Aller au contenu principal
iPhone SE 2022 Lightning Connector Assembly Replacement
Ce dont vous avez besoin
  1. iPhone SE 2022 Lightning Connector Assembly Replacement, SIM Card Tray Removal: étape 1, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, SIM Card Tray Removal: étape 1, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, SIM Card Tray Removal: étape 1, image 3 de 3
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the right edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  2. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the pentalobe screws: étape 2, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the pentalobe screws: étape 2, image 2 de 2
    • Power off your phone before beginning disassembly.
    • Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
  3. iPhone SE 2022 Lightning Connector Assembly Replacement, Mark your opening picks: étape 3, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Mark your opening picks: étape 3, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Mark your opening picks: étape 3, image 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone SE 2022 Lightning Connector Assembly Replacement, Tape over any cracks: étape 4, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Tape over any cracks: étape 4, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Tape over any cracks: étape 4, image 3 de 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  5. iPhone SE 2022 Lightning Connector Assembly Replacement, Anti-Clamp instructions: étape 5, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Anti-Clamp instructions: étape 5, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Anti-Clamp instructions: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  6. iPhone SE 2022 Lightning Connector Assembly Replacement: étape 6, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 6, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 6, image 3 de 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  7. iPhone SE 2022 Lightning Connector Assembly Replacement: étape 7, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 7, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 7, image 3 de 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  8. iPhone SE 2022 Lightning Connector Assembly Replacement, Heat the front panel adhesive: étape 8, image 1 de 1
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  9. iPhone SE 2022 Lightning Connector Assembly Replacement, Insert an opening pick: étape 9, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Insert an opening pick: étape 9, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Insert an opening pick: étape 9, image 3 de 3
    • Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
    • Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
    • If you have trouble creating a gap, apply more heat to the bottom half of the screen to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap under the screen's plastic bezel.
  10. iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: étape 10, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: étape 10, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: étape 10, image 3 de 3
    • Slide the opening pick to the bottom right corner to slice the front panel adhesive.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  11. iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: étape 11, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: étape 11, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the adhesive: étape 11, image 3 de 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  12. iPhone SE 2022 Lightning Connector Assembly Replacement: étape 12, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 12, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 12, image 3 de 3
    • Slide the bottom right opening pick along the right edge of your phone to slice the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Stop near the top right corner of the display.
  13. iPhone SE 2022 Lightning Connector Assembly Replacement, Lift the screen: étape 13, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Lift the screen: étape 13, image 2 de 2
    • Remove the opening picks.
    • Gently pull up on the suction handle to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Remove the suction handle.
  14. iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the remaining adhesive: étape 14, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the remaining adhesive: étape 14, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Slice the remaining adhesive: étape 14, image 3 de 3
    • Slide an opening pick underneath the top left corner of the display.
    • Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
  15. iPhone SE 2022 Lightning Connector Assembly Replacement, Disengage the front panel clips: étape 15, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Disengage the front panel clips: étape 15, image 2 de 2
    • Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
  16. iPhone SE 2022 Lightning Connector Assembly Replacement, Lift up the display: étape 16, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Lift up the display: étape 16, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Lift up the display: étape 16, image 3 de 3
    • Open the phone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display from the phone assembly yet, as several fragile ribbon cables still connect it to the logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  17. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the lower display cable bracket screws: étape 17, image 1 de 1
    Magnetic Project Mat
    $19.95
    • Remove the four Phillips screws securing the lower display cable bracket:
    • Two 1.2 mm-long screws
    • Two 2.8 mm-long screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  18. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the lower display cable bracket: étape 18, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the lower display cable bracket: étape 18, image 2 de 2
    • Use a pair of tweezers to carefully remove the lower display cable bracket.
  19. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the battery: étape 19, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the battery: étape 19, image 2 de 2
    • Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
  20. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the display and digitizer cables: étape 20, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the display and digitizer cables: étape 20, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the display and digitizer cables: étape 20, image 3 de 3
    • The display and digitizer cables run on top of each other. To avoid cable damage always start by disconnecting the upper cable first and never try to disconnect both at the same time.
    • Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
    • To re-attach press connectors like this, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  21. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the front sensor assembly bracket screws: étape 21, image 1 de 1
    • Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
  22. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the front sensor assembly bracket: étape 22, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the front sensor assembly bracket: étape 22, image 2 de 2
    • Use a pair of tweezers to carefully remove the front sensor assembly bracket.
  23. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the front sensor assembly cable: étape 23, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the front sensor assembly cable: étape 23, image 2 de 2
    • Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
  24. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the display assembly: étape 24, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the display assembly: étape 24, image 2 de 2
    • Remove the display assembly.
  25. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the Lightning connector bracket screws: étape 25, image 1 de 1
    • Unfasten the three screws securing the Lighting connector bracket:
    • One 1.2 mm-long Y000 screw
    • One 2.7 mm-long Phillips screw
    • One 2.9 mm-long Phillips screws
  26. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector bracket: étape 26, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector bracket: étape 26, image 2 de 2
    • Use a pair of tweezers to remove the Lightning connector bracket.
  27. iPhone SE 2022 Lightning Connector Assembly Replacement, Loosen the Wi-Fi diversity antenna flex cable: étape 27, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Loosen the Wi-Fi diversity antenna flex cable: étape 27, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Loosen the Wi-Fi diversity antenna flex cable: étape 27, image 3 de 3
    • Carefully slide an opening pick between the antenna flex cable and the top of the speaker.
    • This portion of the flex cable is lightly adhered to the speaker. If you're struggling to separate the cable from the speaker, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the flex cable safely.
  28. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Wi-Fi diversity antenna: étape 28, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Wi-Fi diversity antenna: étape 28, image 2 de 2
    • Use the pointed end of a spudger to disconnect the Wi-Fi diversity antenna by prying its connector straight up from its socket.
    • The socket of this connector sits loosely between the speaker and the Taptic Engine and it's a bit fiddly to disconnect the cable. To make the disconnection easier, you can use an opening pick to hold down the connector socket during this procedure.
    • Reconnecting this cable can be tricky. Make it easier by using tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place.
  29. iPhone SE 2022 Lightning Connector Assembly Replacement: étape 29, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 29, image 2 de 2
    • Use the pointed end of a spudger to disconnect the Wi-Fi diversity antenna from the logic board by prying the connector straight up from its socket.
  30. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Wi-Fi diversity antenna: étape 30, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Wi-Fi diversity antenna: étape 30, image 2 de 2
    • Use a pair of tweezers to remove the Wi-Fi diversity antenna.
  31. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the Taptic Engine screws: étape 31, image 1 de 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the Taptic Engine:
    • One 2.1 mm Phillips screw
    • One 2.1 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  32. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the grounding bracket: étape 32, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the grounding bracket: étape 32, image 2 de 2
    • Use a pair of tweezers to remove the grounding bracket at the left edge of the Taptic Engine.
  33. iPhone SE 2022 Lightning Connector Assembly Replacement, Pry the antenna cable socket: étape 33, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Pry the antenna cable socket: étape 33, image 2 de 2
    • Use the pointed end of your spudger to pry the antenna cable socket up and away from the Taptic Engine connector below.
  34. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Taptic Engine: étape 34, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Taptic Engine: étape 34, image 2 de 2
    • Use the pointed end of a spudger to disconnect the Taptic Engine by prying the connector straight up from its socket.
  35. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Taptic Engine: étape 35, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Taptic Engine: étape 35, image 2 de 2
    • Use a pair of tweezers to carefully remove the Taptic Engine.
  36. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the barometric vent screws: étape 36, image 1 de 1
    • Remove the two screws securing the barometric vent:
    • One 1.9 mm-long Phillips screw
    • One 1.7 mm-long Phillips screw
  37. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the barometric vent: étape 37, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the barometric vent: étape 37, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the barometric vent: étape 37, image 3 de 3
    • Use a pair of tweezers to remove the barometric vent.
    • The barometric vent is lightly adhered to the rear case. If you're struggling to separate the vent from the case, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the barometric vent safely.
  38. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the rear camera: étape 38, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the rear camera: étape 38, image 2 de 2
    • Use the pointed end of a spudger to disconnect the rear camera by prying the connector straight up from its socket.
  39. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the rear camera bracket screws: étape 39, image 1 de 1
    $5.49
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm-long standoff screw
    • One 3.1 mm-long Phillips screw
  40. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the rear camera bracket: étape 40, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the rear camera bracket: étape 40, image 2 de 2
    • Use a pair of tweezers to remove the rear camera bracket.
  41. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the flash: étape 41, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the flash: étape 41, image 2 de 2
    • Use the pointed end of a spudger to disconnect the flash by prying the connector straight up from its socket.
  42. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the upper cable bracket screws: étape 42, image 1 de 1
    • Remove the two screws securing the upper cable bracket:
    • One 2.8 mm-long Phillips screw
    • One 1.2 mm-long Phillips screw
  43. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the upper cable bracket: étape 43, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the upper cable bracket: étape 43, image 2 de 2
    • Use a pair of tweezers to remove the upper cable bracket.
  44. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the upper flex cable: étape 44, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the upper flex cable: étape 44, image 2 de 2
    • Use the pointed end of a spudger to disconnect the upper flex cable by prying the connector straight up from its socket.
  45. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the top left antenna component screws: étape 45, image 1 de 1
    • Unfasten the three 1.2 mm-long Phillips screws securing the top left antenna component.
    • Don't try to remove the antenna component yet. There's a fourth screw securing it to the rear case.
  46. iPhone SE 2022 Lightning Connector Assembly Replacement: étape 46, image 1 de 1
    • Unfasten the 1.4 mm-long Phillips screw securing the antenna component to the top edge of the rear case.
  47. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the top left antenna component: étape 47, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the top left antenna component: étape 47, image 2 de 2
    • Use a pair of tweezers to remove the top left antenna component.
  48. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the grounding bracket screws: étape 48, image 1 de 1
    • Unfasten the two screws securing the top left grounding bracket:
    • One 1.5 mm-long Phillips screw
  49. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the top left grounding bracket: étape 49, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the top left grounding bracket: étape 49, image 2 de 2
    • Use a pair of tweezers to remove the top left grounding bracket.
  50. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the logic board screws: étape 50, image 1 de 1
    • Unfasten the four screws securing the logic board:
    • One partially threaded 1.7 mm-long Phillips screw
    • This screw is covered by protective foam surrounding the rear camera connector. Use a pair of tweezers to peel just enough foam off to unfasten the screw.
    • One 2.5 mm-long standoff screw
    • One 2.2 mm-long standoff screw
  51. iPhone SE 2022 Lightning Connector Assembly Replacement, Pry up the logic board grounding bracket: étape 51, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Pry up the logic board grounding bracket: étape 51, image 2 de 2
    • Use a pair of tweezers to carefully pry up the logic board grounding bracket in the top right corner of the rear case.
  52. iPhone SE 2022 Lightning Connector Assembly Replacement, Position the SIM card eject plunger: étape 52, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Position the SIM card eject plunger: étape 52, image 2 de 2
    • Use the pointed end of a spudger to move the SIM card eject plunger out of the logic board's way by pushing it to the right edge of the rear case.
  53. iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Lightning port and the wireless charging coil cable: étape 53, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Lightning port and the wireless charging coil cable: étape 53, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Disconnect the Lightning port and the wireless charging coil cable: étape 53, image 3 de 3
    • Use the pointed end of a spudger to disconnect the Lightning port cable by prying the connector straight up from its socket.
    • Use the pointed end of a spudger to disconnect the wireless charging coil cable by prying the connector straight up from its socket.
  54. iPhone SE 2022 Lightning Connector Assembly Replacement, Pry up the logic board: étape 54, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Pry up the logic board: étape 54, image 2 de 2
    • Use the flat end of a spudger to gently pry up the battery connector end of the logic board.
    • Be careful not to pry against any cables. If you feel resistance, check that all cables, connectors, and components are clear of the board.
  55. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the logic board: étape 55, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the logic board: étape 55, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the logic board: étape 55, image 3 de 3
    • Grasping it by the edges, lift the logic board near the battery connector and remove it.
    • Make sure that none of the surrounding cables are tangled with the logic board or blocking its way.
  56. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the loudspeaker screws: étape 56, image 1 de 1
    • Unfasten the two screws securing the loudspeaker:
    • One 1.4 mm-long Phillips screw
    • One 2.1 mm-long Phillips screw
  57. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the loudspeaker: étape 57, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the loudspeaker: étape 57, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the loudspeaker: étape 57, image 3 de 3
    • Use a pair of tweezers to remove the loudspeaker.
  58. iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the Lightning connector assembly screws: étape 58, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement, Unfasten the Lightning connector assembly screws: étape 58, image 2 de 2
    • Unfasten the five screws securing the lighting connector to the rear case:
    • One 1.3 mm-long Phillips screw
    • Two 2.3 mm-long Phillips screws
    • Two 1.4 mm-long Phillips screws
  59. iPhone SE 2022 Lightning Connector Assembly Replacement, Free the microphones: étape 59, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Free the microphones: étape 59, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Free the microphones: étape 59, image 3 de 3
    • Use the pointed end of a spudger to gently pry the two microphones on the left and right of the Lightning connector free from the adhesive securing them in place.
    • Don't try to completely remove the microphones; just separate the adhesive as shown.
  60. iPhone SE 2022 Lightning Connector Assembly Replacement, Loosen the charging port assembly adhesive: étape 60, image 1 de 1
    • Apply a heated iOpener to the bottom of the rear case to loosen the charging port assembly adhesive, angling it as shown.
  61. iPhone SE 2022 Lightning Connector Assembly Replacement, Separate the Lightning connector assembly cable: étape 61, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Separate the Lightning connector assembly cable: étape 61, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Separate the Lightning connector assembly cable: étape 61, image 3 de 3
    • Slide an opening pick underneath the top portion of the Lightning connector assembly flex cable, and begin separating the cable from the rear case.
    • Part of the wireless charging coil lies directly underneath this portion of the Lightning connector flex cable. Aggressive prying may damage the coil.
    • If needed, use your hair dryer or iOpener repeatedly to re-heat the area behind the Lightning connector assembly flex cable in order to further soften its adhesive.
    • Continue separating the upper portion of the flex cable, being careful not to damage any other components along the way.
    • Keep the battery connector gently folded out of the way to avoid damaging it.
    • Be very careful not to damage the battery itself. A punctured battery can leak dangerous chemicals and/or catch fire.
    • Stop sliding the pick once it passes the lower edge of the battery.
  62. iPhone SE 2022 Lightning Connector Assembly Replacement: étape 62, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 62, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 62, image 3 de 3
    • Starting at the corner of the phone, slide the pick underneath the cable towards the Lightning connector.
    • Stop sliding the pick when it reaches the Lightning connector.
  63. iPhone SE 2022 Lightning Connector Assembly Replacement: étape 63, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 63, image 2 de 2
    • Gently pull the Lightning connector out of its recess in the rear case.
    • Don't try to remove the lightning connector assembly all the way yet. It is still partly adhered to the rear case.
  64. iPhone SE 2022 Lightning Connector Assembly Replacement: étape 64, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 64, image 2 de 2
    • Slide an opening pick below the Lightning connector to further separate the assembly from the rear case.
    • Continue to slide the pick until the Lightning connector assembly is no longer adhered to the bottom of the rear case.
    • Don't try to remove the lightning connector assembly all the way yet. A last bit is still adhered to the left edge of the rear case.
  65. iPhone SE 2022 Lightning Connector Assembly Replacement: étape 65, image 1 de 2 iPhone SE 2022 Lightning Connector Assembly Replacement: étape 65, image 2 de 2
    • Slide an opening pick between the left edge of the rear case and the remaining adhered section of the Lightning assembly.
  66. iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector assembly: étape 66, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector assembly: étape 66, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Remove the Lightning connector assembly: étape 66, image 3 de 3
    • Remove the Lightning connector assembly.
    • Before installing or replacing the Lightning connector assembly:
    • Remove any remaining adhesive, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Before removing the adhesive backing on a new assembly, make sure the Lightning connector assembly is correctly positioned by aligning the hole in the flex cable with the screw post. If the cable is misaligned, you won't be able to reconnect it to the logic board.
  67. iPhone SE 2022 Lightning Connector Assembly Replacement, Transferring and replacing remaining components: étape 67, image 1 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Transferring and replacing remaining components: étape 67, image 2 de 3 iPhone SE 2022 Lightning Connector Assembly Replacement, Transferring and replacing remaining components: étape 67, image 3 de 3
    • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
    • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
    • Check if your new part comes with an antenna converter cable. If it doesn't, use the pointed end of your spudger to pry up and transfer the cable from your old Lightning assembly to the new one.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Compare your new replacement part to the original part—you may need to transfer other remaining components or remove additional adhesive backings from the new part before installing.
7 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
228 969 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 410 tutoriels rédigés
Un commentaire
After doing this my loudspeaker has static. Anyone else experience this?
yzcheema11 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 117
30 derniers jours : 427
Total : 8,422
