Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPhone 17 Pro Back Glass Replacement
Ce dont vous avez besoin
  1. iPhone 17 Pro Back Glass Replacement, Safety precautions: étape 1, image 1 de 2 iPhone 17 Pro Back Glass Replacement, Safety precautions: étape 1, image 2 de 2
    • Let your iPhone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
    Demander à FixBot
    Ajouter un commentaire
  2. iPhone 17 Pro Back Glass Replacement, Cracked glass preparation: étape 2, image 1 de 3 iPhone 17 Pro Back Glass Replacement, Cracked glass preparation: étape 2, image 2 de 3 iPhone 17 Pro Back Glass Replacement, Cracked glass preparation: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    iFixit Safety Glasses
    $7.95
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone is cracked, follow this step.
    • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
    • Make sure there's a single strip of tape (not overlapping) across the bottom edge, big enough for a suction cup to fit on.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    Demander à FixBot
  3. iPhone 17 Pro Back Glass Replacement, Remove the pentalobe screws: étape 3, image 1 de 2 iPhone 17 Pro Back Glass Replacement, Remove the pentalobe screws: étape 3, image 2 de 2
    • Use a P2 pentalobe screwdriver to remove the two 7.5 mm‑long screws on either side of the charging port.
    Demander à FixBot
  4. iPhone 17 Pro Back Glass Replacement, Heat the bottom edge: étape 4, image 1 de 1
    • Adhesive secures the back glass to the frame. Heating the glass softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the back glass until it's slightly too hot to touch.
    • Improper use of a heat gun can destroy the wireless charging assembly and/or battery—follow the linked instructions carefully.
    Demander à FixBot
  5. iPhone 17 Pro Back Glass Replacement, Apply a suction handle: étape 5, image 1 de 2 iPhone 17 Pro Back Glass Replacement, Apply a suction handle: étape 5, image 2 de 2
    • Apply a suction handle to the bottom edge of the back glass, as close to the edge as possible.
    Demander à FixBot
  6. iPhone 17 Pro Back Glass Replacement, Insert an opening pick: étape 6, image 1 de 3 iPhone 17 Pro Back Glass Replacement, Insert an opening pick: étape 6, image 2 de 3 iPhone 17 Pro Back Glass Replacement, Insert an opening pick: étape 6, image 3 de 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
    • If you're having trouble, apply more heat and try again.
    • Insert the tip of an opening pick into the gap you just created.
    Demander à FixBot
  7. iPhone 17 Pro Back Glass Replacement, Separate the adhesive: étape 7, image 1 de 3 iPhone 17 Pro Back Glass Replacement, Separate the adhesive: étape 7, image 2 de 3 iPhone 17 Pro Back Glass Replacement, Separate the adhesive: étape 7, image 3 de 3
    • Slide the opening pick around the perimeter of the back glass to separate all the adhesive securing it.
    • Only insert your pick slightly under the back glass near the top of the left edge. Otherwise, you may damage the wireless charging ribbon cable.
    Demander à FixBot
  8. iPhone 17 Pro Back Glass Replacement, Prop up the back glass: étape 8, image 1 de 3 iPhone 17 Pro Back Glass Replacement, Prop up the back glass: étape 8, image 2 de 3 iPhone 17 Pro Back Glass Replacement, Prop up the back glass: étape 8, image 3 de 3
    • At this point, the back glass should be completely separated from the frame. If it feels stuck, go back around the perimeter and separate any remaining adhesive.
    • Flip the back glass over the left edge and use the suction handle to prop it up.
    • Alternatively, you can lay the glass down flat over the left side.
    Demander à FixBot
  9. iPhone 17 Pro Back Glass Replacement, Remove the cover screw: étape 9, image 1 de 2 iPhone 17 Pro Back Glass Replacement, Remove the cover screw: étape 9, image 2 de 2
    • Be careful not to damage the exposed battery with your tools during the next few steps.
    • Use a tri‑point Y000 screwdriver to remove the 1.0 mm‑long screw securing the wireless charging connector cover.
    Demander à FixBot
  10. iPhone 17 Pro Back Glass Replacement, Remove the cover: étape 10, image 1 de 2 iPhone 17 Pro Back Glass Replacement, Remove the cover: étape 10, image 2 de 2
    • Remove the cover.
    Demander à FixBot
  11. iPhone 17 Pro Back Glass Replacement, Disconnect the back glass: étape 11, image 1 de 2 iPhone 17 Pro Back Glass Replacement, Disconnect the back glass: étape 11, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the wireless charging press connector.
    Demander à FixBot
  12. iPhone 17 Pro Back Glass Replacement, Remove the back glass: étape 12, image 1 de 1
    • Remove the back glass.
    Demander à FixBot
  13. iPhone 17 Pro Back Glass Replacement, Disassembly complete: étape 13, image 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone.
    • Depending on your iPhone model, some reassembly photos may have minor visual discrepancies. The procedure, however, will be correct for your iPhone.
    Demander à FixBot
  14. iPhone 17 Pro Back Glass Replacement, Remove the leftover adhesive: étape 14, image 1 de 2 iPhone 17 Pro Back Glass Replacement, Remove the leftover adhesive: étape 14, image 2 de 2
    • Use blunt-nose tweezers or your fingers to remove large pieces of adhesive from the frame.
    • Use a spudger to scrape the adhesive residue off the frame.
    • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
    Demander à FixBot
  15. iPhone 17 Pro Back Glass Replacement, Orient the replacement adhesive: étape 15, image 1 de 1
    • Without peeling any liners, lay the adhesive sheet over the frame to determine its proper orientation.
    • Use features such as the back glass connector notch to help orient the adhesive.
    Demander à FixBot
  16. iPhone 17 Pro Back Glass Replacement, Apply the replacement adhesive: étape 16, image 1 de 1
    • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
    • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
    Demander à FixBot
  17. iPhone 17 Pro Back Glass Replacement: étape 17, image 1 de 3 iPhone 17 Pro Back Glass Replacement: étape 17, image 2 de 3 iPhone 17 Pro Back Glass Replacement: étape 17, image 3 de 3
    • Carefully align and press the exposed edge of the adhesive strip onto the frame.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
    • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
    • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
    • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
    Demander à FixBot
  18. iPhone 17 Pro Back Glass Replacement: étape 18, image 1 de 1
    • Use a spudger to press the adhesive around the entire perimeter.
    • Don't press too hard, or you'll stretch and deform the adhesive.
    Demander à FixBot
  19. iPhone 17 Pro Back Glass Replacement: étape 19, image 1 de 2 iPhone 17 Pro Back Glass Replacement: étape 19, image 2 de 2
    • Use the pull tab to peel off the large front liner from the adhesive—the pull tab is often in a corner of the liner.
    • If the adhesive starts to peel up with the liner, hold the adhesive down with the point of a spudger as you go.
    • At this point, you may still have a liner covering the perimeter, which prevents the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
    Demander à FixBot
  20. iPhone 17 Pro Back Glass Replacement, Install the back glass: étape 20, image 1 de 1
    • Position the back glass so you can comfortably reconnect it.
    • Use your finger or a spudger to press and connect the back glass press connector onto the logic board.
    Demander à FixBot
  21. iPhone 17 Pro Back Glass Replacement: étape 21, image 1 de 3 iPhone 17 Pro Back Glass Replacement: étape 21, image 2 de 3 iPhone 17 Pro Back Glass Replacement: étape 21, image 3 de 3
    • Slide the connector cover in place so the tab on the top edge tucks under the lip.
    Demander à FixBot
  22. iPhone 17 Pro Back Glass Replacement: étape 22, image 1 de 1
    • Use a tri‑point Y000 screwdriver to install the 1.0 mm‑long screw to secure the connector cover.
    Demander à FixBot
  23. iPhone 17 Pro Back Glass Replacement: étape 23, image 1 de 2 iPhone 17 Pro Back Glass Replacement: étape 23, image 2 de 2
    • Use one hand to hold the back glass up. Be careful not to strain the cable.
    • Use your fingers or tweezers to peel away all remaining liners, exposing the perimeter adhesive.
    Demander à FixBot
  24. iPhone 17 Pro Back Glass Replacement: étape 24, image 1 de 2 iPhone 17 Pro Back Glass Replacement: étape 24, image 2 de 2
    • Align the top edge of the back glass with its cutout and lay it in place.
    Demander à FixBot
  25. iPhone 17 Pro Back Glass Replacement: étape 25, image 1 de 3 iPhone 17 Pro Back Glass Replacement: étape 25, image 2 de 3 iPhone 17 Pro Back Glass Replacement: étape 25, image 3 de 3
    • Use your fingers to firmly squeeze around the entire perimeter of the back glass.
    Demander à FixBot
  26. iPhone 17 Pro Back Glass Replacement, Install the pentalobe screws: étape 26, image 1 de 1
    • Use a P2 pentalobe screwdriver to install the two 7.5 mm‑long screws on either side of the charging port.
    Demander à FixBot
After your repair, run Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
11 autres ont terminé cette réparation.
Spencer Day
Membre depuis le 09/14/22
195 148 Réputation
1 243 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 69
7 derniers jours : 385
30 derniers jours : 1,800
Total : 11,435
