Aller au contenu principal
iPad 7 Logic Board Replacement
Ce dont vous avez besoin
  1. iPad 7 Logic Board Replacement, Heat the left edge: étape 1, image 1 de 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 7 Logic Board Replacement, Screen removal information: étape 2, image 1 de 3 iPad 7 Logic Board Replacement, Screen removal information: étape 2, image 2 de 3 iPad 7 Logic Board Replacement, Screen removal information: étape 2, image 3 de 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 7 Logic Board Replacement, Anti-Clamp instructions: étape 3, image 1 de 3 iPad 7 Logic Board Replacement, Anti-Clamp instructions: étape 3, image 2 de 3 iPad 7 Logic Board Replacement, Anti-Clamp instructions: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 7 Logic Board Replacement: étape 4, image 1 de 3 iPad 7 Logic Board Replacement: étape 4, image 2 de 3 iPad 7 Logic Board Replacement: étape 4, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 7 Logic Board Replacement: étape 5, image 1 de 2 iPad 7 Logic Board Replacement: étape 5, image 2 de 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 7 Logic Board Replacement, Insert an opening pick: étape 6, image 1 de 3 iPad 7 Logic Board Replacement, Insert an opening pick: étape 6, image 2 de 3 iPad 7 Logic Board Replacement, Insert an opening pick: étape 6, image 3 de 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 7 Logic Board Replacement, Separate the left adhesive: étape 7, image 1 de 3 iPad 7 Logic Board Replacement, Separate the left adhesive: étape 7, image 2 de 3 iPad 7 Logic Board Replacement, Separate the left adhesive: étape 7, image 3 de 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 7 Logic Board Replacement: étape 8, image 1 de 3 iPad 7 Logic Board Replacement: étape 8, image 2 de 3 iPad 7 Logic Board Replacement: étape 8, image 3 de 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 7 Logic Board Replacement: étape 9, image 1 de 3 iPad 7 Logic Board Replacement: étape 9, image 2 de 3 iPad 7 Logic Board Replacement: étape 9, image 3 de 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 7 Logic Board Replacement, Heat the top edge: étape 10, image 1 de 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 7 Logic Board Replacement, Separate the top left adhesive: étape 11, image 1 de 3 iPad 7 Logic Board Replacement, Separate the top left adhesive: étape 11, image 2 de 3 iPad 7 Logic Board Replacement, Separate the top left adhesive: étape 11, image 3 de 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 7 Logic Board Replacement, Separate the top adhesive: étape 12, image 1 de 3 iPad 7 Logic Board Replacement, Separate the top adhesive: étape 12, image 2 de 3 iPad 7 Logic Board Replacement, Separate the top adhesive: étape 12, image 3 de 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 7 Logic Board Replacement: étape 13, image 1 de 3 iPad 7 Logic Board Replacement: étape 13, image 2 de 3 iPad 7 Logic Board Replacement: étape 13, image 3 de 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 7 Logic Board Replacement: étape 14, image 1 de 3 iPad 7 Logic Board Replacement: étape 14, image 2 de 3 iPad 7 Logic Board Replacement: étape 14, image 3 de 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 7 Logic Board Replacement, Heat the right edge: étape 15, image 1 de 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 7 Logic Board Replacement, Separate the top right adhesive: étape 16, image 1 de 3 iPad 7 Logic Board Replacement, Separate the top right adhesive: étape 16, image 2 de 3 iPad 7 Logic Board Replacement, Separate the top right adhesive: étape 16, image 3 de 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 7 Logic Board Replacement, Separate the right adhesive: étape 17, image 1 de 3 iPad 7 Logic Board Replacement, Separate the right adhesive: étape 17, image 2 de 3 iPad 7 Logic Board Replacement, Separate the right adhesive: étape 17, image 3 de 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 7 Logic Board Replacement, Heat the bottom edge: étape 18, image 1 de 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 7 Logic Board Replacement, Separate the bottom left adhesive: étape 19, image 1 de 3 iPad 7 Logic Board Replacement, Separate the bottom left adhesive: étape 19, image 2 de 3 iPad 7 Logic Board Replacement, Separate the bottom left adhesive: étape 19, image 3 de 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 7 Logic Board Replacement, Separate the bottom adhesive: étape 20, image 1 de 3 iPad 7 Logic Board Replacement, Separate the bottom adhesive: étape 20, image 2 de 3 iPad 7 Logic Board Replacement, Separate the bottom adhesive: étape 20, image 3 de 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 7 Logic Board Replacement: étape 21, image 1 de 3 iPad 7 Logic Board Replacement: étape 21, image 2 de 3 iPad 7 Logic Board Replacement: étape 21, image 3 de 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 7 Logic Board Replacement: étape 22, image 1 de 3 iPad 7 Logic Board Replacement: étape 22, image 2 de 3 iPad 7 Logic Board Replacement: étape 22, image 3 de 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 7 Logic Board Replacement, Heat the right edge: étape 23, image 1 de 1
  24. iPad 7 Logic Board Replacement: étape 24, image 1 de 2 iPad 7 Logic Board Replacement: étape 24, image 2 de 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 7 Logic Board Replacement: étape 25, image 1 de 2 iPad 7 Logic Board Replacement: étape 25, image 2 de 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 7 Logic Board Replacement, Separate the right adhesive: étape 26, image 1 de 3 iPad 7 Logic Board Replacement, Separate the right adhesive: étape 26, image 2 de 3 iPad 7 Logic Board Replacement, Separate the right adhesive: étape 26, image 3 de 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 7 Logic Board Replacement: étape 27, image 1 de 2 iPad 7 Logic Board Replacement: étape 27, image 2 de 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 7 Logic Board Replacement, Remove the LCD: étape 28, image 1 de 2 iPad 7 Logic Board Replacement, Remove the LCD: étape 28, image 2 de 2
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the LCD to the frame.
    • Remove any tape obscuring the LCD screws.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  29. iPad 7 Logic Board Replacement, Flip the LCD over: étape 29, image 1 de 3 iPad 7 Logic Board Replacement, Flip the LCD over: étape 29, image 2 de 3 iPad 7 Logic Board Replacement, Flip the LCD over: étape 29, image 3 de 3
    • Don't attempt to fully remove the LCD during this step, as it's still connected by several cables at the home button end.
    • Only lift the LCD from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
    • Lay the LCD down onto a clean, soft, lint-free surface to allow access to the display cables.
  30. iPad 7 Logic Board Replacement, Disconnect the battery: étape 30, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the battery: étape 30, image 2 de 2
    • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
  31. iPad 7 Logic Board Replacement, Battery connector information: étape 31, image 1 de 3 iPad 7 Logic Board Replacement, Battery connector information: étape 31, image 2 de 3 iPad 7 Logic Board Replacement, Battery connector information: étape 31, image 3 de 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 7 Logic Board Replacement, Disconnect the battery: étape 32, image 1 de 3 iPad 7 Logic Board Replacement, Disconnect the battery: étape 32, image 2 de 3 iPad 7 Logic Board Replacement, Disconnect the battery: étape 32, image 3 de 3
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 7 Logic Board Replacement, Unfasten the display cable bracket: étape 33, image 1 de 2 iPad 7 Logic Board Replacement, Unfasten the display cable bracket: étape 33, image 2 de 2
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
  34. iPad 7 Logic Board Replacement, Remove the display cable bracket: étape 34, image 1 de 2 iPad 7 Logic Board Replacement, Remove the display cable bracket: étape 34, image 2 de 2
    • Remove the display cable bracket.
  35. iPad 7 Logic Board Replacement, Disconnect the LCD: étape 35, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the LCD: étape 35, image 2 de 2
    • Use the flat end of a spudger to disconnect the LCD cable by lifting straight up on the press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  36. iPad 7 Logic Board Replacement, Remove the LCD: étape 36, image 1 de 2 iPad 7 Logic Board Replacement, Remove the LCD: étape 36, image 2 de 2
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
  37. iPad 7 Logic Board Replacement, Disconnect the home button: étape 37, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the home button: étape 37, image 2 de 2
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
  38. iPad 7 Logic Board Replacement: étape 38, image 1 de 2 iPad 7 Logic Board Replacement: étape 38, image 2 de 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
  39. iPad 7 Logic Board Replacement: étape 39, image 1 de 2 iPad 7 Logic Board Replacement: étape 39, image 2 de 2
    • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
  40. iPad 7 Logic Board Replacement, Disconnect the display cables: étape 40, image 1 de 3 iPad 7 Logic Board Replacement, Disconnect the display cables: étape 40, image 2 de 3 iPad 7 Logic Board Replacement, Disconnect the display cables: étape 40, image 3 de 3
    • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  41. iPad 7 Logic Board Replacement, Remove the vibration isolator: étape 41, image 1 de 3 iPad 7 Logic Board Replacement, Remove the vibration isolator: étape 41, image 2 de 3 iPad 7 Logic Board Replacement, Remove the vibration isolator: étape 41, image 3 de 3
    • Use the flat end of a spudger to pry up the vibration isolator near the bottom-right corner of the device.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the vibration isolator.
  42. iPad 7 Logic Board Replacement: étape 42, image 1 de 2 iPad 7 Logic Board Replacement: étape 42, image 2 de 2
    • The home button cable is secured with some light adhesive.
    • Use a pair of tweezers to peel the home button cable away from the frame.
  43. iPad 7 Logic Board Replacement, Remove the front panel assembly: étape 43, image 1 de 3 iPad 7 Logic Board Replacement, Remove the front panel assembly: étape 43, image 2 de 3 iPad 7 Logic Board Replacement, Remove the front panel assembly: étape 43, image 3 de 3
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  44. iPad 7 Logic Board Replacement, Unfasten the upper component bracket: étape 44, image 1 de 2 iPad 7 Logic Board Replacement, Unfasten the upper component bracket: étape 44, image 2 de 2
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the upper component bracket.
  45. iPad 7 Logic Board Replacement, Remove the upper component bracket: étape 45, image 1 de 2 iPad 7 Logic Board Replacement, Remove the upper component bracket: étape 45, image 2 de 2
    • Use tweezers, or your fingers, to remove the upper component bracket from the frame.
  46. iPad 7 Logic Board Replacement, Disconnect the front camera: étape 46, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the front camera: étape 46, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the front camera cable's press connector.
  47. iPad 7 Logic Board Replacement, Remove the front camera shell: étape 47, image 1 de 2 iPad 7 Logic Board Replacement, Remove the front camera shell: étape 47, image 2 de 2
    • The front camera shell is lightly adhered to the frame.
    • Insert an opening pick between the front camera shell and the frame.
  48. iPad 7 Logic Board Replacement: étape 48, image 1 de 3 iPad 7 Logic Board Replacement: étape 48, image 2 de 3 iPad 7 Logic Board Replacement: étape 48, image 3 de 3
    • Slide the pick along the perimeter of the camera shell to separate the adhesive.
  49. iPad 7 Logic Board Replacement: étape 49, image 1 de 3 iPad 7 Logic Board Replacement: étape 49, image 2 de 3 iPad 7 Logic Board Replacement: étape 49, image 3 de 3
    • Pry up with the opening pick to separate the front camera shell from the frame.
    • Remove the front camera shell.
  50. iPad 7 Logic Board Replacement, Remove the front camera: étape 50, image 1 de 3 iPad 7 Logic Board Replacement, Remove the front camera: étape 50, image 2 de 3 iPad 7 Logic Board Replacement, Remove the front camera: étape 50, image 3 de 3
    • The front camera is mounted on microphone assembly with adhesive.
    • Insert a spudger between the front camera and the microphone assembly
    • Pry up to separate the front camera's adhesive.
    • Remove the front camera.
  51. iPad 7 Logic Board Replacement, Disconnect the headphone jack: étape 51, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the headphone jack: étape 51, image 2 de 2
    • Use the flat end of a spudger to disconnect the headphone jack by lifting straight up on the press connector.
  52. iPad 7 Logic Board Replacement: étape 52, image 1 de 3 iPad 7 Logic Board Replacement: étape 52, image 2 de 3 iPad 7 Logic Board Replacement: étape 52, image 3 de 3
    • Use your fingers to peel the headphone jack up from the frame and fold the cable out of the way.
  53. iPad 7 Logic Board Replacement, Disconnect the rear camera: étape 53, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the rear camera: étape 53, image 2 de 2
    • Use the flat end of a spudger to disconnect the rear camera by lifting straight up on the press connector.
  54. iPad 7 Logic Board Replacement, Disconnect the microphone assembly: étape 54, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the microphone assembly: étape 54, image 2 de 2
    • Use the flat end of a spudger to disconnect the microphone assembly by lifting straight up on the press connector.
  55. iPad 7 Logic Board Replacement, Disconnect the button control cable: étape 55, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the button control cable: étape 55, image 2 de 2
  56. iPad 7 Logic Board Replacement: étape 56, image 1 de 2 iPad 7 Logic Board Replacement: étape 56, image 2 de 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable ZIF connector.
  57. iPad 7 Logic Board Replacement: étape 57, image 1 de 2 iPad 7 Logic Board Replacement: étape 57, image 2 de 2
    • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
  58. iPad 7 Logic Board Replacement, Disconnect the Smart Cover sensor: étape 58, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the Smart Cover sensor: étape 58, image 2 de 2
    • Peel off any tape covering the Smart Cover sensor cable ZIF connector.
  59. iPad 7 Logic Board Replacement: étape 59, image 1 de 2 iPad 7 Logic Board Replacement: étape 59, image 2 de 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Smart Cover sensor cable ZIF connector.
  60. iPad 7 Logic Board Replacement: étape 60, image 1 de 2 iPad 7 Logic Board Replacement: étape 60, image 2 de 2
    • Use a pair of tweezers to carefully pull the Smart Cover sensor cable straight out of the ZIF connector.
  61. iPad 7 Logic Board Replacement, Disconnect the antennas: étape 61, image 1 de 3 iPad 7 Logic Board Replacement, Disconnect the antennas: étape 61, image 2 de 3 iPad 7 Logic Board Replacement, Disconnect the antennas: étape 61, image 3 de 3
    • Use the tip of a spudger to pry up and disconnect the left antenna's coaxial cable.
    • Repeat for the right antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  62. iPad 7 Logic Board Replacement: étape 62, image 1 de 2 iPad 7 Logic Board Replacement: étape 62, image 2 de 2
    • Peel up the right antenna cable.
    • Grip the antenna cable by the cable itself and not at its connector. Pulling coaxial cables by their connectors can break them.
  63. iPad 7 Logic Board Replacement, Reposition the left antenna cable: étape 63, image 1 de 3 iPad 7 Logic Board Replacement, Reposition the left antenna cable: étape 63, image 2 de 3 iPad 7 Logic Board Replacement, Reposition the left antenna cable: étape 63, image 3 de 3
    • Peel the left antenna cable away from the frame, along the bottom edge of the iPad.
  64. iPad 7 Logic Board Replacement, Remove the vibration isolator: étape 64, image 1 de 3 iPad 7 Logic Board Replacement, Remove the vibration isolator: étape 64, image 2 de 3 iPad 7 Logic Board Replacement, Remove the vibration isolator: étape 64, image 3 de 3
    • Use the flat end of a spudger to pry up the vibration isolator at the bottom left corner of the iPad.
    • Use a pair of tweezers to remove the vibration isolator.
  65. iPad 7 Logic Board Replacement, Disconnect the speakers: étape 65, image 1 de 3 iPad 7 Logic Board Replacement, Disconnect the speakers: étape 65, image 2 de 3 iPad 7 Logic Board Replacement, Disconnect the speakers: étape 65, image 3 de 3
    • Use a pair of tweezers, or your fingers, to peel up the tape covering the speaker connectors.
  66. iPad 7 Logic Board Replacement: étape 66, image 1 de 3 iPad 7 Logic Board Replacement: étape 66, image 2 de 3 iPad 7 Logic Board Replacement: étape 66, image 3 de 3
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on both the left and right speaker cable ZIF connectors.
  67. iPad 7 Logic Board Replacement: étape 67, image 1 de 3 iPad 7 Logic Board Replacement: étape 67, image 2 de 3 iPad 7 Logic Board Replacement: étape 67, image 3 de 3
    • Use a pair of tweezers to carefully pull the left and right speaker cables straight out of their respective ZIF connectors.
  68. iPad 7 Logic Board Replacement, Disconnect the Smart Connector: étape 68, image 1 de 2 iPad 7 Logic Board Replacement, Disconnect the Smart Connector: étape 68, image 2 de 2
    • Use the pointed end of a spudger to disconnect the Smart Connector coaxial cable by prying up as close to the connector as possible.
  69. iPad 7 Logic Board Replacement: étape 69, image 1 de 2 iPad 7 Logic Board Replacement: étape 69, image 2 de 2
    • Use a spudger to pry up and disconnect the Smart Connector cable's connector.
  70. iPad 7 Logic Board Replacement: étape 70, image 1 de 2 iPad 7 Logic Board Replacement: étape 70, image 2 de 2
    • Use a pair of tweezers to peel back the tape securing the Smart Connector cables to the frame.
  71. iPad 7 Logic Board Replacement, Reposition the Smart Connector cable: étape 71, image 1 de 3 iPad 7 Logic Board Replacement, Reposition the Smart Connector cable: étape 71, image 2 de 3 iPad 7 Logic Board Replacement, Reposition the Smart Connector cable: étape 71, image 3 de 3
    • Peel the Smart Connector cables away from the frame.
  72. iPad 7 Logic Board Replacement, Unfasten the charging port: étape 72, image 1 de 2 iPad 7 Logic Board Replacement, Unfasten the charging port: étape 72, image 2 de 2
    • Use a Phillips screwdriver to remove the four screws securing the charging port to the frame:
    • Two 2.2 mm-long screws
    • Two 3.2 mm-long screws
  73. iPad 7 Logic Board Replacement, Soften the adhesive: étape 73, image 1 de 3 iPad 7 Logic Board Replacement, Soften the adhesive: étape 73, image 2 de 3 iPad 7 Logic Board Replacement, Soften the adhesive: étape 73, image 3 de 3
    • Heat an iOpener and apply it to the bottom, top, and logic board side of the iPad for thirty seconds in each location.
  74. iPad 7 Logic Board Replacement, Separate the charging port cable's adhesive: étape 74, image 1 de 2 iPad 7 Logic Board Replacement, Separate the charging port cable's adhesive: étape 74, image 2 de 2
    • Insert an opening pick under the charging port cable near the logic board and slide it toward the charging port to slice the adhesive.
  75. iPad 7 Logic Board Replacement: étape 75, image 1 de 3 iPad 7 Logic Board Replacement: étape 75, image 2 de 3 iPad 7 Logic Board Replacement: étape 75, image 3 de 3
    • Insert an opening pick under the charging port cable near the charging port and slide it towards the logic board to cut the adhesive.
  76. iPad 7 Logic Board Replacement, Remove the charging port: étape 76, image 1 de 2 iPad 7 Logic Board Replacement, Remove the charging port: étape 76, image 2 de 2
    • Pull the charging port out of its slot in the frame.
  77. iPad 7 Logic Board Replacement, Remove the logic board: étape 77, image 1 de 3 iPad 7 Logic Board Replacement, Remove the logic board: étape 77, image 2 de 3 iPad 7 Logic Board Replacement, Remove the logic board: étape 77, image 3 de 3
    • Insert an opening pick under the upper arm of the logic board and slide it toward the logic board to cut the adhesive securing it to the frame.
    • Leave the opening pick inserted to keep the adhesive from re-adhering.
  78. iPad 7 Logic Board Replacement: étape 78, image 1 de 2 iPad 7 Logic Board Replacement: étape 78, image 2 de 2
    • Remove the battery blocker.
  79. iPad 7 Logic Board Replacement: étape 79, image 1 de 2 iPad 7 Logic Board Replacement: étape 79, image 2 de 2
    • Insert an opening tool near the middle of the logic board and pry up with a slow and steady force to peel it away from the frame.
    • Bending or warping the logic board could lead to permanent damage. If the adhesive feels extra stubborn, apply more heat and try again.
    • If the logic board won't budge, slide an opening pick underneath the bottom edge of the logic board to slice some of the adhesive.
  80. iPad 7 Logic Board Replacement: étape 80, image 1 de 2 iPad 7 Logic Board Replacement: étape 80, image 2 de 2
    Halberd Spudger
    $2.99
    • Use a halberd spudger or an opening pick to slice any remaining adhesive securing the logic board to the frame.
  81. iPad 7 Logic Board Replacement: étape 81, image 1 de 2 iPad 7 Logic Board Replacement: étape 81, image 2 de 2
    Tesa 61395 Tape
    $5.99
    • Remove the logic board.
    • During reassembly, ensure that there are no ribbon cables stuck under the logic board before gluing it down.
    • During reassembly, apply strips of Tesa tape if the original adhesive is too mangled to be reused.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 7 Answers community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
162 071 Réputation
769 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 425 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 53
30 derniers jours : 163
Total : 3,609
