Introduction
Ce guide est conservé mais n'est plus valide. Utilisez la nouvelle version de réparation. Ici.
Ce dont vous avez besoin
Retirez les deux vis Pentalobe de 3,4 mm qui entourent le connecteur Ligthening.
Tout en tenant l'écran à un angle d'environ 90°, enlevez les vis suivantes qui attachent le cache des nappes d'écran:
Trois vis Phillips #00 de 1,3 mm
Une vis Phillips #00 de 3,0 mm
Pour remonter votre appareil, suivez les étapes dans l'ordre inverse.
153 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
21 commentaires de tutoriel
while technically correct, this guide is not complete in the sense that a new tech cannot follow it step-by-step to successfully complete a screen replacement. You should include the steps necessary to move the parts over from the old screen. Yes you can buy screen replacements with small parts but most repair operations don't do that as it isn't that hard to move them and much less expensive.
There are many small parts involved in moving from one screen to another. There are also a few steps that require prying a flex from the frame that is taped down. Having the additional steps in this guide that point out exactly where each small parts go and how to successfully pull the flex off without tearing it would be a huge improvement to this guide (and all the other screen replacement guides as they all have the same gap)
thanks - this is a great site and my techs use it for training every day.
As stated in the intro, this is just the full front panel assembly guide. We'll be posting more thorough screen replacement guides in the future. Stay tuned ;)
When will you be selling the 6S replacement screen. I only see on for the 6 and it says not compatible with the 6S.
Additionally is it possible to replace just the glass and not all the other parts?
