'écran et le châssis.
    • Insérez un médiator dans l'espace sous le joint en plastique de l'écran, pas dans l'écran lui-même.
    • L'adhésif étanche qui maintient l'écran est très solide ; ouvrir cette première fente nécessite beaucoup de force. Si vous avez du mal à le faire, chauffez le tout encore une fois. Puis faites doucement basculer l'écran de haut en bas pour faire céder l'adhésif, jusqu'à que vous ayez ouvert une fente suffisamment large pour y insérer le médiator.
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
    The top about applying more heat and gently rocking the screen up and down to weaken the adhesive did the trick for me. Thank you!
    Monil Shah - Réponse
    There needs to be more clarity on where to shove the opening pick into. There is actually two openings that the pry tool can be forced into: one below the black plastic bezel, and one above the black plastic bezel. When I heated my screen with a warming pad and pulled up the suction cup, it actually pried apart above the black plastic bezel which removed the touch screen from the display panel. With this being the first newer iPhone I'd opened since the 3GS, I didn't realize that I was opening the wrong opening as the directions only mentioned one opening and did not warn of this. I was pretty disappointed in the lack of mentioning this, as I was taking my time and following it to the tee. As a result, it destroyed my original iPhone screen.
    Caleb Davison - Réponse
    DO NOT separate the glass from the plastic bumper or rim around it. As someone else noted, these instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body of the phone. When pulling upwards with the suction cup, it is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - Réponse
    Thank you for pointing this out! I've updated the step to reflect this.
    Arthur Shi -
    The suction cup doesn't work at all... The minimum force I apply to lift it up, it comes off completely. This is very frustrating!!!
    Mario Silva - Réponse
  9. Remplacement du haut-parleur inférieur de l'iPhone X: étape 9, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 9, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 9, image 3 de 3
    • Faites glisser le médiator le long du coin inférieur gauche de l'iPhone, ce qui va trancher l'adhésif qui maintient l'écran en place.
    • N'insérez pas le médiator de plus de 3 mm, vous risqueriez d'endommager des composants internes.
  10. Remplacement du haut-parleur inférieur de l'iPhone X, Informations écran iPhone X: étape 10, image 1 de 1
    • Il y a des nappes très fragiles sur le côté droit de votre iPhone. N'y insérez pas le médiator ! Vous risqueriez de les endommager.
    Wouldn’t it be better to put this part BEFORE the step where you have to pry open the phone?
    Jan D. Höllwarth - Réponse
  11. Remplacement du haut-parleur inférieur de l'iPhone X: étape 11, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 11, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 11, image 3 de 3
    • Ré-insérez votre médiator dans le bord inférieur de l'iPhone, et faites-le glisser jusqu'au côté droit pour continuer à séparer l'adhésif.
    • N'insérez pas votre outil de plus de 3 mm, vous endommageriez les nappes de l'écran.
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003” thick gauge goes right in. Work your way up in thickness until you can get the pic or supplied pry tool in. Don’t insert metal feeler gauge in too far, just enough to hold crack open. I didn’t need to use the suction cup. I used a hot/cold gel pack heated in microwave to heat edges to soften glue a bit. Made sure it wasn’t so hot I couldn’t stand it on my skin.
  12. Remplacement du haut-parleur inférieur de l'iPhone X: étape 12, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 12, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 12, image 3 de 3
    • Le bord supérieur de l'écran est retenu par de la colle et des clips.
    • Glissez le médiator sous le coin supérieur de l'écran tout en faisant délicatement jouer l'écran vers le bas, en direction du port Lightning.
    • Les clips peuvent se casser si vous forcez trop. Progressez avec prudence et restez patient.
    • N'insérez pas votre outil de plus de 3 mm. Vous risqueriez d'endommager la rangée des capteurs du panneau frontal.
    • Glissez le médiator sous le côté opposé pour faire céder l'adhésif restant.
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - Réponse
  13. Remplacement du haut-parleur inférieur de l'iPhone X: étape 13, image 1 de 1
    • Tirez sur la petite bosse de la ventouse pour la décoller du panneau frontal.
  14. Remplacement du haut-parleur inférieur de l'iPhone X: étape 14, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 14, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 14, image 3 de 3
    • Ouvrez l'iPhone en tournant l'écran depuis le côté gauche, comme s'il s'agissait de la couverture au dos d'un livre.
    • N'essayez pas encore d'enlever complètement l'écran, car plusieurs nappes fragiles le relient toujours à la carte mère de l'iPhone.
    • Comme sur la photo, assurez-vous que le châssis se détache avec l'écran et ne reste pas coincé dans l'appareil.
    • Appuyez l'écran contre un objet pour le maintenir à la verticale pendant que vous travaillez sur le téléphone.
    • Lors du remontage, posez l'écran iPhone X à sa place, alignez les clips le long du bord supérieur. Puis appuyez délicatement sur le bord supérieur avant de refermer le reste de l'écran. S'il ne s'enclenche pas facilement, vérifiez l'état des clips sur le pourtour de l'écran et vérifiez qu'ils ne sont pas déformés.
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - Réponse
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - Réponse
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - Réponse
    Advice for re-assembly: Before closing up the phone with the seal, check if phone is powering up again and speaker, mic and sensors are still working. If done this check even before installing the board connector bracket in Step 13.
    Alexander Nowak - Réponse
  15. Remplacement du haut-parleur inférieur de l'iPhone X, Écran complet: étape 15, image 1 de 1
    Magnetic Project Mat
    $19.95
    J'achète
    • Dévissez cinq vis Y000 fixant le cache du connecteur de la carte mère, des dimensions suivantes :
    • Trois vis de 1,1 mm
    • Une vis de 3,1 mm
    • Une vis de 3,7 mm
    • Tout au long de cette réparation, veillez à bien organiser vos vis et à revisser chacune exactement là où elle était, afin d'éviter d'endommager votre iPhone.
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - Réponse
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - Réponse
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout - Réponse
    Be careful on reassembly. Keep the screen supported and not moving. I had difficulty getting the screws in and ended up ruining the screen connectivity at the back of the screen where the ribbon cables go in near the center. I was trying to hand hold the screen and it ended up moving around too much.
    SETH GREEN - Réponse
    To keep track of the screws, I copy the photos showing their places, then arrange these photos on document in Pages, print it. Next I apply two sided sticky tape (the roll-on type). So all screws have their corresponding places …
    Max Glanzmann - Réponse
  16. Remplacement du haut-parleur inférieur de l'iPhone X: étape 16, image 1 de 1
    • Retirez le cache.
    • Il se peut que le cache soit légèrement collé. Soulevez-le délicatement mais fermement pour le décoller.
    • C'est le moment idéal lors du remontage pour allumer votre iPhone et en tester toutes les fonctions avant de le refermer hermétiquement. Veillez à rééteindre complètement votre iPhone avant de continuer votre ouvrage.
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - Réponse
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
    I tested all imaginable functionality on the new OLED screen. Taptics are fine. Then, I noticed that the battery wasn't charging. Any ideas as to what could have gone wrong?
    Monica - Réponse
    for me, the replacement battery was completely dead, small panic when the power-on button was pressed, but quickly realised that this was the situation, and now watching the phone take a power cycle.
    James Stanbridge - Réponse
    Before clicking the screen assembly back, I tried to test the iPhone by pushing the start button, but nothing happened. After taking off the bracket, reseating the plugs I tried again - nothing happened! Then I plugged in the charging cable connected with the iMac, and it started immediately. So if the phone does not start using the startup button, it might just be a glitch when reconnecting the battery.
  17. Remplacement du haut-parleur inférieur de l'iPhone X: étape 17, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 17, image 2 de 2
    • Faites levier avec la pointe d'une spatule (spudger) ou un ongle propre pour débrancher le connecteur de la batterie de sa prise sur la carte mère.
    • Essayez de n'endommager aucun des joints en silicone noir qui entourent les connecteurs de la carte. Ces joints sont une protection supplémentaire contre les intrusions de liquide et de poussière.
    • Repliez et écartez légèrement le connecteur de la carte mère pour éviter qu'il ne rentre accidentellement en contact avec la prise et alimente le téléphone pendant que vous effectuez la réparation.
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - Réponse
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - Réponse
    Thanks, already did it)
    Stephen Hedrick -
  18. Remplacement du haut-parleur inférieur de l'iPhone X: étape 18, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 18, image 2 de 2
    • Avec la pointe d'une spatule ou un ongle, déconnectez l'ensemble capteur du panneau frontal.
  19. Remplacement du haut-parleur inférieur de l'iPhone X: étape 19, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 19, image 2 de 2
    • Servez-vous de la pointe d'une spatule ou d'un ongle pour déconnecter le connecteur de la nappe du panneau OLED.
    • Les connecteurs à pression comme celui-ci se reconnectent ainsi : alignez-les soigneusement et appuyez d'un côté puis de l'autre pour les enclencher. N'appuyez pas au milieu. Si un connecteur est mal aligné, les broches pourraient se déformer et causer des dommages irrévocables.
    Snap ‘em in like little Legos.
    Ray Johnson - Réponse
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
    Renout - Réponse
  20. Remplacement du haut-parleur inférieur de l'iPhone X: étape 20, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 20, image 2 de 2
    • Soulevez le connecteur de la nappe de la vitre tactile avec la pointe d'une spatule pour le débrancher de sa prise.
    • L'espace restreint autour de ce connecteur en complique la reconnexion. Prenez votre temps et alignez-le correctement, puis appuyez soigneusement avec le bout du doigt – d'un côté, puis de l'autre. Vous devriez entendre un clic quand il s'enclenche.
    • Si jamais une partie de votre écran ne réagit plus quand vous avez fini la réparation, déconnectez la batterie, puis réenclenchez ce connecteur, en veillant à ce qu'il fasse bien clic et qu'il n'y ait ni poussières ni saletés sur la prise.
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
    I was positive that I had messed something up, I had powered up the phone to test three different times and everything seemed find except there was no touch at all. On my fourth attempt, I carefully examined everything for dust and debris (blowing gently), and I did notice that a corner of the connector (more like part of the ribbon) was bent slightly, and I straightened it. I don't know if it was the ribbon or some tiny debris, but after reseating a fourth time, it worked.
    Pol Llovet - Réponse
    Very important part of the tutorial. Be careful and patience! In my case the screen and camera didn't respond after assemble, so I tried again to reconnect the connector like tutorial said and it worked well. Now my iPhone feel like a new one 💪🏼
    Efrain Maestre - Réponse
  21. Remplacement du haut-parleur inférieur de l'iPhone X: étape 21, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 21, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 21, image 3 de 3
    • La nappe de l'ensemble capteur du panneau frontal adhère légèrement en dessous.
    • Soulevez délicatement la nappe jusqu'à ce que l'adhésif cède.
    Do this sensor affect face id?
    bonglkv - Réponse
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - Réponse
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - Réponse
    My flex cable was more than lightly adhered in place. I needed to use a guitar pic or similar to help encourage adhesive to separate. I wouldn’t pull too hard like shown in pictures unless you had just the right grip on the ribbon cable so as to avoid damaging flex cable. See note above (5/31/20)
    Bizarre — it turns out my whole front panel sensor assembly came entire off of the front screen and is stuck to the logic board.
    Karl Jarvis - Réponse
    I also found the glue quite recluctant to release so I applied a second or two of heat using the wife's hair dryer which softened it and the cable lifted much easier then. Be careful not to apply too much heat though which could then impact other internal components.
    LosBenitos - Réponse
    Cho ít cồn 90° vào để mềm keo dễ tháo
    huuhaukimngan - Réponse
    my iphone x doesn't have a front panel sensor? in fact, it looks completely different than the picture???
    Kenneth McLeod - Réponse
    @kennethmcleod, most likely you've separated the screen frame from the screen itself. We see this most commonly when people neglect to remove the pentalobe screws next to the charging port. Usually the cure is to take out those screws, then repeat the screen removal process on the frame that's still attached to the phone.
    Jerry Wheeler -
    You don't need to disconnect the front sensor to change the screen. Just leave it connected and remove from the screen side.
    Anthony Boshell - Réponse
  22. Remplacement du haut-parleur inférieur de l'iPhone X: étape 22, image 1 de 1
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - Réponse
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - Réponse
    Excellent guide! Would love to have a link to moving the sensor assembly from the old display to the new here.
    Nicole - Réponse
    CAUTION:
    Removing the Taptic Engine or Speaker in next step is optional and the guide continues as this was per se needed.
    Unnecessary work and also If you remove the speaker you lose the adhesive gasket and this is not included in the scope of delivery of the "Battery replacement" offering.
    So do not remove and avoid losing waterproofing.
    Julian Gonzalez - Réponse
  23. Remplacement du haut-parleur inférieur de l'iPhone X, Haut-parleur inférieur: étape 23, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X, Haut-parleur inférieur: étape 23, image 2 de 2
    • Faites attention à ne pas toucher les trois lignes de contacts proches du bas de l'iPhone (encadrées en rouge).
    • Retirez les sept vis qui fixent le cache sur le Taptic Engine et le haut-parleur :
    • Deux vis Y000 de 1,9 mm
    • Une vis Y000 de 1,2 mm
    • Une vis Y000 de 1,6 mm
    • Une vis cruciforme de 2,4 mm
    • Une vis cruciforme de 1,7 mm
    • Une vis cruciforme de 1,5 mm
    For battery replacement:
    It is not necessary to remove Taptic Engine and speaker to replace a battery. Go straight to the step #33
    Additional video: https://youtu.be/2GfBOlJEW10
    Alexander - Réponse
    I wish I seen this before I did all that! Thank you for that information. Next time I do something like this. I'm gonna pay more attention to the comments.
    Eric Marino -
    Removing the Taptic Engine and speaker greatly improves your chances of getting the battery adhesive strips out intact. If those break, you’ll have a much tougher time.
    Jeff Suovanen -
    Boy, I tried to skip removing these items but was unable to get the glue strips out with them in place, not much to grab and tabs were kind of stuck to a seam in the battery, and hard to tell the difference between the seam and the strip tabs. For me I had to remove these items to get this done.
    marshallburchard -
    I stopped removing things after getting the display side off. There were 3 screws stripped on the speaker cover which wouldn't come out so I punted. Just pried the battery out with a smudger tool and some patience, starting at the top and working towards the bottom. New battery is in and working fine.
    Andy Price - Réponse
    The 2.4mm screw identified as “green” needs a Y000 screwdriver
    seb6po - Réponse
    Thanks for not removing the following steps. this made me break the connector for the bottom speakers >:(
    Andrew Romano - Réponse
    The color codes are missing from my display — only on this step.
    nat2 - Réponse
    The screws color and quantities in list don’t match the schematic ! I wish i had a magnetic screw mat before starting, because not only i removed the Taptic Engine and speaker unnecessarily, but i also lost a screw ?
    fb.mailing.lists - Réponse
    For first timer, dont think its possible to skip these steps and remove battery. It’s hard to remove the glue
    Wex - Réponse
    Does anyone know the purpose of this bracket "with grounding pads"? What would be the possible side effects if it was damaged or not connected properly during reassembly?
    Anne Aunyme - Réponse
    I had to remove the tactic and speaker could not get the glue strips out so glad the steps to do so were in this guide.
    P Bond - Réponse
    Sure would like to know WHY the warning "Be careful not to touch the three rows of grounding pads..." What would or could happen if I did touch them??
    Chad Gagnon - Réponse
    Removing the battery strips is a major PITA, just skip this step and everything onwards, remove the one strip on the top part of the battery (according to step 33) and for the bottom part of the battery, pry it off with a plastic spudger.
    Yes, this is not the elegant solution, but the quickest and easiest one. This method is better, as you don't want to keep the old battery anyway, so why bother. (You must not puncture the battery though! But as long as you're only working with a plastic tool and are careful, nothing can happen from my experience.)
    speaker gasket - Réponse
  24. Remplacement du haut-parleur inférieur de l'iPhone X: étape 24, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 24, image 2 de 2
    • Soulevez le cache par le bord le plus proche de la batterie. N'essayez pas encore de le retirer complètement, car il est toujours connecté à une petite nappe.
  25. Remplacement du haut-parleur inférieur de l'iPhone X: étape 25, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 25, image 2 de 2
    • Repliez le cache et utilisez la pointe d'une spatule (spudger) pour soulever et déconnecter la nappe qui se trouve en dessous.
  26. Remplacement du haut-parleur inférieur de l'iPhone X: étape 26, image 1 de 1
    • Ôtez le cache.
    My bracket was in two pieces.
    Jim Steward - Réponse
  27. Remplacement du haut-parleur inférieur de l'iPhone X: étape 27, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 27, image 2 de 2
    • Dévissez la vis Y000 de 2,1 mm qui fixe le cache du connecteur du haut-parleur.
    L'unique vis non?
    Easy Repair - Réponse
    Effectivement ;-) Merci pour les bons yeux et la remarque !
    Claire Miesch -
  28. Remplacement du haut-parleur inférieur de l'iPhone X: étape 28, image 1 de 1
    • Retirez le cache du connecteur du haut-parleur.
  29. Remplacement du haut-parleur inférieur de l'iPhone X: étape 29, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 29, image 2 de 2
    • Avec la pointe de la spatule, soulevez et débranchez le connecteur du haut-parleur.
    As mentioned in a comment by timblake2112 (see step 29), this step is not necessary and can be skipped skipped. I would advise you to do so, as removing your speaker is guaranteed to ruin your gasket and rubber seal. This will result in loss of water resistancy of your iPhone and could potentially harm the sound quality of your speaker.
    Try removing the Taptic Engine without removing the speaker. It might still be possible removing the battery adhesive strips and your speaker will stay in its original condition.
  30. Remplacement du haut-parleur inférieur de l'iPhone X: étape 30, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 30, image 2 de 2
    • Quand vous soulevez le haut-parleur, veillez à ne pas endommager la nappe que vous venez de déconnecter. Si nécessaire, repliez-la de côté pour retirer commodément le haut-parleur.
    • Insérez une spatule sous le bord supérieur du haut-parleur dans le coin de la coque de l'iPhone.
    • Faites délicatement levier pour soulever le bord supérieur du haut-parleur.
    • Au moment de remonter le haut-parleur, vérifiez la position de la nappe et veillez à ce qu'elle ne reste pas coincée sous le haut-parleur.
  31. Remplacement du haut-parleur inférieur de l'iPhone X: étape 31, image 1 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 31, image 2 de 3 Remplacement du haut-parleur inférieur de l'iPhone X: étape 31, image 3 de 3
    • Saisissez le haut-parleur par les bords latéraux et faites-le osciller d'un côté à l'autre pour faire céder l'adhésif qui le fixe au bord inférieur de l'iPhone.
    • Écartez le haut-parleur du bord inférieur de l'iPhone jusqu'à ce que le joint adhésif se décolle.
  32. Remplacement du haut-parleur inférieur de l'iPhone X: étape 32, image 1 de 2 Remplacement du haut-parleur inférieur de l'iPhone X: étape 32, image 2 de 2
    • Retirez le haut-parleur.
    • Le joint adhésif du haut-parleur n'est pas réutilisable. Nettoyez tous les résidus d'adhésif avec une pincette.
    • Lors du remontage, remplacez le joint adhésif pour une protection plus efficace contre l'intrusion d'eau et de poussières. Nettoyez la surface avec un peu d'alcool isopropylique et un chiffon non pelucheux ou un filtre à café pour que le joint adhère correctement. Collez un nouveau joint sur le haut-parleur, puis posez le haut-parleur.
    You don’t need to remove the speaker and ruin its gasket. You can wiggle and slide the taptic engine out without removing the speaker. I’ve done this twice on rear shell replacement jobs.
    timblake2112 - Réponse
    Maybe I'm a bit daft, but where's the instruction just how to line up the speaker gasket when replacing? I only have one so I'd like to avoid wrecking it. And I completely cleaned off the old one in order to do a good job of things. Why no simple instruction from part supply link?
    MrRoundel - Réponse
Comparez votre nouvelle pièce avec l'originale, vous aurez peut-être besoin de transférer les composants restants ou d'enlever l'adhésif sur la nouvelle pièce avant de l'installer.
Pour remonter votre appareil, suivez ces instructions en sens inverse.
Apportez vos déchets électroniques à un recycleur certifié.
La réparation ne s’est pas déroulée comme prévu ? Consultez notre Forum de réponses pour obtenir de l’aide au diagnostic.
40 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Jeff Suovanen
Membre depuis le 08/06/13
428 125 Réputation
259 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
2 commentaires
What is the purpose of that long bracket over the speaker in step 20? Is it some type of heat sync? I noticed it has a flex cable connected to it
Nathan M - Réponse
Where would I apply B-7000 glue if I don’t have a replacement gasket?
pomonella01 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 80
30 derniers jours : 407
Total : 70,746
