Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPhone 16e Screen Replacement
Ce dont vous avez besoin
  1. iPhone 16e Screen Replacement, Before you begin: étape 1, image 1 de 2 iPhone 16e Screen Replacement, Before you begin: étape 1, image 2 de 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power button and either volume button, then slide to power off your phone.
    Demander à FixBot
    Ajouter un commentaire
  2. iPhone 16e Screen Replacement, Tape over any cracks: étape 2, image 1 de 2 iPhone 16e Screen Replacement, Tape over any cracks: étape 2, image 2 de 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Demander à FixBot
  3. iPhone 16e Screen Replacement, Remove the pentalobe screws: étape 3, image 1 de 2 iPhone 16e Screen Replacement, Remove the pentalobe screws: étape 3, image 2 de 2
    • Use a pentalobe P2 screwdriver to remove the two 7.8 mm‑long screws on either side of the charging port.
    Demander à FixBot
  4. iPhone 16e Screen Replacement, Mark your opening picks: étape 4, image 1 de 3 iPhone 16e Screen Replacement, Mark your opening picks: étape 4, image 2 de 3 iPhone 16e Screen Replacement, Mark your opening picks: étape 4, image 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Demander à FixBot
  5. iPhone 16e Screen Replacement, Heat the bottom edge: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    iOpener
    $14.95
    Demander à FixBot
  6. iPhone 16e Screen Replacement, Insert an opening pick: étape 6, image 1 de 3 iPhone 16e Screen Replacement, Insert an opening pick: étape 6, image 2 de 3 iPhone 16e Screen Replacement, Insert an opening pick: étape 6, image 3 de 3
    • The screen consists of a display panel and a bezel. Make sure you insert the pick under the bezel, or you risk separating the two layers and destroying the screen.
    • Apply a suction handle to the bottom edge of the screen.
    • While holding the frame down with one hand, pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    Demander à FixBot
  7. iPhone 16e Screen Replacement, Screen information: étape 7, image 1 de 2 iPhone 16e Screen Replacement, Screen information: étape 7, image 2 de 2
    • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the phone—one next to the Action button and the other about halfway between the volume down button and the bottom of the phone.
    • Multiple spring contacts around the perimeter of the phone.
    Demander à FixBot
  8. iPhone 16e Screen Replacement: étape 8, image 1 de 3 iPhone 16e Screen Replacement: étape 8, image 2 de 3 iPhone 16e Screen Replacement: étape 8, image 3 de 3
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the opening pick in the bottom right corner.
    Demander à FixBot
  9. iPhone 16e Screen Replacement, Heat the right edge: étape 9, image 1 de 2 iPhone 16e Screen Replacement, Heat the right edge: étape 9, image 2 de 2
    • Heat the right edge of the screen until it's hot to the touch.
    Demander à FixBot
  10. iPhone 16e Screen Replacement: étape 10, image 1 de 2 iPhone 16e Screen Replacement: étape 10, image 2 de 2
    • Slide your opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive and release the metal clip.
    • You'll hear and feel the metal clip release as you pass it.
    Demander à FixBot
  11. iPhone 16e Screen Replacement, Heat the top edge: étape 11, image 1 de 1
    • Heat the top edge of the screen until it's hot to the touch.
    Demander à FixBot
  12. iPhone 16e Screen Replacement, Separate the top adhesive: étape 12, image 1 de 2 iPhone 16e Screen Replacement, Separate the top adhesive: étape 12, image 2 de 2
    • Continue sliding your pick around the top right corner and across the top edge to separate the adhesive and release the two metal clips.
    Demander à FixBot
  13. iPhone 16e Screen Replacement, Heat the left edge: étape 13, image 1 de 2 iPhone 16e Screen Replacement, Heat the left edge: étape 13, image 2 de 2
    • Heat the left edge of the screen until it's hot to the touch.
    Demander à FixBot
  14. iPhone 16e Screen Replacement, Separate the left adhesive: étape 14, image 1 de 2 iPhone 16e Screen Replacement, Separate the left adhesive: étape 14, image 2 de 2
    • Slide the opening pick down the left edge of the screen to separate the remaining adhesive and release the last two metal clips.
    Demander à FixBot
  15. iPhone 16e Screen Replacement, Prop up the screen: étape 15, image 1 de 3 iPhone 16e Screen Replacement, Prop up the screen: étape 15, image 2 de 3 iPhone 16e Screen Replacement, Prop up the screen: étape 15, image 3 de 3
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the screen over the left edge of the phone and support it with a clean, sturdy object.
    Demander à FixBot
  16. iPhone 16e Screen Replacement, Remove the cover screws: étape 16, image 1 de 2 iPhone 16e Screen Replacement, Remove the cover screws: étape 16, image 2 de 2
    • Use a tri-point Y000 screwdriver to remove the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
    Demander à FixBot
  17. iPhone 16e Screen Replacement, Remove the covers: étape 17, image 1 de 3 iPhone 16e Screen Replacement, Remove the covers: étape 17, image 2 de 3 iPhone 16e Screen Replacement, Remove the covers: étape 17, image 3 de 3
    • Use tweezers or your fingers to lift the front sensor cover to a 90-degree angle and unhook it from its slot in the logic board.
    • Lift the cover out of its slot and remove it.
    Demander à FixBot
  18. iPhone 16e Screen Replacement: étape 18, image 1 de 3 iPhone 16e Screen Replacement: étape 18, image 2 de 3 iPhone 16e Screen Replacement: étape 18, image 3 de 3
    • Use tweezers or your fingers to lift the screen connector cover at a slight angle to unhook it from its slot in the logic board.
    Demander à FixBot
  19. iPhone 16e Screen Replacement, Disconnect the screen: étape 19, image 1 de 3 iPhone 16e Screen Replacement, Disconnect the screen: étape 19, image 2 de 3 iPhone 16e Screen Replacement, Disconnect the screen: étape 19, image 3 de 3
    • Use the tip of a spudger to pry up and disconnect the screen press connector.
    • Repeat for the front sensor press connector.
    Demander à FixBot
  20. iPhone 16e Screen Replacement, Remove the screen: étape 20, image 1 de 1
    • Lift the screen off the frame and remove it.
    Demander à FixBot
  21. iPhone 16e Screen Replacement, End of disassembly: étape 21, image 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    Demander à FixBot
  22. iPhone 16e Screen Replacement, Remove the old adhesive: étape 22, image 1 de 2 iPhone 16e Screen Replacement, Remove the old adhesive: étape 22, image 2 de 2
    • Use tweezers to remove the adhesive around the perimeter of the frame.
    • You may need to bunch up the adhesive with the point of a spudger before gripping it with tweezers.
    • Use a coffee filter or a lint‑free cloth and high‑concentration isopropyl alcohol (>%90) to clean off any adhesive residue.
    Demander à FixBot
  23. iPhone 16e Screen Replacement, Orient the adhesive: étape 23, image 1 de 2 iPhone 16e Screen Replacement, Orient the adhesive: étape 23, image 2 de 2
    • Lay the adhesive on top of the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
    Demander à FixBot
  24. iPhone 16e Screen Replacement, Apply the adhesive: étape 24, image 1 de 3 iPhone 16e Screen Replacement, Apply the adhesive: étape 24, image 2 de 3 iPhone 16e Screen Replacement, Apply the adhesive: étape 24, image 3 de 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
    • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
    Demander à FixBot
  25. iPhone 16e Screen Replacement: étape 25, image 1 de 3 iPhone 16e Screen Replacement: étape 25, image 2 de 3 iPhone 16e Screen Replacement: étape 25, image 3 de 3
    • Continue peeling the back liner off the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    Demander à FixBot
  26. iPhone 16e Screen Replacement, Press the adhesive into place: étape 26, image 1 de 2 iPhone 16e Screen Replacement, Press the adhesive into place: étape 26, image 2 de 2
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    Demander à FixBot
  27. iPhone 16e Screen Replacement: étape 27, image 1 de 3 iPhone 16e Screen Replacement: étape 27, image 2 de 3 iPhone 16e Screen Replacement: étape 27, image 3 de 3
    • Use the tip of a spudger to lift up the pull tab on the top right corner of the blue adhesive liner until you can grip it with your fingers.
    Demander à FixBot
  28. iPhone 16e Screen Replacement: étape 28, image 1 de 3 iPhone 16e Screen Replacement: étape 28, image 2 de 3 iPhone 16e Screen Replacement: étape 28, image 3 de 3
    • Use the pull tab to peel the blue liner off the frame.
    Demander à FixBot
  29. iPhone 16e Screen Replacement, Connect the screen: étape 29, image 1 de 3 iPhone 16e Screen Replacement, Connect the screen: étape 29, image 2 de 3 iPhone 16e Screen Replacement, Connect the screen: étape 29, image 3 de 3
    • Prop up the screen along the left edge of the iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the screen press connector.
    Demander à FixBot
  30. iPhone 16e Screen Replacement: étape 30, image 1 de 3 iPhone 16e Screen Replacement: étape 30, image 2 de 3 iPhone 16e Screen Replacement: étape 30, image 3 de 3
    • Insert the top of the screen connector cover into its slot in the frame and lay it over the press connector.
    Demander à FixBot
  31. iPhone 16e Screen Replacement: étape 31, image 1 de 3 iPhone 16e Screen Replacement: étape 31, image 2 de 3 iPhone 16e Screen Replacement: étape 31, image 3 de 3
    • Angle the front sensor connector cover at a 90-degree angle and insert it into its slot in the frame.
    • Lay the cover over the press connector.
    Demander à FixBot
  32. iPhone 16e Screen Replacement, Install the cover screws: étape 32, image 1 de 2 iPhone 16e Screen Replacement, Install the cover screws: étape 32, image 2 de 2
    • Use a tri-point Y000 screwdriver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
    Demander à FixBot
  33. iPhone 16e Screen Replacement: étape 33, image 1 de 3 iPhone 16e Screen Replacement: étape 33, image 2 de 3 iPhone 16e Screen Replacement: étape 33, image 3 de 3
    • Use tweezers or your fingers to grip the blue pull tab and remove the liner along the right edge.
    • Without letting the screen touch the adhesive, hold the screen over the phone and remove the other two liners.
    Demander à FixBot
  34. iPhone 16e Screen Replacement, Place the screen: étape 34, image 1 de 2 iPhone 16e Screen Replacement, Place the screen: étape 34, image 2 de 2
    • Hold the screen above the phone and align it with the frame.
    Demander à FixBot
  35. iPhone 16e Screen Replacement: étape 35, image 1 de 3 iPhone 16e Screen Replacement: étape 35, image 2 de 3 iPhone 16e Screen Replacement: étape 35, image 3 de 3
    • Lay the screen straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the screen to engage all clips.
    Demander à FixBot
  36. iPhone 16e Screen Replacement, Heat the screen: étape 36, image 1 de 2 iPhone 16e Screen Replacement, Heat the screen: étape 36, image 2 de 2
    • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
    Demander à FixBot
  37. iPhone 16e Screen Replacement, Press the screen: étape 37, image 1 de 3 iPhone 16e Screen Replacement, Press the screen: étape 37, image 2 de 3 iPhone 16e Screen Replacement, Press the screen: étape 37, image 3 de 3
    • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    Demander à FixBot
  38. iPhone 16e Screen Replacement: étape 38, image 1 de 3 iPhone 16e Screen Replacement: étape 38, image 2 de 3 iPhone 16e Screen Replacement: étape 38, image 3 de 3
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    Demander à FixBot
  39. iPhone 16e Screen Replacement: étape 39, image 1 de 3 iPhone 16e Screen Replacement: étape 39, image 2 de 3 iPhone 16e Screen Replacement: étape 39, image 3 de 3
    • Place one layer of coins or similarly thick objects on the tape along the edges of the back glass.
    • Depending on the thickness of the coins, you might need multiple layers.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    Demander à FixBot
  40. iPhone 16e Screen Replacement: étape 40, image 1 de 1
    • Stack multiple books or other heavy objects on the iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Demander à FixBot
  41. iPhone 16e Screen Replacement, Install the pentalobe screws: étape 41, image 1 de 2 iPhone 16e Screen Replacement, Install the pentalobe screws: étape 41, image 2 de 2
    • Use a P2 pentalobe screwdriver to install the two 7.8 mm‑long screws on either side of the charging port.
    Demander à FixBot
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16e Answers Community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
239 234 Réputation
1 171 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 946 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 49
7 derniers jours : 255
30 derniers jours : 1,048
Total : 8,321
